PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 [284] 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. ASP Pulley eating belts
  2. intake question?
  3. Vacuum Pump Setup
  4. Doesn't anyone make a bellow from the TNT ring to the LID???
  5. LS6 intake porters inside
  6. True duals or not to duals???
  7. shaner TB's: S2 vs S3
  8. Magnaflow cat-back
  9. y pipe banging kmember and torque arm
  10. car wouldnt stay running?
  11. Muffler flow and dB comparison, Hooker Maxflow & Bassani Real Street?
  12. Had problems with Pacesetters? Inside please!
  13. sealing air box how to ws6
  14. Car missing at idle.
  15. Instilation Costs
  16. newbie exhaust question
  17. question on asp alt pulleys (need help asap)
  18. headers banging?
  19. Headers and AIR question...
  20. mti billet tb
  21. Question on MTI and TSP lids
  22. Intake LS6 Experts Explain
  23. cat gone bad?
  24. i installed headers now i have 2 questions
  25. Bigger Throttle body worth any gains on my setup right now
  26. Poly Motor Mounts
  27. lots of cats!! buts whats best.
  28. Moroso Blue Max Wires and NGK TR55's
  29. New 90mm TB
  30. mufflex spintech muffler vs borla
  31. Installing Pacesetters
  32. Exhaust tip size, does bigger diameter make louder sound or not?
  33. LT's with dual cutout ?
  34. Volant cold air induction
  35. Can fiberglass be used to repair...
  36. To the doubters of dual cut outs..
  37. What should I do now
  38. Question about Exhaust sizes etc...
  39. shaner TB's?
  40. ls6 intake?!?!?!
  41. Anyone running the race EWP?
  42. My FLP LT Install Notes
  43. New! MTI Billet Throttle Body
  44. spintech muffler
  45. Slp Ram Air induction system
  46. talk about your SLP LM
  47. Should I upgrade plugs/wires?
  48. So what do I need to install my Pacesetters?
  49. Best Exhaust Size?
  50. Need a little help!
  51. Spintech mufflers
  52. Where can I get a electronic cut out?
  53. Who sells the center mount exhaust for camaro's?
  54. Who makes custom Y pipes for pacesetter or hooker long tubes??
  55. What happened to all the LSX intake hype?
  56. 98 ws6's or SS guys with LT's and stock catback?
  57. Whisper or ASP underdrive crank pulley???
  58. Bullets In Place Of Cats ?
  59. Parts list with costs for true duals
  60. magnaflow or dynomax bullets?
  61. Header Bolts--Loc-Tite..Antiseize?
  62. Help,revese jump start problem question!!!
  63. Smaller LS1 starter available????
  64. LM vs. Borla vs. GMMG
  65. how can you tell a ls6 intake from a ls1 intake?
  66. Pics of Pacesetters?
  67. LS6 intake... what all do I need?
  68. Borla
  69. Any 1/4 mile gains from FTRA?
  70. Installed Borla XR1-Borlamouth impressions
  71. FLP w/ GMMG?
  72. O2 sims needed for race headers??
  73. Hilborn style, Good/Bad?
  74. ram air hoods
  75. Finally found out what was causing my PO300
  76. dyno predictions? after these mods:
  77. just hit 75k miles, on stock belt!
  78. Bassani Y_pipe From Hell!!!!
  79. AIR Pump Fuse
  80. Bassani Y_pipe From Hell!!!!
  81. Does engine have to come out to install LT headers?
  82. Need EGR-A.I.R. System Clarification!
  83. center mount exhaust
  84. Pacesetter headers(just ordered)
  85. lifting motor, what to watch for?
  86. scoogin dicky TB BBK TB cfm?
  87. Porting Throttlebody?
  88. How high to get engine out from bottom.
  89. Dyno and track times after JH long tube install
  90. F.A.S.T. products...
  91. Lanes true duals vs. cutout
  92. short O2 sensors??
  93. Hooker y-pipe with cats?
  94. Mac's to FLP's Dyno ##???
  95. Taking Engine Out!
  96. PCV fitting for a 99+ LS1
  97. anyone with magnaflow soundclips WITH CATS AND HEADERS?
  98. which thermostat Meziere waterpump
  99. The best longtube headers
  100. whats better coated or stainless kook,s LT,s
  101. Can I make good power with cats?
  102. GMMG Gains on Dyno...Anyone Know?
  103. Another muffler comparison, looking for more
  104. Another new guy with a dual exhaust question
  105. Corvette o2's on a Camaro???
  106. what can i replace the resonator in the LM with?
  107. Mufflers?
  108. What lid gives the best flow?
  109. Harlan shift light instructions needed
  110. Header Install
  111. A/C Help needed
  112. Pacesetter install
  113. Exhaust Leak???
  114. stock MAC's vs. modded MAC's?
  115. What is the size of a stock crank bolt?
  116. What to gap plugs at?
  117. alternator relocation bracket
  118. Exhaust for stock car?
  119. ZO6 exhaust manifolds
  120. For those running High Flow Cats....02 Sensor question
  121. TTS headers: pic of AIR connection
  122. LPE Headers
  123. belt size for asp crank pulley?
  124. ls 6 intake
  125. Flp's With Borla Or Slp Loud Mouth??
  126. QTP y-pipe a good piece???
  127. Electric Water Pump Belt?
  128. I'm hosting exhaust clips and movies! Link within!
  129. 2.5in True Duals part 2...PICS
  130. New FAST LS1 Intake/ Cartek Intake
  131. question with magnaflow??
  132. Anyone with centermount exhaust?
  133. what gains with mods?
  134. Custom y-pipe with cutout's
  135. I broke the Oil Sender Assembly in the back of intake
  136. delta force sound clip
  137. flowmaster delta force or dynomax ultraflow (single 3.5" exhuast dumped under car)
  138. Power steering pump issues
  139. Full Hooker Sound Clips
  140. 2.5in Stainless Steel Duals installed...all the way back...
  141. bauer tb
  142. !Air system(quick ?)
  143. meziere electric water pump question?
  144. WOAH! how to get to that passenger motor mount???
  145. What gains to expect with theses mod?
  146. magnaflow muffler # 14267
  147. ac belt
  148. Back-to-stock..LS6 back to LS1 intake
  149. Stainless works headers and Catco cats
  150. SLP LM sound clip??????
  151. Im gonna go back to a quiet exhaust
  152. Quality of Corsa back up or still down???
  153. good to go on the ported & polished throttle body
  154. lid and new MAF, now slower?
  155. Pcv System Alternative
  156. Hooker ORP
  157. hp question
  158. Race style LTs install?
  159. Dynatech stepped Headers
  160. anyone have this chambered system?
  161. anyone switch from SLP LTs to another brand of LTs?
  162. O2 sensor gone bad, which one is it?! - NEED HELP ASAP
  163. a quick question??
  164. Cheapest place for shortie headers?
  165. Anyone done this -Borla XR1 Oval in I-pipe. Will it fit?
  166. CME Tips Cracked
  167. Are the stock 97-99 vette MAF sensor...
  168. NGK-TR6's suck
  169. ATR pit-pull mufflers
  170. JET-HOT Cats
  171. any1 use the slp loudmouths with the baffles installed?
  172. What is the baddest sounding true dual setup?
  173. pro flo twisters???
  174. SLP Dual/dual verses Hooker
  175. Loud Mouth VS Hooker
  176. Mac Headers...
  177. headers
  178. Volant Cool Air Intake
  179. Mr Bling meets Mrs Bling - Chrome EWP
  180. pacesetter y
  181. egr leak=lean?
  182. Which cut out for Qtech?
  183. parts for header install....
  184. Pacesetter Headers
  185. Want to know more about Mac Headers.
  186. anyone ported out a slp maf?
  187. bullets dumped at the axle?
  188. who sells a dual exhasut kit complete
  189. pics of cars lowered with headers
  190. exhaust set up?
  191. poly motor mounts
  192. How much for kooks?
  193. people w/ kooks headers inside please, need help...
  194. FAST intake manifolds
  195. Is coating worth it?
  196. Considering MAC Purchase
  197. Any other y for Pacesetter LT's?
  198. Dynoed with the Jet-Hots Installed
  199. Anybody Just Have A Shift Light?
  200. anyone have dyno#'s from mac's to kook headers?
  201. u guys think my loose crank pulley...
  202. LoudMouth System Question
  203. Anyone got new katech valve covers with relo brackets
  204. Header Choices...HELP ME!!
  205. Flo Pro Twister or Dynomax Bullet
  206. Difference between LS1 and LS6 intake??
  207. !EGR Blockoff plates?
  208. SLP vs. Granatelli MAF
  209. Threw a code for Cat ineffiency?
  210. flipping intake manifold 180
  211. Pacesetters going in tonight....
  212. honest opinion...pacesetter or jet hots
  213. Where to put bung for use with wideband dyno tuning?
  214. need some help/advice of TRUE DUALS
  215. New Headers
  216. LS1 speed custom true dual exhaust inside
  217. Shortbelt Mod!
  218. custom gmmg help
  219. 3" X pipe set up with mufflers!!!
  220. SLP 2 Out The Left - Opinions please
  221. Can any body find the nascar exhaust post?
  222. Nice gains at track with Jet Hots!
  223. Spark Plugs, Which ones ?
  224. New Dyno Numbers
  225. FLP's, Pacesetters, or SLP Headers...?
  226. Polished Valvecovers!
  227. Turndown for Cutout?
  228. Borla XR1 and LoudMouth or Borla Catback?
  229. QTP's?????????
  230. PaceSetter Headers, anyone
  231. exhaust
  232. would any damage be done if...
  233. Anyone try this exhaust set up?
  234. Flowmaster vs: Borla Dyno Shootout Results
  235. BlackBird T/A-Manifold you spoke of?
  236. Magnaflow dual/dual
  237. 3" or 2.5"??
  238. X vs. H pipe???
  239. VR Stack - Part #2
  240. Hollowing Cat
  241. can the stock pulley be used with a double roller timing chain?
  242. is there any place...
  243. muffler comparisons?
  244. F.A.S.T Intake
  245. electronic cut out??
  246. BG Ram air or FTRA
  247. Open Borla vs. Cutout; Same Diff?
  248. header bolt size
  249. Keep cutout or get GMMG?
  250. Are cutouts really helping you. Look inside.
