PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Hooker LTs With Pacesetter OFR Y
  2. input on what high flow cat to get?
  3. Stripped manifold thread in drivers side head
  4. Loss from cats on a bolt on car?
  5. best way to install harmonic balancer?
  6. Professional Products/BBK intake
  7. Fair price for used headers?
  8. Need to quiet down exhaust
  9. LS1 Throttle Body cable difference?
  10. Question about modifying water pump hard lines
  11. ATI Damper Install
  12. Want to switch LM2 Resonator with actual muffler...
  13. HELP! In need of a stock LS1 MAF WITH Screen for my '01 TA
  14. High flow cats vs ory?
  15. Dyno shop...
  16. PCM depinning
  17. DIY Fan mod?
  18. What starter to use with long tubes?
  19. BBK or pacesetter headers
  20. Motor mounts
  21. Are Catted LTs legal in cali?
  22. Power Steering going out need advice
  23. Will I need a retune? LS6 intake.
  24. Hooker Off Road Y
  25. underdrive pulley keyway?
  26. about to perform my first engine swap, anything i should do while the engines out?
  27. Intake hose to Fast 102 to FTP 98 lid
  28. Porting the MAF cause tranny issues?
  29. Question about the air lid...
  30. Fast intakes and using rtv instead of fast gasket between shells
  31. Tsp Catted y pipe bad clearance?
  32. Critique My soon to be done setup!
  33. *Need Help / Advice* Best flowing exhaust for custom CME
  34. bolt on true duals x pipe
  35. Which is the Best Off Road Y?
  36. Catless Corsa With LTs
  37. Question about my Boral Catback
  38. Anyone Selling a?
  39. need help
  40. Will exhaust cutout make rasp?
  41. Performance Mod Advice
  42. Connecting y-pipe...
  43. Silicone Reducer Question
  44. TSP Duals...banging noises under car...anyone else?
  45. Installing 2step - Need wiring help
  46. gmmg
  47. Throttle Body Upgrade, Options?
  48. MAF to lid bellow problem?
  49. I lost EVERYTHING last night. HELP!
  50. Thread size for starter post
  51. Pacesetter Longtubes Install
  52. Exhaust after Y-Pipe
  53. y did my thread get locked?
  54. Are mail order tunes really worth it?
  55. Will this fit my 2002 Ls1?
  56. well my issue is back....and worse then before
  57. Which heads?
  58. Oil Cooler??
  59. Power steering pulley dimensions
  60. QTP Electric Cutout Full Metal Jacket Protection
  61. Used fast 78mm intake manifold good deal?
  62. looking to add boltons for MPG's to my ls based vehicle.
  63. My First Camaro
  64. broke timing cover......will it still work?
  65. Exhaust won't stay put
  66. BBK 80MM Throttle Body
  67. milled 243 heads with ls6 intake
  68. 2.5" exhaust, 3" input mufflers. Issue?
  69. Does anyone recognize this muffler?
  70. Starter 2001 LS1 PG260L
  71. OEM CME catback?
  72. Mods please dont move need help LS1 Experts/anyone come in
  73. Borla Plate Dimensions?
  74. cam swap questions
  75. Radiator ?
  76. Does any sponsors have an asp pulley in stock??
  77. Fast 102mm intake with 92mm T/B
  78. Misfire.. Computers Error or Bigger Problem?
  79. Is there any gain from running open headers at the track only
  80. intermediate & over axle pipes
  81. Going From Catted to Catless
  82. Crank, Cam, & Knock sensors
  83. Electric fan and Hi Idle
  84. Long tubes and off road y.
  85. ls6 intake with pro-products fuel rails
  86. LT's and A/C?
  87. HELP header install car wont stay running
  88. LTs, 3in Duals, P/P TB, CAI= tune??? car wont run after warm up
  89. dual 3.5" cutouts overkill for a 404?
  90. Intake manifold expierience
  91. Part number for x-pipe on ls1
  92. Valve Cover Question
  93. Simple queries from the owners of expertise and experience
  94. Any other intake options besides Edel. Pro-Flo or LSXRT?
  95. Any have Just FAST90/90 and LT Headers..come inside
  96. i want evidence dammit lol
  97. Bought P&P TB and now I have problems
  98. Question About Ordering DMH Cutouts....
  99. Parts for header install
  100. Oil Pressure Adapter
  101. Dual Electric Fan Wiring w/ 2003 LQ4 Harness HELP
  102. fast intake plastic??
  103. Will SLPs catted y-pipe fit Pacesetter LTs?
  104. Obx headers came in....a little worried
  105. '00 Corvette cutting out/bogging
  106. Car to lowered to drive on dyno???
  107. QTP Headers...A Y-pipe that fits???
  108. Throttle Cable Question.
  109. QTP or DMH E-Cutout
  110. BBK SSI Intake, Potential Vacuum Leak....
  111. SLP Lid
  112. Air Induction
  113. dropping ls1 from bottom
  114. CME upgrade
  115. Problem with FTP and Suncoast
  116. LS6 Intake Vs Aftermarket
  117. TR6 what gap with E85?
  118. Rear O2 Sensor Question
  119. engine bay mechanical oil pressure gauge ?
  120. 4" Flowmaster merge and cutout review-vids
  121. Typhoon intake mani
  122. Starter Problem...Need Serious Help!!
  123. Dmh cut out/please help
  124. P0300 Code. Here's my issue and question.
  125. Best way to hold Y pipe onto headers without welding
  126. Daily Driver Cam
  127. Dont know
  128. Need some header help!
  129. Weiand intake questions
  130. Cost of getting Fast 78mm intake ported by tony mamo?
  131. Front-end accessory drive squeak/squeal...
  132. Corsa Tips rotating... :(
  133. Should I just weld it? Exhaust question
  134. LS1 Heads and Cam Package
  135. valve chatter: how do i stop it?
  136. looking for a few things
  137. need advise asap.
  138. code P0174 lean bank 2
  139. Side exit exhaust setup?
  140. What is this supposed to plug into
  141. ls1 starter pictures
  142. Thinking of swapping out my powerpacks with powersticks...
  143. Can I use the LQ AC parts?
  144. Tuner and cold 99 ws6 advice
  145. 99 ws6 front and side honey inserts
  146. LS7 hydroformed or C5 sheet metal?
  147. Pacesetter Longtubes
  148. What do I need for a true dual set up?
  149. Does Anyone Have This Hallowed Out Cat?
  150. Is the theory of porting a ls6 intake true?
  151. Single cutout on the y pipe or double on the headers?
  152. Car wont start after manifold swap
  153. fbody 1 7/8 SS headers question??
  154. 2000 trans am problems
  155. smooth bellow
  156. incessant chirping noise!
  157. HELP! BBK manifold install problems
  158. help choosing ported and polished throttle body
  159. Solid motor mount help
  160. Review on my P/P Throttle body from Sponsor!!
  161. Removing power steering pulley
  162. Installed built LS3 into 2001 Fbody now Throttle Cable is way loose ** HELP**
  163. ls1 98 s10
  164. LT's with cats questions
  165. valve cover spacer gasket material
  166. Question for you guys who deleted your A/C
  167. Where Do I Get a 104mm Lid, 100mm MAF?
  168. ls7 cam in a Lq4 CEL
  169. Tuning question.?
  170. LT's are beating up my floorboard.
  171. pushrod
  172. Stupid header question?
  173. Map Sensor wiring extension !102mm intake!
  174. can anybody figure this problem out please.
  175. Should I keep my stock catback for headers
  176. Tsp true duals opinions.... Please.
  177. Volant intake on a 102 tb
  178. questions about a ls1 swap im doing
  179. Poly Motor Mounts HELP!
  180. which is best bang for my buck.
  181. LS6 90MM Intake
  182. Head Bolts
  183. Would dumped LTs be ok on my setup?
  184. Relay position question.......dumb question
  185. 3 Question About Intakes/Throttle Bodies???
  186. Ls6 intake/317 heads what gasket?
  187. Help! what headers on a fox with qa1 set up?
  188. 3.8 firebird ignition blues... HELP!!!
  189. Finally Made A Sweet Exhaust Video
  190. Please Help!!!
  191. accessories
  192. I need exaust configuration advice
  193. American Racing Headers and TSP duals ?
  194. 100+ rwhp guaranteed from just CAI, full exhaust and a tune!
  195. LQ4 Harness Question
  196. Hooker headers with what ory?
  197. Testing for a short/continuity?
  198. Corsa without Cats
  199. Oilpan and Dipstick questions
  200. FAST 102 question
  201. MAF Help!!!!!
  202. Spark Plugs for N/A
  203. Cant seperate Y pipe from I pipe.
  204. Long tubes which vender is better
  205. Fast 102
  206. Dynomax ultra flo catback
  207. TSP true dual "bullet"
  208. Am I hurting anything with excess backpressure?
  209. Engine / Body Shop Recommendation near Detroit or Port Huron, MI? Engine Replacement
  210. Who has Edelbrock Victor Series Headers ?
  211. Exhaust....
  212. Installed Ported FAST 90/90..Throttle sticking..AC wont work...wtf?.
  213. throttle body upgrade
  214. 02 ws6 ordered pacesetter long tubes with egr
  215. anyone know of any good catalogs to order?
  216. Resonated tips...follow up from original posting with video
  217. setup too loud? :D
  218. Battery Wiring! Need help!
  219. Concerned about chalky plug??? Pics inside
  220. LQ4 to SM420
  221. Coolant Leak TSB
  222. What motor mounts?
  223. ORY MPG question :)
  224. Will this Pulley pulley work? (PIC)
  225. Different Corsa Mufflers?
  226. rough idle like cam
  227. LS2 coils
  228. Ebay Throttle bodies?
  229. Plug wires with headers?
  230. Pacesetter Headers and factory exhaust
  231. Sound clips for LS1 w/ Headers, ORY and 2otl
  232. Stupid Question....is there difference between driver/pass coil packs?
  233. Head Gasket Size
  234. single exhaust all the way back?
  235. Stripped Starter bolt threads...What to do??
  236. Moroso Ultra 40's?
  237. coil power?
  238. what else to order with bbks
  239. SLP header redesign
  240. different direction thermostat
  241. FAST Intake: Do I have a problem?
  242. Help: Spohn Adj.Tq. Arm with Drive Shaft Safety Loop Cross Memeber and True Duals
  243. Fast billet fuel rails not holding injectors down all the way
  244. Factory 'shorties'?
  245. 4" catback 2002 camaro options
  246. Flames from exhaust
  247. EGR and AIR delete question
  248. Exhaust intalled now car runs horribly - 1999 C5
  249. Y-pipe solution?
  250. new ls1
