PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. stripped bolts on rear cover
  2. magnaflow vs true dual , need some help
  3. are fast injectors worth the buck??
  4. whats this part??
  5. Tac Module location LS6
  6. bolt ons to reach 500hp
  7. ls6 intake help
  8. Line on front passenger side of intake Manifold
  9. Odd starting prob.
  10. Help! LPP Catted Y-Pipe or TSP Catted Y-Pipe??
  11. High Dollar Headers vs. Low Dollar Headers??
  12. Hey guys....... question????
  13. Whats wrong with my lid/intake? Take a look
  14. how do you prevent the headlights from turning on automatically
  15. accessory comparison between fbody and GTO
  16. What rubber coupling are you 85mm maf/90mm tb using?
  17. Not happy with my current catback & headers.. need advice
  18. 99 WS6 A4 vibration in park HELP!!!
  19. lt1 ignition wiring
  20. Stainless Works Exhaust vs GMMG
  21. ls2 intake on ls1?
  22. Looking for fuel rail covers.
  23. head question
  24. Misfire help!
  25. Pypes M-80's??
  26. Y pipe, X pipe, H pipe, WTH???
  27. Throttle cable adjustment after bump stop mod help
  28. Mufflers after axle on Trans Am
  29. Worst Spark Plug You've Ever Seen?
  30. Does a pipe like this exist? See pic...
  31. how much to pay for 243 heads?
  32. LT1 Ram Air box on LS1??
  33. flowmaster merge 3 -3 1/2 vs flowmaster merge 3-4 inch
  34. A Big Thanks!
  35. ls1/ls6 intake on 5.3
  36. Spark Plugs question.
  37. What YPipe will fit XS Stainless Headers?
  38. Some boxes showed up...wanna see what's inside?
  39. Motor Mounts
  40. Engine codes help.
  41. 160 Tstat
  42. A laugh at my expense
  43. LSXrt 102mm
  44. bullet mufflers opionions !
  45. Bosch or Denso?
  46. Help with reinstalling oil dipstick tube
  47. Question about power from Borla Adjustable Exhaust-has to do with plates
  48. Will I break....?!
  49. Hi everyone I need some help
  50. LPP Headers and TDs
  51. 12573572 intake
  52. lingenfelter 2 step help pleeeaaaasssse.
  53. how restrictive is a press bend?
  54. Exhaust help
  55. Hooker
  56. water pump..?
  57. temp gauge question
  58. Ls1 Miata overhears!! 250 degrees! Help please
  59. FAST 102 install on LS1... relocate MAP to front or not?
  60. LTs, ORY, free mods, now what?
  61. Anyone used these??
  62. What are all these parts? Pic inside
  63. ARH Y pipe install ???
  64. No IAT hole in new lid
  65. LS1 water pump with truck acc's?
  66. Oil Filter thread size??
  67. Anyone have a Y-pipe hanger laying around?
  68. stock mufflers..different?
  69. Removing the exhaust
  70. leaving LS fest.. low coolant light stuck on...
  71. Battery, Alternator, or Coil Pack Problem?
  72. To delete cats or not?
  73. Header Question...
  74. Gen IV to Gen III help
  75. SLP Ls6 Intake Help
  76. PRC Stage 3 LS6 heads on a 408/416
  77. LQ4 intake to ls6 intake questions
  78. Quick question, water pump gasket
  79. C clamps vs. V clamps
  80. UD Pulley Questions
  81. No Oil Pressure uh ohhh..2 vids inside please look
  82. Electrical Issues
  83. Apparently the MAF is a big restriction
  84. New to the site need some opinions!!
  85. My take on "ghetto cold air"
  86. Is an aftermarket YPipe really worth it?
  87. Best Header back exhaust combination?
  88. Best place to get a oil pan
  89. Thinking of a trade Z for a GOAT
  90. Redyno after installing FAST 90/90 over ls6.
  91. Pacesetter Longtubes & LPP True Duals (Video)
  92. PRC LS3 & L92 CNC Ported Heads
  93. Idle problems after header install.
  94. Coil Packs
  95. coolant resevoir
  96. early ls1 vs late ls1
  97. its time..
  98. Electrical Issue - Headlights
  99. Can someone tell me what throttle body this is?
  100. LS1 shutting off like a Diesel
  101. heads/cam combo
  102. Will gear swaps....
  103. NEED HELP, Va speed maybe?
  104. decisions - decisions- LM2?
  105. Help! Starting Flight School in a WEEK!
  106. DMH Electric Cutout keeps blowing fuses HELP
  107. Truck coils firing 2 coils only..
  108. Exhaust suggestions
  109. Mandrel Bent Vs. Chopped Up?
  110. How to clean center mount exhaust
  111. Pcv/ tpis tb ?
  112. Broken vacuum t on 2000 ss
  113. no spark/power to engine acc.
  114. Exhaust broke, time for true duals?
  115. question bout the cables that go to the tb
  116. HELP, cant get y-pipe off...
  117. Start motor without trans/flexplate?
  118. Edelbrock LT
  119. spark plug wires
  120. GMMG Exhaust Input Please
  121. Fast 90 TB, how to hook up to CAI
  122. Ceramic or painted headers?
  123. Do I need to ...
  124. Centre mount exhaust help
  125. Exhaust tail pipes
  126. 01 Trans am odd starting issue
  127. Anyne know if LS truck FBW throttle body is compatible w C5 FBW TB
  128. Catted FLP y-pipe, should I upgrade?
  129. GMMG catback question
  130. O2 question
  131. weiand LS street warrior intake???
  132. air flow question
  133. PTV results
  134. Need a bit of assistance - trying to troubleshoot the AIR system.
  135. Catback mounting points please?
  136. true duals with cats?
  137. cutout question??
  138. PS Pump hose choice, and broken tube? Need suggestions.
  139. Help on AIR vaccum hoses?
  140. Help me out guys.
  141. Lashway Motorsports Catch Can Special
  142. 1 3/4 headers vs 1 7/8 headers
  143. intake help h/c/i build
  144. ls6 pcv (04 version) - plug heads, or connect?
  145. MAF Question
  146. True Dual Setup Suggestions
  147. how can you tell if you have prc heads
  148. will y pipe fit??
  149. pypes x pipe???
  150. noises
  151. Which Y pipe will fit?
  152. ORY vs Catted Y
  153. Strange or moser 12 bolt housing & axle package
  154. Eliminating Header Tick..??
  155. question for a set of heads i have
  156. Electrical help
  157. Any idea what to do with this intake? no egr fresh air
  158. need cam/crank sensor voltage specs pullin my hair out here
  159. I did it!
  160. Are heads for a ls1 on a lq motor restricting?
  161. oil pressure sensor relocation kits for ls1 camaro's?
  162. PCV System for Stroker DIFFERENT???
  163. underdrive pulleys
  164. Header install checklist.
  165. hooker headers
  166. Carb LQ4, which ignition is best??
  167. Procharger now it over heats
  168. Want to make 500wheel with ms4 92 ported fast and heads
  169. throttle body question
  170. will the iron 6.0l heads work on an ls1?
  171. Did 03 Corvette ZO6 Valve Springs Come In black?
  172. Sputters at WOT
  173. Motor Mount Question
  174. Bolt-on's - which one next?
  175. Power Steering Pump
  176. Blackwing vs SLP vs Factory Lid
  177. Norris catch can routing?
  178. LS6 PCV conversion worth it?
  179. Shorties vs LT's
  180. does the DMH e-cutout fit on the QTP cutout?
  181. Correct steam tube to use with a FAST 102?
  182. LS6 intake ?
  183. Cutout self-install question...
  184. Blow through carb bonnet on NA engine?
  185. Which throttle body can I use for my intake?
  186. Bbk headers
  187. Lost Spark Plug
  188. LS6 vs. LS3 intake manifold
  189. I know, another header thread, but different question
  190. Help! where do these vacume lines go??
  191. How many have or had true duals dumped?
  192. true dual hanger locations???
  193. CTS-V vs. Z06 LS6
  194. Best idea for heads with this combo
  195. Exhaust Help/Advice
  196. Are SFCs visible from the side?
  197. ASP/Powerbond Underdrive Pulley Belt P/N# for A/C
  198. Lost Bolts Need Help
  199. cme stock muffler?
  200. Dumped borla
  201. Mamo Fast92 - Shaved/Smoothed/Painted
  202. Fuel Injector Connection, injector performance?
  203. Mounting LM7 to engine stand
  204. Exhaust Question!!
  205. cheap AND dependable heads
  206. Chambered on a budget (help)
  207. Skipping 99 T/A
  208. headers?
  209. New Ls6 with NO EGR! HELP!
  210. Cam in my car an got slower
  211. Question on tuning and headers!!!!
  212. please help asap. lq4 pcv routing.
  213. what GM injectors work on an LS1 that are bigger than stock
  214. dyno tuned...will new heads improve the power?
  215. Not the usual bullet muffler/Loudmouth thread
  216. LS6 vs 90/90: H/C 346
  217. truck heads, max valvespring lift
  218. Would you say this is too loud?
  219. reuse headers bad y-pipe?????
  220. GMMG Exhaust vid up!
  221. What to put in front of an LS3 intake on a 408?
  222. Battery relocation bracket vs relocation box
  223. out of balance water pump?
  224. boltons = loss on power
  225. Mast Motorsports Fully Ported Custom Cast CNC Intake Manifolds
  226. fast 92 intake?
  227. Help deciding on parts
  228. So thinking pacesetters LT/ HP?
  229. TB install question...
  230. Spark Plug's time to change !!
  231. tsp header install
  232. is it worth it to swap the bbk for a fast 102 for my set up
  233. stainless works catback
  234. odd question but curious
  235. ac delete
  236. help
  237. Whats the deal with Rev Extreme????
  238. Picked up an 02' Z06 85MM MAF, already have a tune. How to re-tune?
  239. Lt's from 04 gto,will they fit 04 vette?
  240. cheapo ebay header install question
  241. Ls7 427 camaro which catback?!?!?
  242. Any difference between a Zo6 and a F-Body LS6 intake?
  243. Need kooks header help
  244. eBay Throttle body???
  245. Which mufflers for tsp tds?
  246. Steam Tube Location
  247. ORY pipe size?
  248. 3.8 obx headers whos got them and results
  249. 160 t-stat ?
  250. How does this look?
