View Full Version : Generation III External Engine
- TSP rumbler catback..
- Installed LPP headers.
- what y-pipe can i get with stock manifolds?
- Advice on compression...
- Raspy sound after installing ORY
- fuel injectors
- Pricing question for TSP catted y pipe
- Header bolts backing out...Locking header bolts or lock washer?
- LPP Stainless LS1 Headers and Y's now in stock.
- Armor Coated Pacesetters
- Injectors for MS4 cam swap?
- where are ETP??
- ???bleeding Coolant Thru Waterpump???
- i need a link for ls6 intake install
- Car Is Done!!!
- Can a TB be to big..........
- Poor Mans Exhaust!!!
- FAST + meziere WP
- My TSP Y-Pipe cracked!!!!!!!!
- Any luck with ebay headers?? LINK inside
- map/baro circuit?
- going through 02 sensors pretty fast idk why??
- Poly Mount install tips/pics?
- cats Qs ????
- running on 4 cylinders
- who makes the best 3.5" x pipe?
- Strange noise - Ticking
- exhuast pipe vibration dampening
- 98 LS1 coils bolt up to 99+ coil bracket?
- I joined the club
- Custom Ram Air
- low rpm stumble/misfire
- Considering 85mm TB/Intake Manifold Combo
- parts needed for bare motor...
- which y to buy???????
- Really dumb question about intake.
- Fast 92mm intake questions?
- ???gmmg Vs. Loudmouth 1???
- "hunting" idle got worse with PCV valve
- catchcan install with EGR
- Installed manifold today....had a few issues.
- problems with the daily
- which one do i choose??????
- ls6 intake, egr question
- new Z06 intake on L92 heads?
- Mufflers straight off the heads question
- ASP Pulley part number
- poly mounts raise engine height??
- 2000 cfm throttle body questions
- SLP Long Tube Header Install question
- Swap Ls1, what kind of power am i looking at?
- Which mufflers for CME?
- Help!!!!!!!!!!headers!!!
- First Mod
- what size injecters does a 03 z06 hav?
- Best First Mods
- What is a good cat for a GMMG with LPP long tube headers??
- Gonna be getting a new exhaust setup.
- ultra z hood
- SLP help
- will a ls6 intake fit my stock throttle body?
- how much et gain form cut outs
- Who has the best Throttle body for me....LOOK INSIDE!!!
- vacuum canister install
- need fan switch help!! (:() for people that used their own switches.
- Exhaust to fit Kooks 3.5" collector....
- Slp power Flo Catback.
- My next mod having problems choosing
- 92 FAST Install Questions?
- My American Racing Headers got here (pix)
- Need Problem Diagnosed
- This is banging my exhaust
- SLP Underdrive Pulley
- Ms3
- is my cutout broke?????
- ls1 and ls2 bellhousing?
- muffler testing
- plugs help!
- MY Ported and polished T/B
- Help with power steering pulley puller ls1. 2000
- Need bolt ons!
- Something feels off.....
- K@N Cold Air Kit
- Leaded Cam2 + O2 sensors
- Best exhaust setup for slammed / lowered car?
- ls6/fast intake
- Trouble shooting after F.A.S.T 92/92
- Urgent! Borla will not mate up to new Y Pipe
- SLP Dual/Dual
- LT cats and emmisions
- Options for intake
- Y Pipe Options For Pace Setters
- LS7 maf & LS1 pcm
- New Weiand Street Warrior vs Fast 92mm Manifold
- Quick question guys. What is the use of da idler pulley?
- bellow
- Second and third primaries are going to eat my plug wires!
- underdrive pulley bolt
- 02 extensions, what length do I need?
- Installing LG Sreet's Soon What Else Do I Need?
- HEADS what does milling do for them.
- Stock Motor 1 3/4" Vs. 1 7/8 Engine Dyno Results!!
- Stock Z06 or Borla Stinger Catback
- Aftermarket MAF
- Possible to get just the SLP Dual/Dual muffler new???
- p0355b ignition control 5 circuit???
- What would happen if Air got past the MAF
- where is the compression ration for heads and gaskets
- Whats the best spark plugs?
- Occasional, severe stumble/loss of power
- Y pipe confusion
- I want different tips for my SLP DD
- Where to find a/c idler pulley?
- Looking for LS1 fbody front accessories...
- ???how Much Do Vent Tube Plugs Cost???
- Few questions about QTP cutouts.
- Getting headers, y, cats, and catback installed, QUESTIONS
- Long storage
- Good Houston trans shop for 4L60e ???
- LS6 & stock inj. --to--> FAST90 & SVO 30#
- Thermostat Help
- Cooling problems in town
- Which knock senors? Where to get them?
- SLP dual/dual VS. Corsa
- what is the corvette 02 sensors part #?
- changing my exhaust setup
- Has anyone tried these edelbrock headers?
- Vent tube on ls2 valley plate?
- Header to spark plug clearance issues
- O2 sensor simulator
- Qtp Header Question
- Exhaust Suggestions
- Steam pipe vent block off?
- need to quiet down my head and cam car at idle
- Pacesetter question.
- Please help!
- Mass air/Lid combo
- Let Me See Your Cutout Switch Location
- Question Lt1 to Lsx swap Related.
- Magnuson Supercharger
- my exhaust clip
- Exhaust Dilemma
- Which Intake??
- Water Pump Gaskets
- '98 Z Header Install
- looking for 00-02 fbody engine harness+pcm
- Running an Open Cut Out
- question about 3 inch exhaust
- 160* Thermostat for 99 LS1 won't fit?
- will i have enough back pressure
- Need to quiet my SLP LM1 setup.
- Does a stall effect gas mileage?
- Port and polish location in Houston
- all u true duals guys please enter
- Removing AIR question
- 4" Cutout vs 3" Cutout
- Please help!
- Ported 853, ported 241, or stock 243's??
- What do you guys know about the l92 truck heads
- Magnaflow
- Map sensor relocation question
- Unique Exhaust situation... need advice
- Front Mount Headers and Front Exit Exhaust Idea
- Exhaust volume...How loud is too loud?!
- slp header question?
- ultra z hood, debafled???
- 853 and 241???
- Parts needed
- Which way to go?...
- dmh electric cutouts
- Raced a ricer fly by mazda speed.(need belt help!!!)ls1.
- Installed LS6 Intake Today
- help on exhaust id
- Fuel Rails
- Cutout
- what to do with $500
- Magnaflow Cats
- Did I fry my alternator?
- FAST 78 throttle body?
- heck out my new valve covers
- Car feels faster with cutout closed?
- LS6 intake
- CFM Question??
- Help me pick out my exhaust
- Oil pan bolt part#
- magnaflow problems?
- Whats best to cut 3" pipe??
- Fast Intake bolts backing out
- what should i expect?
- ms4 cam
- Should I header wrap?
- radiator question
- Lid...
- No SES after header install
- Engine bay Before and after
- MAF Question!!!! (25168491 85mm) Help me out please!
- Hooker Aero Cat-back
- I can get dynomaxes best exhaust system for 320$ because I work for advanced
- Exhaust Problem
- CD2 lead substitute???
- that manual fan switch again.
- Crate LS6 install problems (F-body)
- Where to find/buy part...
- hooker cat-back
- Pulling off x-pipe
- Who has drilled a hole in their TB?
- head bolt rounded off. WTF help
- Cam for LS1
- Got photos of my new dual setup, sound really good.
- DIY for a electric cutout?
- LPP Stailess Headers and Y now in stock:)
- Oil sending unit
- Pics of my BAD Rusty Knock Sensors!!!
- Help me.(12 volt wire) manual fan switch ls1
- Finally figured out my exhaust setup
- Fuel rail covers for TA
- No spark to right bank?
- 3.5" true duals-stock location!
- Cam/piston question
- Cat back question
- Starter motor - broken nylon gears
- E3 Spark Plugs
- Ls6 cam or headers which one will produce more?
- car running lean?
- O2 extension....
- Can I clean these braided fuel lines?
- ARH owners please step in!
- Header Install
- V6 Air lid
- Exhaust Sound
- LS1 vs LS6 valve guides?
- Need an idea on my computer........
- New SLP PowerFlo exhaust?
- edelbrock efi carb intake?
- 408 guys step in!!!
- Need Advise...
- Y-pipe: Kooks fits Hookers and Jet Hot fits Hookers??
- Exhaust Video - Got a new camera so I had to test it out...
- are my headers holding me back?
- Dexacool or No Dexacool
- Intake setup recommendations?
- Help with intake install
- 2 questions about motor mounts.
- Coilpack interchange?
- Got my ls6 intake today!!
- TSP 1 7/8 Long Tube Install
- looking for header flanges
- BEST READILY available OIL... Mobil vs Castrol vs pennzoil??
- New car
- Headers Back, will I run lean?
