View Full Version : Generation III External Engine
- No cats=No torque?
- What colors are the available paper air filters?
- BBK 80mm vs 78mm ported stock TB?
- oil temp and tranny temp guage install????
- Quick Header Install ???
- would i gain anything?
- I OWE TSP AN APOLOGY: Their true duals fit Kooks LT's
- spitting and sputtering whenever first driving
- people with tsp true duals
- QTEC wiring
- Car shakes worse than a harley at idle Please help.
- New SLP pulley?
- Cutout or Diff. Muffler?
- Strange Idle after TB install
- Qtec
- True Duals with No Mufflers?
- o2?
- After 6 years,finally installed Pullies and Ported TB
- Windsheild Wiper Problem. Kinda wierd !
- magnaflow with no cats
- Need help- HEADER INSTALL
- Water Pump Question
- header tick ?
- off road Y pipe for a 2001?
- Will TSP Rumlber cat back rust?
- Headers / Plugs
- anyond with an MSD DIS4 ignition yet?
- pics of true duals
- header gasket ?
- How many people run ory? Too loud?
- Pacesetter Install Problem
- Best none dual set up??will it work??
- Muffler question?
- Changing plate on my Borla Exhaust
- tb or not tb
- street pro cut out installed
- What SLP options does my car have?
- headers?
- Magnaflow installed... weird things happening...
- SLP Longtube Opinions...Experience is helpful
- question about intake
- Gmmg Installed....
- Installing a tb
- Confused with piping for TD's
- tb bypass issues
- Installing Jet Hots and Hooker ory this thursday!!!
- How will this Sound?
- Quick Asp Pulley Question
- How to get rid of slight rasp with hooker and ory setup???
- Thunder racing headers?
- Anyone with SLP LTs , y, and cats
- SLP Lid fitment issue! need help
- What to Expect From LS6 Intake/Ported TB?
- EGR/AIR removal???
- Header install, need help ASAP!!!
- Where can one find this??
- Need info for Weiand\LPE\Holley Intake Users 98-00 F-Bodies.
- lost torque after cat removal..
- Anyone seen these problems?
- Tucking exhaust tips?
- well i finaly did it 3.5x3 inch x pipe installed
- Need Help ASAP Pulley install
- Thundermouth
- 2000-2002 custom y-pipe w/magnaflow collector!!
- Flowmaster Y Collector
- when I remove engine from top does the intake absolutly have to be removed? on an 02
- Need help with identifying manifolds and tensioner
- Freaking incredably loud with LT with ORY, a few questions
- I'm convinced MAGNAFLOW!!!
- Cats or ory?
- pacesetter ory
- SLP LM and Y pipe
- Y-pipe gains
- x pipe question
- LSX 90mm issues... car hangs BAD at 2400 rpm
- FYI: #'s after Headers and Duals on Stock Car.
- Small question about LS6 Install
- Gutted Cats
- will a throttle cable off a lt1 fit a ls1?
- How Can I tell if I have a Vacuum Leak on a LS1?
- Misfire after LS6 Intake Install
- Idle problem after backfire
- Kook's install help needed
- Just installed my LT & Cam And it SUCKS!
- need some exhaust help
- Exhaust Clamp
- O2 Sensor Extensions
- FLp Y pipe?
- Jeg's DS loop for duals?
- Magnaflow Round Race Mufflers???
- Anyone with edelbrock brag headers...
- Electric Cutout Placement
- Header questions
- LT Headers
- TSP installed!
- A/C PSI readings for low and high side
- Alternator wires? Ground strap?
- what's the best flowing muffler
- Pacesetter LTs and 02 Extensions, Can I get away with just one?
- GMPP singleplane tested in the new Popular Hotrodding mag.
- Size Pipe?
- Help!!!
- Exhaust question
- Slp Ram Air Induction Package
- Tiny plastic vac. line on back of intake manifold?
- Panhard bar
- 90 mm Fast TB problems
- Will a lid and Trans Am lower airbox fit under the stock Formula hood?
- coils?
- Sorry, another LM question
- another header question.
- Who makes an ORY that will bolt up to stock manifolds?
- What coolant overflow cans are you guys running?
- shift light hook up
- Sheetmetal Intake Owners Post in Please
- Header Gasket Suggestions?
- shorty header install
- I need pics of true duels with cats
- Headers or LM?
- I have Borla, thinking about the LM though
- More LS6 intake questions (well, just one)
- Help ID this SLP intake mod?
- Limited $$: Which bolt-on?
- Plase help with RWHP numbers! :(
- TSP true dual
- Y-pipe with GMMG?
- Best flowing muffler for 3 inch Y pipe???
- Terrible Header Install..... Need Major Help.
- AIR system gaskets
- Exhaust cut out
- Car doesn't want to start now and then
- one quick question
- Got my Jantzer Ported TB........PICS
- What is this noise? Download MPG
- 78mm LSX Intake
- mystery vacuum line
- What exhaust?
- Gatorback Belts
- true duals with cats? looking for some input
- another pulley question.
- QTP C5 Tri Y Header Dyno Numbers!
- Do the new flowmaster super 40 muffelers really flow any better??
- is anybody having problems with pacesetter lt's
- Better Cooling?
- How to remove hose fittings on back of intake manifold?
- hp question?
- Installed Jet Hot headers
- Corsa Cat back goes best with what header?
- A Few LS6 Intake Questions
- Headers slowed my car down .3+ tenths, White plugs?
- Cats for 98 and 99
- Help? Used GM SS muffler
- Sfi Or Asp Pulley?
- True Duals? Anyone ever use Summit Racing?
- will TSP-X fit with SLP SFC?
- Hyfire 6a ignition box w/pertronix points replacement
- Trans/Lock Line In Way of LS6 Install
- True dual Exhaust opinion's, please help
- specs on over the axle?
- ASP Pulley ?/please help
- Replacing power steering pump?
- Intake, pulley, and ported TB
- keep TDs or GMMG????????
- Cats add torque?
- Some help please!
- FYI on Fram Air Hog
- Free ram air and sealing the airbox?
- Can you put the O2's in header primaries?
- MAF Error ( On my conversion )
- my exhaust setup
- Will the Hooker ORY pipe slide onto Kook's long tubes?
- Header Install Problem
- Need some help
- what was once gone, is back again, could use some help
- Question on Valve cover install
- No spark or injectors pulsing, need help!
- AC PROBLEM "PLEASE HELP"
- Anyone have this setup? Opinions?
- How hard is it to R/R b1s1 and b2s1
- Air Box Question
- Anyone heard LS1 with fart cannon?
- Header Problem?
- Coolant not circulating in stale LS1
- Way to go Legally to 01-02 EGRless system?
- Where to get magnaflow tips?
- New, old idea mount for your AMW catch can.
- Edelbrock LT headers & Y pipe, any good?
- cooling question
- HELP! Problems after LS6 intake install, car won't start.
- Need new O2s Bosch or AC Delco?
- Going To Look At Used Intake--?'s
- Kook's VS macs what will i gain???
- ? About SLP Intake
- y pipe the bolts up the stock manifolds
- 110 octane??
- 3.5 inch magnaflow with dual cats vid within
- Bullet Muffler Help.
- Magnaflow Article on True Duals with x-pipe
- DynoMax Ultra Flo chambered muffler question
- cut muffler off want to know what kind of problems would occur....
- race headers
- Gains From Modifying Ypipes With Flowmaster Ycollector?
- What is the purpose of the x-pipe?
- Need some HELP...car wont start
- LS6 Intake install next week... Please Help
- Exhaust install this week... Help please!
- How important is a retune after cat removal??
- power loss between 1/34 and 17/8 on 408?
- TSP true duals questions....
- is it possible to lose power with different plug wires?
- Thundervolt wires
- Stock SS Exhaust?
- Tap here for mechanical oil sender unit?
- Enough belt tension?
- Open header questions concerning RWHP.....
- Pacesetter install today
- hooker ory Pipe picture?
- header install
- FLP y-pipe vs custom 3"
- CA legal Headers?
- Will one bad electric fan make me run hot??????
- SLP Rear D/D Mounts---Need Picture---
- Intake?
- Headers touching a/c box?
- No spark after motor rebuild...
- Who designed these plugs wires!?!?
- popping hooker
- ?? Are '99 cats different than '02's...??
- Pacesetter Headers?
- Troubleshooting an overheating engine....HOW????
- MAP Sensor Plug Pinout
- rear o2's on lts
- Lt's cause explosion!
- BMR Makes 3" Over-the-Axle Duals Possible!!!
- My header Opinion!!
- Clunking From Under Car
- need help w/ spark plug replacement
- supermaxx header gains? dyno or track results?
- Safest way to install harmonic balancer?
- bad idea??
- GMMG with QTEC... is it worth it?
- QTP headers on Z06
- GTO Exhaust Manifolds
- Ported T/B ??
- backcat
- Fan Mod?
- is MAGNAFLOW really the way to go
- Maf....
- 6.0L intake manifold?
- Edelbrock Comp Headers.
