PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 [309] 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. ORY-Pipe Questions PLZ
  2. I got a Fernco coupler and it doesn't exactly fit.....
  3. Cut Out Installed!!!!!!!!!! I have a couple questions also.
  4. How Do You Unplug the Knock Sensor Under the Intake?
  5. Ford SVO 30lb injectors .
  6. are hooker lt's the same as hooker super competition headers
  7. Need Some Help
  8. Hooker/Jet-Hot LT Install....HELP!!!!
  9. What should I replace the Loudmouth resonator with?
  10. Does anybody know...
  11. 1 3/4" primaries
  12. SLP Y pipe or G2 Y pipe??
  13. anyone with MSD ignition?
  14. 2001 Exhaust manifolds Question
  15. Did the engineers at GM get fired after the LT1?
  16. Hypertech vs Air Intake
  17. X-pipe...Dual cutouts or no?
  18. What is needed to put a LS6 intake on a 98 SS?
  19. Crank bolt stripped!!!
  20. PULLEYS
  21. SLP 85 maf?
  22. WS6 Lower Airbox
  23. What do you guys think about Absolute Speed's Stage 2 heads?
  24. true dual pics
  25. The Reckless $10 Coil Relocation Mod
  26. best brand of fuel
  27. Light weight flywheel?
  28. Hooker LT's Rubbing on Steering Column??
  29. Y Pipes
  30. Which way to angle turndowns?
  31. Installing NGK TR-55's Today... What Gap?
  32. Plugs...which are best?
  33. SES light 3 days after getting duals? What's causing this?
  34. Anyone using justin Sutton xpipe??
  35. hooker headers LT
  36. hooker exhaust question
  37. hooker question...
  38. LS1 Motor Mounts for...
  39. plugs question
  40. Scraping badly
  41. maf ends????? whats that?
  42. Here's a true dual sound clip for ya!
  43. injector help needed STAT
  44. Pics of my Fenris Ulf ported TB!
  45. I NEED pics of cut out RIGHT AFTER Y-PIPE! URGENT!!!!!!
  46. IF GOING TO DO EGR MOD SHOULD I GET HOOKER LT'S WITH OUT EGR HOLE
  47. Ordered Katech Billet tensioner...do I need a new pulley?
  48. How good is the collector that come on the TTS headers y-pipe?
  49. Getting 1 7/8'' to 2'' stepped headers. X-pipe or Y-pipe with dual cutouts?
  50. Grotyohan long tubes
  51. Whats the best catback out there?
  52. 6.0 Truck Exhaust
  53. Dont know where to put this but..Do you know where I can find a manual for LS1's?
  54. "Direct Hits" ignition,anyone using it ???
  55. SLP Lid/Bellows install ugh lol
  56. Wiring Shift light?
  57. What kind of gas do you use?
  58. true duak exhaust
  59. Jet Hot Header install
  60. Car burning up?
  61. SLP Headers and LM Dyno question, Please Help
  62. Throttle body stop mod
  63. What do you think The Car Will run?
  64. Safe?: HPP3 tuning, GMAF, and 100 octane fu
  65. LS6 D-shaped exhaust ports
  66. "Tornado under the hood" Good or bad?
  67. O/R Y-pipe Questions...
  68. G2 Y-pipe from L-G Motorsports
  69. Par # for short belt to use with ASP pulley?
  70. Any problems or tuning after LT install I should be aware of?
  71. Tubes and hookups on the back of an LS1 intake manifold
  72. Why isn't there a freer flowing intake manifold?
  73. Whats the best catback to run with FLP's and high flow cats?
  74. Hooker LT's on 02 Z28
  75. True Dual users... c'mon in!!
  76. Urgent!!! SES LIGHT??
  77. SLP linelock install...dont work....
  78. FLP+LOUDMOUTH=WHAT
  79. lenght for O2 Sensor Extensions ???
  80. Update...relocation of coil packs...
  81. whats louder???
  82. QTEC Mounting question
  83. please share your exhaust sound files
  84. anyone from ARE please respond
  85. Custom 1 7/8" to 2" stepped headers vs. QTP 1 7/8" headers
  86. 160 thermo.... questions w/ install
  87. no oil touches it...
  88. 1.75 inch long tube LS1 truck header will be available February 2003!!!
  89. Anyone modify an SLP 3" Y pipe to fit their Grotts?
  90. cutout in I pipe????
  91. Stealth airbox v. regular airbox
  92. Is there any difference between the Fast Toys and Whisper ram air kit?
  93. Why the special y pipe.
  94. Aluminum Intake Bolts
  95. Whats the best exhaust set up with FLP's?
  96. 98,99 ORY on 00 car???
  97. What size fuel injector...
  98. Advice on setups
  99. where can i find a good hooker long tube header install document??
  100. Magnaflow.....
  101. Just bought New 30lb SVO Injectors, ??? though
  102. SLP Bellow collapsed??
  103. Planning on buying a bellow, what are the sizes on the ends?
  104. Does anyone have trouble with FLP's being too long?
  105. Steering wheel shakes when braking..HELP
  106. Stealth Lid--Horrible MAF placement??
  107. STEALTH and FTRA (Good Combo???)
  108. SS front end alignment..
  109. which merge collector?
  110. Does anyone know how to get a truck intake manifold to fit in a Camaro?
  111. Fan Switch Problem
  112. DELCO battery = leaking piece of junk.
  113. Where can I get a block off plate for the EGR?
  114. Is it bad to overfill oil?
  115. Why does my car.....
  116. help with getting true dual setup...
  117. Car surging after o2 simm install
  118. Bullet install and hacking off stock muffler?
  119. current times
  120. CRANK PULLEY
  121. spark plug install
  122. Any input on the Quicktime dual cutout Y?
  123. --since we dont have a section dedicated to tools--
  124. Problems With Free Mods
  125. mac headers
  126. Header question
  127. AIR and EGR gasket part numbers??
  128. Mac 98/99 ory pipe to fit a 2000 what mod's are needed
  129. Holy MisShift Batman!!!
  130. Borla exhaust vs stock WS6 exhaust
  131. is the catback worth it ?
  132. help with LT welding
  133. Post pics of your custom y-pipe
  134. Battery dead...rear hatch won't open
  135. Q, what to expect for tenths and mph in quarter with these mods
  136. Where do I go to delete EGR and AIR code???
  137. Steering link removal questions.
  138. still problems with my TB
  139. Do headers "always" richen up an LS1?
  140. cat gone bad?
  141. Hi flow cat??????
  142. 160* vs 180* Thermostats
  143. california emissions....
  144. Will my car pass emissions without EGR provisions?
  145. Hooker Vs. QTP quick help
  146. Questions pertaining to tuning with maft on stock MAF vs. Aftermarket MAF.
  147. MAF ends
  148. Why isnt the Magnaflow Catback More Popular?
  149. just got magnaflow
  150. Plugs and Wires....
  151. Buying new tires.....
  152. 91 octane?
  153. ls6 intake port sizes
  154. Any special tricks to applying header wrap?
  155. QTEC cutout vs Loudmouth
  156. Q about MAC headers or Hooker LT's
  157. Help with Valve covers, coil relocation, and PCV
  158. Will NGK TR55's void a factory warranty?
  159. What would happen if I "removed" the PCV system?
  160. Help......spark plug in wrong!!!!
  161. got my intake bellows
  162. mac headers on 2000
  163. which injectors???
  164. What should i have my G/F get me for my birthday/chsitmas?
  165. 2000 mac headers on 2001 is it possible???
  166. how does the PVC system actually work or what does it do?
  167. where to get 42 lbs injectors???? need help.
  168. MAFT requires w/ ZO6 MAF?
  169. Who has tried the sweet-thunder bullet on their true duals?
  170. EGR pipe on Grot's broke - fix?
  171. SVO INJECTORS
  172. hp and fuel sys
  173. Dynatech Y?????
  174. what injector size and what brand??
  175. Anybody have dyno #'s for hooker LT w/O.R duals compared to stock headers and borla??
  176. NGK TR-6's or NGK-Iridiums????
  177. ported my own throttle body today
  178. SLP CAI worth the $
  179. Question about 2002 Ram air
  180. Odd hooker long tubes????
  181. Misfiring, HELP!
  182. Few true dual questions, especially for Chicago area
  183. SLP headers.....rwhp gain?
  184. Remote Start
  185. Radiator question
  186. Fuel Pump......
  187. Any estimate on what Im pushing to the wheels?
  188. LOUDMOUTH EXHAUST
  189. ??? on y pipes
  190. What size injectors...
  191. Dual exhaust w/ cats
  192. Eliminating the cats
  193. Hooker LT
  194. JetHot vs hooker collector design
  195. New Jet Hot Header pics
  196. Fuel Pump issues...
  197. Mac header worth $500?
  198. Maf Ends?
  199. Anyone have SES after header install?
  200. Best gauges??
  201. Questions on TR Whisper lid pack w/SLP cold-air, PowerShot or K&N...
  202. Ported MAF ends price
  203. Just curious about the pcv in a 98?
  204. Any difference in N/A performance between TR-55 and TR-6 plugs?
  205. Alternative to GMMG?
  206. What should be my next mod?
  207. Oil Pressure ...PLEEEZ Help
  208. Plugs and Wires
  209. Garage Size
  210. BBK 80mm Throttle Body ?
  211. Why has any one not asked this question yet?"
  212. How do i tighten the throttle cable? TB stop mod
  213. ? on free mods.
  214. idel
  215. LS1 to LS6 H/C Swap, LS6 MAF?
  216. Edelbrock
  217. Nitrous plugs hurting power N/A??
  218. Whats a good throttle body cleaner that won't damage plastic intake?
  219. help on deciding which headers
  220. What kind of REAL-LIFE gains with ASP pulley?
  221. throttle body spacers
  222. advice on headers
  223. Paging NICK FILPPIDES (Kooks LT)
  224. sealing airbox......????
  225. Autometer gauge, roll cage mounts
  226. Stupid question...were's the PCV ?
  227. The Ultra Z hood will give me more hp ?
  228. Kooks Headers and custom exhaust
  229. Changing generator bracket???
  230. Shorty headers questions
  231. ned help on litle bro's LT1 problem...
  232. Need Help Fast!! Got crank pulley half off and...
  233. Will it hurt performance if I don't have all 3 bolts in the Borla plate?
  234. slp y pipe
  235. #'s on new Jet Hot's
  236. CLUTCH STICKS to the FLOOR
  237. New to the board, just ordered SLP headers.
  238. Fuse cover
  239. Bad O2 or Bad wire or wtf just break stuff
  240. Tips On Spark Plug Install
  241. dual or single??? w/LT's
  242. What Good Factory Bolt-ons Can Do
  243. Borla wide open vs. Loudmouth
  244. Where to find the Loudmouth for the cheapest price?
  245. Which resonator has the best flow and sound?
  246. Can i run cats on my exhaust if i get EGR and AIR deleted and removed?
  247. Need all info on Hooker LT's !!!
  248. Stealth air box vs. BG ram air
  249. RTV silicone sealant and 02 sensors dieing
  250. Best Fuel Pump
