View Full Version : Generation III External Engine
- Oil type?
- engine restorer clogged my oil pump???
- Question regarding the Hooker Catback?
- FAST 90/90, Paint it...?
- ok guys need your help...Magnaflow True Dual mufflers needed
- Hooker Exhaust Review
- Vacuum line block offs
- Header install, what o2 extensions do i need for 2000 fbod?
- can bad o2 sensor make your car run lean? PO134 code
- Are there any good fitting Catted Y's
- Just installed SLP lid...
- what kind should i go with?
- Picture of the inside of my FAST...how much oil is bad??
- Getting MAF out of stock resonator WTF
- Damn i'm a newb...
- Review of PaceSetter Y pipe
- Stainless Works Headers
- Which intake? FAST 90/90 or LS6/ported TB
- Couple Exhaust questions...
- Question about installing UNCOATED STAINLESS headers
- complete exhaust install
- Fast 90 map sensor problems-Corvette
- Would anyone buy a K&N knock-off?
- Going from completely not legal to an emissions-passable exhaust
- Anyone have this intake?
- anyone with QTP hvmc's, please post passengers side spark plug wire clearance pics.
- 2002 Alternator Rebuild
- Have U Passed?
- BIG Single Exhaust??
- The Battle of the +90mm TBs!!!
- plugs/wires
- Typhoon Manifold
- will a LS2 inake/TB work on a LS1?
- pacesetter headers?
- true dual help.
- AC tensioner/pulley question
- question about pacesetter coated headers..
- Header Install
- HELP!! Knock after intake/headers?
- replacing oil pan gasket
- the new SLP lids
- Attention. . major upgrades soon~! need help~
- Got My Edelbrock Race Headers Today!!!!!!! WOW
- Stock catback, replacing muffler?
- engine removal question
- obx LT's - swap resonators with cats
- How do i get rid of my EVAP system?
- Car Backfiring!!!!!
- H-Pipe set-up for LS1?
- long tubes and scraping
- Should I install my FAST 90 now or wait until my H/C setup is ready?
- rev limit
- hooker headers
- Injectors: stock 28# or SVO 30# for <450rwhp
- Does the FAST intake 90/90 come with everything needed?
- Cold Air Kit on WS6?
- Optima Fitment
- Having trouble with the header bolt...
- Powersticks vs Sweet Thunder
- TB
- whats the price
- new exhaust idea input needed
- Ls1 or Ls6 intake
- plugs/wire/tires
- whats the advantages of not running a M.A.S.???
- straight headers?
- Lid?
- Alternator charging help.
- To those with true duals and no cats...
- Stock water pump vs electric water pump
- Put headers on with LM2 and car is WAY to loud....suggestions....
- Intake
- Typhoon 85mm manifold &TB dyno: final results
- Local shop will not install headers
- Service Vehicle Light?
- Broken oil sensor unit!
- Pacesetter Vs. Jet Hot
- TSP Rumbler question
- Pacesetters,TD's and spark plugs in less then 7 hours
- How to delete p/s in 10min
- Car is Slower with FAST 90, NW 90
- Polished my kooks Y-pipe
- cats cut-off
- Where should I buy Patriot stg.III lq9's at?
- Pacesetter's chipping?
- Taking apart Stock Exhaust
- Best flowing muffler
- True duals done! Let my season begin!
- TSP True Duals and being lowered....
- Problems with slp lid matching up with stock maf
- Crank Bolt Part #
- car should run with battery disconnected?
- Charging system question
- Fitment of my MTI airlid and smooth bellows!
- TB Port Question
- header gasket question
- Jet Hot, TSP ORY & B&B Tri Flow Exhaust Clips!
- cant find connector...
- Ctas! ?
- stock exhaust removal - 1 piece?
- what plug wires with QTP LT hvmc's? passengers side touching on 2 and 4.
- What is this part?!?!
- Longtubes with or without emissions?
- Fast 90mm to stock maf
- Percy's Seal4Good MLS Gaskets
- Crane Cams/Vinci Performance Tuner vs Unichip Piggy-back ECU
- y-pipe for Grotyohann headers?
- Oil pressure sending unit part number
- Air intake setup! Which one??
- Question about inlet/outlets on waterpump
- pcv catchcan?
- Does this sound good? (exhaust clip)
- pros and cons to having the stock tb ported......
- 3" TDs and Lowered Cars
- Fast 78mm or Slp Ls6 intake......
- How much HP can a stock injector maintain?
- What sensor? Back of the ENG top black cylinder
- Easy questions about Magnaflow?
- Cobalt Gauges
- intake upgrade info
- ms4 vs. F13
- Poly motor mounts going in, quick question, search no help
- Harrop 8-throttel intake finaly installed !
- Search Down- Replacing Power Steering Resirvoir
- Throttle body question
- Meziere EWP Thermostat Inst.
- Typhoon Warning
- are rear O2 sensors the same as front?
- 2.5" true dual systems
- whats with slp??
- New FAST 85/85 track results
- Hooker Or Rumbler?
- Anyone ever heard of this pulley?
- Need Help. ..what should i do with exhuast?
- Installing Race Style Long tubes
- Pacesetter LT Headers
- Gm 90 Vs Fast 90 Vs Typhoon 96
- Driver's side header is a bitch!!!!!!!!!!!
- Header install...deleting AIR EGR?
- Y-pipe options for QTP headers?
- side exit
- question about hooker off road y pipes
- cutout ?
- Intake bolt size,thread,& length needed
- anyone got 99 f-body EGR and AIR
- oil dipstick please help
- This is what I've got for my header install...
- TSP TD Clearance
- o2 sensors
- Mass Air Flow Sensor
- Alternator and voltage question
- My Edelbrock Headers
- L76/L92 Throttle bracket adaptor, same for LS2?
- exhaust hitting driveshaft!
- Are the FAST T/B okay? I heard they were problematic or something.
- Change my exhaust??? Vid Inside
- Quality of NEW FAST 90 MM TB
- Any A/C guru's out there? need help
- Fixed my banging duals....
- X or H??
- Header Install Questions....(HELP!)
- Pro 5.0 vs B&M ripper
- need some help quick!!
- Best place to mount 02 bung?
- SLP loudmouth resonator broke
- G-Tech Pro SS
- Underdrive pulley
- Guys With A Muffler on I-pipe
- TB bypass
- BEST Headers for MY setup
- Damn this is a hard decision...
- Tune necessary?
- bleeding coolant system
- Anyone ever made their own Air Intake
- Dynomax Ultra Flo X muffler=crap?
- Smell w/out cats
- holden monaro engine cover
- what does this usually mean?
- Question a bout tsp ory and pacesetter
- What belts with TCI pulley?
- How loud would this set up be?
- Exhaust leak driving me insane
- ATI balancer question
- AR headers and exhaust
- Corsa Rattling
- Poor Numbers after torquer v2 install. ideas?
- Where to buy center mounted SLP exhaust?
- SLP vs. HOOKER
- PCV Hose broke...Catch can, or no?
- cat back question
- Y-pipe question
- ARH LT's, LS6, 38#, couple other goodies.
- Deep 60's style tone from Sweet Thunder Duals???
- Has anyone ever done this?
- is there a y pipe available for stock manifolds
- yes,my pacesetter ORY bangs the floorboard
- FAST 90mm Intake and Stock TB?
- Finally! Its Alive.
- crank bolt
- Pacesetter Kat Back
- exhaust fatigue
- Changing my exhaust
- flowmaster outlaw's? Sound clips?
- Terrible vibration after Header Install
- 160 thermo. ?
- Installed Ported TB now idle issue
- x - h - or true dual
- which gasket ?
- QTP LT's with SLP Y-pipe fitment.
- Exhaust SIZE question
- Do you guys who go to true duals miss the rasp???
- Powerstick or keep bullet...
- help with ORY
- Specific exhaust reviews...check here..
- Vacuum Canister?
- Leak
- Question about headers
- header install checklist ... make me feel comfortable about doing this next tuesday..
- need to verify part...
- Does this sound right? Install price help
- LS1 Starter need Shims/Adjustment?
- Edelbrock Headers
- What the hell is going on here?????
- A few true dual set up questions.
- need exhaust more quiet!
- TSP Rumbler vs. TSP TDs v. cam only/nitrous car
- LS1 accessories on 5.3L LM7
- Pulleys
- help finding
- Kooks or Hooker Y with my QTP's?
- Car wont start off ignition
- MSD Wires w/ Pacesetter LT's...Question about #3 Cylinder Plug Wire
- Pacesetter LT's + ORY + Corsa
- Considering ORY instead of True Duals...
- do need a better maf
- Anyone running hushpower?
- accel kool blue
- Had an idea with the LM 1 or the Texas speed rumbler
- any one else have this problem
- carb'd blow through ls1
- QTP's do yours hang low?
- 90mm NW throttle body problem, need help.
- LS1/LS2 engine mount question
- Intake out...Broken Hose ?!?!?!?!?!? (HELP)
- LT's w/ a catted y and LM cat-back....
- Popping + loss of power under acceleration
- SLP Flo Pac...Worth It?
- need suggestions for exhaust on 01 ss???
- Overdrive Alternator Pulley on M6 Car?
- Spec Clutches
