View Full Version : Generation III External Engine
- Went from MACs to Jet Hots
- QTP Headers
- Interesting flow numbers on mufflers
- Those of you with the MTI Lid please come in...
- Headers info...
- Lucas stop-leak fluid?
- Intermittent ABS INOP light... help!
- Opinions on Exhaust
- New O2 with longer wires?
- US oil pans-NO OIL DIPSTICK ??????
- MSD Plug wires & MSD Ignition Box???
- Somebody's swapped for Edelbrock headers and they're not sharing...
- where 2 get 3" bullets?
- LS-6 Intake install problem...help please
- Catch Can Install Question?
- Removing Alternator
- any advantages using TR6 plugs....
- Porting TB
- problem with header install
- True dual
- Kooks 1 3/4 or 1 7/8
- motor mount question
- Spintech of Flowmaster 1 chamber?
- 3" Exhaust Question
- Stupid F'IN Poly Motor Mounts!!!
- 90k Tune-Up and Maintenance
- Power steering pump problems
- 93 Chevy K1500 Timing
- Intermittent Charging with "Overdrive" Alt Pulley???
- Where can I get a stock MAF ???
- SSRA and No A/C condenser..????
- Part # for passenger side cat heat shield?
- Flowtech LT's + ORY + LOUDMOUTH
- Will this PCV setup work? - Already searched
- Question reguarding HOT FUEL LINES.
- i keep breaking exhaust brackets...
- Where is the Low Pressure Side of R-143a?
- will hot exhaust heat ruin my paint?
- Throttle Sticking
- Cat back ?
- Alternator question
- Getting a 3rd exhaust.. hopefully I'll stick with the new setup. Need advice..
- Cat Question
- True Duals HELP?
- Kooks + ORY + Dynomouth
- which ported TB to buy...
- What size bellows?
- Will WS6 lower airbox fit non RA Firebirds?
- How To Get Rid Of Exhaust Drone?
- Can a stock throttle body be used on a 90mm LSX?
- Killing cats...need advice
- SLP Muffler ?
- how are the proflow twister bullet mufflers?
- what's the final torque for the LSX
- Who runs a stock muffler?
- cutout effects
- GMMG put on today with my QTP LT's!!
- Port TB without Epoxy Fill??
- Running rich
- flow tech headers
- Qtech switch placement on a4's
- 02 sensors...02 sims...ahhh
- Does a TB off of a 01 fit a 00?
- Need some Opions on this Popping Noise-FLOWS!!!!!!
- Exhaust sound with shorty headers
- Power Steering Noise.
- All those with MACS, come in
- GMMG and Borla XR-1...
- Spark Gap affect Exhaust Smell & Power
- MSD plug wire resistance fluctuation
- Any Quieter Mufflers????
- Hooker muffler? and opinions on hooker tips
- Need helpfeels whipy after headers and threw a code!!
- Radiator Swap Question
- TSP Lid doesn't sit right
- Intake Question
- Manifold interchange question
- Truck TB cam gear
- Power Steering Hose
- Just ordered some parts :D
- Long Tube Or Shorty Headers???
- Header - noise question -
- 4" inlet dual 3" outlet Magnaflow Muffler?
- Headlight issue.. any suggestions? (progressive failure)
- Street Pro Cutout Install
- Pacesetter headers?
- GMMG installed today with ORY........
- damn camaro
- dynomax bullet or chambered muffler
- ??What wires to use with TR's valve cover spacers??
- 1 last manifold question
- Stock air lid modification.
- other than ATI...
- I got my car dyno tuned, how much would a ported TB affect it?
- LOUDER? 400 or 346?
- HELP high idle after tb install
- What tool to remove an ASP pully?
- Parts needed for TB bypass?
- Porting MAF sensor?
- Where can I get some Accuseal band clamps?
- 98 5.7 heads to 2004 5.3 heads PCV ???
- started buying dual pieces
- LSX impressions inside
- Inco muffler
- Changing LOUDMOUTH exhaust note
- Anyone using short belt on there daily driver?
- QTP Catted Y Pipe Owners Here...
- I need help finding a rubber boot.
- New possible TD problem
- K&N worth it???
- Porting TB
- spark plug heat sheilds how to remove from wire
- Denso O2 Sensor Questions
- Do i need '98 AIR
- Does Corsa still have the blowout prob's?
- SLP SS muffler vs Z28 stock muffler
- ORY Question!
- Removing ASP pulley to change seal
- Long tube header info?
- Did any of u have problems fitting the torque wrench
- exhaust manifold ?
- ok i need answers!
- broken flange bolt?
- Volant Intake Owners Need help Radiator Support
- Open Header Lt1: Performance Difference?
- use the hose, or not use the hose
- Tornado
- Valve Covers Poll
- Dynomouth vs. TS Rumbler
- adjustable plates:borla cat back
- any last words
- Qtec Bolts
- cats are in the car
- Weight of underdrive pulley help.
- Misfire= ses light?
- Flowmaster 53083
- every bolt on?
- New Pacesetters with local coating!!
- 6.0 coils
- Nitrous with Shorty headers? ... or LT's????
- Need help with pulley and cam info?????
- Over axle duals experts please help!!
- where to buy headers an y pipe best price
- Part # Help
- How to quiet Loudmouth??
- Will a Vette oil pan fit on an F-body?
- Vacuum lines
- Need pulley help...
- Flowmaster in I pipe
- I need some help please!
- porting MAS on an A4
- Could buy GMMG with this tip? **See Pic**
- Two on the left
- Edelbrock catback?
- TR6 or TR55 for N/A
- velocity stack upgrade
- does the loudmouth shave more tenths off in the 1/4 than the gmmg?
- Changing my exhaust (AGAIN).. which option this time
- Who has QTP Merge Collector LT's, QTP Y-Pipe, and 3.5-4" Catback?
- Harmonic balancer
- Symptoms of a Bad IAC
- fabbed true duals....
- Texas Speed Duals
- shift light help
- What coupler for 90mm TB
- Is it just my set up or have you run into the same problem? (short belt)
- whats the best muffler for replacing the resonator on the LM?
- Which muffler has a better deeper louder sound for LT headers? Aerochamber or Borla
- Spark plug gap - how much variance is acceptable?
- Oil Cooler Adapter- PN 15725587
- Best LT Header
- Denso O2's
- Cold Air Induction
- Corvette owners with Corsa systems...
- H/C+Macs+ORY+loudmouth=RASP!!!HELP
- Excellent up grade
- should i sell my jethot catted y pipe and get the qtp catted y pipe for jethot lts?
- Solid Motor Mounts
- BG ramair and SSRA questions
- charging system problem
- I'm going with 3 inch duals. How loud???
- Pics of AMW catch can installed
- My exhaust situation
- taylors or msd????
- dr gas/pacesetter
- Which spark plugs and wires???????
- Questions about street legal long tubes with catilitic converter!!!
- Anyone with a good way to clean the insides of an oily LS6 intake that's off the car?
- where can I buy a Catch Can?
- Well, I drove the car with the new intake....
- porting MAS infor obtained at install U
- decarbonizing intake how often
- Just Bought An ASP Crank Pulley!
- Has anyone used Dynatech Powercat Cats
- Are all O2 sensors created equal
- Post Flowtech LT install
- Can you buy just the motor/wiring for the QTEC?
- Anyone running a Bassani catback???
- another AC recharge thread...
- Clearance PICS of Kook's LT's/Catted Y pipe lowered on Eibach Pro Kit...
- borla vs loudmouth vs GMMG
- pics of true dual exhaust
- !EGR & !AIR on 2000 TA
- who makes the best damper?
- plug change
- Duals on the street
- What is this darn squeaking / chirping noise I hear ?!!
- anyone else experience this or is it just my luck
- intake comparison from Chevy Hi Performance mag?
- jet hot or hooker?
- GMMG or Borla
- !Power steering
- nobody seems to know, so I'm posting here.
- Installing a MAC ory
- Need pics of AMW catch can installed to make sure that I have mine routed correctly.
- My belt set up with no A/C or P/S
- rattle
- Do 01-02 exhaust manifolds have an egr outlet?
- one chamber?
- mufflers or resonators?
- borla xr-1
- magnaflow question
- LS6 intake swap problems..
- My oil pressure gauge is stuck??
- Stainless True Duals kit from Stainless Works
- Engine removal from the top
- Uncoated Headers Burning Plug Wires. Solution?
- Problems after Coil Pack Relocation
- shorty headers worth it??
- Need help with c5r valvecovers modifications
- Best exaust
- LS1 Intake Temp?
- I'm broke ... what can I do?
- Should I Drill The TPIS Throttle Body?
- VW sound in LS1?!
- Did poly motor mount tonight...
- Removed alt. now no charge?????? WTF?
- bad cats
- Interesting read on Bosch Platinum Plugs...
- QTP catted y-pipe
- Doing poly motor mount right now, need help!!! ASAP!
- Taking off my dual 2 1/2" x-pipe setup, for 3"
- 1-3/4 or 1-7/8?
- Confused...O2 sensors vary, swapped O2s, same thing...sparkplugs?
- complete exhaust system
- What belt? (No PS/AIR/AC)
- Hooker header install
- AC Delco Irridium Plugs?
- Header/Cat Rattle
- Easy z06 maf quesions
