View Full Version : Generation III External Engine
- Do front 02 sensors go out often when you have long tubes?
- Y-Pipe Problem
- H/C guys! What MAF are you running?
- having my TD's installed today
- Power Difference - Dumped Duals and Out the Back Duals
- TSP true dual people, i need help!
- Tensioner Pulley
- pulley help please!
- Custom cat-back ?
- Source for OEM Bolts/Nuts
- Help Please!!!!!!!!!!
- odd smell
- Am I hitting the rev limiter
- can I weld a 1 chamber flowmaster in the I pipe for a cutout?
- Considering Gutting Cats... Opinions Please
- Car starts then stalls on a cold start!!
- ARP Header Studs
- Can we rebuild our water pumps?
- QTEC cutouts
- What size dual exhaust for 440HP motor?
- What holds heat better?
- starter engaging when battery is hooked up?
- Help Please
- serpentine and cold weather
- Part #'s for you true dual guys
- Kooks Headers......good and bad?
- Stock catback???
- Shift Light Question.
- LS6 Intakes
- Any one with a 2OTL catback
- Any idea whereto get 3.5" exhaust pipe?
- Best Headers Around
- broke sensor what sensor is this?
- B&B Performance Exhaust Systems?
- MAF sizes...
- Free Mods...I Know I know
- Pully help????????????
- Ported TB - who's is best?
- I LOVE my MAC's ... anybody who doesn't?
- ASP web sight Address???
- Sweet Thunder Guys Come in
- getting rid of headers....
- C5 TAC Module Pinouts for ETC
- Wheres the best place to get new O2's from?
- Put the Jet-Hot LT's in!!
- getting duals soon...
- True dual guys.......
- Hooker catback
- Finally got the GMMG
- Stupid newbie question
- SAMCO Silicone Hose Kits for LS1 F/B, T/A, Camaro, Vette Still Available Here
- Kooks catted y-pipe with Borla
- What does your March pulley look like?
- ngk problem
- Does This Price Sound Okay?
- 3 inch exhaust too big?
- what intake will best fit my setup.. i am on stock intake!
- Kook's SS Vs. Kook's
- Pipe Air flow chart needed
- Do I need o2 extentions for mac mids
- TSP with mac mids headers?
- corvette borla stinger exhaust
- jet-hot "Y"???
- Edelbrock TES exhaust
- mufflex & cutout ?
- big cube cut out question
- Loudmouth with Sweet Thunder
- Getting ready for Header Install...
- Interesting Sight as I came home from school...
- Quick coolant question
- Brisk plug info PTII!!!
- Intake comparison
- LS6 intake swap Q's.
- C5 exhaust question
- Stock headers best - Car Craft Mag.
- Clearance with 3" True Duals and XR1's
- header installation instructions
- Holy Crap!!!!!
- removing AIR pump and things that plug into headers throw a code?
- header help
- My oil looks like a chocolate milkshake!
- My clothes smell like fuel after driving my car!
- Mac's, RT cat's, and corsa...
- installing underdrive pulley
- Removing EGR...urgent
- help in porting TB
- Throttle Body
- 01' Vette ls6 intake on f-body Whistle noise?
- Quick Market Survey
- SLP headers fitment?
- What type of headers to run with big bore
- 02 Sensor Problem
- Larger than stock CID, what cat back do you run?
- Quietest Exhaust
- Header choice with GMMG/ORY
- Headers
- GM Service Manual Site
- power steering vibration and noise?
- 90mm lsx TPIS tbody problem
- Driveshaft loops
- __________3'' or 2.5'' for Y-pipe?_________
- lsx 90mm intake manifold too much?
- Going to install LT headers soon
- Pulley Question
- Belts for underdrive pulley
- HUSHPOWERII muffler anyone??
- pipe bending question
- factory header bolts to long for mac mids? help dont wanna mess up heads!
- What headers to buy
- y pipe question
- Removed PCV valve? Good or bad?
- Y Pipe Help
- LSX intake installed tonight, hearing a whistle? anybody hear of this?
- welcome to my nightmare
- T-bolt clamps?
- Busted Cat internals..please help!
- Blackwing Airbox Lid
- Lt w/ cats and loudmouth = Too Loud
- pepboys mufflers
- Rear exit duals?
- 6 ltr block in ls1 camaro
- 1 7/8" primaries vs 1 3/4" primaries
- NEW Edelbrock SDT mufflers, anyone using them?
- new o2 sensors, what year corvette
- racing headers or not
- Security Light
- How do I remove a starter on a 98 A4?
- will corvette manifolds fit on an f body?
- reusing header bolts
- CME tip drop 5- 10 cooooooooome iiiiiiiiiiiiiiiinn
- Cheap Fluid Damper pulleys on ebay
- 98 z28 w/ new headers, lost hp
- Direct Flow lids
- Pics!!! Makin Macs Look Good!!!!
- Replaced Headlight motor, still not working.
- Who Has Port Matched Their Fast 90?
- Speedo = Tach? Other issues too...
- Edelbrock long ti & ceramic headers are out.
- installing lt headers
- what could be causing me to slip my belt?
- Can I buy ONE replacement Taylor TV plug wire?
- good deal???
- Help! Throwing codes after Mac install.
- Hooker LTs, no cats...Borla XR1? Help me pick a muffler!
- SLP DD, no exhaust coming from driver's side tailpipe?
- whats the general opinion on Stainless Works
- 1 and 3/4" or 1 and 7/8"
- for those with vacuum gauges hooked up???
- For owners of SLP LT's
- 90MM intake bellows question???
- Interesting results after welding my tsp true duals
- just bought mac mids? anyone have trouble installing these? got them and y for 250$!
- part number for air deflector for radiator
- Cop stop help
- What wires are you guys running and why
- MAF issue part 2.
- 160 deg. Thermostat?
- people with jet hot headers...
- Ordered my Kooks!!!
- Properly sized Y-pipe can flow as much as X pipe
- Ported Throttle Body Pics
- True duals or cut outs?
- 98-03 TB's same?
- FM11 + True Duals (XR1's) Clip
- Most Quiet Long Tubes?
- J/W who has the uncoated paceseater headers
- More Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Too loud
- GMMG Installed
- Mac/ORY pipe
- sweet thunder mufflers
- my freind wants to buy my a/c components i just pulled.. whats a fair price?
- Question on muffler for my TD's
- What Happened to www.Oiltown.com website?
- ls6 or ls1
- cutout question
- Do I really need the flimsy tunnel brace?
- Which Magnaflow Mufflers for True Duals
- Is it worth changing my exhaust setup?
- Air pump whinning noise
- Installing GMMG Tonight...Any Suggestions?
- X-Pipe and H-Pipe
- Help!!!!!!!!!!!!!
- Just curious, but why are so many people wanting to buy center bolt valve covers?
- Mac Mids w/offroad y-pipe
- slp dual duals
- exhaust bracket
- Question about running rich after header install?
- Manifold Design issues
- Another "just installed my LT's thread"
- place for oil temp sender???
- Help with oil filler neck
- duals under axle
- How much there pars install will cost?
- Hooker LT stainless?WTF
- stainless steel hookers
- AIR System
- QTP headers installed with sound clip
- Project for my brother car Heads/Cam, Header...what else we need?
- aluminum or stainless steel
- Dent in Header???
- K&N FIPK won't fix SLP maf
- Quick lid question
- Need some help from the group on this problem!
- Anyone wanna hear how my cutout sounds in the tunnell?
- Which Borla XR-1?
- why do some LTs trip O2 codes and some dont?
- who sells sheetmetal valvecovers
- Belt size?????????
- Tension pulley question
- Need help with a possible MAF problem!
- Header Install??????
- all those with QTP header setups
- breather filter
- Kooks LTs + Catted Y + GMMG Vids !!Added!!
- Problem tossing belt, please advise.
- Obnoxious Grinding Sound
- a seemingly stupid question
- Stock MAF same as Chevy Van?
- who sells GMMG???
- Just how low are the SLP longtubes?
- Catback weld or bolt-on?
- What can I use to clean the gunk out of my intake?
- True Duals In
- MSD Coil Packs?
- Need size for airflowonline bellow
- MAF or TB (next mod)
- TSP ported TB, any good?
- K&N FIPK
- Premium Corsa tips
- kooks y pipe not stainless?
- coolant hoses sucking together
- SLP ported throttle body?
- Magnaflow Exhaust Installed !!
- What causes MAF to go bad? (PO101)
- Borla or Magnaflow
- Maf
- Exhaust band clamps
- bunk pacesetter gaskets
- QTP Header ?s
- 3" TD's too much flow??
- Best Bang 4 your Buck Exhaust?
- keeping stock headers
- (Flowmaster 80 Series or Hooker Aerochamber) & !CATS
- what bellow for TPIS 90mm and stock MAF
- when you install headers do you ??????
- Has anybody ported the neck of their LS6 intake?
- 2000 ls1 to new ls6 questions
- GMMG and only grott style headers?
- Looking for headers
