- I did something bad! (O2 sensors)
- Jet Hot coating has rusted off. Now what??
- 160 tstat a good decision??
- Pacesetters Lt's installed
- Squeky noise!!!
- getting LT headers and Y. do I need O2 sims?
- Need some advise please....
- Got My LS6 today, got some q's
- borlamouth peeps inside please...
- Need help right NOW! plz post quickly!
- ? chambered muffler in place of resonator on loudmouth ?sound?
- Would 2.5" carsound cats on a true dual system be too restrictive? ASAP
- My LSx problem hopefully fixed!
- asp crank pully and now slower?
- ATR Pitbull Exhaust system
- THose with Kooks headers andan Xpipe setup, please post pics.
- Anyone have the Stainless Works Xpipe setup?
- Factory Tensioner Pulley or MBA Tensioner Pulley?
- Edelbrock Performer Intakes
- QTP LT's ROCK !!!
- catch can?
- This months Super Chevy intake tests
- Help! I'm Confused!
- Best way to check for bad coils?
- QTP ORY & Corsa Cat Back
- Any custom intakes making significant power over the LS6?
- help with steering shaft connection
- exhaust sounds?
- race tips needed here
- belt tensioner
- Texas Speed Rumbler
- magnaflow owners inside
- Chevy High Performance Intake Shoot Out
- different exhaust
- Is the Dr. Gas x-pipe worth the money?
- loudmouth
- help with ORY fitment
- Installing non-EGR LS6 intake.
- Fast Toys Ram Air Tid Bit.
- Lock-Tite on ARP crank Bolt?
- wont be buying from flowtech anymore!!
- LS1 underdrive pulley Identification???????
- March Underdrive pulley Fluid balanced
- remove hood baffles or no?
- Damn rasp gossip....
- LS1/LS6 intake manifold swap to 5.3
- Anyone know how to remove the AC?
- Pics of my Kooks with engine out of car
- Anyone have side pipes??
- Torctite Exhaust Clamps
- question on cats going bad
- Best sounding exhaust I've ever heard on an LS1.
- Little Pissed about this LsX, called FAST..FYI
- ASP Pulley FELL OFF!
- kinda disappointed in headers.....
- Porting the LSX manifold
- Removed Cats = Rough Idle.
- SES light after header install
- Can Someone Educate Me on EGR?
- true duals+CME=???
- Is the battery tray removable from the coolant overflow?
- Need a favor from someone with a Helms manual
- Ebay Headers
- Exhaust cutout
- Help Please
- earl's header gasket?
- Knocking Sound on IDLE!
- Question about my 98 trans am
- Need some Help... LM/no cats.. Major Rasp!
- edelbrocks new carbed ls1with msd ignition
- what are the best spark plug wires to use
- Flowmaster Exhaust
- How can i get a TB quick?
- Home ported MAF vs. aftermarket??
- Crankcase Pressure
- Gutted Cats.. Pass emissions?
- AC compressor
- Intake casting #'s? Fastchip programming?
- Torx bit size for AC evaporator holder?
- Header install....no codes, but strange sound...please help
- Witch throtle body to get for 2001
- DS Loop with FLP Headers?
- Pacesetter LT's question
- CHP Intake Manifold Tests.........
- FINALLY got a Borla
- Anyone have a little rust on there stainless headers?
- Confused? Is the Kooks Ypipe Stainless?
- Noise is driving me crazy!!!
- FAST 78mm I HAVE BIG ISSUES!
- LS6 Intake Install... Bad to WORSE
- Headlight problem, both high and low on at the same time
- TPIS 90mm TB.... Has anyone tested this with LS6 Intake?
- Coil Re-Location Installation ?
- How Much To Knotch The K Member
- which spark plugs to run?
- Locally Made X-Pipe vs. Mass-Market X-Pipe
- Installed catback...fitment concerns...pictures inside
- Need Help with AC
- Which headers tuck the highest?
- going w/duals..
- Anyone pass smog w/o cats?
- TB spring not hitting bump stop
- Hooker Header Track Improvements
- tr6 plug number
- 90mm LSX & TPIS T/B & H/S roller rockers install
- QTP Y pipe better than Kook's Y pipe?
- welded or clamped??
- OK for rubber in ASP pulley to be cracked
- Pacesetters suck
- Help with exhaust for trans am
- Little header install help, will take 2 secs to answer
- meiziere install snag
- Does anyone use a Evans waterpump?
- Borla People
- Engine to Bellhousing Bolt Pattern
- True duals installed...
- which is better? a stock ls6 intake manifold or Holley Aluminum LS1 intake manifold?
- Edelbrock stepped headers
- Breslin Split-Lock header bolts
- Alternator or Alternator plug?
- Cheap 3" cats
- Removing Wiper Blades
- Would these Flowmaster's work for true duals?
- Impression of Flowtech headers within
- Where can I buy a Dr. Gas x-pipe?
- true duels with tips in back
- Ported my LSX 78mm........
- Who sells Hooker Aero chamber mufflers?
- How would this sound?
- Anyone running LT's/no cats/ with a flowmaster?
- QTP on production vehicle?
- rattling exhaust driving me to kill.
- Turn down pipe for Q-TEC electric cut-out!!
- Help Car wont start!
- New Taylor 10.4mm wires = rough idle
- Be Cool Radiator and Meziere EWP ?
- 1 or 2 cutouts?
- Coil pack relocation!!!
- Questions about heads and valve covers???
- Would bad crank sensor cause random misfire and rough starts (non-LS1)?
- Cut-out Question?
- FlowTech headers any good
- need instant header install help
- full size oil pan
- cutouts???
- You guys using ASP UD Pulley is your Power Steering harder to turn?
- true duals with a cut out?
- Advice on some LT'S
- Why true duals when they aren't?
- I need a catted-Y that fits the Hooker LT's....
- Calling all Kooks owners
- Getting ready to buy headers????
- can an ls1 intake fit on a lt1
- Going with true duals..
- Please help me decide
- Cutout before LT install a problem?
- 78mm FAST & Shaner or LS6 & Shaner ?
- BakerElectronix O2 Sim... Anyone using one?
- where can i get X peice for true duals?
- How many of you true dual guys.......
- how to wire o2 wires with jet hots?
- WAR Intake, Accel Teaser pictures
- Volant Intake
- Wiper Removal???
- A/C compressor reinstall ???'s
- Horrific Idle after ASP Underdrive
- K&N tell me how bad is it???
- QTEC Cut-Out Toggle Switch
- Headers/Exhaust...??????
- Quick MAC question....
- Removing Air
- hooker stainless
- March Pullies
- gut intake manifold?
- Who sells off-road pipes?
- Shorty Install Q?
- Spark Plug Gap
- T/b
- Headers
- Which Y pipe to use with pacesetter LTs
- Are there any stainless steel bullet mufflers out there?
- R there NE pre-fabbed mandrel x-pipes out there that will work w/ the Spohn TA?
- Please Help
- When is TSP coming out with the true dual system?
- what headers compare to FLP
- Headers
- Mccord or QTP electric cutout?
- Problems with Exhuast Cutouts
- Do u need a tune after header/lid install?
- Paging those with the 1 3/4 to 1 7/8 Edelbrock headers
- Ls1 Lower AirBox Bolt's & Washer's
- Question about Lanes True Duals..
- WHy does it go to 2 3/4
- blind leading the blind....
- gmmg question?
- pacesetter headers
- Best headers and exhaust
- How many deleted pcv?
- exaust diameter
- What do you know about this intake?
- Clearance between DS Loop and Y-pipe
- Sticky tensioner pulley...?
- hooker y pipe work with qtp headers??
- Need Help ASAP
- Has anyone had their true duals ceramic coated?
- Need pics of true duals/x-pipe/bullet style mufflers/dumped with Spohn torque arm.
- Going to install my LSX intake, just one question?
- Cruise Control Not workin??
- catted Y and performance with corsa
- ?mods¿
- Those with true duals/x-pipe/dumped, using bullet style mufflers, please come in.
- Got a new Hood, Keep the FTRA or No?
- PCV Valve Swap
- new ceramic LTs/catted y cheapest
- Cutout Install - A somewhat different approach
- Chambered muffler question(need explanation)...
- LTs/catted y-pipe is it redundant?
- header/ory install success
- Need help installing hooker headers!!!
- Advice on Y-pipe
- Any year LS1 not have power steering cooler in upper radiator hose?
- Exhaust help.
- Free Mods?!?!?!
- The next BEST! bolt on???
- How To Remove The Intake
- Cheapest place to buy LS1 brake backing plates?
- What's the difference between GMMG and Loudmouth?
- cleaning holly power shot
- AC Capacity Question?
- NECK PORTING LS6 intake?
- Anyone run the traditional green antifreeze?
- Difference in a 160 and Fan Control Switch
- Carsound cats
- 40 Series Flowmaster
- Flashing SES After Header Install - HELP!
- drilling my TB?
- With my True Duals, will SLP subrames fit ?
- Longtubes installed, now catback decisions
- Corsa exhaust owners
- dynomax bullet
- Must be only one running stock air piece
- meziere water pump
- Wideband O2 bung - yes or no?
- Bah QTEC wont work...
- dent header cause misfire?
- O2 sensor question ASAP please
- Help!!!!lt Headers
- 78mm LSX intake?????
- LSX V's Weiand V's anything else? What do you suggest?
- sensor ontop of intake next to driver fuel rail
