PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 [313] 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. GMMG exhaust dealers?
  2. engine removal and stand question...
  3. Where do you find the Baker hose for the bellows at?
  4. Header size question...
  5. More Mods?
  6. Octane Help...Please Read!
  7. Just pulled my rear bumper support
  8. Custom Exhaust
  9. Help- Hooker Y and Catback problem
  10. How does synthetic help...benefits?
  11. CYCLONE AIR INTAKE for LS1???
  12. rattling cat...?
  13. Slp Loudmouth......
  14. Could exhaust really rob this much power?
  15. running lean ???
  16. Hooker catback-- Flow well??
  17. SLP Lid or K&N Induction
  18. Exhaust Dump
  19. Guaging Interest in my custom 2OTL.....read this
  20. Anyone running any ignition addons or mods?
  21. Whats wrong with my Car?
  22. X pipe...angling turndowns???
  23. AAHH! fule pump driving me nuts!
  24. mecham tips
  25. I see that someone is doing a GP on Supersuckers for $199 on LS1.comm
  26. I just got a new t/a and need help
  27. Any update on the new intake being developed in Austraila?
  28. Anyone have Spintech cat-back
  29. Z06 vs. LS1 Z28??
  30. Anyone with problems from bassani ory-pipe?
  31. What size Bullet??
  32. HOOD BAFFLE HELP PLS
  33. Metco breather question
  34. Removing Smog Pump, Air pump, Vacuum Pump???
  35. BMR weld in Subframes attach to the floorpan?!?!
  36. ? EGR Manifold block off plate?
  37. !EGR & AIR!
  38. Q-Time Cutout got sucked in
  39. Who has an engine tie down strap?
  40. Coil pack
  41. ZO6 MAF Vs. Grantaelli MAF ??
  42. What's the clutch drill mod?
  43. QTP Cutout
  44. Baffle removal and FRA mod
  45. bbk throttle body
  46. slp headers
  47. Sweet Thunder Mufflers ??
  48. Whatever Happened to Gale Banks Exhaust for LS1 F-body?
  49. LS1 A/C system gurus inside...
  50. Fuel Rail Pressure for a C5
  51. ASP PULLEY BELTS HELP.....pleez
  52. a/c leaking in car...
  53. Looking for header input for my Z06
  54. Who is running the ASP alt. pulley?
  55. Installing the K&N FIPK, along with a B&M deep trans pan and have questions:
  56. Knock Retard
  57. LS6 Intake.........will it hurt me in performance?
  58. ATI dampener questions?
  59. To do list - hows this look?
  60. Z06 Maf conversion
  61. Will dual cut outs affect my A/F mixture?!
  62. stall converter
  63. modifying stock thermostat....
  64. Replacing Flowmaster
  65. Pace MAF?
  66. Who makes headers for the 6.0 liter???
  67. I think I need bigger injectors??
  68. where can i get a hi-perf damper??????
  69. Racetronix in-tank kit...anyone have any recent update?
  70. Fuel system requirements for...
  71. MAF?
  72. Stock rear exhaust size question?
  73. Everything Rattles and Shakes
  74. Any opnions on the Venom 400 control module?
  75. Which Exhaust ???
  76. Installing only one poly motor mount. which side?
  77. Can I use Autometer Mechanial Gauges with LS1
  78. What brand of bullet mufflers are being used
  79. Anyone had this happen to them????
  80. Installed 12 in Bullet, have ?????'s.
  81. Flowmaster 80 Series. The horrible truth
  82. Hey InSSane! Questions on exhaust?
  83. Who's exhaust is this?
  84. Replacing engine mounts...
  85. knock out box
  86. BRAND NEW ASP PULLEY FS
  87. What is this?
  88. hard tube or soft hose (fuel system)
  89. A4 X pipe guys, 2 questions...
  90. Need Belt Tensioner,What is Katech Website ?
  91. Anywhere to buy I-pipe?
  92. True Dual Exhaust questions?
  93. Do pullies help more with top end or low end
  94. Flowmaster.....
  95. FLP banging alittle after floor pan "massaging". need help...
  96. Hooker LT's on a 2000 Camaro SS?
  97. What alternator do we have?
  98. What would cure resonance?
  99. Help. I need 20hp. What else could I add?
  100. WHITE SMOKE AFTER MAC INSTALLED
  101. Benefit of !EGR & !Air, Info Please
  102. Lighten up the Z
  103. Need HELP !!!something is making my front O2's crap out ?
  104. #8 Plug
  105. X-Pipe w/ Stock Manifolds
  106. Asp belt sizes??
  107. mti clear lid?
  108. Value of "H" exhaust cross-over?
  109. Install Hooker LTs on 2002??
  110. What torque arm are the x-pipe guys running?
  111. Problem with cutout?
  112. Ported TB pics and some how-to's
  113. Burned out/busted blinker
  114. Where can I find 4 MAC header collector bolts??
  115. Will a bullet eliminate....
  116. SLP Loud Mouth exhaust clearance
  117. After MACs install ????????
  118. Anyone have dyno numbers with hooker longtubes?
  119. Any difference between Slp LT and Hooker LT?
  120. ASP PULLEY
  121. Largest tube Headers?
  122. An electric cut-out with a LoudMouth, any difference??
  123. balancer tube in the y-pipe
  124. Should I kill my cats?
  125. SLP or Whisper Lid??
  126. electric cutouts?
  127. New type of Y-pipe??
  128. What Now???
  129. 3.5" QTEC installed!
  130. SLP Loudmouth FEEDBACK
  131. pulley question
  132. fuel pressure?
  133. Tell me what you think of this exhaust set up
  134. ported throttle bodies
  135. x-pipe setup
  136. Will higher Octane gas work better w/ 5.3L heads?
  137. EGR Free mod? worth it?
  138. Who has had success with the SLP 85mm MAF?
  139. How Much HP do Open LT Headers Give you over stock exhaust on stock engine?
  140. Mac header guys come in here......
  141. DAMPER=$$$$$$
  142. 98+ differences
  143. Bullet Mufflers
  144. Blue Smoke
  145. How Much Hp from ls6 intake and 2001 ls6 cam or hot cam?
  146. Best Intake Manifold?
  147. Is it o.k. to run around w/o o2 simms for a week or 2?
  148. shifter knob
  149. Cutouts are Fun!
  150. how do you remove the egr/air system, is there a step by step process online somewher
  151. My exhausts blowing raspberries.
  152. Ported MAF or Not?
  153. Who can make me duals for hooker headers
  154. SLP underdrive pulley
  155. Help identify intake manifold
  156. Ignition problem HELP!!!!
  157. Ported Throttle Body Pics
  158. IAC, vacuum, and idle... Any ideas ?
  159. the OFFICIAL motor swap in and outs, do's and dont's thread...
  160. Coil Pack Part Numbers
  161. Stock exhaust manifold questions... who's got thier service manual handy?
  162. LS6 Intake Swap part #'s and questions
  163. EGR removal
  164. Larger throttle Body ?
  165. Exhaust popping?
  166. Tricks for keeping header bolts tight?
  167. borla exhaust
  168. 2000 Firehawk Dyno
  169. What do to with exhaust now?? Buy a new one??
  170. LS-6/EGR
  171. belt diagram for a 98? will power steering pulley cause belts to fly off
  172. AIR system?
  173. intake swap
  174. Qustion on fuel sending units.
  175. Smoke Problem- - - - - - Why?
  176. JB Weld Problems!
  177. Best Catback with LTs and ORY
  178. Is an aftermarket cam the only way to make an LS1 loud at idle?
  179. How to install "larry pulley"/asp tensioner pulley
  180. Choices for Header ceramic coatings
  181. Choices for Header ceramic coatings
  182. headers and cats
  183. ATR Catback Anyone?
  184. Open Headers... good or bad?
  185. HELP!!! Oh God Help Me HELP!!!
  186. Hood baffles Help?
  187. quick mods
  188. Finally got the numbers!
  189. How much would I gain from a cutout?
  190. Header 'flange' flatness?
  191. Lid sealing and filter ? Everyone please respond.
  192. 2 cutouts after Mac headers?
  193. WERE TO PUT A CUTOUT????
  194. Indexing Plugs
  195. GOING TO TRACK TOMORROW NIGHT
  196. Groythann Offroad y pipe
  197. Headers burning up starter?
  198. inlets??
  199. HELP ME SEAL MY LID!!!! PLEASE!
  200. Spark Plug Wires Problem
  201. X vs. Y vs. H =mc2 ?
  202. guys with hooker lt's and cats, please help asap.
  203. HEADERS HELP???
  204. ARE LONG TUBE HEADERS WORTH IT?
  205. WHAT CONVERTER
  206. Chambered Loudmouth Done! Finally
  207. Cheapest place to get a driveshaft loop?
  208. Speed Density........
  209. which makes more power???
  210. what to replace factory lug nuts with?
  211. Water Pump, going, going....
  212. Starting problems......intermittent
  213. Washer fluid spitting up?
  214. Loudmouth
  215. Would this be a good idea?
  216. fuel cell/race fuel
  217. Engine removal
  218. Hooker Catback?
  219. Install Headers?
  220. Surging REALLY bad on Stock motor... Drill TB?
  221. The quietest muffler
  222. Probs after LTs
  223. Highest flowing muffler
  224. corrosion on battery post
  225. My engine is overheating!!! Need some help...!
  226. ASP Pulley w/ belts -- cheap
  227. Ok, need the true dual people in here.....
  228. Does anyone run bullet mufflers with turn downs off of the headers on the street?
  229. How much lighter is a 99+ plastic gas tank than a metal 98 tank?
  230. Those that have sent Corsa muffler in for replacement
  231. 1 3/4 headers: Dyna vs Hooker
  232. Ignition problem
  233. does metco have a website?
  234. Accessories/Pulleys/Brackets
  235. Question about C5 intake...
  236. fule pressure regulator question?
  237. Screws in my catalytic converter???
  238. Flowmaster exhaust
  239. Putting headers on and need some help.
  240. grinding down front brake calipers
  241. bought '98 T/A need mods
  242. Need help, problems with FLPs!
  243. Pics of PCV mod
  244. Corsa vs Factory WS6
  245. GM Warranty?
  246. Help!!! Hooker LT install
  247. Exhaust Help
  248. MAF?
  249. ttt
  250. Spark Plugs
