PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 [165] 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. question about ls1sounds.com
  2. Switching from 1 7/8 headers back to 1 3/4" on H/C car?
  3. What throttle body with LS6 Intake?
  4. Exhaust Question guys, would this setup be restrictive?
  5. well i got my cut out , and
  6. ground wire?
  7. where at??
  8. 98z what coolant to use?
  9. Tach output connector location
  10. whats the difference between ws7 and ws9
  11. Ok fellas! Talk to me!!!
  12. Crankshaft bolt - halfway out and stuck
  13. Gains with headers over cutout
  14. got headers installed today, questions/problems
  15. Has This Ls6 IM been Modified?
  16. Will Lanes True Duals fit my Pacesetters
  17. New exhaust on today......
  18. Whos got it
  19. Fast intake VS. BBk SSI intake
  20. Someone explain speed density
  21. Injector Measurment
  22. c6 oil pan on a fbody
  23. Changing battery cables write-up?
  24. Putting a Spiral Flow after the y pipe
  25. LS6 Intake Swap ??
  26. For the love of God!!!!!!!
  27. flp 1 3/4 vs kooks 1 7/8 on a 408?
  28. TDs VS catted Y with no catback
  29. Idle at 1500- 1600 RPM's help!
  30. Anyone have actual data comparing a FAST 78 to a FAST 90
  31. Installing QTP's, few questions
  32. AC Delco Iridiums
  33. How much heat to kill a coil???
  34. cheap headers?
  35. plugs
  36. LS6 install ??
  37. Are my rpm's too low???
  38. MAF screen
  39. bad gas milage after egr removal
  40. Jet Hot y-pipe Leak Solutions
  41. need help....on exhaust choice
  42. Results from Jethot LT's and mod'd Hooker Y
  43. need an airfilter
  44. ??? about grinding ls6 intake ribs down
  45. Whisper lid gasket
  46. spohn k member
  47. GMMG is on. The good, the bad...and the ugly
  48. gauge pods
  49. Service Engine SOON Light??
  50. 160 Thermostat? Should i Do it. Please Help
  51. 98 maf is bigger than 99
  52. Magnaflow Quad Tip Pics
  53. solid motor mounts (hope this is in the right place)
  54. my shift light doesnt work.
  55. Bad Spark plug?
  56. ls1 BLOCK = lq4/9; HELP!
  57. Which is correct?
  58. Quick catch can question..
  59. Catch-Can help needed
  60. Y-pipe question
  61. Igintion problems
  62. SS catback, chambered or what?
  63. Oil pump install?
  64. qtp question
  65. My exhaust is done! *Sound Clip!*
  66. Jet Hot and True Dual fitment questions
  67. i like em loud..which is loudest??
  68. typhoon intake or ????
  69. Air temp sensor before Mass air flow sensor
  70. "Stinking" cats
  71. need help big decision
  72. Cam Position Sensor
  73. header/ypipe question
  74. which fast for my setup?
  75. So, apparently AIR is different in 01-02 than in 1999....
  76. Relocating battery?
  77. pacesetter bolts
  78. MTI Lid Question
  79. no lid !!!!!!!!!!!!!
  80. no lid !!!!!!!!!!!!!
  81. headers banging
  82. Pacesetter LT's and Cut Out Question? Help
  83. AN fitting sizes
  84. running problem, O2 sensor, plugs/wires
  85. How will cats affect my duals?
  86. Anyone Make the Own True Duals?
  87. y pipe and tunnel brace torque arm
  88. Is this magnaflow cat high-flow?
  89. LM or gmmg can't decide
  90. AC pully tensioner removal
  91. Junky lids
  92. Best exhaust in your opinion.
  93. lt1=ls1 02 sensor?
  94. Pacesetters got here today!!! got???
  95. QTP ypipe pictures please...
  96. LT header install / lift engine?
  97. Header bolt hell!
  98. BGRA question
  99. Exhaust Problem Help!
  100. guys w/ speed density tunes, what are you using to reach from air lid to throttle bod
  101. SLP Dual/Dual or Ultraflow Dynomax??
  102. What do I do with this EGR Plug?
  103. Non-Mandrel Bend Question
  104. Shift light prob.
  105. Welding cats on a QTP orp
  106. ls6 intake w/injectors
  107. Need intake manifold bolts for L76
  108. Q. pinning a balancer & keyway on the crank
  109. REplacement Waterpump non Gm, aftermarket
  110. Ipipe?
  111. Header Questions
  112. another stupid "where does this go" intake
  113. LT1 x pipe help!! People with experience
  114. SMOG i need help quick!
  115. Solid motor mount guys...
  116. NW 90 TB with F.A.S.T intake suggestions
  117. The TSP offroad Y on a VERT?
  118. Ls1 Breslin Bolts?
  119. Pics of Loudmouth II tips
  120. Paging ~JOSHUA
  121. what's the difference?
  122. Installed my FAST 85/85... holy hell!!!
  123. Exhaust tube leak
  124. DynoMax Bullet Question Please HElp
  125. Egr Removal
  126. PICS of Y-Pipe
  127. Quieter with Headers and 3" pipes?
  128. Another Lid Problem
  129. edelbrock or pacesetter
  130. k&n oil filter, quick question
  131. Borla or Corsa Clone exaust tips??
  132. Help needed! Ram air rubber piece missing... (pic)
  133. Help On Lid
  134. How to wire up an Air fuel gauge?
  135. Positve QTEC stories
  136. Which to install first???
  137. programmer suggestions
  138. Are FLP Headers Considered a Restriction?
  139. headers question
  140. LS7 VS L76 intake on L92 heads
  141. BBK intake install now my oil pressure.
  142. Wanted New Headers, what to buy? Kooks Stainless?
  143. Header hitting the steering shaft!!
  144. F.A.S.T. intake, LS2 90mm T.B., and Haltech worth it???
  145. installing headers tomorrow..any tips?
  146. Holley 90mm
  147. Best bang for the buck?
  148. header install lost power??
  149. I to add cats to my tsp duals. Car is lowered. Need advice.
  150. Loudest Bullet? Most Quiet Bullet? please help.
  151. Speed Inc X Pipe?
  152. Little Help Please
  153. Header Help?!?!?!?
  154. Dynomax Bullet or Loundmouth 2 or Sprialflow??
  155. Exhaust Manifold Gasket
  156. will a z28 exhaust fit a V6 camaro
  157. Ebay exhaust tips for Loudmouth
  158. Flowmaster or Magnaflow Merge?
  159. Sound Clip: Finally Got a Tune--MS4, TD's, 1-Chambers
  160. How to clean/shine stainless headers?
  161. Sounds level from these mufflers/setups?
  162. Best Elec. Cutout?
  163. true duals: dual in/dual out muffler
  164. High Flow Cats.........
  165. How much is a used Loudmouth worth?
  166. What comes in Kooks catted Y box?
  167. SLP cold air Induction
  168. Need help with ory
  169. SLP Cold air intake.
  170. SLP CME question
  171. ls6 intake
  172. Victor EFI or F.A.S.T 90MM ?
  173. How many LS6 Intakes??
  174. Valve cover breather
  175. Dumb exhaust gasket ???
  176. Question on these headers?
  177. BUllet in the I-pipe?
  178. mids VS LTs
  179. Exhaust layout help please!!!!
  180. best TB
  181. Direct Port Nitrous With Fast Intake?
  182. how much HP?
  183. Exhaust suggestions....Drag car!!
  184. Belt Slipping Prob!
  185. Cutout Question .........
  186. Loudest exhaust ?
  187. TSP True Duals
  188. Lid Question
  189. quick question on TSP website
  190. Pics Beck intake on Car!
  191. unported FAST intake vs ported FAST for stroker
  192. LS1 Sounds
  193. Convertor Heat Shields different?
  194. HTS vs Ceramic coated
  195. Who has DMH e-cutouts?
  196. LS6 Intake Manifold
  197. Centerforce Clutch
  198. Something in my AIR system gone bad?
  199. Advantages of coating stainless headers
  200. GM Part number for front seal??
  201. Cheapest pacesetter to buy this week??
  202. Sound/Video Clip - Stock Exhaust w/ Cutout
  203. Anyone looking for more height from their TSP TD'S?
  204. 2 OTL to Loudmouth?
  205. LS2 Intake Direct Bolt on?
  206. Remove a V-Clamp? Help!
  207. cam installing info...
  208. curved underbody intake?
  209. GMMG or Basani true duals?
  210. Stock airbox lid rubbing hood
  211. Once and for all..having no rear O2's affect gas mileage?
  212. Shift Light Wires
  213. Fast To Slow???
  214. Quick longtube install question
  215. Magnaflow catback help
  216. Dumping my exhaust....
  217. throttle body question
  218. tsp
  219. 85mm PP throttle body
  220. Intake manifold
  221. need help please, ASAP. Changed TB and now idling at 2500rpm
  222. FAST 90/90 question.
  223. Breathe, BREATHE DAMN YOU!!!!!
  224. help please
  225. MSD Plug Wires part number?
  226. Update -- Problem w/coated Pacesetters
  227. pacesetter headers.. please look
  228. How can I tell if LS6 intake?
  229. F-Body Pully->Corvette Engine
  230. painted LS6 intake installed
  231. sensors
  232. pacesetter l/t
  233. Installed New Era Ported TB - Looking for header help
  234. home ported FAST results
  235. Stupid oil pressure sending unit!!!
  236. MagnaFlow or Hooker AeroChamber
  237. Exhaust change-up *Now w/ PICTURES*
  238. baterry gauge still on red???wtf
  239. Dynomouth, anybody have any videos??
  240. '00 TA Just Bought Unsure of exhaust to get
  241. is it bad to run with a bad o2 sensor?
  242. Broke a valve cover bolt...im starting to give up.
  243. So Im installing my FAST 90/90 setup...
  244. got some extra money and nee help spending it!!
  245. crank position sensor??? please help.
  246. Part # for valve cover gaskets
  247. need help asap..
  248. 2002 corvette intake lS6????
  249. exhaust/stock y?
  250. Is it possible???
