PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 [290] 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Motor out the top
  2. DAMNIT I'm NOT getting any SES lights or codes...
  3. Where to find a 2 into 1 Y-collector (3")???
  4. cutt cats??
  5. O2 sensor wire routing
  6. True duals vs y pipe and catback dyno results
  7. Yanked Pwr. steering kept stock pulley...which belt???
  8. slp header question ...did you loose top end power?
  9. Help Me Build a 350
  10. to cut the egr tube or not cut the egr tube...
  11. which muffler to stop rasp
  12. headers to buy?
  13. What Bolt on's am I missing?
  14. 00' SS wont turn over, dunno what to do...
  15. Intake choices
  16. f body throttlebody work on 5.3 truck?
  17. Anyone know the size hole for the header bolts?
  18. Car dies when headlights turn on!?
  19. Dual Cutouts & SLP LT's
  20. Cutout.......?
  21. EGR and AIR question
  22. Throttle Body Liners? WTF?
  23. SLP Headers and true dual
  24. subframe connectors
  25. Have any of you have problems with this
  26. cut out
  27. MagnaFlow Muffler
  28. 28x10.5x15 ET Drag?
  29. I changed my belt, and now it whines and throws it off...
  30. Engine covers for 02 F-Bodys?
  31. Do I really need an MAF?
  32. Help!! Header install tach not working?
  33. muffler delete
  34. Help me with Rasp!!!
  35. paging dynatech LT headers users
  36. Q-TEC exhaust cutouts
  37. can you reuse intake gaskets????
  38. Spark Plug Change
  39. lid and filter?
  40. PaceSetter Coated Long Tube Headers
  41. QTech pics inside........
  42. 911 Please help now!!
  43. DIY True Duals
  44. LSX
  45. tts headers?
  46. Macs --> Kooks (FI)
  47. How often do NGK TR-55s need to be changed?
  48. True duals with BMR Extreme T/A setup?
  49. Got My True Duals Put ON!
  50. Merge Collectors
  51. Crappy Idle
  52. Who makes a true dual setup for FLP Headers???
  53. Air restrictor mod
  54. Dynomax Bullet Installed
  55. getting some rasp? listen to the clip and let me know
  56. O2 extenstions
  57. HELP ME STOP THE RAPPING !!!!!!
  58. Recommended LT's for custom cam/heads?
  59. Summary of the new intake offerings coming out?
  60. NGK TR5 OR NGK TR55 spark plugs
  61. what plugs to do with?
  62. Who all makes1 5/8" tube headers?
  63. Car is idling rough
  64. The blue air filter?
  65. Mid Length Headers
  66. should i get a 160* stat ??
  67. should i take off my egr valve? pros and cons?
  68. if i remove the motor mount bolts?
  69. removing my stock air box?
  70. Quietest Possible Exhaust
  71. any tips on installing my exhaust.
  72. im removing my AIR system,what to do about vacuum tree?
  73. AIR blockoff?
  74. Meziere Pics on Milled Heads
  75. Mandrel Vs. Crush Bends
  76. any word on the LSX intake yet?
  77. who sells coil pack relocation kit??/
  78. Installed Headers had it tuned now we have multiple 02 senso
  79. What are some symptoms of a bad
  80. Catalytic Converters
  81. difference between 98 and 2001 radiator
  82. Macs on a 2000?
  83. exhaust sound with no cats? let me know if its normal
  84. Anyone have pics of polished or chrome meziere pump
  85. New Jet Hot Y Pipe w/ Cats - Not what I expected
  86. How much hp gain?
  87. Muffle down the SLP LM
  88. PPC dyno numbers
  89. What do I need to put 01-02 FLP's and Y on my 99?
  90. Headers
  91. Kook's Headers For C5 Available Soon!!!!
  92. Q about Pacesetters and ORP
  93. True Duals
  94. what is a good exhaust, header combination
  95. ? about the SSRA for whoever has it on their car...
  96. Throttle Body Compatability 99 to 01?
  97. Underdrive and Alternator Pulleys?
  98. Pulsing Electrical System??
  99. Cutout installed today.....HOLY SH!T!!!!!!!!
  100. any problems with the slp 85mm maf?
  101. Dynomax Bullet vs the SLP LM vs Hooker
  102. POR-20 instead of ceramic coating on a y-pipe?
  103. quietest high flow muffler
  104. Which of these two setups will work best?
  105. Hooker Headers AIR Connection popped off on the freeway...
  106. Part number for the oil gally plug w/ 0-ring...
  107. Which motor mounts to get?
  108. Meziere pump come with new gaskets????
  109. Poly Motor Mount install?
  110. Flp Headers and Loudmouth?
  111. Difference in ported TB
  112. For those looking for an exhaust ......look inside.....
  113. Dyno Results...........good or bad???
  114. Header mufflers?
  115. So i installed the headers finally...
  116. MAF screen removal my results, good or bad?
  117. Anyone have QTP headers?
  118. NE1 running dual cutouts, FLPs, ORPs/cats, & x-pipe?
  119. FLP kit and Loudmouth, can this be improved?
  120. Will a cutout make me run rich?
  121. racing chip
  122. Throttle body use gasket or o ring?
  123. k&n intake?
  124. LS1 exhaust sound
  125. Question on Pace Setter LT
  126. ignition boxes...
  127. What exhaust sounds the best
  128. What does it take to fab braided lines?
  129. make sure your MAF is clean if you run K&N filters
  130. LS6 intake or Holley intake?
  131. Can I reuse my stock manifold gaskets?
  132. Pace Setter LT??????
  133. Another "Catch Can" inside...
  134. Motor Mounts & LT headers
  135. LS6 Valley cover ... How does it hook up?
  136. water temp sensor question
  137. Cross drilled and slotted rotors!!!
  138. A/C Blower Part #????????
  139. O2 extentions
  140. How hard is it to switch pedals? (manual to auto)
  141. Is it worth it "t-duals and stock headers w/cats"?
  142. smooth bellows?
  143. cold air unduction question
  144. Dual Exhaust need pipe measuremant lengths?
  145. How much louder without cats?
  146. Part number for the oil pressure sensor??
  147. oxygen sensors
  148. weight removal
  149. Cut outs?
  150. Hooker headers suck!
  151. AIR Pump Question, is this Right? (PIC)
  152. CC exhaust insert update! So long rasp!
  153. Got my headers today!!!!
  154. to those who have installed their own headers ORY and cutout
  155. Best placement for cutout
  156. Aftermarket Wires
  157. What would this sound like?
  158. Katech Pulley Tensioner
  159. LS6 Intake Manifold ??
  160. Stock LS1 w/ cats . What is the best cat back sound
  161. Emissions testing without EGR and AIR?
  162. Car pinging after hooker to stock headers?
  163. intake
  164. Alternator noise
  165. Any way to quiet a stroker w/duals?
  166. AIR system
  167. Here's a different Intake.. LPE one..
  168. Anything I need to know about installing new O2's?
  169. B4C police Camaro alternator
  170. offroad x and chambered vs. catted y and gmmg
  171. Which Header Bolts?
  172. CAT SHELLS??
  173. guys who have modified the collectors on macs
  174. Jegs Universal True Duals
  175. Average Cost of True Duals
  176. Pace Setter Header Good or Bad?
  177. Why wont car start?
  178. PCV part number for 2000 TA?
  179. Best Hiflo Cat?
  180. head bolts
  181. Thermostat opening temp
  182. old question.... sorry
  183. Where to Find GMMG Exhaust?
  184. Dual exhaust with X-pipe installed
  185. Any dyno or track results from the new Edelbrock headers?
  186. Used ASP Question !
  187. Which y-pipe are you guys running with your Pace Setters?
  188. Meziere EWP dyno numbers.....
  189. ELECT. CUT OUT
  190. tuning after lt's???
  191. Test Fitment of Meziere EWP on Milled Heads
  192. My Dyno #s Vs. Mods inside!... BOLT ONS
  193. External Oil Line Sizing
  194. SS exhaust
  195. New SS Owner looking for complete Exhaust
  196. Was this a stupid decision or was it worth it??
  197. Where to get True Duals for Pacesetters?
  198. Qtp's on
  199. From Macs to Hookers, through GMMG my thoughts.... (pics)
  200. New LS1 owner, help with first mods
  201. Drilling thermo to allow air to escape.Where to drill? (pic)
  202. Meziere Water Inlet Allen Head Dims Inside
  203. What size cut out for stock exhaust?
  204. header question
  205. want to order some jet-hot LT's, have a few newbie questions
  206. Hooker LT primeries O/D size
  207. Does anyone know how much DynoJet drums weigh?
  208. QTP 1-7/8s headers are in..........56K beware
  209. Help me decide what mods to go with.
  210. please help with air pump
  211. 172 stat vs. 160 stat. advantages and disadvantages?
  212. Just had my Pacesetters installed.........
  213. Borla exhaust dyno question
  214. Headers: Equal length or unequal length?
  215. What symptoms does an unbalanced pulley create
  216. Body mount torque arm with true duals, which one?
  217. Custom Taylor Wires
  218. Who is running BOTH ASP underdrive pullies?
  219. sweet thunder mufflers
  220. Help! Mysterious leak in my LS1 part II
  221. Bolt broke off in head, what thread/size bolt is it??
  222. Anyone With True Duals 98-02 LS1
  223. Electric Cutout Problem
  224. Stainless Works mufflers
  225. where to get exhaust hangers?
  226. Exhaust coatings worth it????
  227. smooth bellows
  228. Electric cutout exhaust leak...
  229. Anyone try a CC exhaust insert?
  230. Whats the best Intake Manifold?
  231. Loudmouth Questions
  232. MAC headers ORP
  233. Will a bad 02 sensor
  234. 3" true duals, too big for bolt-ons motor?
  235. 2" headers too much for hydraulic 422??
  236. What Plugs and Wires for N/A Heads Cam LS1?
  237. easiest way to gut factory cats
  238. big problem
  239. O2 sensor size?
  240. Installed ORP-Can you say RASP!
  241. pacesetters
  242. how to wire meziere wp toggle?
  243. Spark Plugs on a 409?
  244. EDITED Exhaust Frenzy
  245. do any of you know about tbyrne's double discount? help fast
  246. Katech TB on bolt on car?
  247. what should i do for new exhaust system??
  248. Meziere Pump installed! Pics inside.........
  249. buying headers and need advice please
  250. Will an exhaust leak cause a rich condition?
