PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 [321] 322 323 324 325 326 327 328 329 330
  1. OBDII Inspection in Texas
  2. Studs for stock exhaust manifolds?
  3. A/C blowing cool NOT cold
  4. EXPERTS - Flooded and strange spark?
  5. How many cans to make A/C operable ?
  6. Quick oil question
  7. question about nuts on MAC headers
  8. Starter is fried after 3 months! WTF!
  9. 2000 Z28 Stock injector rating?!?!
  10. 4-2-1 collector ???????????
  11. 3 Leaky Pinion Seals in 42K..Anybody Else?
  12. upgrading to ls6 intake any concerns??
  13. Stumble at Idle on an all stock LS1
  14. A/C wont work WTF
  15. Fan Switch=SES light
  16. Anybody take off AC?
  17. WS6 INTAKE CHOICES
  18. LS1 experts...please help!!!!!!
  19. Thinking about Upgrading from my Flp headers to Dynatech 1 7/8 headers..
  20. Help reversed connector between car and maf translator..did I hurt anything???
  21. loudmouth
  22. Where can I get a dual pump intank
  23. Stock Fuel System limits?
  24. mac vs hooker LT
  25. What trap speeds are you intake/headers A4 cars running?
  26. Anyone have a part # for hooker aerochamber muffler
  27. FIRST MOD?
  28. Where do you gap your plugs @ ???
  29. Help please! - problems after heads/cam/intake swap
  30. cutout
  31. Quick Time electric cutout(s)
  32. bank 1 - drivers side or passenger side?
  33. GM wire harness connectors
  34. Dynoed Hooker LTs and ORY today.
  35. Is there any actual reason (besides emissions) for the PCV to be a 'sealed' system?
  36. How to make Hooker Louder?
  37. 1 3/4 vs 1 7/8 primaries
  38. intake manifold fix up
  39. Mac's in but it won't start...Help!!!
  40. cooling fan mod?
  41. Highest # Injectors i can use???
  42. Just got my Mark Shaner TB installed. [PICS]
  43. Need help. Quick!!!
  44. TB bump stop=4.33 volts.......OK?????
  45. short belt mod
  46. Good price on install?
  47. PAGEING Nine Ball
  48. Air tube broke off my Grott header
  49. Problem after B&M Tranny Cooler Install
  50. any one have a stock torque arm laying around???
  51. Need Help! Dealer Can't figure out problem!
  52. HELP! ok to install tb when I can see light through it between throttle blade?
  53. Help with codes please: PO122 TP low voltage, PO133 PO153 slow response O2's
  54. O2 harness is fried
  55. What's the difference?
  56. Holley air filter, re-oiling?
  57. LT1 caprice hesitation problem
  58. Can the FLP header collector be bent?
  59. best header for your dollar
  60. Tts are ordered..questions on o2 extensions..??
  61. Detonation with FIPK?
  62. Ported maf=cut black center piece?????
  63. SAND IN RADIATOR?
  64. cooling
  65. Ported MAF ends and LTrims?
  66. high temp spray
  67. Vapor Vent Pipe & Exhaust Questions
  68. Which model NGK
  69. RC Fuel Injectors.... Good or NG
  70. Check this out....input please
  71. 1/8 th mile times
  72. Bauer ported & polished throttle bodies
  73. BIG cam + dual cutouts = lost power?
  74. ASP underdrive pulley on a daily driven M6 SS???
  75. fuel filter ?
  76. help
  77. help
  78. smoking
  79. NEED Pics of true duals...please!
  80. COMPATABILITY : SLP BELLOWS/MTI CLEAR LID/2002 Z06 85 MM MAF for my LS1 T/A
  81. who has a hooker?
  82. Battery under extended warr.???
  83. Thinking about getting rid of my FTRA
  84. Sound clip of my exhaust up!!! (!muffler)
  85. I need some bolt on advice
  86. Random tech catback raspy??
  87. TTS headers on Firehawk
  88. ATR Exhaust Opinions?
  89. O2 Simms On Front Cats
  90. Question with my Air Lid
  91. Space between header,cat,and muffler?
  92. Please post if your Corsa cat back has had no problems!!!
  93. What is "timing" all about?
  94. true duals with cats
  95. How easy was your BMR k member to install? min is not lining up well
  96. Stealth airlid installed! pics and thoughts
  97. just got lid, need some help PLEASE...
  98. FUEL PUMP
  99. FLP's or Grotts or TTS
  100. Anyone know anything about the Stealth High-Flow Airbox from ls1speed
  101. Horsepower TV
  102. Different LS1Edit Question
  103. 6.0 iron block useres
  104. Whisper Lid and K&N filter OR K&N fuel injector performance kit?
  105. Random Tech vs. Hooker exhaust
  106. One more question about true duals>>>>>
  107. FLP headers
  108. What size bullet muffler to replace LM resonator?
  109. gears or headers
  110. Dual or Single Cut Out
  111. Anybody had trouble with shifts???????????
  112. Need help with gas tank re-install
  113. WOW Picked up 3 1/2 MPH trap speed with MACS and ORP !
  114. Who makes those modified A/F guages??
  115. SLP cats
  116. SLP cats
  117. BS?
  118. got SLP QUAD setup pictures?????
  119. can someone tell me what size injectors these are?
  120. What brand injectors to get
  121. Differences between years for headers???
  122. $#&*@%& Headers!!!Please Help
  123. sound clip
  124. Finally epoxied the TB
  125. A/C clutch not kicking on, any ideas?
  126. Help .. ticking noise
  127. silverado maf on ls1???
  128. A couple of ?'s about modifications to MAC's?
  129. POWER STEERING HELP!!
  130. Accel Injectors??? Why so bad???
  131. O2 extentions on Hooker Headers?
  132. Z's stock #'s
  133. Any benefit to keying the stock torsional damper?
  134. A look at the Grot Y-Pipe
  135. !!!HEADER PIX!!! ???Is straighter, better???
  136. Anyone had to replace a water pump yet?
  137. Torque spec for headers?
  138. Another Bad Corsa!?!?
  139. Hooker Catback Is In!
  140. Re-routed pass. wire harness this weekend.
  141. OK ....which catbacks have no rasp with MAC headers and ORP??
  142. Got true duals with x-pipe and 2 Flowmasters...
  143. Not the dyno results I expected
  144. torque strap
  145. Lid vs K&N FIPK
  146. Who runs Hooker LT's with cats?
  147. Hypertech Power Programmer # 3 - Is it worth it?
  148. For those evaluating these two exhausts (LoudMouth and Corsa)
  149. Reverse Lights:
  150. 85mm Z06 MAF conversion
  151. Switching Injectors between Years
  152. How come some Grotts have different collector flanges than other Grotts?
  153. True Dual Vs CatBack
  154. How high ocatane can i go???
  155. Difference after solid motor mounts?
  156. Need screw size for IAC on TB
  157. need info on the new setup...
  158. How can I richen up????????
  159. hey guys need some bolt on hp please
  160. Pulley install on A4?
  161. Removing motor mount bolts for BMR k member w/out removing A/C or alternator. HELP!!
  162. oil leak
  163. Cutout w/SLP Loudmouth?
  164. 2001 Vette Alternator Part # Needed...
  165. Crazy Idea I have...
  166. AIR Pump Inlet Filter?
  167. What does it take to beat the 03 cobra?
  168. Grotts with SLP Y-Pipe
  169. SLP LT GIVE ME NO GAIN ?
  170. Injector sizing,duty cycles and efficiency,etc..??
  171. Need quick help w/ starter
  172. Hooker Cat-back installed
  173. What is the difference between the stock catback and dual/dual?
  174. how do you install an A/F gauge? do it yourself?
  175. I need some expert help...please!!!!!
  176. The Hooker Aerochamber is on
  177. major stalling issues
  178. Egr mod ?
  179. What is good and what should i get?
  180. what bolt-on should i get? opinions wanted
  181. How much horsepower loss from a vaccum leak ?
  182. Hookers and y pip are on.
  183. What's the primary length for the Dynatechs?
  184. whats the deal with the stock MAF sensors?
  185. Need to cange my FLP Y pipe
  186. ac problems
  187. i need suggestions for motor mount replacements
  188. Who gets these two annoying codes??!!
  189. catback?
  190. MAF change vs. HPP3 tuning
  191. !!!!!I need a header choice?!!!!!!!
  192. Any body use Bosch Platinum plugs?
  193. Exhaust Dilemma
  194. Accel Fuel Injectors?
  195. If I do the flowmaster collector mod will I ......
  196. Cooling fuel.........
  197. Got my hooker!
  198. Exhaust Question for you H/C guys
  199. Question about the MAFT mass air flow translator, ASAP
  200. Cat Back vs Muffler Change Only
  201. what sparkplug for a high compression motor?
  202. Vig 3200 gas mileage losses.....
  203. Seal for air box?
  204. ASP need help.......
  205. What is needed for thottlebody bypass???
  206. Hooker LT's and y-pipe are installed
  207. ASP need help.......
  208. is it normal for a new engine to run hot??
  209. Need a favor, where is the pre-cat driver's side O2 sensor connector?
  210. track-tested FRA mod
  211. Help!!!! Need some specifications quick
  212. Jantzer TB installed today - YYYYYYEEEEEE HHOOOOOOOOO!!
  213. Dynatech Headers install?
  214. Ok, lets list all of the boltons....
  215. K&N replacement foam gasket
  216. Stealth Intake Question?
  217. dual dual question
  218. FRC Install help
  219. What size Intermedite pipe 4" or 3"
  220. What's the Purpose of the MAF Screen?
  221. O2 simms, question ASAP
  222. good catback system wit headers??????
  223. help me revise my exhuast setup
  224. METCO BREATHER
  225. Good exhaust setup?
  226. WHAT DO YOU GUYS THINK??????
  227. BACKFIRE HELP...
  228. Block-off plates
  229. what manifold is part # 12560894
  230. Stock spark plugs?
  231. Has anyuone ever swaped windshield wiper arms ?
  232. Anybody runnign that direct hits ignition
  233. hooker LT vs Dynatech LT 1-3/4
  234. ASP pulley
  235. I just ordered that bellows from air flow systems inc..opinions??
  236. will removing the air conditioning throw a ses light
  237. hooker LT vs Dynatech LT 1-3/4
  238. Dynoing today to see how much rwhp the Shaner Stage 2 TB gives me...guesses anyone??
  239. questoins about removing AIR and EGR
  240. HOOKER LT ????
  241. Catback Exhaust... Whats the best flowing?
  242. Superflow Induction kit?????
  243. Exhaust upgrade time! What will 434ci like....
  244. money to blow
  245. SFIK Super Flow Induction Kit
  246. Anyone try the Bassani catback yet?
  247. Bolt-Ons
  248. 2002 ZO6 LS6 manifold????
  249. Installed Headers... doesnt feel the same?
  250. ???Crapy Grotyohann Y-Pipe???
