PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. header install
  2. Battery Draining...what is causing this?
  3. Lid or FIPK?
  4. Exhaust crushed...
  5. Stepped header 1 3/4 to 1 7/8 on an AFR 205, 224/228 car?
  6. Car is still acting crazy in rain
  7. HELP! Did something dumb!
  8. what should I expect
  9. for the searching gurus
  10. Header "XPERTS" need opinions please
  11. Dumbfounded
  12. Who has the Dynatech Supermaxx?
  13. Wow!!!!!!
  14. Quick question before I buy coated Pacesetters.
  15. Full Exhaust Change
  16. Cutout Gains on Modded Cars?
  17. OK can a bullet have a 3 inch inlet/outlet and work with 2.5 piping?
  18. Edelbrock/Lingenfelter Heads and Comp Cam Package
  19. ? about running straight off the LT's
  20. How much gain from full exhaust, air mods?
  21. gains from goin 2.5 in. to 3 in.?
  22. no spark and cel blinks...
  23. Magnapaks
  24. slp-DD or slp lm
  25. wet exshast??????
  26. stalling question
  27. 1/2 drive breaker bar
  28. B&B LS1 exhaust
  29. How much power would I lose swapping to the stock cat-back?
  30. Bending Fuel Lines for dummies
  31. O2 sensor life in a long tube. Who's got the most miles?
  32. i broke something, what is it?
  33. Taking off a/c belt?
  34. Pacesetters on the formula...
  35. TPiS Oval LS6 intake and TB
  36. Is the ceramic coating on headers worth the $?
  37. ls2 intake 90mm
  38. LS2 GTO - How you make a Fast 90 Fit...
  39. Bleeding the radiator - overheating and no heat
  40. 98 LS1 to LS6 PCV Conversion...
  41. What kind of times can I Expect???
  42. Fast 90/PTM 90's Back In Stock!!!
  43. what plugs for a 408
  44. Question for those who have installed the SSRA
  45. Looking at Jet Hots -What do you think?
  46. Diiference in years in exhaust
  47. Good Ole Y-Pipe Beating The Floorboard Issue
  48. Billet water pump pulley
  49. '04 z06, egr or no?
  50. Getting ready for TDs
  51. Gains from ported TB?
  52. New goodies for my 400whp 35TH LE
  53. EWP type of relay ?
  54. ls1 vent tubes/ fast 90
  55. What does WS6 mean?
  56. I need pics of H-pipe setups
  57. exhaust question
  58. Whirring from engine-normal?
  59. Kool Heatmaster Tunnel Shield Work?
  60. Installation Crap
  61. Mounting tips on true duals
  62. how soon do you benifit from exhaust?
  63. 98 ls1 to 02 z06 heads, cam and intake?
  64. I know im boing on a limb for this but maybe you have it?
  65. Buying used headers
  66. Another header question
  67. new water pump
  68. warm ac after waterpump
  69. Spiral Bullet Mufflers?????????????????????????
  70. ABS DELETE BLOCK & BLOCK OFF PLATE FOR A/C
  71. filter-like oil caps?
  72. Maft
  73. pulleys
  74. Borla exhaust
  75. GMPP and Vic Jr. clearance ...
  76. 2 exhausts
  77. Mellings high volume oil pump
  78. 90/90 on cam only set up
  79. Custom Header Tube Size??
  80. Just installed Hugger Orange Katech valve covers - pics
  81. Bye Bye Lm Hello Magnaflow
  82. FAST 78mm vs. LS6 Intake
  83. Steering shaft rubbing headers?
  84. egr/air block-off plates
  85. How are QTP/KOOKS ??
  86. exhaust change
  87. So... Why doesnt meziere make an installation kit?
  88. Eliminating BLAAATTT sound from TD's?
  89. Advise: Volant systems do they add or hurt performance?
  90. Some quick help please
  91. Qtp headers and y pipe question
  92. cut outs and backpressure?
  93. Exhaust is done
  94. Catch can question
  95. Need vid...
  96. Best Place for Cutout
  97. where can i just buy some bullets mufflers
  98. MSD Coils
  99. Where can I get the Y pipe ends ????
  100. Need technical help
  101. Jet hot's version of cats.
  102. TSP y pipe problems
  103. Spark Plugs
  104. ls1 boltons vs. ls2
  105. Quick Crank Evac Question!
  106. Bullets off the headers
  107. new noise
  108. poly mount install ?
  109. underdrive pullys
  110. Are MAC mid lengths good for 2 tenths?
  111. Help me decide which h-pipe setup to go with...
  112. Plastic Mockup Motors ?? Where can I get one ??
  113. Fitment of TSP ORY?
  114. Curious?
  115. Dynomax Ultra Flo X mufflers?
  116. Just ordered my new headers and Y!
  117. help, header/head prob
  118. LS Valve Covers
  119. Installed my Dynatech Supermaxx today.
  120. wierd exhaust noise?
  121. Blown Cat
  122. Can you guys help me with a couple questions/worries?
  123. Question about my damaged oil pan...pics.
  124. Throttle Body question??
  125. ac belt
  126. Another LS6 intake question
  127. Starter issues...need some troubleshooting help...(LONG)
  128. Extending TSP True Duals out the back?
  129. Delfi MAF?
  130. where to find a belt tensior assembly
  131. Flush kit - which heater hose do I cut???
  132. Flowmaster 1 Chambers on a NON trual dual system?
  133. LS 2 sump for offroad?
  134. Kooks LT's and GMMG
  135. Which muffler makes the most power??
  136. This sounds so noob - SLP lid seating question...
  137. Stupid auto parts stores and their generic parts...wrong oil pan.
  138. LTs ORY open cutout wanna get rid of rasp?? Come on in!
  139. Weird Issue..please help
  140. What Bullet Is The Quietest?help????????????????????????????????????? ???????????
  141. Best ported throttle body?
  142. What the heck is causing my detonation? (coated headers?)
  143. Cleaner/Polish for QTP LTs?
  144. Top end power loss after headers
  145. noob stupid question on exhuast.. .
  146. How much of a factor is rust? and one other question
  147. Loudness: GMMG vs. Borla
  148. Dynatech Supermaxx vs Kooks w/catted y-pipe
  149. Latest trends
  150. Oil Catch Can
  151. Thunder racing's ported stock throttle body
  152. Does something suppose to go here?
  153. Are o2 Sensors Needed with Header Swap?
  154. true dual and torque arm?
  155. duals and clearance
  156. Throttle body help...
  157. 2000 corvette intake manifold
  158. changing exhuast any suggestions for a 2001 TA
  159. True Dual X-Pipe setup VS aftermarket Y-Pipe setup...
  160. LS6 Intake
  161. 160 thermo from slp
  162. Ls2 intake on a LS1
  163. Waht do I do with extra sensors
  164. volant intake or aftermarket lid
  165. vaccuum leak/whine!!!!!!
  166. Just got my ........
  167. Ls7 Intake?
  168. Air and EGR!
  169. ls6 manifold?
  170. O2 Question
  171. C5 header questions
  172. LT + catted ory + lm
  173. header collectors
  174. What Injectors should I get?
  175. Any Difference?
  176. LT Battle
  177. Question About Headers & Y-Pipe
  178. LS6 intake swap
  179. anybody here running a 2-step?
  180. Is K&N filter breather needed with whisper lid?
  181. Id like to put an LS6 intake on my 00LS1 T/A. Will this work?
  182. Help with Header install
  183. What Size Intake?
  184. BBK SSI Aluminum Intake?
  185. Will I need a tune with my new Long tubes?
  186. ls1 borla to lt1 ?
  187. Up-grade to the LS1 Silverado
  188. coil relocation
  189. Tell me what you know and think???
  190. Mecham Exhaust
  191. Kooks catted Y-pipe
  192. Expected HP gain
  193. clear lid question
  194. muffler
  195. Dynomaxx vs Kooks
  196. SLP Lid owners help
  197. Ideal header extension length
  198. Does anybody know if
  199. Electronic Cut Out Questions
  200. Wrapping header collectors
  201. nw 90mm or umi
  202. Moving Fuel lines for cats
  203. Cat or bullet insert
  204. 160 thermostat for a 06 5.3l truck?
  205. infamous exhaust Q's
  206. JBA Shorty Header Question
  207. f.a.s.t. intake question
  208. Uh-oh, the mod bug got me
  209. single exit exhaust or not?!
  210. OEM spark plug wires
  211. FI intake manifold, debate, suggestions, opinions, facts?????
  212. is this an ls6???
  213. Need a fast answer!!
  214. QTP or no
  215. Help! Throttle body question.
  216. LS6 intake on a 5.3??
  217. Cutout question
  218. Intake choice
  219. Those of you with ASP pulleys?
  220. block off plates
  221. Weiand manifold????????????
  222. magnaflow catback sytem buying it from...
  223. Question about the stock F-Body Power steering cooler
  224. NLP Billet PCV Catch Can, $74.95
  225. electric cutout keeps blowing fuses?
  226. Qtp headers and hooker ory
  227. LS6 intake part number
  228. K&N and MAF question
  229. trouble with header install
  230. Primary size question
  231. LS6 info.
  232. Rasp and Drone
  233. Nick Williams 90 TB and
  234. Painting Headers?
  235. Problem with Interior Lights and NO HVAC (AC CONTROLS)
  236. Who all makes 1 7/8" headers?
  237. LS6 intake HELP ASAP
  238. Porting LS6 intake?
  239. taylor OTVC wires (LT1)
  240. Cutout on Y-Pipe
  241. tsp 233/239 cam+tsp td's w/dynomax bullets video/soundclip
  242. AIR! removal guides
  243. Electric cutout switch mounting
  244. Cherry Bomb??
  245. where to buy corsa?
  246. ls1 ls6 intake and heads
  247. the new toy
  248. First Time Modding
  249. Header bolt size
  250. A/C delete ?
