View Full Version : Generation III External Engine
- Magnaflow Question!!
- Coil Relocation Kit questions
- Custom y with flowmaster merge question
- Casting Failure on Victor Jr Intake
- After ~50miles... My drivers side plugs are already covered in carbon?
- MSD 2-Step......
- will bad 02 cause this?
- Installed Water Temp Gauge
- True duals to slp lm1
- What is a good hi flow cat?
- Carb or EFI??
- New Hearders
- Lq9/L92 cam options?
- 6.0l 408 belt size?
- Muffler Question...
- '99 MAF on an '01 car
- Carb guys please come in
- Best Bang for the buck throttle body
- Plenum vol of FAST 90?
- GTO oil pan...running oil temp and oil pressure senders
- Guys who have sealed intakes after cutting open, inside please
- Removing the crank pulley????
- How much boost on a 5,3 Lm7 ?
- Anyone running Spintech in there fbody?
- Show me your Turbo exhaust set ups
- Muffler
- Anyone know where I can buy a NW90 blade?
- FAST 78mm intake converted to 90mm?
- Header Hell (funny) cont. of ran into a little problem thread
- Borla mouth
- power sterring deletion question's
- SLP LS6 intake vs. stock LS6 intake
- Ticking noise after headers install
- How much am I choking with my fast 78 on a 6.0?
- f*** california (beat to death)
- Whats best way to clean Intake Manifold off car?
- Need Help! Pacesetter Lt installation
- Vette coil covers
- exhaust help
- questions on new car....
- stock throttle body ?
- egr block off plate for ls1 intake
- What Belts
- Coupler Help needed (Fast Toys 98mm lid)
- looking for soundclips of H Pipes
- GMMG drone reduction
- rear o2 signal wire?
- I need to know - brutally honest here. . .
- What about my exhaust?
- FAST with EGR
- 5.3 Valley cover when going carbed?
- Oil Pressure Gauge Pegged
- Getting Headers
- LT's getting installed
- Coil Pack Sides?
- Would it benefit me to change mufflers?
- Kooks or QTP?
- LS1 Throttle Body Dimensions
- De-Modding!
- blow header gasket what is the best to replace it?
- Anyone know the torque specs for the bolts that bolt the starter to the block??
- choices choices
- FAST Burst Panel Kit Worth It??
- exhaust
- patriot heads and cam package.
- have problem starting car still
- Bad CKP?
- Started my Header install today, Ran into a problem
- Backfiring?
- Should I get an X pipe?
- Banks LS1 Camaro/firebird Cat-back?
- Intake Question
- Converter flow
- not impressed with dynomax bullet!
- b&b catback vs. hooker
- Dangit - Missing hole
- Borla adj. vs. TDs
- eBay headers - revisited
- Can you identify this water pump pulley?
- Would a bigger MAF or TB help my setup? (Answer Inside)
- Need a part number for ati damper
- There is motor oil in my intake?
- no emission headers
- Burning up alternators
- Crossmember and Y Pipe?
- Mac headers...snapped a stub off
- BorlaMouth?
- How much for used Magnaflow?
- Making custom CAI... looking for filter
- Radiator fans affecting track times !!
- Unusual problem
- New Pulleys
- missing oil, missing power & exhaust note changed... help
- Which exhaust system would be best?
- o2 Sensor location on LT's??
- broken header bolt
- MAF Deleters/Speed Density come in
- cutout question??
- whats the thread pitch on cylinder head face
- Wtb used long tubes
- Does this plug into intake? Picture...
- hey needs advice
- why doest my tach work??
- Steam tube into water pump
- Crossthreaded alternator bolt
- Edelbrock Headers?
- Best sounding full size mufflers for TDs w/H pipe
- what color is the wireing harness that plugs directly in the center (back) of the in
- melted plug wires
- Anyone build a custom intake?
- Kill this rasp. Powerstick guys, step in.
- Fuse panel missing the sticker?
- Need balancer help
- Added several boltons....now running lean and low idle???
- What part do I cut on the airbox? (the free mod)
- How do I knock just a few more tenths off my 1/8th in a stock SS??
- Inside Diameter of 1 3/4 headers?
- 4" Exhuast worth it on a basic bolton car?
- lm2 catback questions
- Coolant line under intake.
- LS6 intake and TB questions
- Catch Can & EGR Come Inside!
- Could someone tell me why these are on my car?
- Ls6 Intake and header help please!!!
- what computer to buy Lsx Rx7
- A few questions.....
- kooks owners
- SLP lid
- Do I HAVE to replace timing cover/crank seal?
- 4" reduced to 3" ?
- catback system: hooker or magnaflow?
- Car is misfiring like a mother f***er!!!
- Probably a stupid ? about E cutouts
- going from 75mm to 85 mm 5 plug MAF what wires are what pins?
- Intake for a 408
- Anybody running Texas Speed 1 and 7/8's long tubes with their TD system?
- pinging need help
- Kooks LT + LM2 - clearance?
- I can't find it now!!!
- AIR Removal with Cats
- Magnaflow question ?
- what do you guys think of......
- Used BBK 85mm a good deal
- Opinoins wanted and appreciated!!
- whata ya think
- Raptor Shift light wont work?
- spring on drain plug woops lol
- ram air
- CERAMIC HEADERS AND 02's
- Corsa or borla catback on 99 Am w/heads and cam?
- Tried the SLP MAF at the track last night.
- square or round
- quick hp diy mods
- alternator pulley!!!
- fast intake install trouble
- New catylic converter SVC engine light came back on
- No to open headers
- Hooker lt o2 hole plugs?
- Coils?
- cut out vs catback gains.
- tb stall 2800-2600
- Muffler question.
- what the hell is going on with hooker!!!!
- Newb Questions - Dressing my first LS1
- ATI Dampner
- Socrpion 1.7 RR discussion
- How do I get this last manifold bolt?
- FAST 90 Intake install questions
- problem with cruise control? anyone had this?
- 799 Heads??
- 90mm or 92mm TB & Intake??
- adding hi-flow cats
- will these headgaskets work
- 160 thermostat
- 02 sensor spacer?
- ok, what MAF to go with??
- LS2 intake.
- slp lid
- need help with parts list for 408 stroker
- Oil/Residue on Air Lid???
- TPS issues... While driving, push pedal down, no change in RPM!!!
- Hooker headers
- ls2 intake vs ls1 intake
- How do you wire NEATLY?
- coolant x-over question
- Good Price?
- throttle cable routing?
- Car will turn over but not start.
- best cam for a daily?
- Name that muffler
- Magnaflow questions
- oil pressure
- throttle body mod?
- Putting car back together... Forget where these came from.. pics!!
- Spark plug wires - what to lubricate with?
- Help finding X pipe
- pcv routing for 98 LS1, no valve cover port on pass side
- need help rpm guage quit on me
- Introducing Firecore50 Plug wires
- x pipe question
- 02 camaro ss have 2.73 gears?
- What Engine Mounts?
- Can a clogged cat cuase lower engine vacuum and higher A/F at idle + run terrible?
- p0300 code after fast install.Help
- maf and throttle body mod
- Will my car drive with only two 02 sensors?
- Throttle Position sensor HELP!!! Codes listed.
- SLP CenterMount Exhaust
- Burnout
- Can't seal up thermostat....
- how to port a ls1 intake
- How long can the spark plugs be left out of the heads?
- FLP Longtubes
- Any way to test the Coils ?
- LS6 vs FAST intake Swap
- power steering pump
- magnaflow cat back questions..plus others
- 2'' headers
- pacesetter ory vs. tsp ory
- Rear Main Seal? Help a no0b out-
- Fuel Pump help????
- question bout bbk 85mm tb
- header question
- Cylinder head plate
- long tubes for lowered car
- Water Pump Gaskets . . .
- cat?
- spark plugs and gap
- LM2 even more restrictive than what I had before?
- Question about TSP TD's..
- What size mm is a ls6 intake front opening?
- HO Alternator Purchase
- quick question
- Tsp 1 7/8 headers. Anyone running them?
- 02 extensions
- Pacesetter Header Install
- I'm getting 6.88MPG... ideas?
- magnaflow to corsa? good idea?
- spark plug gap?
- Header install
- mandrel bent tubing vs. regular...
- Fast92/PTM92/SVO30# install; gotta couple of ??
- Cam'd LM2 sound clips
- Issue with my LT install. Pictures to help.
- clearance on y pipe
- throttle body question 4 bolt?
- Throwing code P0171 System too lean, bank 1
- I changed my plugs... now the car is running rough. What wires would you recommend?
- what heads to get ??
- Bullets off the collector
