View Full Version : Generation III External Engine
- Ported 5.3 Head Questions
- FPS products
- Help with mild mods.
- Oil On #2 Spark Plug PCV Problem?
- 430 RWHP goal, what injectors?
- PP Typhoon intake and FRC will it work
- Why does my car fell like it misfire's?
- cutout turn down?
- What is the most quiet catback on the market?
- will a 99 fbody ls1 computer and harness run my 04 ls6?
- SES light flashing like a misfire at high speed?? Please help
- Anco Contour whipers?
- K&N Fipk VS Aftermarket lid
- mod list running out of ideas
- Y Body Throttle body porting question
- Can i use the truck coilpacks?
- Quietest exhaust on a budget:Pacesetters, Y pipe w/ cats, stock cat-back w/ cut-out??
- PCV hoses & oil pressure
- Coil pack bolt thread size
- Volant intake
- Corsa Sport True Duals (Camaro)
- A Few Catch Can Questions
- Lightweight batteries
- help with drag wheels
- bellow size for an 85MM MAF?
- IAC resistance
- Building My SS
- AR Headers cat pic
- black intake elbows for vic jr?
- need help finding heads to match with cam
- Are ALL the bolts on LS motor metric thd?
- true dual routing?????
- hanging mufflers for true duals?
- Think ALL Flowmaster mufflers lose power? Think again...
- Finally Got My Exhaust!!!!
- Need Help Fast!
- Silicone bellow?
- True-Dual Video...Finally !!!
- Measurement request, RAM AIR intake
- mountint catch can with an egr valve.give me some idea's
- Trying to make around 360rwhp Need Help
- professioal products 85mm tb
- Low dollar single in/out catback info/vids
- Safe about of N20 for my car.
- Pacesetter LT, ORY, and rebuilt tranny pic
- Free set of American racing headers. FREE FREE FREE for the holidays.
- Full boltons??
- battery terminal connection issues....
- Flowmaster Exhaust Question
- cant remove power steering wheel.. pls help!
- Opinions please
- muffler advice ???
- SLP Centerline Improvements?
- custom exhaust idea.....
- straight pipe exhaust question
- professional products balancer
- Cut out throwing off computer?
- Ported TB gains & where to send it?
- Need help, need info on the 6.2 liter for a swap.
- Gain from cutout and Flowmaster collector?
- magnaflow muffler
- Post up your dual exhausts
- please help me ????????
- what can i do ???
- rpms too high with no throttle???
- What to do about my exhaust!
- AIR bolt size needed
- Patriot Stage 3 Heads
- anyone using this type of intake from edelbrock?
- Anybody used Hooker....
- runnin duals please???plz help
- Ses
- Dual in/Dual out muffler
- ls6 intake or fast 90 intake??
- TSP 100mm Prototype MAF Results!!
- Whats better?
- LS1 intake rubber piece
- LS1 sensors
- 1 7/8" header options
- Anyone run the Volant Cold Air Induction on a TA?
- Awesome Customer Service from Halltech!
- chirping after underdrive pulley install
- dual/dual muffler??
- Surprised by Pacesetter
- need a set of ls1 truck coil packs
- Will changing my current cats to these louden my car up?
- SLP complete exhaust
- hooker stainless headers
- TB sensors
- Custom True Duals
- What's the link to the 90mm black intake manifold?
- loss of power after header install.........
- NEW Flowmaster Super 44 Single In/Dual Out Muffler
- cold air intake
- what can happen if i leave my rear o2 sensor out????
- Magnaflow Catback
- knock sensor
- Finally got all my cam parts ordered!
- What mufflers can i directly swap with my magnaflow catback?
- Fast Toys 85mm Air Lids with NO IAT Hole - In Stock!
- Flowmaster, the worst possible choice?
- Headers goin' on, what do to while the manifolds are off?
- best sound?
- does y pipe slide into existing exaust
- '02 TB cable on a '99
- Misfire HELP
- Coolant Pipes & Plugs For LS6
- If i install ls6 intake. Do i need to retune?
- How can I quite down my GMMG exhaust?
- cant figure it out!
- Any reason not to run a vented catch can?
- Pics of my JPR EWP and short belt :)
- Where to start on a 2002 Firehawk
- Insertable cats
- Who sells the Flat EXH clamps??
- what type of headers are these
- Full bolt ons for 2001 f-body
- Plates for Borla Exhaust
- OMG!! PIMP NEW CutOUT!! MuST SEE!!!!!!!!!!!
- Cold Air vs. Wisper
- 98 camaro under hood wiring harness not engine harness
- should I rebuild a 98' ls1?WHAT SHOULD I DO ?
- What will an electric water pump really free up power wise?
- If you don't shop here...your slow
- Ls6 Intake swap coolant lines?
- Qestion for those with cut outs close to the header.
- need a pic of pacesetter LT's and pacesetter ORY installed!
- Water Pump Ports Questions
- Should I get a Lid and MAF
- Clip of my new TD's with single chambers on H/C car
- New SLP Lid...
- 96mm Typhoon
- maf sensor?
- SLP lid fitment
- Electrical Gremlin ,Ls1 CamShaft Postion sensor
- headers and A.I.R. system removal question
- Got some new bolt-ons!!!!!
- Pacesetter and tsp ory Install HELP!!
- edelbrock or GMPP carb intake
- shaft mounted 1.75
- Cat spark plug non fouler size.
- Which is better 90/90 setup or carb style?
- Thinking about lt headers and cat back
- LS1 Fbody Air Filter
- would it be worth it?
- fast 78mm throttle body
- ***help!!!!*** Slp Package ????????
- Slp 1.85
- New Member - New Project
- Hooker (Super Comps)
- cost for LT?what will i need
- Pushrod ends worn off?? has this happened.
- XS headers
- Purchased my KOOKS today...
- What to use and how do you set the idle set screw?
- Generic Alternator Questions
- 2002 Fbody harness on an '04 GTO pull out?
- cut out?
- Throttle cable adjustment(no tcs)
- Wanted ---> Reviewer For WS6 Ram Air Kit
- Car stumbles at light throttle
- GC 0w30
- PCV valve and oil catch can giving me problems.
- Opinion on headers?
- Futral 228/230 .576 .595" Cam's
- headers
- Will running my TSP Duals out the back change the sound?
- Most quiet true dual mufflers?
- Too Loud?
- cutout v. catback
- Header Install. Help me out.
- does closer= louder?
- my headers and td's
- how will i know if blew a head gasket ???
- Flowmaster question
- How loud is GMMG with ORY/LTs
- no more true duals for me........
- Rear 02 sensor question (pertaining to ORY)
- TB Interchangibility?????
- GTO cat deletes fit on my car?
- Catted Y on lowered car
- long tube header problems
- Replacing positive battery cable?
- Intake Swap
- 02 AIR Detail Question
- Is It Holdin Power Back?
- Mac Off Road Y-Pipe
- slp loudmouth 2
- lower radiator hose size???
- exhaust cutout wiring question
- Porting out a 85mm bbk intake to 90mm?
- What kind of exhaust is on this thing?????
- 2.5 or 3" I-Pipe & Cut-Out?
- ls6 intake??
- Ported and Polished Throttle Body
- Fernco tubing?
- Stupid AC Delco
- O2 simulators purpose?
- Is this manifold too much for a stock cam?
- custom dual/dual
- muffler delete stock ws6
- strait pipes?
- Map Sensor Help
- does this fernco fit right?
- Looking for opinions on coated pacesetters and TSP off road Y
- how much difference in a .125" test bore?
- Is Mobil 1 5w30 really crap?
- MAC mids vs AR Long tubes
- Does anyone have any comments on this leak-down tester?
- XS Header Install
- geting pacesetters go with cats or no cats?
- Exhaust question
- Legit Header Question
- yank or vigilante stall ?
- What the hell kind of exhaust is this? (vid)
- Stock LS1 specs
- Pacesetter headers just come in
- Spark Plugs and Wires
- bolt size ?
- 3D Breakouts of manifolds
- Quick Question
- Tps
- Y pipe and headers
- valve job, timing chain, oil pump questions
- Best intake porter?
- help
- ORY pipe question
- LS2 in place of an LS1?
- true duals question??
- o2 sensor question...
- muffler size
- FLP header? 3.5 main pipe ?
- Another header bolt rounded
- Exhaust elbow bypass mod ?
- Fast 90, LS2 90 TB, C5, Oil catch can giving me a problem. Help.
- Ever modify rear seat pans for TDs w/ Magnaflow 4x9's?
- Air fitting for stainless headers
- victor jr intake
- what do you think?
- Weiand Streetfighter Intake
- victor jr intake
- GMMG..LT's, ORY...with TR224/112 cam..??
- Maf
- spark plugs....
- What grinder for TB porting..
- Anyone have the Volant CAI
- Questions on leak down testing
- Anyone modify thier own coolant tube instead of getting the later one and plugs?
- Exhaust for a 347 procharged camaro?
- underdrive pulleys
