- Oil consumption results from Foreman Motorsports Catch Can
- Is SS exhaust 3" mandrel bent cat back ?
- got harlan's 2step on the 98 tonight.
- SLP LTs with cats or ORPS,,, anyone heard them both?
- More power from boost or compression?
- Fuel gauge inaccurate??
- My report on the SuperSucker (3 largish pics, and LONG)
- Alternator hums and drains battery with ignition off
- Hooker LT's jet coated....Dyno results/Gains?
- HELP!!!!
- Which Converter and Street ET's ??????
- induction question
- Dynabatt jump-start problem
- hooker y pipe stock exhaust
- which stock pulley is the POS?!?!
- SLP Headers, 1 3/4" Tuned/Long Tube 2001-02 LS-1 Camaro/Firebird P/N: 30053
- Muffler or Cat back
- What Pound injectors does my 2001 SS have???
- Replacing MAC Cats with Bullets or High flow Cats
- adjustable temp. fan mod
- cool videos...
- Best sounding Muffler???
- anyone dyno before true duals and after?
- cats, running rich ?
- Water pump whines - after throttle body mod.?
- 1/2 studs with stock 16s
- Magnecor or Taylor?Which one & why
- TB Question?
- People with true duals and lowering springs.
- Need part # for cooling fan plugs
- chevy HP mag, 15 rwhp for FRA, TBB, !EGR??
- Newbie question on headers
- OK it's time for a new cat back........
- PSJ or anyone please help!!!!
- MAF Suggestions....Is it the cause of my detonation?
- True Duel Exhaust?
- Holley intake
- Modifying Holley's LS1 Intake?
- Primary Tube Size
- Thread dimensions for header bolts?
- D@mn I made a boo boo.
- factory ws6 hood and air box on a t/a???
- Just installed LT's
- LS1 Motorsports 310 HP Package
- Removing cats with FLP's....result in richer or leaner?
- Installed the ghetto torque strap...
- Running rich and rotten egg smell???
- extrude hone (or otherwise ported) cast iron exhaust manifold?
- What do I need to run open headers?
- Borla vs. Corsa
- LTs or mids with just a cam, and a few more ??
- My MAFT encounter questions
- port matched manifold and gutted CAT.....
- Shaner throttle body overrated
- Just installed my headers, got a quesiton
- Flo-Tech cutout install at end of Y-pipe
- high flow cat question
- Quick Help Please..Do I use gasketonDirectFlow directwHelp
- Pics are 10-8
- Create a link for sig
- free MAF mods
- Anyone know how to get rid of a rattle from the headers
- Sealed airbox worth it??
- EGR block-off? what's wrong??
- ??underdrive pulleys??
- How do I remove my AC pulley?
- Need Help w/ a Part Number
- part # where to get weld on collector for dynatechs
- headers
- FLP's and Hotcam installed today.
- Exhaust question,any adverse effect....
- LS1 Motorsports Airlid good lid?
- Gutting the Cats
- Dynomax Bullets placement???
- Has Anyone Ever Heard of This???
- B&M Shift Plus
- Question about LS6 intake manifold ?
- Oil pressure
- Just got Jantzer P&P throttle body....questions
- Part # please dynomax
- Header Prices
- SLP Off road Pipe?
- 1 3/4in LT Headers---->Hookers or Dyna's?
- To Coat or not to Coat........
- Anyone running a 85mm Ls6 MAF on an F-body?
- Smoke on hard acceleration
- Y pipe
- mccord electric cutout
- So i finally decided I want my full exhaust system, come in and help
- Electric Cutout
- want new exhaust after converter...(which?)
- Need Help
- Need cutout with Hooker catback?
- Pulley question for bolt-on car
- Pics of bullet in the I-pipe?
- ALL WS6 guys please give me input on this intake!
- Suprising dyno results - FLP's vs. Stock Manifolds...
- Can I take my AC belt off?
- How to drive your HotRod...
- How many miles to full tank??
- SLP Bellow....what happened to mileage?
- Mac Headers
- Cutouts before cats
- Bang for the buck.....
- I have a stupid question
- Help... How do I get the Grot's on????
- Starter Problem
- Pic of my PCV catch can
- headlight/electrical problem
- will a WS6 airbox fit??
- Tech Advice - Please Help
- Anyone know any free tricks to richen up my car?
- X Pipe?
- x or h pipe for 427 ci
- Help me drop 3 tenths.....
- Who sells the dual gauge pod??
- uNDERDRIVE pULLEY
- Mac Header install?
- witch ram air hood will give me the best power
- What would be worth more as a mod????
- Need to know the belt size for short belt
- set up like borla
- Head Studs Torque Specs?
- 2001 LS1 Intake Gasket Part Number?
- anyone know where to get the clear headlight covers for t/a's?
- Need Borla really Cheap
- WHERE CAN I FIND PULLEYS
- Need help with ASP pulleys
- 02 Firehawk?
- No more truck sound.... going with x-pipe
- FLP's arrived today...first impressions...
- just got my 2001 SS!!!!!!!
- o2 sensor extension
- How much HP do you think all of this is worth?
- descreening an slp 85mm maf sensor
- h-pipe/x-pipe location question...
- Which exhaust will be louder?
- Hedman or Dr. Gas X-pipe?
- FLP Y-Pipe ? ? ? ? ? ?
- How to keep Hooker catback from rusting?
- Will my exhaust drone or resonate?
- which bullet muffler???
- Will the rear O2 sensors work on the fron???
- More injector questions..
- Performance Parts
- LS1 fan switch -> SES light
- OMG!!!! Major backfiring after header install
- Air filters
- x-pipe,bullets
- just put cats on my car, it seems like it's quicker?
- GROTTS HEADERS........THE SOURCE...FROM VICTOR!!!!!!!!
- Bauer Racing TBs ????
- C5-R valve covers???
- Quick ? about Seafoam Engine Treatment
- QTEC & Borla
- Grotyohan headers are now TA headers, same exact thing with no wait.......
- Strange detonation problem, any ideas??
- Can this be removed? I think it's a evap solenoid? GeorgeC?
- Check out my dyno with FLP LT's, looking for opinions
- How much RWHP can a stock fuel system support?
- Dynatech or hooker longtubes?
- First Serious Mods
- My car sounds like a truck
- Whisper Lid
- New lid, how do i get out the sensor???
- K&N oil on a power shot filter?
- 1998 to 1999 PCM/Wiring Harness Change
- Anybody running Open Exhaust?
- '99 throttle body on a '00?
- EGR Valve
- Why does Flowmaster have such a poor reputation?
- AIR Problem HELP
- magnaflow cat-back
- Corsa is on!
- Oops!! Battery Over charged..
- TSB on Radiator Caps
- Descreening MAF will it hurt my car
- 1 7/8" Dynatech vs 1 7/8" Grots
- Difference between Truck Throttle Body and F-body TB???
- Downside to a beather? Pros/Cons??
- FLP LTs are on!!
- Does anybody have an answer?
- Possible way to get HP for a given injector PW
- Could use some help installing some gauges please
- Fuel Pump Question
- 1K to spend..???
- K&N oil filter oil
- Good 'ghetto torque strap' pics
- SLP vs Whisper
- Will this work?
- SLP to FTRA Conversion!! Help!!
- descreen maf w/A4?
- Ok,I admit to probably drilling my tb hole too big..neatest fix /size of factory hole
- pn# for 6.0L MAF....
- Temp gauge not working inside car??
- New Hooker Y is dented right out of box?
- can a lower temp thermo. cause KR?
- Want to hear a GMMG Camaro
- fuel pump & pressure question
- Air Lid
- Question about A/F Ratio after header install...
- The Better Header
- LS1 coolant flush
- Need some advice
- Lesson in restrictive exhausts
- Airlid and MAF
- Corvette exhaust manifolds - look good, do they fit?
- Could you bolt in a Z06 engine in a z-28 ??
- Borla XR-1 muffler fixes the Loudmouth sound!
- Dyno Testing results true?
- Will a PACE LS6 MAF help lean me out a bit???
- Am I fogetting something?
- How is everyone setting up aftermarket oil press gauges?
- ORY HITTING FRAME UNDER LOAD..... HELP!!
- URGENT:Need to know prodction #of camaro asap
- Flowmaster install
- header clearence
- Better y-pipe for FLP's?
- Custom exhaust with Bullet mufflers
- just got bullets!!
- Replacing coolant hoses, what brand if not GM?
- Guys with exhaust dumping underneathe your car. . .Quest.
- Opinons on running car with just 9 intake bolts
- Exhaust question...need some input..
- Hooker Headers, Which Y-Pipe??
- Am I getting screwed here?
- Can anyone tell me the length of ORP's
- Flashing Check Engine light
- I just spilled some oil, while adding a quart. Does that...>
- Umm...installed 160 'stat .. gauge still reads.....>
- WICH LS1 EXHAUST?
- is it useful/useless to have a cold air induction on your WS6 Ram Air?
- Dump with a "Power Plate"?
- SLP Loudmouth
- QTEC's
- Best plug wires?
- Does anyone make a coilpack relocation kit
- asp crank pulley
- How do I get rid of the ill fated "rasp"???
- Exhaust
- F-Body Shop
- Gotta Beat a Z06
- IS it possible to make a LS1 sound good?
- black smoke and popping from the tailpipe?
- M6 car have A4 connectors in harness?
- Hooker's website?
- WANTED.... SOLID MOTOR MOUNTS FOR LS1..
- Need Help Fast!
- getting dynatech's, which collector WON'T leak?
