- Accufab 4150: What all is needed to make work
- removal of PS and AC - wot pulley set up ?
- SUPER victor intake V JNR V Fast for FI
- F.a.s.t Intake ?
- My engine runs "cool"
- SUMMIT RACING LS1 valve covers
- Passenger side header problems
- o2 sensor issue
- first start up -no oil pressure,with remote oil filter
- Headers Installed..Few questions on the rest
- Is $1400 a good price for ported fast 90 with nick williams tb included?
- which lid to replace my MTI?
- Wix air filter doesnt fit slp lid?
- Rear o2 sensors information please!
- how low can I go!
- Can I unhook Steam line to re route?
- Motor mount bolt size
- Intake build worth it with shorty headers?
- 1998 alternator - I need to rewire, HELP!!!
- PCV valve
- Possible TPS and MAF problems...Help!
- Hooker LT's install issue
- corsa clones where to buy?
- fuel pump removal help
- SLP Loudmouth on Stock Exhaust
- header install help
- Keep getting P0134 after having headers off.
- 3inch band clamp help
- hooker super comp + new tsp y = no work
- coil relocation
- Pulling 1/8 7.98 @ 86 mph . Will these headers help or hurt?
- Thunder Racing RapTR Cam Idle W/ SLP LM1 & BBK Lontube/ORY **VIDEO**
- Painted Pacers with Wrap
- Need Some Info On These Mounts
- Worth getting a 85mm maf before my tune?
- Tach and shift light question.
- header gaskets
- airbox and intake temporary fix?
- any gains going to new lid/maf?
- Cut out worth it?
- ARP headER Stud Torque
- Drive shaft loop and td's
- Removinng the Rasp?
- AFR 205'S or LS3'S
- Oil Pressure Sender
- turn down on dmh cut out?
- looking for more power
- Why are these two crank flanges different? Cannot get my flywheel to bolt up..
- Thinking about gutting my cats...
- can you bench test A/C compressor?
- where can i get a egr block off kit
- how to tell difference on motor mounts
- Exhaust question
- How tight do I make the belt on my manual belt tensioner?
- Anyone replace a ground cable?
- Ported TB Question
- LQ4 build ?'s
- What throttle body for non-elbow single plane intake
- LS6 Coolant crossover tube
- Should I get these hooker headers?
- ARH headers
- are 2 inch headers too much for 346?
- 2000 ss front spring rubs on control arm bolt
- Headers with EGR comparable to TSP
- i cant find the right pilot bearing!
- Which MAF, i THINK mine died.
- 4" mufflex w/spintech ?s...yes i searched
- LS6 to Fast 78mm?????? yes or no
- oil pressure problems, opsu?
- New 85mm MAf not working, any ideas?
- What's the deal with using truck coils? Watch this video!
- Doing headers soon, any tips/advice?
- 1 7/8 LTs and FAST 102 on a H/C 346. Worth the $$ or overkill?
- Which to do first cam/exhaust or 12 bolt
- Dipstick question H3 alpha
- FAST 90 and 102 questions...
- From stock intake
- DD in big trouble need some desperate help
- crank pulley question
- Where does this connect
- Yet Another Ebay Headers thread, sorry in advance
- what else do i need victor jr efi
- Buying my headers, just a quick question
- Question about true duals
- Catalytic converter question
- need help exhaust too loud
- Will LS7 ex. manifolds fit ls1/lq4
- Arh & tsp ory?
- Anyone run the PRW waterpump??
- I need a quieter free flowing muffler
- How to drill intake for Injectors and how much torque
- straight pipe?
- 98 coil packs
- Excessive carbon build up on left side exhaust tips.(but not right side)
- How to get top water pump fitting out?
- LQ4 Throttle body
- How well would it be?
- RPMs raise up without adding gas after ls6 intake install
- Longer Magnamouth/ Magnapack catback comparison?
- Tall Rocker covers
- is it really that loud?
- spark plug non-foulers and header wrap on cats
- Do I have everything?
- Slp Dual Dual hardware
- TSP Stainless True Duals
- Where can I get valve spring shim spacers 1.437" OD, .645" ID x 0.120 thick & 0.160 T
- Loudest Texas Speed tru duals
- Header removal
- 98 ls1 pcv system pieces.....?
- Catalyst inefficiency theory
- slp lm2 muffler on....... sex!!!
- Is this high enough for LT Header install?
- MSD/mini starters
- Let's talk BBK
- installing 92/92
- GM 85mm MAF
- bad o2 sensors cause low/rough idle?
- Oil pressure AND temperature gauge sensors into a LS1 Oil Cooler Block Off Plate?
- swapped 98 SS motor and trans to a 2000 Z28 and now no gauges?
- Best headers for my budget
- Is my Fast 90mm intake Ported?
- Help with selecting o2 sensors
- weird clunking sound need some help
- LS2 Belt Tensioner
- Air Pump and PCV INSTALL???
- EGR Provisions?
- header question
- BBK 80MM Throttlebody, Stock MAF, SLP Lid, need compatible hose
- Longtubes o2 sensor
- Fast 92 Inatake Manifold Help
- What kind of intake: Carb style mount T.B.
- starter is an over achiver need help!
- SLP PowerFlo installed w/pics & sound
- Help! How to remove stripped o2 sensor
- About to buy Headers?
- What catback is this?
- Catch can question (not the same as everyone else's)
- ported oil pump??
- Msd coil testing
- Anyway to stay quiet with headers?
- Can anyone identify this muffler? Pics and Vid inside.
- ls1 dipstick in a ls3
- Need help and advice about overdrive problems....
- Looking for best ram air system out there
- FAST LSXR 102mm intake is 50 state legal
- Mid/Low 12 sec. daily driver questions
- Manifold Vacuum Leak
- What to do before my tune..
- Clunking when putting it into gear
- Post pictures of your FAST 102 air intake set ups
- ported fast 92/92 or a ported fast 102/102 for a 396
- BBK LT's finally installed with impressive Dyno gains/Vids and results
- Ls1 intake vs. Ls2 intake
- Tick in pass head area
- EGR/AIR removal questions (yes another thread)
- Growing issude after heads/cam swap!!!
- Sent my power steering pulley flying today
- alternator hiss
- exhaust manifold gasket
- ORY Suggestions
- koni coilovers??
- Is 102mm intake worth it?
- BBK LT/ORY with poly mounts and a Hooker Aerochamber exhaust review
- I need 1 longer plug wire...any ideas?
- Granatelli 350200 work on a 2002 Camaro SS?
- piston to valve clearance question
- Wheres my oil?
- Motor mount install question.
- Suggestions switching from LM1 to...
- Engine idles low after intake install
- pics of LM1 or 2 dumped
- New Water Pump, Engine Overheats!
- 3" Magnaflows w/ x-pipe
- My oil is really dirty!
- vacuum pump kits?
- Help! I broke something, but what the hell is it?
- Need picture of F-Body Air pump plumbing
- Looking for an slp air lid for my 2000 z28 new or used aand cheaper than ebay.
- LS1 Bolt Size List
- Finally Installed My GMMG catback
- Prof Prod Typhoon intake with LS1 coolant tubes?
- Good set of long tubes?
- Please help!
- Negative oil pressure gauge reading
- spintech exhaust.....opinions? replacement sugg.?
- Building True Duals for LS1 Swapped IrocZ
- can i use my stock push rods?
- Breather or plug for AIR pump whole in lid?
- Kooks True Dual Exhaust with Pacesetter Headers?
- FAST 90 HP gains ???
- Want to know how good the stock catback pipe is?? Answer is inside.
- highcomp with Bolt ons
- Which mufflers for duals to keep the same volume and tone as my magnaflow catback?
- how much oil pressure is too much?
- Loudest place to put cutouts?
- Order my potz throttle body
- Oil Breather
- true duals with spohn tunnel mount t\a
- lose power with FAST 102 from VS ls6 Intake
- Temp sender options
- ls6 to fast 92
- tune for longtubes?
- electric cut outs worth it??
- Coil cover questions picture requests
- AIR removal on '01 c5
- Coming back to the crowd and need some info
- sfi truck balancer
- LS2 Knock Sensors on LS1 Block
- When is the Stock Crank Pulley Obsolete?
- 02 exhaust fit on 99?
- cracked side walls on oem ls1 intake manifold normal?
- Ls1 build, fast 90 suggestions?
- Throttle cable bracket bolt
- Lq4 swap
- True Duals, LM1, 224 Cam, Headers, California... Bad Combo?
- Catch cans and breathers?
- Are Intake pads necessary?
- replacing muffler myself on 2002 ss ?
- any recommedations for a new maf sensor?
- Oil pressure switch
- Bad transmission or engine mounts? Videos included
- Hesitation problems
- LS3 intake on cathedral port heads?
- Need help, corrosion on coil packs and spark plug wires
- Throttle body coolant
- Question for Improved Racing re: Low Profile Oil Cooler Adapter
- LS1 Pulleys?
- Thinking about a catch can, but not sure its gonna help
- sponsers and other proflo haters step in
- 5.3 compressor won't fit. Relocation options
- Opinions on best option: truck manifolds are too big on 5.3 LS
- A few FAST questions
- Bump stop mod?
- smaller pullys
- Oil Pressure Reading
- couple FAST install questions
- Catch can install
- single chamber mufflers
- F body x-pipes still sound like Y pipes
- Car craft write up
- Vacuum pump - how much vacuum should i.....
- What do I need to put a LS2 MAF/T body on my LS1?
- Flowmaster 1 chamber? Super 10 Series vs. Delta Force.
- ok, what did I break?
- ****What belt for a 10% underdrive pulley?
- Help identifying these duals? pics inside
- Muffler placement
- Coolant Tubes...what to use?
- Wtf ory
- 71k miles..... new wires???
