- Slack in Gas Pedal
- Xmas Bonus = EXHAUST
- single plane, manual trans guys.......
- cme exhaust
- Carb Spacer
- LS1 starter
- Problem: Ls1 slp underdrive pulley on lq4
- tach hooked to the coil?
- Will LS1 Longtube Headers fit on an LS3?
- Metallic Core Catalytic Converters?
- Bbk vs kooks
- 02 ws6 427 lsx boosted, which MAP? Fast?
- Phab Exhaust
- Ls1GTO harmonic balancer vs 4th gen ls1
- Difference between these Magnaflows
- What mods are needed to go from a FAST 92 to a 102?
- Kooks header question
- How do I quiet down my Borla?
- Timing with boost: pump gas vs race gas
- *Our Holiday Sale is going on! Great gifts at great prices!*
- Intake tube question. What angle is this?
- F-Body waterpump depth
- Please help identify PCV Valley Cover
- anyone seen cats inside headers?
- SLP MAF and smooth bellow
- Anyone make a ypipe bracket for a 4l80e?
- will my ls1 ASP balancer work on my ls2 build?
- Less bulky coil packs...
- LS1 Help!
- exhaust question
- electrical gremlins playing with my locks
- Cammed my ls1 a while back, need feedback on sound? (Idle Video included)
- LS1 Heads
- Intake differences from EGR and non EGR models
- Anyone running a Holley Dual Plane EFI Intake??
- Feels like I'm losing power
- Any guys with with stock shortblocks n/a running a vacuum pump?
- PTFE fuel pump wire source??
- lq4 injector swap
- Starter wont engage, ran after bumpstart.
- 6.0L mix match part help
- Exhaust help.
- Header Coating
- Breather filter on oil filler neck 2002 z28
- Black water spots all around engine bay...**UPDATE***
- throttle body
- New LT headers, should i change my new rubber motor mounts for poly mounts?
- Can anyone tell me if this crank pulley is off a TBSS or C5?
- Fbody trans am swap to 6.0 HELP
- Anyone in Phoenix with True Dual setups?
- Anyone use Griffin 27.5x15.5x3 radiator in stock location?
- Hooker LT's TSP True Duels
- Firecore LS1 Plug Wires
- 90mm Throttle Body question?
- LS6 Cam, 1.85 Rockers, PAC 1211X?
- Extremely High Voltage Issue
- ls6 intake to ls1 intake
- Hooker Headers for LS1 on CLEARANCE!
- P/S pump shaft size?
- hoosier slicks! opinons
- Magnaflow glasspack vs dynomax race bullet
- Where are all the true dual guys at?
- LS1 Injectors and Fuel Rails
- Billet Aluminum Coil Brackets
- Best sounding muffler on stock exhaust?
- Pfadt Tri-Y Headers
- 241 Stage 3 RGR Heads
- Won't start help..
- Lq4 weight
- ++Check Out This Black Friday/Cyber Monday Sale For Awsome Deals!++
- thanks peak speed shop!
- 6.0L LQ4 to LS6 intake fuel rail problems
- TD's dumped = great Out the back now = Rasp??
- How much hp would I lose
- F=Body Damper on 5.3 crank
- Racetonix Dealer Question
- LS1 Camaro Valve Train Noise & Questions
- Anyone with a ATI ls6 Damper?
- msd 8733 with microsquirt ?
- Magna flow or Flowmasters
- Installing Cruise Control In Non-Equipped Car
- Universal ORY?
- What intake?
- Tap oil oan
- can't decide on the mufflers
- What parts are need for AC install
- Electric Race waterpumps
- lq4 intake swap
- Harmonic Balancer NEED HELP!!!
- Speed Engineering Race Version Headers Now Available!!
- low profile catalytic converter? steel or ceramic?
- lid/airbox restriction?????????????
- Ls skyline
- Kooks Exhaust for LS1: Great Deals from AJUSA!
- what AFR head and cam
- LS6 intake install problem?
- LS6 valley plate question.
- High flow cats or a 2nd muffler for rasp?
- eBay true duals install HELP!!!!!!!!!!
- Exhaust Manifold Double End Stud, correct size.
- Fluffy stuff coming from my exhaust... No, really!
- Super Vic., Edelbrock Pro Flow XT, Holley High or Mid Rise Intake For Max Effort 346
- over axle exhaust pipe
- Is this belt routing ok?
- I guess i had to brag lol
- what is this?
- 02 TA FAST 102, 102mm TB, and stock Maf and SLP Intake what coupler?
- Engine number location Ls-1
- Im an idiot....water pump question
- Bosch greet giants or racetronix 42lb injectors?
- Rock auto gaskets
- Which intake flows better?
- d585's to regular truck coils
- PFADT RACING HEADERs and SUSPENSION VENDOR
- exhaust help
- looking for a pic....
- Ok I'm changing my exhaust one last time.... Suggestions
- Rst clutch on stock flywheel?
- Sound Clip Request - Cam, FM Merge, Hi Flow Cats, Corsa Catback
- ls2 intake on 5.3l motor
- L92 intake what do I need to Fit 102mm Throttle Body
- Stainless Works Headers and Y pipe
- EBay Top End Kit
- Kooks and Subframe Connectors
- AC Delete Questions
- idle issues need ideas
- Hi-Ram, Pro-Flo XT, or Super Vic for the 383 LS1 in my boat?
- Ordered Kurt Urban steam vent setup
- 232/236 .600 112 lsa. Cam only?
- Car will not start at times?
- Fitting 85MM MAF to 75 MM Lid
- I Need Some Help Guys
- LS1 Idle issue please read
- ORY and 3 inch pipe to small?
- How do you convert to the Vette accessories?
- Pulling intake
- Question, Harmonic Bolt & other
- Valve size with e85 395 stroker build plus other questions
- TBSS intake or LS1 on 5.3???
- Kooks Headers and True Duals Video
- ls1 engine mount spacing distance
- removing rusted catback, too loud?
- ls1 intake swap
- powerbond 1480ss
- ls6 intake problem
- Magnaflow true duals with cam. Anyone have sound clips?
- One head off.. Any mods while she apart???
- Things to do first before adding power?
- Steam ports
- Can someone help me with a part number off their stock intake?
- Spark plug help
- power loss from LT to ST headers
- Help identifying ls1 headers
- make lt1 intake work on my ls1
- Best way to clean out ls2 intake after porting
- Need some help
- PowerBond UDP Question
- TNT Nitrous kit on 4th gen Firehawk- What air box lid to use?
- Help me choose a ps pump
- Option for Headers for 4x4 Yukon
- TSP LT's, ORY to borla adjustable
- 98 ls1 camaro only firing 3 coils
- Valve cover grommets need help
- Head & cam packages by performance & cost
- idle issues, iac??
- ls1 custom exhaust sizing questions for best overall flow.
- v6 to lt1 swap questions
- Question regarding pcv routing..i know another pcv thread..
- Need quick advice/info on 243 heads off an 07' 5.3L truck motor....
- Will This Timing Cover Work on My LQ4?
- High Flow Cats and Y Pipe Stainless Works
- Other y pipe options?
- My DBW is not functioning Correctly
- Fast 102 and trap speeds
- 33lb or 36lb injectors for LM7
- What does this go to??
- New Exhaust Route after H/C
- Starter bolt size?
- Type of exhaust for cam?
- How much HP can I expect
- 02 sensors bad without codes?
- Rich after headers?
- 2003 LQ4 Truck Engine
- ideals on next bolt-on mod
- Ok guys bear with me - Stock Trans Am
- Another alternator problem... help me trouble shoot please.
- truck coil relocation kit?
- holley 20-149?
- TSP Y-Pipe Fitment...
- 5.3 connector ID help
- Dual cutouts vs 4" system... anybody have any results?
- Slp Throttle body with LS6 intake?
- Flowmaster True Duals DIY Kit?
- Ls1 water pump depth
- 1999 LS1 no spark on right side (passenger)
- Header choice for 500 rwhp Build??
- Underdrive pulley
- Crank Balancer Question
- Kooks True Duals
- car Wont Start
- 3" Corvette Exhaust?
- Help with consistent miss
- Fast 102 Fitiment Questions
- oem water pump?
- Cracked FAST intake and replacement option
- 4inch throttle body spacer
- Y-Pipe exhaust flow question
- QTP stainless headers for sale
- What goes here on an LS2
- fast 14632-kit
- Turndown tip or no?
- Sensor questions...
- Smoking Alternator?
- fast rails help
- green belt from gates??? anyone have a product#
- Intake Manifold Choice LS6/FAST
- Value?
- Another underdrive/harmonic balancer pulley question
- new ls1 owner 2000 ss slp
- Quality of this piece
- EVAP delete on LS1 out of 2000 TransAm
- Borla/Pacesetter Exhaust Packages for LS1/LS6!
- Exhaust System Input Needed
- Hot Start Issue - Need Help!
- Newbie here with exhaust question
- Hoosier QTP's !!
- ARH 1 7/8" with tsp duals
- Switching from elbow to 4150?
- Battery relocated and now trip and fuel trims reset on start
- Breather Set
- CME Valance Push Pins
- Whats worth more?
- 1993 lt1 popping from tailpipe
- Ls1 coolant tubes
- Need advice on intake setup for 383
- Need help with knock sensor, 24x swap
- Lets talk Sensors..
- How To: Power Steering Pulley and Pump Removal and Replacemnt, LS1 F-Body, Turn One
- Ignition troubles, please help!!
- can I delete this?
- MAF sensor question
- What is the quietest 4" muffler I can get?
- Oil pressure problem please read
- AC install questions
- Quick bolt size help....
- Starter making grinding noise while cranking on a 5.3??
- Making valley cover lift plate.
- Question about knock sensors
- I dont know what to do with my exhaust!
- 64.5 Mustang LS swap?
