View Full Version : Generation III External Engine
- QTP y-pipe is hangs LOW..... too low.
- Race vs Street Electric Water Pump ?
- 2004 truck coil packs
- leaking gasoline?!~!
- Making custom headers, which cylinders to pair up together 4-2-1's.
- gains from fast lsx&90mm t-body? 1-company says 0 hp,other says 20hp?
- Best air intake?
- bassani dual exhaust
- LS6 intake throttle mount
- Electric cut out?
- Pulley is squeeking.........
- Belt Tensioner
- Proper procedure for refilling coolant?
- A quick pic of the NEW EDELBROCK Victor headers ceramic coated
- Broken Fuel Injector Wiring Socket
- Header size question !!!!
- Intake part # 12556333
- LS6 intake manifold
- Easy one .. how to change belts
- Dual cutouts with Bolra type adjustable plates?
- Help :(
- How to get some sound!!
- Dumb questuion Header install
- MAF for 01?
- New Stainless Headers?
- Cold start-up noise
- Question for all Engineers (or just smart folk)
- O2 Sensors interchangeable front Vs. rear?
- Anyone with an ASP pulley???????
- MAC Midlength Questions?
- People who have had bullet muffler based duals for awhile.. inside please!
- Which is louder Flowmaster or Aerochamber?
- best intake manifold and throttle body??
- ???to buy or not to buy???
- Gonna get TSP true duals, should i wait fot LTs first or just put them on?
- Y-Pipes?
- Normal header noise, or exhaust leak?
- Need parts list 4 LS6 intake on a 98.
- Metal rings around o2's making noise...
- Anyone Using Brisk Plugs?
- Edelbrocks Carb conversion kit is out?
- Help me with squeaky engine
- True duals+convertible.
- Checked catch can after 1500 miles
- Quietest Exhaust?
- Header Help!!!!!!!
- ? track times after LT install
- I may have a new free mod
- Built my own exhaust.
- TSP True Duals installed this evening
- x-pipe?
- Corvette exhaust manifolds
- Should I buy a 90mm FAST intake, a LS2 intake, or wait & see what happens w/the LS7?
- poly motor mounts installed
- sucked water into the engone and blew it up, getting new one...suggestions?
- Is the fitment any better between the older style and newer style SLP bellow?
- Eliminate EGR and AIR?
- TB or MAF first? Your input needed
- Ls6 intake install question..
- LG Headers for C5 ZO6--Worth the cost?
- Searched already ... mac vs pacesetter
- A4 w/LT's place cats were?
- Mojave Heater Install
- surging!
- Weind Holley manifold on 99ls1...what all do i need??
- Metco breather
- Exhaust Leak Help
- How to remove the oil filler neck
- question about MSD 8.5 wires
- march pulley does work with double roller chain
- tsp true dual problem?
- Mod Questions
- Boramouth owners come on in
- what yall think.... Headers
- How i ran my catch can
- Egr ?
- Holley Lingenfelter Aluminum Intake Manifold
- Direct-Flow Airlid Purchase... WHERE CAN I GET IT???
- MSD LS1/LS6 blaster coil....
- Ordered my exhaust. What do you think?
- long tube headers with sts system
- Will 12556450 gm coils work on ls-6 engine
- Transmission Oil Cooler used as Engine Oil Cooler?
- Header Bolts
- SLP LOUDMOUTH vs FLOWMASTER
- Funny Noises?????
- Thirdgen exhaust on a LS1 Camaro....
- Fuel Rail Covers
- Problems w/ FAST intake and tb?
- **Need help**Heater Hose control valve???
- Ticking after Mac Header Install?
- lt1 vs ls1 borla
- LS6 intake Manifold From ZO6 to C5
- kooks lt install
- Anyone have pics of offset magnaflows for X-Pipe
- I got my TSP X-pipe true duals today!!!!!!!!!!!!!!!!!
- Those w/ZO6 85mm MAF, what did U use 2 connect the lid 2 the MAF & the MAF 2 the TB?
- motor install
- Corvette and Camaro starter motors the same?
- Anything else I can do?
- Swap catted y for ory. Worth the trouble?
- f-bodys rear end pics w/ SLP loud mouth
- TD's setup on stock manifold and cats?
- Long Bolt for pulley install is stuck...
- LS6 Maf? will it work?
- ASP vs March! About to order...need advice
- A/C compressor help..
- Engine Vibration...
- How difficult is it to change the pulley? Which set do I need?
- QTP rasp
- Dying o2s. Denso f-body or Bosch vette rears?
- Those With GMMG Exhaust
- LT Headers and emissions sniffer test
- Hardest job on an LS1
- Good True Duals Setup
- PICS of Catted AND Dual Cutout Y-pipe
- Headers
- Battery Relocation
- 2.5" or 3" duals for MY application???
- Z is out of its coma!!!
- Advantage of corvette oil pan
- Who is it safe to buy TBs from now?
- 3/4 inch hole on top of header tube...
- weird exhaust noises.. please step inside
- installed slp lid and now...
- 98+ plz leave pics of Exhaust tips
- coated or uncoated
- I am an idiot, please help
- Underdrive Question
- exhaust manifolds
- From headers to exaust tip what do I need?
- Remove 4" Spintech Dual Muff and lose less than 1hp? Can it be true?
- Want opinions on my theory about intake pressure at WOT.
- 1&3/4" vs. 1&7/8" Longtubes.....
- vette to f-body exhaust manifold?
- pacesetter lifespan....
- A Few Question to be Safe.
- edelbrock headers
- Mods on my exhaust
- True Duals
- Does Anyone Other than Mufflex Offer a Nice Y for Hooker LTs?
- Is this an LS6 intake?
- Does this Weld Look OK?
- need advice on installing SLP long tube headers
- Dyno'd the Hooker LT's and True Duals today....
- banging on hard acceleration?
- cleaning holley powershot air filter...
- Which water pump dealer or bosch
- Throttle Cable Nightmare
- does the autometer guages include right adapter to fit head?
- True Duals Set Up
- Where To Buy True Duals
- new pacesetters=8+ codes thrown???
- oil leak and shreaded belts
- New Pacesetter ORY
- air conditioning compressor probs
- Egr/air Blockoff/removal?
- Got rid of RASP from BORLA + LT headers/ORY
- True Duals X-pipe dumped on slammed f-body*PICS* (56k Take a nap)
- Cut out exhaust? is it worth it?
- billet grill and airlfow
- What Gap for Plugs?
- Cruise Control
- header installation
- Flowtech headers
- Pacesetter problem
- Why won't my car start on the first try anymore?
- Pacesetters Headers K-Member Trouble?
- True duals(idea)What you think???
- LS6 vs. fast LSX intake
- Who else has LT's + ory + LM or any exhaust w/ no mufflers....
- cutting the dip stick tube, read inside...
- broken speedometer?
- finally got my coated headers
- How thick is the K-Member? Need to drill through it...
- Sweet Thunder 3" True Duals all the way over the axle....
- Is the ARP crank pulley bolt worth getting?
- Dual Vs. Catback (More Power?) (How much?)
- BIG thumbs up to corsa...
- Anybody know how to clean a MAF?
- Happy B-Day LS1TECH!
- firing order
- Troubleshooting: Any help would be appreciated.
- 02 simulators?
- pics of rear-exit under axle true duals
- valve cover and coil interchange
- High Idle with TB - Next step?
- loudmouth muffler on Borla?
- air pump removal
- Engine running at 210 constantly, normal?
- Fipk2
- QTP vs Kooks?
- LSX 78mm = how much power?
- dex-cool
- exhaust and NC inspection
- What is this part officially called?
- Lid without AIR fitting?
- Which Exhaust
- how to check cam sensor?
- what spark plug wires would you recomend?
- TSP true dual question
- wtf is with my asp pully
- kooks catted y
- Could this be my TB?
- EGR/intake questions
- Alternators
- AMW now making a bracket for there catch can.
- pacesetter race longtubes
- Corvette 02's
- removing the brake booster
- Cheapest O2 simulators...
- what pulley is upper left looking into the bay?
- Header and Mid-Section question.
- Looking for a header setup that don't leak. ><
- My Ported Throttle Body
- Does placement of the cats affect sound?
- stepped headers????
- Vibration At Low RPM
- Heads up: New LS1 products in Jegs
- crank problems
- help 95 3.4L raw fuel smell
- Just got AMW catch can
- power steering delete
- P0121 In-Range Operating Throttle Position Sensor circuit failure
- Intake upgrade for 5.3
- PCV Rubber Boot
- Hooker Catback Fitment
- Need guidance on removing AIR & EGR for Race Headers
- Is Flp Outta Business?!?!
- QTP Lts + TSP duals...video
- Gmmg exhaust with LTs
- who can do the epoxy on my TB?
- Problems after intake install, please help!!!
- Valve cover connections?
- Burnt oil smell, blue smoke???
- taking off the A/C, what to do??
- 90mm TB: Have You Checked Your TPS Readings?
- Help with smoking at idle only problem, after LT install
- Car wont start?
- 235.00 true dual pics
- T/A Wont start... Ticks
- Anyone had this happen to their exhaust mount?
- true duals sound clip
- kooks stainless headers question
- think i fucked my throtle body!!!Help..
- MSD aftermarket LS1/6 coil packs....
- Help with exhaust tubing
- Which 3" off road y pipe would work best with Kooks headers?
- SLP Radiator Porblems?
