- my headers have dents in them is thay going to affect flow
- Stainless steel headers give more power than coated?
- X-Pipe
- ground clearance on x pipe :(
- Need some help with header decision...
- Bassani
- Hooking up an electric water pump wiring
- Gutted Cats Backpressure
- P?N for belt with ASP pulley
- TRUE DUALS WITH X PIPE?????????
- loose map sensor
- Who all has duals over the axle?
- GMMG vs. MagnaFlow
- aftermarket intakes
- Headers/ORY install
- coil pack voltage
- Losing Rasp w/ Corsa & LT's
- Are SLP, Z06 & GM Truck MAF's the same?
- question about SLP pip with cats?? impt
- Loudmouth to DynoMouth??
- Cracked LS6 Intake, what epoxy,jbweld etc to use to fix??
- LT's
- Who's making over 400RWHP with short headers or midlengths
- Super Sucker scoops for FTRA or SLP CAI kits?
- 1.875>2.000 Kooks Step Header, great plug access
- SLP 85mm MAF
- SLP Cats and Y Pipe with LM
- Magnaflow sucks!
- how many cfm is my car pushing out the exhaust?
- Poly Motor Mounts
- Headers
- Will a hooker y-pipe fit jet-hot headers?
- Exhaust
- Those w/TTS LT's pleas help
- Anybody have their car lowered with true duals?
- to anyone that knows about lids?
- Cutout ???
- SLP CATTED Y ON PACESETTERS
- LTs = KR?
- anyone install pacesetters and got a catted y pipe 2 fit?
- how much HP does the Borla plat cost you? Answer inside
- what next
- Anyone make a coilpack relocation kit?
- pasesetter headers
- Increased valvetrain noise after installing headers?
- i cured a problem tonite go me !!!
- TB bump stop mod question
- Gutting or removal of Cats, will it throw any codes???
- who sells replacement coils
- Installed FLPs in 6 hrs.
- How do you test stock coils
- where is there a hole to run the fan switch ? in the firewal
- Drone with dumps before the rear axle.
- Stopping Header from banging
- Stupid Header Question( I know another one)
- Car missing at WOT
- Question about Loudmouth with no cats
- Jet-Hot Headers and y-pipe
- Meziere Water Pump + ASP Pulley = drained battery?
- Just bought an ls6 intake what else do i need for install
- Sensor question!!
- FAST LSX Intakes @ Thunder Racing
- Which flows better, Magnaflow or GMMG?
- Intake Manifold Question
- TSP Installation: Filter Breather, what is it where do I get
- The Right Exhaust
- Short Shifter
- Jet Hot Headers
- Where to get TTS headers?
- Running a Badass Mustang GT tonight. What to do?
- What Header/Catback combo is recommended?
- Do pacesetter LTs have EGR and air hook ups?
- can you put cats in a pacesetter y-pipe???
- Got my headers on finally!
- Pacesetter Qs and Ypipe pics?
- CAR PAUSES
- 2/3 of the way done on Prothane install. WOW!
- weight of cat backs?
- Thermostat mod question
- !AIR without SES
- Direct Hits ignition
- NE1 besides Meziere make an electric water pump for an LS1?
- another question...EGR...what does it do? can I remove it?
- xpipe clearance
- Which Thermostat, Hypertech or SLP and 160 or 180?
- Missfire after removing AIR pump
- Finally ordered GMMG!
- ATTN. -Jet-Hot Headers- ATTN.
- Who makes the best electric cutout w/the least problems?
- O2 Extension lengths with pacesetter headers?
- I fought the car, and the car won
- NEED HELP WITH EGR AND AIR BLOCK OFFS
- Mufflex Y pipes...
- Loudmouth Vs. Dynomouth
- WARNING... If you have an aftermarket cat-back installed,
- Porting an LS6 intake....
- TTS headers
- quick waterpump removal question
- Thinking about getting rid of the Mac's but what should I go
- Header install. What else do I need?
- intakes??
- Hooker ORY
- Jet-Hot AIR fittings 90 degs off
- Block off plate questions.
- what yall think
- Pro and Cons of Loud Mouth?
- Will removing the A.I.R. cause you to fail emissions?
- Everyone with QTP's, please come in...
- baker hose will not fit!
- Failing nj inspection w/ LM exuast what are my options?
- Question about LS6 Intake
- Is it possible to use a Trans Am lower air box on an SS?
- Straight Pipes Too Loud?
- slp cme with loud mouth?
- Question about macs and hookers....PLEASE READ
- Exhaust system questions, please HELP!!!
- Which LUBE for ASP Pulley?
- Which Plugs?
- tunning after ls6 intake install?
- do meziere water pumps pump enough?
- motor mounts - left and right?
- dual exhaust
- Opinions on LS1 Motorsports Direct Flow Air Lid?
- CFM Ratings from MAF to Intake Manifold
- LT1 valve covers on LS1 heads?
- Will Granatelli LS1 MAF fit a 2002 Silverado 5.3??
- Heres BOTH oil pressure sensor part numbers...
- installation of 160 degree thermostat
- Stainless Works Headers and 3-1/2" Exhaust System
- ls6 vs weiand intakes
- throttle body porting how-to's?
- What are the advantages/dis to.....
- FLP worth the $??
- Headers...which brand do you think are the best?
- y pipe size
- The best exhaust
- Headers...which do you think are the best?
- anybody got a stock ls1 intake just layin around?
- Ported/Powdercoated TB's now on SPECIAL $130
- Building true duals, Dr Gas X and what else?
- LS6 PCV not my friend.. Need proven catch can setup!
- Which Headers on a lowered car??
- X pipe questions
- What size muffler will bolt to the stock Y-pipe????
- what size injectors?
- MPP2 with factory tcs or fog light switch
- Help-Need a VIN # from a '01-02' car to buy SLP CME parts.
- Worth it to put cutouts on this exhaust?
- how to seal up exhaust.
- What else do I need with headder purchase?
- Need Pic's of X-Pipe Setup!
- Headers
- Gonna gut them cats!!!
- Installation of slp loudmouth in my driveway?
- Spintech Mufflers Any Good on LS1's?
- Low on gas -> computer pulls timing ???
- Who makes a dual muffler that looks & hangs like stock?
- where can i find 3" core chambered straight-throughmufflers?
- MAC headers
- Anyone have the part # for the front O2 sensors??
- where to start looking for vacuum leak?
- 250 max hp Dyno Run
- meziere water pump {street } wiring question...
- Voltage suddenly dropped. Need input
- Have KBDD SFC's... Limited to mid-length headers?
- what size fernco w/ 85mm maf?
- True duals vs. GMMG?
- I need pics of true duals with Flowmasters
- Considerable loss of E.T and MPH, what could be wrong?
- spend my money for me
- sorry guys, know this doesn't go here, but i need HELP
- TR Poly motor mounts
- Does anyone make a 4 inch cutout?
- free ram air mod hypothesis.
- ELECTRIC SUPERCHARGER
- just ordered some QTP headers........
- LT headers with off road Y pipe?
- corsa w/LT and ORY?
- Headers installed, problems abound
- Cutout sound?!?
- Jet Hot/Hooker Paper Gaskets
- Need part number for 160 deg t-stat for street meziere pump!
- People using the Greddy oil catch can...
- Are LS1 and 6 cyc radiators the same??
- Spyder intake?
- where to find qtech elec cut out
- LSX Intake Dyno numbers from Corvette Fever Mag
- FTRA vs SSRA, which would you get?
- installed air lid getting a ses light?
- Hissing After I turn the Ignition Off
- car wont start
- Ram air on a Firehawk
- Pros and Cons of GMMG?
- Y Pipe Install .. How long should it take?
- HEADER INSTALL
- PPC Headers?
- Belts for ASP Pulley?
- Blocking EGR
- What muffler for center exhaust?
- Intake "Whistle"
- If you could do it all over, what exhaust would you get?
- All dash lights flash while driving.
- Fitment Issues w/ PaceSetter Y Pipe
- Good lord, another header post
- Headers?
- Stock MAF vs 85mm?? any proof ones better?
- Thrown a Belt?
- Nasty Performance sheet metal intake gains 43RWHP
- Negative Effects of blocking off an X pipe?
- Would 1 cat in the I pipe be as effective as 2 in the y?
- To all running Meziere race water pump....
- Anyone Recharge Their Own AC?
- Home portted TB pics
- custom racer
- Difference between the 2000 WS6 and the 01-02's?
- Bolts halfway in *DELETED*
- I hate the Noisy BELTS,,, WHAT Can I do???
- 75mm or a 85mm MAF
- Duals & X w/ stock exhaust manifolds...
- Got to vent! POS PARTS!
- Question about pacesetter y-pipe...cats
- Cutout question
- Anybody wanna donate some 01-02 exhaust manifolds?
- Odd Idle after TB/LS6/FIPk Install
- vr velocity stack
- Gmmg?
- Y pipes
- Hoods
- asp pulley problems
- Car idles low then dies off
- swaping power steering pump, need help please!
- true duals????????
- Coolant problems........HELP!
- JET HOT HEADERS
- Installed Hypertech coil and got CHECK ENGINE light,,,,
- To tune or not to tune?
- Problem after Header Install
- Benefits from removing AIR and EGR???
- Question About Headers Please Help
- '01 and '02 exhaust manifolds better than the 99-99?
- ls6 intake?
- Someone who knows their crap about threads come in here
- Lifting engine
- how to remove the spring from the left of the TB
- CAI, How does Ram-Air keep water out?
- Ordered MTI Clear Lid...will it crack if????
- possible tensioner problems
- Just installed ASP pulley and....
- Anymore news on the LSX Intake??
- P/N for A/C high pressure line?
