View Full Version : Generation III External Engine
- Corvette alt braket and powersteering pump - need pics
- how to clean EXTREMELY dirty K&N filter
- EGR delete question
- Header collector question
- How many miles on your ASP pulley?
- Hose question....
- What Bellows with WS6?
- Another Mac to LT ?
- electric cut-out
- LS1 to LS6 intake coolant lines/plugs where does it go?
- coolant line bypass?
- Fast Intake...from vacume tit...
- Cheating the system of $$$
- Egr ?
- Any interest in LS1 EGR intake block off plates?
- MAC ORY O2 bungs, only 3?
- SES light comes on periodically
- Cats Clogged
- what kind of gains?
- tsp true dual instalation question
- Smog
- Pocket Bike Exhaust
- Valve Cover and Intake gaskets
- SLP Loudmouth Exhaust
- What headers with GMMG ?...
- Has anyone else done this?
- Opinion needed (Sound): Pacesetter LT's, ORY, Magnaflow cat-back
- How much HP lost through CATS?
- is the Electric Cutoutworth the money?
- LS6 intake coolant lines
- After market Tach works for 30 seconds...
- Want to make my 98 TA ram air
- Which way does water circulate thru the front 4 holes in the block??
- QTP 3" Cutout users look here
- Help w/pacesetter lt's install please...
- Sound clip for true duals, w/bullets on stock maifolds and cats
- XR-1 or SpirlFlow???
- wrong thing to do wit intake!
- Pacesetter Headers (Pics inside)
- Whats better for a 408 1 7/8 full or stepped?
- TSP Rumbler pics
- Fact Or Fiction
- true duels ?
- 90mm TB elbow???
- my dual's pics
- Radiator Hose Part Number Needed
- is this a decent deal to have longtubes and poly motor mounts installed?
- Header/cat/y pipe question
- bellow for ws6
- Headers and exhaust - need opinions
- Dont you ever mention that again!
- thermal wrap
- intake swap, replace gaskets??? OR use old ones?
- My SSRA lives again!
- Is it really worth it?
- ASP pulley Questions
- Port Polish throttle body??? help
- Hi Flow Cats Question.
- My Exhaust Idea, let me know what ya think
- Convert 3 to 5 wire maf
- need a little info please.
- Will a truck TB work on a Camaro?
- Thanks for everyone's input on the GMMG!!!
- 3" Stainless Y pic!
- Problem removing borla I pipe
- Need help, car surges to 2000 rpm between shifts!!!
- Finally, My baby is back!
- ATTN: Jason and Joseph @ TSP
- Long Tub Headers – time to fish or cut bait
- need a waterpump question answered! asap plz
- Need tips on banging up heat sheild
- Power Window Goes Up Part Way And Stops
- MACS ORY, Dynomouth
- Best flowing stock manifolds
- Where to put torque strap...
- Flp collector clamp bolts!!!
- Anyone have the part # for Borla xr-1 muffler?
- Borla Exhaust with LT's
- Best spark plugs for the LS1?
- Cutouts just after collectors… good idea?
- keep melting spark plug wires..
- OEM - replacement cats
- Headers + True Duals = Backfire?
- Will bad 02's rob horsepower?
- Loom fuses - what do I need?
- Where to place X in my exhast system.
- help locating B&B style tips...
- Short circuit in loom - traced to O2 sensors - help!!
- This one might be a little awkward, but here goes...
- acting weird
- TSP duals are on!
- Mac midlengths install
- Mac header rattling
- pacesetters question???
- which cats???
- Headers better et's?
- How much louder with headers
- spark plug wires
- ARP Header Studs -- RIP OFF
- Put my headers on and now im running rich Help!
- Header Bolts -- Need Opinions -- Pics
- Aftermarket MAFs Explained
- TSP Duals and Jegs Drive shaft safety loop
- burnt wiring on header question....
- What TB and MAF?
- 85mm SLP MAF or port my own?
- AIR / EGR Questions
- Ground Clearance
- Help me figure out this sound
- New Exhaust Idea, NEEP HELP
- stainless works..size issues..
- Mezier Pump Quit on Me
- Anyone Know Where To Buy A Oxygen Sensor
- Dumped Exhaust...
- How do these headers compare?
- Sound with a cutout vs. Open headers
- Cutout on SLP DD worthwhile?
- K&N HP2006 filter too long?
- what size is borla I pipe?
- Is the SLP Dual/Dual a cross flow muffler?
- how do i route PCV lines?? what parts?
- lsx 90mm Throttle-body help.
- Header swap out question?
- quiet TD's.....
- headers+y pipe + catback best combo
- Solid Motor Mounts
- Best Cut out...? Anyone had problems with there QTP?
- Changing plug with LT's
- Who has KBDD subframs and a QTY
- tach not working after motor/trans goes back in car.
- exhaust rattles, help
- GREDDY Catch can
- hooker header install
- Flowmaster vs. Magnaflow
- Noise under hood, can't tell what it is
- Just ordered TSP True Duals
- Does anyone make a smooth bore F-body throttle body spacer kit?
- What the hell is going on with my crankbolt
- pic of sweet thunder mufflers
- headers help asap
- Rasp problem. Anybody have SLP DD w/ LT's & ORY?
- bolt ons = 11s?
- My SS rattles nonstop!
- I need help!!! (broken studs)
- need help with headers
- Speedo No Go After Alternator Swap
- SLP DD without cats
- Is there anything to DISLIKE about GMMG?
- Stripped spark plug hole!!!
- Who is running NGK TR6 plugs?
- Considering Nascar Boom Tube
- Finally Installed my Harlan shift light and BMR SFCs
- HELP! kooks 1 7/8 header install 1998 z28 question, asap
- bbk throttle body quest.
- Know where to get center mount tips????
- 3" 304 Stainless Steel Duals inside
- Need Help On Exhaust Pipe Sizes
- whats the difference between lids
- Throttle Body Question
- Those who just bought Kooks Headers, I need a measurement.
- slp pullies..not a newbie question..i think
- ?'s about true duals
- Throttle body question
- Will 02 LT's work on a 99?
- Wooo Hooo, just ordered my first non-free mods today
- Sweet thunder
- Parts needed for custom catted Y pipe help!?
- Mustang Style Duals...?
- Poly motor mounts - pros/cons
- Anyone have tips for disassembling stock throttle body??
- What exactly are all the bolt-ons?
- Help me choose exhaust for WS6
- Quiet Exhaust – is it possible?
- Hooker Header Install
- LSX w/90mm TB on an Fbody - inside please
- A/C Compressor Problem
- Borlamouth
- Can an LS6 Intake come from a GM Junkyard?
- How to install autometer oil pressure gauge?
- another backpressure question...
- WS-6 hood mod
- LT Header install question...
- Stainless vs. Coated vs. Stainless and Coated
- Do the oil pressure sending units ever lose their accuracy
- did tsp get their true duals in today?
- borla/corsa
- headers
- How do you make the fans run at high speed all the time ?
- One quick maybe dumb question
- GMMG Exhaust owners... plz step in
- Effects of not running PCV?
- Trans vs Oil Coolers
- I need some help
- Borla Catback And Hooker Lt
- Shorty Headers
- LS2 Intake
- where can i get Mass Air Meters fot my2003 monaro?????
- Rumbler/Corsa Question
- y pipe issues again
- Cutout length
- which exhaust setup do you think is better
- !air vac lines
- Turn signal on solid???!!
- o2 simulator help!!!
- Cut Outs?
- What X-Pipe?
- Thunder Racing Adjustable Belt Tensioner
- My car wouldn't start
- Victors are ordered!
- Got My KOOKS, now quick question!
- Asp Pulley
- X or Y
- Which dynomax size bullet should i use?
- Kooks '01-'02 header onto an '00
- Is the EGR plumbing the same for all 98-00 models?
- NEW bang for buck header!
- FTRA help.....
- Is the stock tach off?
- Quetion about Shanner T/B
- full exhaust system
- Have you guys seen these? Hedman
- Stock manifold to y-pipe gasket part numbers?
- bbk intake
- Need info on location of sending units..
- Help with windows
- Reasonable cost for Cutout???
- Got a shift light, where can I find a switched and fused +12v source?
- is it an intake leak
- What is needed to make the Meziere race pump work?
- Shorty Headers ?, I Know..I Know...
- LS1 Throttle body Part numbers
- header bolt advice
- runing straigh headers
- Header Advice
- exhaust inspection question
- Can anybody tell me where I can get this?
- torquing header bolts???
- Header differences.
- Does 93 to 97 LT1 have the same radiator design?
- Lid
- New TB for LS6?
- Belt length w/o pwr steering? help...
- Texas Speed's New Cat & Off-Road Y Pipes Pics-->
- Mac Mids Installed. Problems!!!
- Custom Flange Kit Carsound 941009?
- True Duels with Stock Manifolds
- AC fan replacement
- long tubes rubbing steering nuckle at idle
- Rumbler Catback Rev. 2 Pics!
- Idle searching...
