PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 [329] 330
  1. What headers should I get?
  2. NEED HELP! Problems With Headers after Install
  3. Any Holley intake dyno?
  4. headers
  5. Gains with LS-6 Intake??
  6. Dynatech install question......
  7. Anyone coat thier Holley intake?
  8. What do ya think I can expect with this combo?
  9. Are these injectors to big?
  10. EGR Block off question
  11. Mac's sh*tty cats
  12. Y-pipe design for Hookers
  13. 2 Questions about the 2002's
  14. BG Ram Air kit?
  15. FIPK and WS6 hood with no baffles, any rain issues?
  16. Help with exhaust?????????
  17. How about Granatelli High MAF ??
  18. Do Hooker LTs come with collector flanges?
  19. Extened Protection Plan ???
  20. Will gutted cats void my warrenty?
  21. 01 or 02 Z06 MAF? Or keep stock one??
  22. People with Shaner S2 TBs or Ported Tbs with epoxy, come in
  23. I Need Some Help Installing my SLP Headers
  24. 00 RAMAIR WS6 EXHAUST SPECS
  25. Fog Light Wiring
  26. Anyone running the Aeromotive fuel rails?
  27. A few drone/sound questions...PLEASE help!!!
  28. I'm installing FLP long tubes and exhaust, pointers please
  29. Electric water pump.....worth it??
  30. Asp Pulley cause prolbems? Recent talk has me worried
  31. Injector Question for our ls1
  32. Dynoed the K&N FIPK kit today
  33. Jet-hot Coated LS1 headers+Holley intake in JEGS
  34. Could this be a header leak?
  35. Is this a bad exhaust idea ????
  36. Squeeky pulley syndrome...how do i fix it?
  37. 3" duals to the rear bumper?
  38. SLP MAF , Translator help....
  39. Off-road Y that will work with stock manifolds?
  40. How long did your Fuel Pump last, and what symptoms did it have when it died??
  41. Is the new FTRA ram air plate worth the $28?? Anyone swap old for new yet? Results?
  42. Spyder intake?
  43. Grot 1-7/8 install, now I need exhaust...
  44. Header's or Cam? Help me out 11 second guys
  45. Finally got SLP LT's in and went for a drive!!
  46. IAT timing tricker has an effect on LTrims
  47. P102....MAF voltage low?????
  48. Header install need help
  49. Pics of Holly Intake installed??
  50. Water Pump gasket part #?
  51. help i want "go to jail loud"
  52. Mild exhaust system
  53. what plug gap to run on my TR6s
  54. Link for the Baker Hose mod?
  55. Anyone know what the code P1416 means on Auto-Tap?
  56. Header gaskets from gmpartsdirect?
  57. Let's compare headers...TTS pri pipe lengths inside!!
  58. APEXI S-AFC controller
  59. Ok guys, how dificult is it to change out the stock spark plugs to NGK-TR55s?
  60. TR6 Question
  61. Anyone know where to get port matching?
  62. What would you do?
  63. Hooker headers and new dual exhaust installed
  64. Help with bad Dyno numbers!
  65. CFM's for 95 LT1 fans
  66. Anybody use a fuel pump voltage controller
  67. HELP! Big time.
  68. Experiencing LS! problems!!! Help!
  69. Winter gas vs summer gas?
  70. How do you test your alternator to see if its bad?
  71. Need more data.. help
  72. Oil Pressure?
  73. 410's
  74. Rich with off-road pipes and stock MAF ends - will...
  75. K&N FIPK pics installed with FRA
  76. MAF vs Throttle Body
  77. resistance for !CAGS
  78. Few Questions from the New Guy-=>
  79. Paging PSJ...Emission ????
  80. Crazy Battery Guage... Flickering 13-15 Volts?
  81. plug gap??
  82. Just how bad will the rasp be?
  83. FTRA hp gains
  84. Fuel pressure gauge install?
  85. Help with a question about low-trac, abs inop?
  86. Shortbelt length for ASP crank and Alt pulley set?
  87. FIPK track times?
  88. Lost alot of my low end after MAC header install
  89. Serious Water pump leak, help
  90. Manual Rack and Steering
  91. High Flow Cats?
  92. Cooling Fan Circuit Questions
  93. HOOKER SHORTIES
  94. Help me build the "Ultimate Bolt-On Car".....
  95. ?? on installing ASP Crank Pulley
  96. Differential fluid?????
  97. Corsa Exhaust?????
  98. Stealth airbox.....worth the $'s?
  99. LS1 "normal" noise
  100. New to LS1's need help with Y-pipe, cat, and/or header selection
  101. MAF ends and OBD-I
  102. How to for PCV valve
  103. At what mile would you recommend changing out the stock spark plugs?
  104. Bassani LS1 headers...Are they out yet???
  105. Torn between exhaust system!!!! Need Help
  106. Torn between exhaust system!!!! Need Help
  107. ASP Pulley or MTI Pulley
  108. The LS1/LS6 Engine Section Is HUGE!
  109. MAFT, LTRIMS, WOT, ahhhhhhhh
  110. Cat Problem
  111. Okay I'm a newbie.
  112. Need some quick help with headers
  113. Where to get an EGR Block off plate?
  114. Fuel Injectors: How do I tell the 99's from '01s?
  115. Repair of a cracked intake manifold.
  116. Fuel Rails
  117. WTB: LS1 edit and egr block off plates - who has them?
  118. Question about this setup.......step inside...
  119. Mac headers on a 01 ss
  120. Muffler Case length?
  121. ASCD WS6 style hood and BG Ram air mod?
  122. Bang for Buck Which Headers ar the BEST?????
  123. how to increase timing
  124. Exhaust Cut-outs
  125. SLP LT'S WITH DUAL DUAL EXHAUST
  126. Found a cure .....maybe
  127. '02 F-bdy LS1 Exterior dimensions
  128. Need part for fuel line
  129. **Paging Black Sunshine/ 00SS**
  130. Ported mass air = Faster car. Why worry about Ltrims?
  131. How much HP am I giving up?
  132. Can I get 20 to 25 rwhp from doing the following mods?
  133. Zo6 MAF on a 98 motor??
  134. FLP or SLP long tube headers....which one?
  135. LS6 pcv system installed on my ls1 block!
  136. LG Custom Y-pipe kicks $/hp ass, dyno within...
  137. custom offroadpipes
  138. 390 rwhp for bolton/cam cars with stock heads? How many of them?
  139. Stock Maf without screen and tuning the car with it..
  140. Bleeding the Fuel System
  141. In the middle of SLP LT install need help to remove steering rack.
  142. In the middle of SLP LT install need help to remove steering rack.
  143. thermostat opening temp on 98 SS
  144. how does a pulley work?
  145. Need help with fuel line problem!!!!!!
  146. MACS.....in from the bottom or in from the top.
  147. Coil Relocation Ideas
  148. Exhaust with stock sound
  149. get me into the 12's...help!!
  150. How does air temp effect air/fuel ratio?
  151. stock exhaust size going into muffler and exiting muffler???
  152. Need Plug/Wire advice!!!
  153. Pics of Gutted Engine Bays?
  154. Here are my Hooker LT gains!
  155. Installed cutout now?
  156. Am I running rich?? (gas smell)
  157. What I did to get rid of the rasp.
  158. FLP off road pipes????
  159. Anyone install a Dynomax Race Muffler?
  160. o2 sims
  161. Will a ported Tb help my set up
  162. Well I just could not help myself.....
  163. Help me build a custom y-pipe
  164. PS Cooler?
  165. Bump stop mod help
  166. Best plug wire?
  167. SLP 2OTL + No cats...
  168. Dynatech stepped headers?
  169. cruising w/cutout open
  170. Guys w/ an ASP tensioner PULLEY.....come inside
  171. Walbro 255lph intank install questions?
  172. Maft adapter plug?
  173. Do I have anything to be ........
  174. Using LS1 Edit to dynotune my ARE 422ci (iron block)
  175. BBK 80MMThrottle body?
  176. which would you use?
  177. short belt
  178. Hooker LT and y-pipe part numbers???
  179. Low dyno numbers
  180. Removed AIR pump and hoses and...
  181. Gains from X pipe truedual over Mac off road Y pipe and catback?
  182. K&N FIPK vs Volant Indution?
  183. My new dual exhaust.
  184. Help out a newbie (MAC Headers)
  185. True Dual Exhaust
  186. Stock fuel system?????
  187. Questions about O2 extension harness
  188. surging problems w/ RPM's
  189. Need diagnostic help on engine bogging at 5500 rpm
  190. What spark plug wires are you guys using to relocate your coil packs??
  191. Starter bolt question
  192. Any issues with using TR-6 plugs N/A if only using NOS 4 times
  193. Adjustable Fan Control Mod
  194. 1-7/8 Headers??
  195. Removing Exhaust Manifold Bolts question
  196. Firebird V6 muffler ? SORRY
  197. IN-LINE PUMP ??
  198. FLP Headers?
  199. Joe Prince just installed my EWP today
  200. Anyone get their Holley Intake on yet??
  201. Oil filler neck removal...and breather part#
  202. A free dual exhaust!
  203. Poly motor mounts?
  204. Opinions: H or X pipe?
  205. FAST TOYS BLEM MAF ENDS
  206. SES after free fan mod??
  207. Quick exhaust quetion.. Hooker Aerochamber direct replacement?
  208. Dyno results: Stock unported 75mm MAF vs. 85mm MAF
  209. solid motor mounts?
  210. Anybody have pics of true duals over the axle?
  211. Anybody know where to get a 4" cutout?
  212. Iron exhaust manifolds?
  213. Dyna Tech Header Install
  214. Will it void my warranty if i install a Monster tach?
  215. what other boltons?
  216. Installed Macs This Weekend
  217. somebody has to have had this same problem (MACs)
  218. What mods have to be done to cast iron exhaust manifolds?
  219. Passenger side SLP's hitting K-member??
  220. Headers Rubbing Steering Column?
  221. Can I remove the heat shield where the exhaust goes over the axle?
  222. Anyone making 400+RWHP or 118+MPH at the track through cats/mufflers?
  223. I'm a bleeping idiot...
  224. what do you think about this set up.
  225. Rubber intake boot thing
  226. Small header install questions
  227. Coil Pack Question
  228. exhaust question
  229. Who knows when the new water pump and Holley intake will come out?
  230. stage 8 bolt broke off in head :(
  231. Bassani headers and X pipe for LS1 at PRI???
  232. Whisper Headers
  233. Random Tech bullet cats vs. CNL cats?
  234. These headers look completely BAD A$$
  235. FLP headers: Extra parts required?
  236. Dynatech Gains
  237. Best Headers
  238. WS6 Cold air induction VS Lid
  239. What size cats should I get for a MAC ORP?
  240. Not having O2 sims- does it hurt hp?
  241. Y pipe diameter
  242. Would like JBA header feedback
  243. FRA vs. Direct Flow Lid
  244. What mods to do to a set of Mac headers??
  245. Exhausting Question
  246. Are later model manifolds that much worse than earlier LS1s?
  247. What is the status of the Electric water pump?
  248. Phone # for Mac Headers? Need Y-Pipe!
  249. Anyone tried to OD the waterpump?
  250. Gains with MACs on stock to mild cam / stock heads motors?
