PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Underdrive pully....
  2. Coated Pacesetters?
  3. Camaro vs Corvette ALTERNATOR, whats the difference besides price?
  4. Fellow Borla Owners.. I got a ?(VID)..
  5. Pacesetter ??
  6. Thermostat V6
  7. pacesetter
  8. which exhaust to get with 350hp package
  9. bad coil pack? help!
  10. Cats after mufflers?
  11. DNA Mufflers.
  12. Which of two options for exhaust?
  13. Lanes TD's all the way out the back?
  14. Please post pics of your catch can
  15. So I was listening to some exhaust clips
  16. Any1 running cats on TSP TD's?
  17. Will a LS2 intake work on a LS1 block?
  18. My plugs have an uneven color? Half good half lean?
  19. Going from mids to Lt's with a pic
  20. Easiest wayto track down a vacuum leak?
  21. Manual cutout removal/replace?
  22. what to fill hole with?
  23. OBX HEADERS FOR LS1 from ebay
  24. Anyone know what muffler this is?
  25. Magnaflow Cats Make a Ticking Noise
  26. B-Cool Rad issues?
  27. Moroso Valve Covers
  28. maf translater?
  29. Name that connector!
  30. slp maf?
  31. tach help NOW!!
  32. will changing catbacks throw the tune off?
  33. o2 bank 1 goin bad....
  34. Draining the block of coolant?
  35. True dual question I've never seen before
  36. Just got GMMG exhaust and TSP Catted Y Pipe (pics).
  37. what is this thing for?
  38. o2 sensor question
  39. Need Guage help!
  40. what temp to set fans, please help
  41. egr removal
  42. Witch is better choice
  43. Starter pic request??
  44. Retapping an o2 bung...?
  45. Optimal catch can/breather arrangement for my setup?
  46. Battery In Hatch??
  47. Watch out STS new bolt on Exhaust "Turbo"
  48. Where can I buy some O2 sims?
  49. Uncoated v/s Ceramic Coated
  50. Throttle body upgrade!
  51. Who has the best ported and polished TB?
  52. will this cam 224/236 work with my springs?
  53. Header bolts
  54. Nick Williams on typhoon
  55. Pacesetter LTs emissions legal?
  56. Mezeire belt question
  57. thermostat
  58. Magnaflow Spun-Cat
  59. ? about Mac mids
  60. Y pipe build size
  61. header leak???
  62. Is anyone using these high flow cats?
  63. full msd ignition on a ls1/ls6
  64. ls6 converion
  65. LT and Y-pipe question
  66. just received Pacesetters and ORY what acc. do I need?
  67. Part #'s MAP & O2 sensors
  68. 06 GTO Spintech side exit
  69. LT B1 Maxed Out ?
  70. Best place to get Percy header gaskets?
  71. Which Band Clamps?
  72. rpms lagging before coming to idle
  73. Question about BGRA corners
  74. Running wide open exhaust setup on a LS1
  75. Header help
  76. *HELP* What companies can I buy a Kooks Catted Y from??
  77. BMR Alternator relocation bracket on a Corvette?
  78. My camaro cone crazy *HELP*
  79. header bolts???
  80. comments and opinions on a dynomax ultraflow dual in/dual out muffler
  81. 98 valve covers compatible with 99 coil brackets?
  82. Plug sizes for TB and intake manifold?
  83. Moroso Spiral-Flo 3" Duals w/ Vid Clip
  84. ls1 water pump where to get one ??
  85. power steering cooler
  86. orange catch can!
  87. Need Help Diagnosing Problem, Help!!
  88. Hey guys
  89. exhaust
  90. Headers on finnaly!
  91. LS1-->408ci, alternator bracket doesnt match?
  92. driving open header question
  93. Paper Header Gaskets
  94. !!FRA ? Sumotomo you might want to check this out
  95. Header questions
  96. Help on LS6 intake install
  97. Shopping List.
  98. Suggestions for Next Bolt-on...
  99. trouble with manifold
  100. my TSP true dual sound clip
  101. 95 Z28 Coolant leak passenger side
  102. Dip Stick Quest. Again~
  103. VIDEO- Dual Exhaust W/ Borla Xr1's...
  104. Started to paint my headers..
  105. FAST 90 intake wont bolt down...
  106. '98 heads on a '99 LS1
  107. Y-pipe clamps ??
  108. UD Pulleys
  109. Alternator problem
  110. Cost to delete EGR&AIR
  111. LT1 waterpump idea...
  112. 90mm or larger air lid?
  113. has anyone made their own muffler?
  114. Headers/Y-Pipe and SFC's
  115. Intake Opinions needed on stock motor
  116. Ported Stock Throttle Body
  117. help with exhaust leak from headers
  118. fast90/90 on 408
  119. Need a throttle cable bracket for L76 intake
  120. Clear Air Lids
  121. SLP Below!! FAST 90/90
  122. Battery recomendations
  123. Question about the TSP Catted Y Pipe and catbacks?
  124. Rasp and Y-Pipe?
  125. Quiet exhaust
  126. Bassani true duals specs
  127. Help with TSP duals install!!
  128. Plug Reading Gurus
  129. ls6 descreen maf
  130. Idler Pulley Questions
  131. ????? About Knock Modules
  132. temp sensor borke off in head.... what do i do?
  133. Headers checklist
  134. Which Optima Battery???
  135. need a part number ASAP for lid install
  136. where can i get a y pipe w/ cats for pch
  137. Intake bolt pattern
  138. Pacesetter LT Headers w/ stock Y-pipe, will it work?
  139. I screwed up!
  140. Torque question
  141. stupid fast intake
  142. Egr / Air Gaskets
  143. Building a Catted Y
  144. Stupid lid ?
  145. Stainless hardware for FAST lsx
  146. Carbed or Fuel Injected?
  147. which muffler flow the best?
  148. AR headers w/TD's??
  149. Typhoon... or just stick with the LS6
  150. Magnaflow tru duals??
  151. Aluminum intake manifold temp.
  152. obx headers?
  153. typhoon intake
  154. Headers and EGR and AIR ?
  155. o2 extensions
  156. provisions?
  157. LPE Throttle Body
  158. Car I'm looking to buy, SES?
  159. O2 sensors
  160. Kooks Long Tube ?
  161. where to get a p/p tb
  162. SLP Longtubes
  163. How to on Headers
  164. H2O sludge
  165. gut cat question
  166. fast intake
  167. LS1 Y-Pipe "Bump Stop" Hanger anyone have one?
  168. Pacesetter headers?
  169. How to support y pipe?
  170. Waterpump Issuse.
  171. LS6 intake swap
  172. Help me please
  173. KOOKS or PACESETTER?? ASAP
  174. Just installed headrers and poly motor mounts>>
  175. FAST manifold?
  176. should i dump em?>
  177. Gut Cat Question
  178. $200 for header and ypipe install..or do it myself?
  179. Best Spark Plug change
  180. Optima battery?
  181. 02 sensors (help)
  182. Magnaflow / Hooker
  183. should i dump my LM1?
  184. JBA shorty headers
  185. intake or headers
  186. ls2 intake
  187. which is better
  188. Stock intake with a K&N filter
  189. Magnaflow CB?
  190. 3 to 5 wire adapter
  191. Corsas Dont Fit Td's Ends?
  192. FAST 90 intake port gaskets?
  193. Quadruple O2 Sensor failure?
  194. After 3 months...
  195. O2 Sensor Questions
  196. SES light
  197. LS6 Conversion Question
  198. Master cylinder/Slave cylinder ???
  199. oil cap extender
  200. Controversy of Free ram air..
  201. header install question?
  202. wiring harness question
  203. miss at idle + clicking=??? (help)
  204. Would there be a point to switching?
  205. Anyone used this muffler?
  206. Crossover "rules"???
  207. 160* thermo...good idea?
  208. 1999 Vette-wiring schematic for the starter? weird symptoms
  209. Edelbrock Victor Jr Manifold
  210. cat questions
  211. MTI intake question
  212. Question about Electric cutout.
  213. exhaust question
  214. borla + LT= loudness
  215. Warning system for guages???
  216. What's a good price?
  217. quick o2 extention question!!!
  218. replace bullets on true duals with dual in dual out muffler?
  219. LS7 INTAKE???? is this possible..
  220. oil filler neck.....need breather!
  221. omg. a rock in the road.
  222. just got my FAST 90 and have a ?
  223. Perimeter Valve covers question!!
  224. i got the hook up man!!
  225. MAF Delete???
  226. what goes in the side of the NW 90 throttlebody?
  227. Deleting MAFS....
  228. Header install help asap
  229. duals and lowering...
  230. TSP Duals w/ stock mans and Y?
  231. tensioner
  232. front O2 sensor problems
  233. Who's running the new Dynomax Catback?
  234. Intake for 2007 Yukon
  235. EGR Question
  236. What should I run ???
  237. Magnaflow installed on Mardi Gras
  238. bbk intake and more
  239. a/c high/low pressure
  240. Low charging volts
  241. Exhaust vid of my setup.
  242. I Need Serious Help
  243. Retrofitting stock WS6 tips
  244. Intake
  245. Who Ports Fast 70mm (sponsors)
  246. i think im finally done!
  247. Breather Filter
  248. going FAST w/ cam only
  249. 3 1/2 Borla XR1 Race Mufflers or 3 1/2 DynoMax 16 length Bullets
  250. Dougs headers, New
