View Full Version : Generation III External Engine
- Anyone have a problem with O'reilly's Idler pulley?
- oh look another ls1 sputtering issue
- Deleting EGR Need Template to Make Block Off Plate for Headers
- 02 Air removal
- Budget Build
- plug gap & missfires
- This is a stock pipe, right?
- Spark plug hole fix?????
- Confused-y pipe vs merge collector?
- LQ4 Ls1 Pilot bearing
- SLP Lid Fitment!!!
- What Lid is this??
- Corsa Muffler
- Introducing another New F-body Publication:
- Starter/Alarm/Battery
- Air Lid
- Tick tick tick
- New full exaust set up with vid
- Your advice in the modified engine ls1
- BBK intake and throttle body?
- Fbody mufflex who has them and what do you think
- LS6 or BBK SSI? (intake)
- Best throttle body for 92mm fast intake?
- help with new exhaust set up
- Which heads are better
- Where can I get the right Y pipe?
- Question to those who have LM1 + LT's w/ CATTED Y
- trade lm1 resonator for magnaflow bullet
- muffler inserts
- y pipe for qtp headers
- 02 Extensions, do I need them?
- QTP catted Y
- Solid Motor Mounts...old idea with a whole new design!
- Key Fob (keyless entry)
- Am I missing something?
- Need a catch can
- 243 heads
- PCV delete?
- Drive without front o's hooked up?
- Ewp?
- 04 ls1 need injector advice..
- Need some help with next mods
- L33 Questions
- Borla to Corsa Conversion
- Stainless Works Catback?
- cleaning out wires, what can go?
- exhaust choice help
- Changing from slp long tube headers
- Victor jr question
- Fast 90/90
- How to replace starter
- looking for a review on 4inch mufflex and magnaflow race muffler
- f-body waterpump on a 6.0 with no other changes?
- Need help with oil pan question
- Glowing Catalytic
- Going from True Duals to Y and GMMG
- Vararam TB insert..
- O2 sensors and LT's....
- Crank pulley with out AC?
- i gotta be forgetting something
- LS coil harness
- Patriot gold spring height
- exhaust clamp
- ?'s about dual valve catchcan....
- I am looking for a higher exhaust pitch. What are my options.
- ARH header install problem.
- Harrop’s “Hurricane” Throttle Plate Intake Manifold
- 4th Gen TSP 1 7/8 LT Install Questions
- Tuning for a cutout ?
- coil relocation wires?
- Oil Pan Question....
- removing cats question
- old and new thermostat won't open?
- starter power wire
- Reverse style throttle body??
- Air Box Filter Tray Problem
- Does anyones W/B go nuts when they open the E-cutout?
- Need advice, LS1 swap into G-body
- Fast 90/90 gains on my set up?
- volts surging alternator going?
- O2 sensor ?
- Lower Radiator
- Y-pipe for eBay headers
- Camaro trouble starting
- Vacumm leak?
- Longtubes best way to install???
- super vic vs. FAST 102
- Repair intake manifold
- cat question
- how do you adjust throttle cable???
- New ECM.....
- Sensor behind the intake manifold
- Thought I share (vid) headers into ory into 3" magnaflowtocutout dumped sounds lik
- Coolant boils & steams out of overflow tube no leaks or overheating... Suggestions?
- underdrive pulley question
- I need ca legal headers
- Coils??????
- Cross flow to single in and out.Idle clip
- which air lid makes most power?best fit
- Need some Exhaust advice ASAP!!
- To weld or not to weld
- v6 sputtering
- fast 102
- Heater core bypass
- slp loudmouth
- What is this??
- Wiring the Starter
- underdrive pulley belt?
- bad alternator? or just wet?
- my header and y install
- LQ4 or LQ9 how do you tell
- Pacesetter ceramic LT's
- Wrapping Headers...
- Slp maf
- i need some help with what intake to go with
- ls6 fuel covers on a 5.3?
- F.A.S.T. 102 install
- ECT Sensor wont work
- Throttle Body bolts size
- The quality of Hooker products: Where did it go?
- FIPK question (Part #s and metal thickness)
- KooKs header install
- Tips on headers/exhaust?
- Intake manifold options? VicJr vs FAST
- ARH 1 7/8 headers o2 bung placement
- OEM throttle body size
- Those who purchased 1 7/8" headers lately chime in....
- Stalls and bucks like there's no fuel
- P&p...
- which denso 02 to get?
- Flange question.......
- Another thermostat question
- stalled when shifting to drive...
- powersticks + lm1=
- Headers opinion???
- debate over magnaflow loud or no
- heads
- What heads are these and what to sell them for?
- Valve seal replacement how to?
- Header Install HELP?!?!
- 3.5" spiral flow OR Bullet?
- Heard about an LPP Christmas GP
- Powersteering exploded, ack.
- Contemplating a/c delete
- Installed headers, now the car is driving badly
- Winter Rebuild Thread
- clearance with tsp true duals
- Drone???
- Texas Speed, or BBK? Opinions, please..
- Ory??
- How many o2 extentions do I need??
- Anyone have cutouts on a catted Y pipe?
- Oil leak at back of engine
- Flowtech LT's, are they any good??
- MSD ignition system?
- Estimated HP???
- Dropping too 500rpm
- Question related to LT's and Emissions
- Exhaust Info Please! LS1!
- how much power is a ls6 intake good for
- need a tune? ls6 to fast 78 with 80mm tb
- ect issues cant get rid of code....
- why is my car doing this??
- Traction control delete question.
- True dual pain in my butt
- Slinging Drive belt "normal"?
- Do i need a tune?!?!?!?!
- Opinions on Porting and Polishing!!
- will cutouts fail safety test?
- Estimated HP?
- how do i get a frost tune?
- What MAp should i buy and where does it mount on a super vic with elbow
- Edelbrock Ceramic Shorty Headers and Magnaflow Heavy Metal Hi-Flow Cats
- Anyone tried the HOOKER 1 7/8 headers
- Anyone running the ebay fabricated valve covers?
- LS6 Intake or LT's?
- Ok Which of these 2 headers should I choose?
- another what exhaust should i do thread
- shop quotes ?
- Full Bolt-ons?
- After thinking I think suspension is next.
- Yet another PaceSetter install
- Best muffler for single dumped set up?
- shop tuned or hand held tuner
- exhaust leak...again, PLZ HELP!!!!
- Motor Mount Thread Size (LS1 Block)
- My car is missing on cylinders 4 and 5 primarily.. NEED HELP!
- Does anyone know what underdrive pulley this is?
- Exhaust Clamps Size Question
- quick Q
- Purpose of epoxy on ported TB's
- headstuds which ones HELP!!!
- yes, another 2K idle thread...
- LS6 valley cover question
- Should I sell my Corsa catback?
- $300 mod
- Vapor canister broke off
- arh 02 extensions
- Dumb question about headers
- Prof. Products intakes
- lookin to quiet my duals up some
- Header ?
- Stock cat question...
- timing cover??
- EGR/AIR delete help
- Exhaust opinion
- Needing Alternator Mounting Ideas....
- broken oil press sending unit
- Help-Stripped wire out of Alternator
- ls1 lokar dipstick on 5.3 ???
- Vacum Map?? LQ4
- LPP or BBK Headers and Y-Pipe
- What is the best Drag Radial to drive in rain.
- Alternator wires picture please
- O2 Sensor Question
- ls1 and ls2 pwr steering/ alterantor bracket same?
- looking to trade my borlamouth for a magnaflow catback
- 'TV-Car' Quiz!!! "Test your might!"
- what to do?
- Are you smarter than a 5th grader? a/c question
- Anyone try Jegs plug wires?
- Need to quiet down GMMG, options??`
- Tsp true dual cabin noise
- SLP lid and MAF a restriction?
- Moroso oil pan
- Exhaust hangers!
- Edelbrock Xtreme RPM Heads #61949
- plug wires for tall valve covers and truck coils?
- Trying to calm my "dynomouth" down some
- LS3 steam vents work on an LS1?
- Need Help With Pilot Bearing
- Oil, Spark Plugs and Coolant for Motor Install
- is a morroso oil pan needed for LS6??
- Replacing LM I Resonator with other muffler
- Block powter coating?
- LS1 valve covers
- Belt squeal?
- Gimme feedback
- How to clean K&N filter in 7 stips !!
- Bad O2 sensors
- how to hook up tach to 95 camaro
- hot to fit a muffler underneath car????
- Best way to make my car quiet(er)?
- More accurate O2 sensor than stock?
- Canadian built or US built 5.3?
- Steering column help!!
- ARP Flexplate bolts
- what do i need to run a vic jr?
- Performance Spark Plug Wires
