PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 [154] 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Intake Question
  2. Header/catback fitment question from Newbie
  3. Austins Cold Air Scoop Kit?
  4. Electric cutout plate measurements needed!
  5. oil pan
  6. Y-Pipe starts banging after installing new tranny mount??
  7. cat delete pipes?
  8. Edelbrock shorty bolt fix???
  9. Header Install!!
  10. 1999 ta headers fit a 2002 ta ws6??
  11. NGK's
  12. lower control arm relocation brackets
  13. heavily modded guys in here
  14. What are my options to get rid of DRONE?
  15. header installation please help
  16. what size are the bolts
  17. QTP headers!! questions on which to buy!!
  18. Any way to tell if you have a 160 thermostat?
  19. 160 degree thermostat running really hot!!!
  20. throttle cables
  21. O2 Sensor and cat-converter questions
  22. coil harness question
  23. Should I Run MY TDs Dumped??
  24. Why do I have two throttle cables???
  25. any benefit to running 1 3/4 stepped to 1 7/8 over 1 7/8 headers?
  26. Dual sraight thru exhaust?
  27. Cats vs no cats on my set up
  28. Car is still not running the way it should
  29. Header Heat Wrap....?
  30. whats my combo worth?
  31. Catch Can ~ Yea Or Nay !
  32. Need audio sound of exhaust
  33. Headers installation help
  34. Wtf????
  35. coil harness connection question
  36. Powerbond Pulley and stock bolt
  37. Edelbrock SDT vs. Flowmaster vs. Magnaflow??????
  38. question for those with center exit exhaust
  39. Coil wiring harness question
  40. Summit X pipe question
  41. tb
  42. Fitting Bassani Duals on '99 WS6
  43. Ned help picking out the correct ATI Damper!!
  44. Mechanical Oil Pressure Guage
  45. No A/C, I'm sweating!
  46. What to do with my loud exhaust
  47. Straight True Dual
  48. mount and QTP help...
  49. car idles high on initial start up.?
  50. cats or no cats
  51. I've come to Loathe my Jet-Hot Y
  52. The new custom racing manifolds
  53. Oil Sending Unit
  54. spark plug question
  55. Professional Products Intake Arrived..
  56. Slp Loudmouth
  57. HELP TB install w/ spacer ?
  58. How much for a LS1 crate motor?
  59. Q. ASP Pulley & Serp. Belt
  60. American Racing Headers!!!
  61. Which A/C pulley chirps?
  62. cat problem..
  63. Your Opinion on Exhaust Options
  64. What MAF is this?
  65. SLP LID not fitting
  66. 3inch Cutout gasket? do i buy collector gasket?
  67. hay guys i have a Granatelli LS6 MAF! can i port it?
  68. newbie cut out question
  69. y pipe used with qtp's
  70. Exhaust Leak Cause Loading up?
  71. Intake setup
  72. Final Exhaust decision help
  73. Are TD's with Dynomax bullets too loud in your opinion?
  74. acufab dealer.?
  75. Any cons of deleting PCV system?
  76. freeze plug...where to buy?
  77. rear of ls* intake
  78. What's this pump?
  79. Which Clutch
  80. GM Part # Please ?????
  81. smooth bellows Q'
  82. Loudness
  83. newbie question about lids
  84. Anyone test LM I vs LM II at the track ??
  85. center moutned corsa tips
  86. Kooks Headers and QTP Y-pipe
  87. LS6 Intake Install
  88. GMPP, Victor JR. Questions?
  89. Another Exhaust question
  90. Spark plugs
  91. Shimming accessories..
  92. Convertor under fuel
  93. My airintake
  94. gains with duals. 2 ?
  95. New exhaust on the way, Just 1 ?
  96. Quick 90mm TB Question
  97. Will a FAST intake work with L92 heads?
  98. pacestters jet-hot coated?
  99. y pipe question
  100. My next mod
  101. Which muffler sounds best?
  102. Vacum check valve question-broken hose
  103. Meizere street EWP w/ stock inlet issues, What T-stat?
  104. Simple question about fuel rail
  105. FAST intake and 78MM TB for...
  106. mest up my tb... oh well time to upgrade...
  107. HELP!!!!Oil Psi coupler
  108. LS6 vs. Power Plus Intake Manifold
  109. Little wire on the alternator.
  110. tune after intake install?
  111. Aftermarket valve cover help
  112. Interested in new mufflers, but are mine good enough?
  113. o2 sensor question
  114. Wierd high idle problem
  115. need pics of true duals
  116. help with Duals!
  117. Cheapest 90 mm Tb
  118. Looking for dynatech LT w/ TD sound clip
  119. pressure clean injectors?
  120. Help With Electric Cut out Ebay
  121. miscelaneous header questions
  122. driver side header
  123. Spiral Flow on true duals. Sound Clips?
  124. Spark Plugs and Pinging
  125. stock 853 heads or 862's
  126. ported throttle body worth it??
  127. dynatech super maxx system
  128. wrench size for o2 sensors
  129. 98 ls1..issues starting/battery related?
  130. What size smooth bellow do i need out of these?
  131. long tubes installed, now no a/c?
  132. SLP "FlowPac"?
  133. LS6 intake
  134. which is harder to install headers on LS1 Fbody or C6 Vette
  135. Custom exhaust question
  136. What puller to remove Powerbond pulley?
  137. Any suggestions on good header gaskets???
  138. Poly mounts
  139. Is this an improvement over the stock throttle body
  140. Engine Bearings
  141. Exhaust or Stall?!
  142. What size cutout do i need for Stock Exhaust?
  143. LS2 heads and intake?
  144. LS1 Valve Cover Bolts - thread style/size?
  145. Project Envy Continued & A picture for everyone who helped me out!
  146. Which Head Gaskets?
  147. QTP LTs, TSP catted Y, GMMGs
  148. which is the most quite?
  149. What intake wire is this?? HELP!
  150. stock alt on a cammed car?
  151. stock manifold bolt on new headers?
  152. Shorty or mids?
  153. Just installed my longtubes
  154. Plug wire management with headers???
  155. Motor mount through bolt ?
  156. QTP issues months after install
  157. FTRA + Lid + PTB = HUGE SOTP gains!!
  158. Need help with header problem.
  159. Breather on the oil filler neck
  160. 400 club
  161. Breather on the oil filler neck
  162. dynomax,magnaflow,hooker,flowmaster mufflers
  163. Need advice on my exhaust set up...
  164. Besides gears, what else should I buy...
  165. Aftermarket vavle cover gaskets
  166. please post pics
  167. So what's the new with synergy's two step...
  168. corsa
  169. obx headers?
  170. what is the purpose of a catch can
  171. Summit racing throttle body?
  172. oil dipstick tube
  173. H/C swap complete - Loud as Holy Hell
  174. 00 T/A LS1 Intake or Head Swap.
  175. HELP! Code P0174!
  176. How much oil with turbo???
  177. need advice on a new setup
  178. QTP header install
  179. installing 1/8'' sender in LS1 head
  180. Got my new exhaust, Sounds like crap.
  181. Driveshaft loop
  182. pacesetter LT's question
  183. Magnaflow SS catback installed today
  184. ported my stock tb now high idle wtf
  185. Texas speed headers?
  186. Anything else to get before i order headers?
  187. question about maf and tb
  188. loudmouth vs flowmasters/cut out
  189. Things Just Aren't Working Out...
  190. Fassst idle
  191. Problems ?
  192. Question on Fast 90/ ls2 TB install
  193. not your normal Ported TB question..
  194. Hey guys L92 conversion "?" searched w/ no answer
  195. Does anybody make urethane catback mounts?
  196. 00-02 SLP Lid on a 98 Z?
  197. I Don't Think That My Catch Can Is Working Properly!
  198. Which o2 extensions??
  199. Which o2 extensions?
  200. Borla Catback
  201. Exhaust
  202. O2 sensors
  203. stainless 4"-3" reducer?
  204. Typhoon Itake...search=nothing
  205. ported throttlebody
  206. 3" exhaust = XXX RWHP?
  207. Aftermarket damper question...
  208. truck alternator
  209. Flowtech mufflers?!?
  210. TSP still making lids???
  211. running cooler question
  212. Free flowing... but quiet?
  213. MAF porting? i need advice
  214. somthing every 98 ls1 owner should do....
  215. where to mount electric cutout switch??
  216. Got the itch RIGHT NOW!
  217. little modds, thats adds up
  218. LS2 TB on an LS1
  219. Will rear o2 work in front?
  220. powerbond pulley users in here!
  221. Need Part Number for a Bigger AC Oil Filter for a 99 LS1
  222. LSX intakes/ 90mmtb
  223. is the throttle body stacker worht anything?
  224. Stepped headers, do they really help scavenge more? Worth the $?
  225. Got the QTP headers today
  226. Cutouts vs. Catback?
  227. Couple questions about ARP Fasteners
  228. One last duals question!
  229. Whistle coming out of my Exhaust
  230. lq4 6.0 install questions
  231. Possibly overheated?
  232. Couple of questions about header installation
  233. Would this hooker muffler fit?
  234. After header install having problems
  235. stainless or coated headers?
  236. Motor mount to engine bolts dont line up PICS
  237. Radiator Hose Leaking!
  238. o2 sensors
  239. XS Headers with Cats
  240. mass air flow screen delete?
  241. what size cut out
  242. catback question
  243. Pacesetter w/slp y pipe and loudmouth 1 ?
  244. !AIR question
  245. 10% or 25% underdrive?
  246. Intake manifold comparison
  247. Are LG pro long tubes worth the $$?
  248. beck sheetmetal intake flow numbers
  249. Re-Installing A/C
  250. water pump
