PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Threw a belt today! WTF
  2. LS2, LS1 and LS6 intakes
  3. 3" True duals louder than 2.5"? H-pipe?
  4. DMH Cutout Question
  5. Cooland crossover line, quick question
  6. new harness and turn signal fuse keeps poping
  7. sensor question
  8. my car sounds like a supercharger
  9. Need a used motor wiring harness for LS1
  10. 317's on a LS1/383
  11. what spark plugs do you recommend for a 98 LS1?
  12. Drive shaft loop w/ QTP LT's and Y-pipe
  13. Update Still Arching
  14. Why would a rocker pedastool break??
  15. Cutout Question
  16. The Typhoon Intake?
  17. TSP 1 7/8 LT's on a stock internal LS1
  18. y pipe banging
  19. Is this catch can set up right?
  20. Has anyone tried
  21. Throttle Cable on Vic. Jr.?
  22. LS1 mod advice
  23. Slp Headers For Sale
  24. ls2 timing chain question
  25. new plugs yesterday, strange sound today....
  26. whistle/whine coming from an engine
  27. HELP motor mounts?
  28. WS6 shocks/springs dilemma/questions
  29. Longtube primary size
  30. What is the 02 TA stock thermostat rating?
  31. Help car misfiring
  32. Doing a catback. Should I replace the Y?
  33. Cooling Fans
  34. Going to do free mods this weekend and have a couple of questions
  35. Apparently a cutout CAN affect a tune!?
  36. Gas mileage with bigger cam?
  37. Manual fan switch
  38. True Duals Question
  39. How to get rid of the cruise control and TC on my SS
  40. Trying to stay incognito.
  41. Valve Covers
  42. Anyone in Milw know where to get plugs and shock/strut installed for fair price
  43. too loud of an exhuast?
  44. NGK NGK TR55's a bad idea? somebody reassure me...
  45. Pacesetter / SLP Y-pipe mix and match...what's best?
  46. disappointed
  47. How to get rid of the cruise control and TC on my SS
  48. Need help with vacuum WITH PICS
  49. LS6 Intake install questions?!?
  50. fule line disconnect on intake swap
  51. 4" over the axle?
  52. Delete the cats or run a cutout?
  53. Help! Compression
  54. Custom Intake, New hood
  55. harmonic balancer
  56. where can i buy a new pcm
  57. Kenne Bell 2.8 LS1 F body?????????
  58. Long Tubes cause the LS1 to burn OIL? Common Knowledge??
  59. O2 sensor help
  60. Porting Victor Jr.
  61. Will these fit?
  62. what is it with exhaust shops and true duals?
  63. 1998 tb on a 2002
  64. Meziere, came with T-stat, is it a 160?
  65. Headers to bolt to my SLP Y Pipe
  66. First Mod, exhaust? or..
  67. Installed SLP Loudmouth Catback - Nice improvement
  68. Look what came today!
  69. Hooking coil packs up..........Backwards???
  70. Help!!! All Parts For Cam Swap
  71. Anyone know if these are any good?!?
  72. Magnaflow muffler
  73. shiftlight how to??
  74. Couple of quick questions about o2 extensions and header gaskets
  75. LS1 vs. LT1
  76. broke header bolt, what do you guys think?
  77. flywheel run out
  78. Longtube Turndowns????
  79. Clutch swap, now car has ignition problem
  80. LS1/ intake ports.
  81. Flowtech 3" Race Readies Cutouts Twinpack NIB
  82. MAF Upgrade Questions
  83. slower after header install
  84. cat. convertor question...
  85. Corvette BBK Shorty headers HELP!!
  86. Need pacesetter collector advice.
  87. extending duals under-axle
  88. Best LT fitment? ARH or Kooks?
  89. Underdrive pulley
  90. magnaflow is not quite loud enough. Any sugestions?
  91. bullets in mac y
  92. The Halo Spark Plug
  93. Magnaflow "Y"Pipe
  94. Header Ground Clearance???
  95. Hooker vs. Pacesetter LT
  96. driver side exhaust manifold
  97. Header wrap??
  98. QUESTION: ls1 to ls6....and 85mm MAF
  99. Who sells TB bypass kits ?
  100. ls6 valley cover conversion part#'s
  101. need a exh that is under 90db @75 ft undrer WOT
  102. Going from duals to y
  103. Kooks jet hot coated.
  104. QTP Electric Cutout Durability
  105. Where to buy Stock Header Bolt
  106. looking for complete after market fuel rail kit.
  107. CME tips....
  108. Which Magnaflow Exhaust
  109. FAST valley plate bolts question
  110. ORY or keep the factory cats with Corsa?
  111. How bad is this choking flow?
  112. 4" Y Pipe Setup Pics and Sound Clip
  113. were is a good school to learn.....
  114. Where can i find Stock LS1 Motor Mounts for 99 Trans am ?
  115. Denso O2's, please help.
  116. Removing transistor from SLP 85 mm MAF?
  117. List of grounds.
  118. Noob needs help learning about internals...
  119. Shipping engine
  120. catback vs cutout
  121. Valve Cover Help Need Asap!
  122. any suggestions on mufflers
  123. 95mm TB question
  124. 95mmTB question
  125. Stupid Spark Plug Wire Removal Question
  126. intake upgrades
  127. Where to mount engine on holder?
  128. Is one better than the other???
  129. "98" ls1 valve covers any aftermarket ones???
  130. headers installed now speedo off???
  131. replacing my Pacesetter y......
  132. Bellow for 92mm TB?
  133. Is this normal for the stock lid?
  134. Installing A Catch Can
  135. What Kind of rwhp should I expect?
  136. True Dual setup for MAC Mids?
  137. Mr. Gasket Thermostat in LS1? How?
  138. Exhaust dilemma
  139. 5.3l truck intake
  140. Pacesetter O2 Bungs...
  141. loud intake whistling problem
  142. spintech mufflers
  143. Headers to bullets dumped
  144. Which Intake For Ultra-z Hood?
  145. magnaflow 14419 LM1 & stock manifolds?
  146. Low RPM stumble
  147. Throttle body/cable problem
  148. Off road y-pipe worth buying?
  149. Intake
  150. anyone know what brand of X pipe this is?
  151. can i adjust the idle or wait for tune?
  152. FINALLY! edelbrock catback installed
  153. full exhaust gains
  154. FTRA install going horribly
  155. Baffled?
  156. Bell housing bolts
  157. Question about ls1 valley cover, timing cover and rear main cover
  158. Rear Main seal #$%&*
  159. Started Pacesetter Install
  160. Header flanges shrunk
  161. Stripped the tb blade screw!
  162. throttle bodies?
  163. Some Little Questions
  164. **What do you think**
  165. fab stock cats to a 3" y-pipe
  166. Is possible that header install lead to burning oil
  167. Any sponsors with the new Super Victor intake ??
  168. TSP TD's
  169. 99 Z28 catalytic converter question
  170. help! AIR blockoff screw broke
  171. Cruise control/TC box or module
  172. Whats the mm size of a stock 98-02 TB??
  173. can i put a 98 ls1 in a 99 ???
  174. What should I do?
  175. Electric power steering?
  176. Detoxx True Duals
  177. IAC replacement?
  178. EGR Questions with PICS
  179. o2 sensor unplugged
  180. Anyone running a 3" bullet in the stock location?
  181. Best Flowing HP muffler
  182. Cleaning Fuel Injectors..
  183. why does this happen?
  184. Headers and Catback too quiet
  185. advice on quiet catback
  186. Anyone actually prove hp differences between Borla plates?
  187. Do i NEED? header bolts and gaskets?
  188. Fast help please =(
  189. coolant temp sensor tourqe
  190. Difference between LS6 and LS2 intake
  191. Flowmaster Merge
  192. How can I tell????
  193. 90mm & stock heads
  194. Best set of Heads for a MS4 Cam?
  195. Exhaust slapping underside heat shield
  196. Thoughts on BBK LT's
  197. Those of you with FTRA Kit....
  198. Looking for porter
  199. 160 degree thermostat
  200. Can some one tell me who makes this underdrive pulley/balancer pics inside
  201. P1637, blown gauges fuse, burning smell!
  202. true duals and torque arms
  203. Which intake to buy?
  204. Intermediate Pipe Diameter
  205. Installed LS6 intake...
  206. Where to find Best priced ORY
  207. should i downsize from 4" to 3"
  208. coil/plug wire crimp terminals
  209. ??? about AIR removal
  210. Edelbrock LS1 two piece timing cover #4254
  211. Intake???
  212. Loudmouth Over Axle pipe
  213. Magnaflow install
  214. MAP Sensor Low Voltage
  215. EWP...gain more as engine power increases?
  216. Electrical Question
  217. !egr AND !egr tables...
  218. Misfire after header install
  219. Headers and y pipe???
  220. SLP Lid Problem!
  221. Couple Pacesetter Install Q's
  222. Ron Davis/be Cool
  223. 99 to 02 ss ls1
  224. Throttle Body problem
  225. 180* stat
  226. the best high flow cat
  227. Who else sells oval pipe
  228. Anyone run this 80mm throttle body?
  229. getting egr tuned out
  230. Airbox lid
  231. ditching the borla???
  232. ls6 or ls2 intake??
  233. Ya'll help me decide on this please......
  234. please help im going crazy
  235. Mufflex Questions, Users Inside Please
  236. mac mid, ory, dynomouth
  237. 3" Powersticks on my C5 Z06, pics and video
  238. SLP loudmouth
  239. LTS installed, couple of issues, can someone help
  240. Finished Re-P&Ping the TB (new pics)
  241. carbed 04 LS!
  242. Need your opinions for SS LS1 upgrades
  243. what intake set up
  244. NEED HELP - SLP LT Install
  245. Who ports FAST 90/90's
  246. 2000 A.I.R. removal
  247. Aftermarket Cat
  248. would silicone work for bbk tb gasket
  249. 2 Coils Not Firing.. Whats going on?
  250. fan trouble...
