PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. 383 rotating assembly????
  2. New Exhaust product (4" single, 3" duals w/TIPS), interest and comments needed!
  3. best place online to get msd wires?
  4. Rumbler vs loudmouth ?
  5. Help! Can someone take some measurements on Mac Mid lengths for me?
  6. catch can
  7. Does porting the Edelbrock Pro-Flo help?
  8. engine mounts
  9. New FAST 102 w/78mm tb
  10. will 13" o2 extensions work on longtube headers
  11. Stainless Works Headers?
  12. Basic ls6 Throttle Body question
  13. cheapest way to LT's and TD's???
  14. Head Question???
  15. Need Head Gaskets and Head Bolts!! Help
  16. LS6 Intake??
  17. Newbie help
  18. 1 3/4 LT vs 1 7/8 LT
  19. Melted Motor Mount???
  20. Longtubes for 78 Camaro LS1 ??? Pacesetters worked great
  21. The true cost of a header install. Done right.
  22. MAF Trade
  23. Need help with air lid
  24. cb pipe to y merge temp?
  25. weld it over or remove old weld and clamp?
  26. Need help finding headers...for a boat.
  27. LS1/LS6 intake coolant/steam tube torque spec?
  28. Replace both O2's??
  29. Header install check list
  30. long tube headers vs short tube headers
  31. Just bought ls6 intake!!!
  32. Is the ls1 camaro a pressurized coolant system?
  33. Fixing a sticking FAST TB
  34. Making a stock ls1 exhaust sound better
  35. Headers and cat y
  36. Anyone with dynomax super turbo catback?
  37. Help!! Choosing a Cat-back
  38. gto valve covers
  39. help me please!!!!!!!
  40. Underdrive Crank Pulley
  41. Is 3.5" exhaust a real problem?
  42. Got in race class, want street class. Restrictive cat/muff tune question with cutouts
  43. Dont know how to re-set throttle cable tension- HELP!
  44. Weird Hessitation at 2500rpms
  45. Need cat recommendation for rumbler on lowered car
  46. Magnaflow + long tubes
  47. Uh-oh! Hole in my pacesetter!
  48. help please asap!!!!!!
  49. Cut to fit LSx plug wires
  50. ls1 wont start
  51. stupid question but...can i fit 2000+ longtube headers on a 98?
  52. AC Delco Iridiums Gap????
  53. Need an X-pipe
  54. Porting a Fast 90
  55. big fitment problem after header install... has this happened to anyone else?? *pics*
  56. Is my PCV setup wrong???
  57. easiest way to to get AIR pump out of car?
  58. Half shaft sticking
  59. header bolts
  60. lq4
  61. Intake porting Ohio
  62. So Lost ! I dont know what to do !
  63. 2000 pcm and harness in 1998 body
  64. Got my 1 7/8 headers
  65. hp/tq estimates?
  66. coil pack ground
  67. FAST 102 w/LS2 fuel rail
  68. K&N Cold air intake, or No?
  69. C6 exhaust manifolds + 317 heads?
  70. Catch can install. A useful tip for hook up...
  71. Will the truck steam vent fit a LS3 Intake
  72. what to expect?
  73. Exhaust Backfiring after Header install?
  74. Borla cut outs?
  75. Anyone have a wiring diagram?
  76. throttle body 85mm??
  77. ls6 intake
  78. what else needs to be blocked off?
  79. How much power out of a cam only L33?
  80. bolt size on end of heads?
  81. striped out the o2 sendor bung! what tap size to use
  82. How do you fix exhaust leaks?
  83. Gasket Question
  84. just changed my wires and...
  85. Electric problems after new rockers ???
  86. SLOW tach
  87. Over heating
  88. Are LT's/ORY/catback really worth it?
  89. Mount install - Need Advice
  90. retune with bigger headers?
  91. can you reverse coil packs?
  92. need ls6 intake pic
  93. rear oil pan bolt
  94. gmmg
  95. has anyone had any problems with MSD Coil Packs??!!
  96. replacing LM muffler with chambered muffler...
  97. radiator info
  98. Which extensions to get/plug and play extension ok??
  99. Will BBK LT's and a TSP 3" ORY fit no problem?
  100. Need New PCV lines
  101. O2 sensors
  102. Help asap!
  103. mezerie race water pump
  104. Is my 1/8 mile time ideal ?
  105. Magnaflow 16723
  106. rough idle after jumpstart?
  107. Crank Snout Tap????
  108. Rough on start up
  109. installed lt's and ory.. question about ses
  110. Aluminum Intake
  111. Any cons to running a catless wide open exhaust?
  112. o2 sensors too short, help please
  113. best lid for ls juan
  114. Can i run an off road y and lm1 catack on stock manifolds?
  115. Anyone cut there non ws6 lower airbox to have a bigger opening
  116. Aftermarket Water Temp Gauge Reads On The Cold side????
  117. ideas on a nice way to fix this fuel line problem
  118. adjusting throttle cable? Help?
  119. help! wierd azz 02 sensor question
  120. what else do I need for lt install.
  121. coil brackets
  122. BBK Setup need to no what maf you think is good
  123. SLP 2OTL vs Magnaflow H/C Sound Clips
  124. car backfiring after header install
  125. Anybody Have Problems With Threading Their ARP Crank Bolt?
  126. do these 02's look shot?
  127. So, about the Edelbrock Pro-Flo Intake
  128. Yes, a headers question....
  129. 12" Dynomax Bullets vs. 16" Dynomax Bullets
  130. Adding cat to ORY
  131. LS6 intake install - change Knock sensors?
  132. thermostat problems!!
  133. Catback vs. True Duals
  134. ATI Super Damper, what size?
  135. PORTING ls6 intake ?
  136. How can I launch better? LCA's and what?
  137. Anybody have ory for 99
  138. which is prefered and why?
  139. best muffler/xpipe to use with custom dual system?
  140. Headers & EGR
  141. Cutout size: same for stock as Magnaflow?
  142. Best Swap?
  143. SLP Loud Mouth question
  144. PS cooler for my camaro ss
  145. Anyone running OBX headers and Y pipe?
  146. slp lid....k&n filter or paper?
  147. Misfire with no dtc's
  148. Battery relocation help!!!
  149. Alternator after alternator, any builders here ???
  150. FAST 102 TB +MAF question.....help please
  151. Can i use Ford racing 47lbs (EV14) ??
  152. Bolt pattern dimensions for FAST 90/92mm TB or other aftermarket TB
  153. true duels
  154. Loudmouth 1 Resonator
  155. TB slack won't fully open butterfly?
  156. Full bolt on's
  157. CAI vs lid and filter?
  158. gasket kit
  159. Header Install
  160. Pacesetter LTs with 3 inch X pipe into Magnaflows dumped
  161. 02 sensors?
  162. header install today... need help fast
  163. whats the best high flow cathletic converter
  164. My final exhaust review!!!
  165. Volant CAI
  166. Where to tune after H/C/I/LT's
  167. Best FAST 92 port job??
  168. Anyone bought TSP headers w/ these flanges?
  169. LPP headers Hitting Motor Mount
  170. Ls6 Intake Fab work !! Opinion's !!(PIC'S)
  171. why would they use 2.5" pipe from LT headers
  172. lq9 bolt ons
  173. ac compressor pump
  174. help removing ac
  175. anyone runnin a Q45 throttle body???
  176. How much HP do you loose installing CATS? (i've searched)
  177. muffler to flow well but be quiet
  178. head gaskets
  179. Mods for street/strip DD!
  180. Headers and starter heat reflective wrap.
  181. Texas Speed Headers
  182. Exhaust on ls1 cars
  183. how much louder?
  184. What is LS1 Tech's opinion on exhaust cutouts?
  185. LS6 intake and stock MAF on a 370
  186. 02 5.3 with 06 5.3 wiring and comp ?????
  187. What Intake/TB Combo?
  188. pcv system question
  189. which muffler with loudmouth1
  190. I need help with my exhaust
  191. Need some info
  192. Alternator relocation help
  193. Rear-end
  194. SLP LoudMouth 1
  195. LM7 serp belt options...?
  196. Vehicle speed vs fan speed question
  197. Over axle exhaust pipe
  198. LSx engine diaper
  199. LS1 starter on LM7?
  200. sensor help
  201. Ignition Wiring Error
  202. Map Sensor Question
  203. lq4...lq9.. but what truck is it from.. help
  204. Exhaust... several questions.
  205. Finally got the 6.0 done!!!!
  206. upgrading to ls6 intake
  207. Motor Firing On Half the Cylinders???
  208. Would car misfire if plug wire wasn't on all the way?
  209. Fast intake re-assembly question Any Help?
  210. New Dynomax VT Mufler
  211. LS2 Crankshaft bolt! **Please Read**
  212. Best Catted Y pipe for Jet hot headers?
  213. removing epoxy from tb
  214. idler hits bracket
  215. SLP Smooth Bellow
  216. summitt racing 3" x pipe kit
  217. Which ls6 intake to use?
  218. ever see someone hack a muffler like so?
  219. Passenger side o2 distance
  220. Need help picking out oil catch can!
  221. Problems with full exhaust install
  222. y-pipe banging.
  223. Got Cam?
  224. Unsolved mystery!!! 01 z28 problem plz help!!!!
  225. anyone using 6LE stainless CME tips? got a question
  226. thinking about powerflo's w/o the lm?
  227. Fresh LT install and now car won't idle
  228. Repeat Offender P0136
  229. Purchasing a short block... which gaskets needed to complete the build?
  230. help o2 sensor problems!
  231. new f.a.s.t. lsxr 102 intake
  232. JEGS Electric Exhaust Cutouts
  233. QTP Headers Help.
  234. Are these cats any good?
  235. damn intake gaskets!!
  236. Lids other than slp?
  237. LS6 or F.A.S.T Intake???
  238. Okay stupid question!
  239. ws6 with these tips..help..
  240. intake gaskets
  241. Electric Cutout....
  242. Huge coolant leak now, please help!!
  243. Is it possible to identify this bullet?
  244. What is this hose? Please help!
  245. ebay valve covrs
  246. ***4" mufflex finally installed!!!***
  247. You know this is a good setup
  248. LS6 intake vaccum line plug
  249. O2 ?
  250. MSD Blaster coil packs
