- Anyone with FAST and 1 7/8 LT's only?
- #2 no fire after engine swap
- Doing a LQ9 Swap into 68 Firebird - Have a question RE Intake Mani
- Help please guys!!! Lnc-2000
- Where to install air/fuel wideband O2 sensor
- Will truck coils work?
- Spark Plug Help!
- What to do with rear o2's
- 4" single enough for 408?
- mandrel bends
- under drive pulleys
- Which throttle body is this?
- LS1 to V6 Swap
- Difference between IAC from 98-99 vs 00-02
- Coolant leak, I need help
- This sensor supposed to flop around? PICS
- Making sure I have all parts before LT and TD install.
- hole in tb blade.
- Texas Speed MAF - two models for fbody?
- New LS1 Face Lift
- Want a louder muffler to replace magnaflow cat back muffler
- Coil Pack wiring harness
- Poor water pump flow?
- Anyone regret NOT wrapping their headers before installing?
- Pics of peoples exhaust tip setups
- Is there any way to detect exhaust leaks?
- What head bolts? 5.3...
- Need help rewiring MAP sensor plug
- Holley Mid Rise
- Misfire at idle, in gear, on rainy days
- Best mufflers for 3" X-Pipe Dumps?
- GTO engine diaper?
- Bullet before cutout?
- Stumbling, but no codes, even with MAF unplugged!
- BBK headers question
- 5.3 with CTS-V Accessory Drive?
- 5.3l heads on ls1
- Oil cap air breather
- Intake question
- Taylor 409 10.4mm wires
- LS6 intake OE 78mm tb and OE fcar MAf holding back 6.0
- 90mm throttle body? bellow?
- are fbody and ls2 gto pulleys the same?
- gilmer set up??
- Different Collector For Stainless Works Headers???
- obx ls1 itb's
- Edelbrock pro flo xt 7139 intake Good/Bad?
- Could you PLZZZ tell me what these motor mount torque specs are refering to?
- The new (Black) fast 92 with 75mm TB VS the stock LS6
- My light upgrade
- Straight pipe w/ muffler & turn down off the LTs or do TD dumps @ axles w/ X pipe
- High-Flow Cats-Worth it??
- Horrible fuel smell
- Good deal for a FAST 90 setup????
- Speed engineering headers question
- Can I use an LS3 TB on a FAST92?
- What o2 sensors do I need
- Open headers burn out O2's?
- Need some SLP Dual dual help!
- PCV & catch can routing question (why plug the rear passenger side valve cover?)
- Broken exhaust manifold bolt in aluminum head
- Conceptual Polymer catch can
- Questions - LS1 to LQx swap
- Another header question
- collector/ORY/floorboard issue
- 304 Stainless Diverter w/Slip fit ends?
- Shifting problems????
- FAST 90 question????????
- Flowmaster or magnaflow
- Best Y Pipe with Flowmaster Scavenger Merge
- LS1 5.3 Procharger LS tuning kit //// fitment problems
- what maf to use
- Is It Normal?
- What brand injectors?
- whats your experience with a efi single plane on the street?
- Need to delete AIR system... HELP PLZ
- Clearance to floor pan?
- Looking for GM part number
- tsp headers and y pipe
- Baffled valve covers
- Best stall converter to run
- Who makes 2" or 2 1/8" headers of 99 f-body w/LS7
- Belt Chirping SOLVED!!!
- What diameter is the SLP Dual/Dual?
- TSP header question
- SD or MAF (yes I've searched!)
- Where can I get a fuel injetor electrical connector?
- what else will I have to do?
- LQ9 stock headed 317's ideas. anyone?
- Thinking about Headers
- got the fix, stripped threads ls1 snout
- Fast 102 vs 90 on H/C LS1
- Review: new Ballistic Speed Parts 92mm throttle body
- Super vic install
- Borla xr1 sportsman or multicore?
- question about ypipe
- Just installed my new BBK headers!!
- LS1 intake on my 5.3
- LS2 pcv plumbing in Fbody.
- LS2 W LS1 knock's and TSP 1-7/8 header clearance.
- catch can or ls6 pvc for d1 setup?
- victor jr or pro flow xt which intake
- Thinking about Engine swapping.
- Determine Proper ORY For Stock Manifolds
- Full length Duals vs. y with cutout.
- Questions on egr block off plate
- Are these flexplates interchangeable
- Sagging motor mounts
- ls2 or ls6 intake on ls1?
- High RPM misfire. I've checked nearly everything!
- can anyone tell if the belt is bad?
- Best transmission for the LQ4
- Truck oil pan in F-body
- What are good mods for a stock LS1?
- Best bang for your buck engine?
- scan tool can't communicate with ecm?
- Rear intake MAP/brake boost port removal
- ls1 timing off?
- tb swap
- Overheating/misfire issue after header install.
- Driveshaft took out catback. Need opinions for build.
- 3-step rev control using 2 MSD 8733 units...
- ls6 intake on my 4.8 , power loss?
- Steering linkage w/ headers
- drop k member/motor or rebuild through the top!?
- Water pump bolts
- Push Rods
- Lowering oil pan to fix leak ???
- Lq9 build... I need help!!!!!
- 5.3 swap in 68 camaro
- Are there any brand of long tubes to stay away from?
- what fuel rails and TB are you guys using on edelbrock pro flo xt
- FAST 90 or 102 on a 408?
- FTP 104 fits really tight
- Exhasut dilemma for cam swap.
- what intake bolts for Victor Jr?
- How would you assess if an engine is "low" mileage?
- Are 01 LS1 injectors sized sufficient for LS2 6.0
- Where can I find a part number on FAST intake
- Need bolts
- What are you guys torqueing your ARP head bolts down to.?
- any one used an edelbrock 2 piece timing cover?
- will 90mm nick Williams tb fit Edelbrock pro flo xt
- TSP and ebay true duals
- Please Help With Install Situation...
- Hardcore Intake
- Is there a way to tell a Ls6 intake from a ls1 intake.
- Rough idle, almost dies
- flowmaster merge provide any gains?
- Tb bypass too close to moving parts?
- Please help me find a fuse!
- exhaust question about mix and matching
- voltage drop issue with brake lights
- will stock fuel rails fit
- Coil wire or coil issue?
- could low oil level make starter continue to run
- fast 92 / 92, ported heads, cam what size maf?
- A/C recharge
- A/C pulley making noise, what is the cause?
- Coil Issues (passenger side not firing)
- TSP True Dual w/ Sweet Thunder
- Looking for high flow water pump
- 7.4 pushrods right?
- anyone try an engineered cooling products radiator?
- Quick question: LS1 heads on 4.8L
- Can I use this to pull crank pulley
- LS1 to FAST swap, question on steam pipes
- can i buy just an OTA elbow? - exhaust qurstion
- what sensor is on drivers side in front of #1
- heads question for firehawk
- What killed this o2?
- Coolant crossover quick question...
- Tsp 3" catted y pipe & bmr driveshaft safety loop
- Anyone do a 3" y to flowmaster merge and single 4" out dumped?
- True duals Question: Borla xr1 (40085) vs. Magnaflow bullet (14419)
- Chirping Alternator Bearings Again .... GRRRRR
- Accessory Drive compatibility queston
- Fast 90 questions
- Y pipe with a cutout OR True dual x pipe
- Belt questions with relocated alternator and no ps
- Exhaust opinions
- Help Fuel Rail Question
- I think i made a bad call on the LT headers i bought last week.
- Header install question
- UPDATE!!!! Bought TSP Stainless True Duals
- Which gasket for 241s on a 2000 ls1
- 5.3 Lifter Valley Cover Question
- Help! What are best stock headers for 99 camaro ss, Ls1.
- need advice with my valvs seal dilemma
- Are Corvette and F-Body PCV Systems the same (PCV Hose P/N)
- NGK TR55-IX Spark Plugs Gap
- Header bolts
- going carbureted, have a question
- Question on 99-00 LQ4 Transmission Fitment
- headers?
- Used fast concerns... Pics inside sugesstions
- gas line over exhaust help
- SLP loudmouth 1 with LT or Manifolds?
- EBAY Catch Can
- EBAY fuel rails? Anyone using?
- intake
- 4.8 heads on 6.0
- AIR removal
- How many of you match the head side to intake, as well
- Pfadt Tri-Y C5 header system build problems and customer service challenges
- Anymore EO Certified shorty header available now
- LS6 Custom Exhaust
- were myvalve seals installed improperly
- Oxygen Sensor Locations - Pass vs Driver Side
- High Idle. Trouble code list inside. Im stumped
- LQ4 Miata IAC getting stuck closed
- [PICS] Oil Pan Crooked Relative to K Member. Problem?
- Welding oil pan without removing it from car...yay or nay??
- Removed engine last fall, help me remember how these battery cables go please
- header size
- Slp LT's, which ypipe
- Harmonic Dampner
- Mightymouse Solutions 'Black' PCV catch can install
- dual 4500's
- HELP! choosing header size is becoming a nightmare!
- OBX headers. Anyone used these particular ones?
- Pypes Violator MVV71 Muffler compatible /w stock exhaust?
- Fixed my damaged LS6 intake
- Fresh off engine rebuild, oil pressure issue?
- Header finish quality
- EGR block off plate = strong exhaust stink with a twist
- need help
- P0332 again, after new KS's and harness
- Losing voltage at high rpm?
- Anybody have the texas speed underdrive pulley?
- 6.0L LS6 Upgrade
- Looking for H/C/I Guidance
- 100mm MAF on LS1
- What spark plug seat for MAST heads?
- Part number for rear seal retaining plate bolt
- New NRE X-Ram Inatake
- Where does this bracket bolt to?
- Engine wont start Starter not responding.. Electrical Problems
- Intake Gasket Thickness, Does it Matter?
- Meziere Wiring
- 96mm LS2 Typhoon Intake on 04 LS1 Goat, throttle cable issue need HeLp
- Stock LS1 Fuel Pump Limits?
- about to buy kooks 2" headers and 3.5" true duals but will it work with a watts link
- Who makes intake manifold spacers?
- Used fast 92/90
- 98 vs 99 Computer
- Not sure whats stock and whats not...
- anyone use American Racing Headers with Pacesetter Y ?
- 21721hkr or 21729hkr aero chamber for weld-in?
