View Full Version : Generation III External Engine
- Header Help
- Damnit.. forgot to put intake gaskets in
- Fast 78MM Intake?
- Car won't idle! Help
- Anyone else have mti stage 2E heads or info?
- possible FAST TB fix
- PCV Setup? 5.3 w/ls6 manifold
- modding help!!
- LS6 intake EGR Adaptor HELP
- Can i do.....??????????????????
- Good cam for what i want to do?? please help....
- help me plan my next mod
- MAF deleate
- lol, you've got to be kidding me...
- Victor Jr. on bolt on ls1
- F.a.s.t tb help
- Air Lid Clips
- Cooling Question
- question about stock exhaust hangers
- what bellow to use w/ fast 92 t-body and regular maf?
- LS6 intake vs Fast Intake Track Results
- Victor Jr VS Super victor
- EGT caps?
- Carbed victor jr on 5.3
- Header install - do I have everything I need?
- Do all 25% underdrive harmonic balancers use same belts??
- Carbon Fiber valve covers?
- Muffler after y-pipe with turndown...
- Finished modifying my TPIS modified 90mm LS6 intake, pics inside.
- Deepest Loudest Exhaust?
- My car shuts off after a little while of idling with open headers
- TD vid showing ground clearance
- Upgrade to LS6 intake req. tune?
- poly mounts
- LS1 Motor Mount Question
- Solid Motor Mount Questions
- Dyno tune?
- Nuts and bolts..
- KYB shocks?
- Front Cover
- LS6 intake install question
- throttle doesnt respond to pedal!!
- TSP True Duals & Cutouts?
- Good reliable and leak-free electric cut outs?
- FAST 92/92 on a stock internal LS1
- Air lid post headers question
- Who has installed ms4/trex into stock 1998?
- Which Oxygen Sensor?
- K-Member
- TSP 1 7/8" Header Fitment?
- Looking at intakes.
- how much power could I gain from ls6 heads and intake?
- Removing intake vacuum plug
- High Idle after Cat Removal help!
- Bad Cam position sensor????
- Knocking
- Negative battery cable and ground question
- New header gaskets breaking in?
- shorter serpentine belt
- removing the converters cats
- Anyone use this catch can?
- were to buy gto dipstick?
- anyone i need air lid help
- Where can I buy a seperate Air Lid Gasket?
- New Oil Pan-Filter
- Best Roller Rocker arms
- noob with headers and y pipe
- Accel Shorty Spark plugs!?!?
- used fast 90/90?
- PCV system question
- New LS1 9ltr High Performance alloy cast sump
- Kooks Custom Exhaust?
- exhaust clamps
- Descreened Maf or 85mm Maf conversion?
- Ls1 Speed Alt relocation bracket problems!!!!!
- torque loss between 1 3/4 & 1 7/8
- head studs or bolts
- Who's the guy that buys converters?
- Vengeance Racing 96/96 combo!
- Problem after header install
- tb help please
- Maf
- Pics of dual cutouts
- what cutout to get?
- How do you put the pulley back on the PS pump?
- Slp lid install ??'s
- 706 casting heads??
- Check Your FAST 92 Bolts?
- what were your TRACK results with the fast 90 or 92mm intakes?
- What wires for NGK TR55 spark plugs?
- need opinions on new exhaust
- FINALLY! Weiand Street Warrior RESULTS!
- Mufflers right after the header
- AIR & EGR Removal?
- Underdrive Pulley Installation
- Random Surge
- Question about the hose from oil filler neck to the top of the throttle body.
- Best oil for break in??
- Clean YOUR FAST intakes!!!
- Ordered All My Parts!!!! l92 build**look inside**
- Intake Help!!!!
- Anyone recommend someone that ports TB’s?
- Exhaust choices
- fast 102??
- losing oil pressure?? any suggestions??
- custom stainless y pipe
- Slp cme?
- Which is louder?
- TSP headers finished need help?
- how much power can a stock trans/rear take?
- Is this a good setup?
- Hooker aerochamber help!!
- Motor has 500 miles in it and head gasket leaks any pointers
- Fault codes
- 0-60 times??
- pcv catch can
- o2 sensor extension question
- Exhaust opinions?
- FAST 90 Vs STREET WARRIOR INTAKE
- finally made it..........
- Magnaflow owners
- replacing driver side o2 extension
- where to find stainless steel ypipe
- Best way to clean O2 sensors
- Catalytic converters
- Ignition coil connectors 98 and 99-01
- *NEW* Under Polished 85mm LS1 Air Lid
- How can I be sure I'm buying an LS6 intake manifold?
- How to remove Catback without cutting?
- Exhaust questions...
- [Full Test] (Descreened Maf, P/P TB, CAI) Find out what they each do here...
- Vengeance Ported FAST 96mm Intake/Nick Williams 96mm TB Combo!!!!!!!!
- will a CATCH CAN work for me???????
- Missfire breaks up around 5k rpm, p0358
- Cutout clearance problems?
- O2 Ses Light after header install.
- Do all ear LS1's 97-04 have the same starter?
- whats the best way to fir pacesetters in?
- whats more quiet?
- disrupted air flow............
- Need help finding replacement air filter for volant cai
- Experiences with ati superdamper, tci rattler ?
- Are all aftermarket alternators crap?
- Which headers are these?
- Lids really worth it?
- Balancer LQ9
- Janzter 92mm TB
- Victor Jr. Intake manifold owners step in...
- Will removing EGR harm my engine?
- Random misfire...need help
- How do i unhook the oil sending unit?
- ORY PIPE to fit 2 3/4 lts
- Intake manifold questions....
- LS1 Coolant hose help...
- bought a fast 90 intake, what do i need to change w/ the cooling lines?
- Level of Difficulty Installing Header/ Y-Pipe?
- TSP ported fast??
- questions about AIR and EGR
- Is this a good buying list for N/A power/ Expected RWHP?
- Has anyone ever powdercoated an LS2 throttle body?
- Finally got the long tubes on order
- Anyone ever had?
- Question about my new Breather....
- What bolts are you guys using for header installs
- flowmaster merge
- Pulley torque specs
- Got a ? about hooker headers
- Installing Pacesetter LTs, ls6, 42lb injectors
- l76 intake problem need help asap!!!
- Porting the stock Throttle body
- SS stud kit for LS intake manifold???
- Big oil pan / filter problem.....
- Quietest muffler with true duals
- power steerin bypass from SAM car
- Dyno tune??
- FAST 78MM LSx Intake or LS6 Intake?
- Mixing headers and y-pipes from different companies. Problems?
- Oil pan question
- Anyone have Jet Hot coated Pacesetters?
- how well do ebay headers fit?
- Wanted hooker cat back 16811hkr 99 camaro
- TD vs. catback
- Going from BBK IM and Stock TB to 92/92 setup...
- TSP ORY and Pacesetter LT
- car losing power at 4,000rpm
- LS1 Stock Idle ?
- What are some cheap mods i can do to my car?
- back firing
- True LS6 Intake? p/n 12556333?!?!?
- 85mm lid to 92mm tb bellow??
- What will i gain if i install LS6 intake?
- LS7 heads on a LS1 block?
- Looking for Fast 90/90 setup SALE ?
- FAST 90/92 Installers HELP plz.....!!!!!!
- Opinions on the Summit Racing pulley???
- intake ?
- Smooth Bellow question
- ASP pulley.....which belt?
- new muffler
- Which belt length??
- weekend job
- is this the right belt size?
- Best way to remove ac box?
- coil pack question
- Hey guys, got the LPP's today... PICS
- your opinions on best headers for the buck??
- I Broke something when installing ls6 intake
- new belt for UD pulley?
- auto meter tach?
- 853 or 862
- custom exhaust questions
- with crate engine should i....
- 85mm maf questions
- LS6 Intake Question
- Anyone sell exhaust piping?
- 243 LS6 heads worth it?????
- 408 MAF? 90mm 100mm or No Maf
- Is there a link to a comparison of current intakes on the market?
- Will it work?
- GM OE 4.10 gears??
- Balancer question
- ls1 coil packs
- Procharger installation??
- LS1 headers on 5.3?
- 4.10 or 3.73??
- Service engine soon light
- New 160 Thermo question.
- need rear main seal help
- LS6 Intake on 98 LS1?
- LS6 Intake
- 98, 99-02 coil bolt pattern??
- anyone using edelbrock pro-flo
- (best) carb intake elbows
- LM1 + E-Cutout
- Lid Question
- installing ls1 into 95 camaro
- Header Gasket?
- Exhaust???
- ft 85mm lid ?
- upgrading the LS1 need opinions
- ?? Question about Borla Cat back ??
- Idle issues????
- Pass 'visual inspection'
- What is your opinion on these heads?
- Egr/air removal
- Lpp header virbration
- E-Brake Ajustment
- vacuum pump?
- Who has installed long tubes with no tune?
- Custom PCV setup... trouble finding parts
