PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. alternator problem
  2. Which Motor Mounts?
  3. Exhaust clamps
  4. FIPK back to LID!! (opinions/options)
  5. What is it?
  6. What muffler do you like best??
  7. Help! Custom LS2 4-500hp Exhaust Questions
  8. LS6 manifold swap, p0107 and no AC!
  9. Fast 78mm on a stock 99 z28..
  10. car wont start/run
  11. MAF delete
  12. ls1 vs ls6 vs weiand vs BBk
  13. LS6 or NNBS/TBSS intake? 243 heads onto an LM7
  14. Headers - ARH or SLP 2000 ws6
  15. exhaust gaskets
  16. Help hooking up LQ4 fuel system
  17. TAURUS FAN WIRING HELP! Diagram Inside
  18. borla multcores?
  19. Ls1 5.7 or LQ4 6.0
  20. Ported Stock Lid
  21. Duals under the axle.
  22. A little ss history
  23. Input on headers
  24. port and polishing heads
  25. Cam sensor???
  26. oil pressure sending unit cost (sponsor)
  27. True duals/bullets w/hi flow cats
  28. BBC LS Coil Covers
  29. lingenfelter trg-002 58 conversion box...12v power wire???
  30. Running pipes out the back
  31. If I got a new hood which intake should I run?
  32. Ground clearance with ARH longtubes and Strano springs/Koni SA's?
  33. Bbk headers install HELP
  34. TSP STainless Headers
  35. Help with high Idle
  36. c.b.m. - pacific street car association
  37. stock manifolds vs. lt/ory with magnaflow
  38. Another vibration thread
  39. Catch Can
  40. Anyone ever port the stock lid???
  41. removing iron exhaust manifolds from iron heads
  42. Removing MAF from SLP Lid
  43. Clamp for Slip-Fit Y-Pipe?
  44. New to ls1
  45. lsxrt intake in fbody
  46. Volant CAI or Lid for my T/A
  47. Any here using......
  48. Help with parts numbers
  49. Anyone tried this with kooks headers??
  50. Porting TRUCK intake manifolds and throttle bodies!
  51. TSP 1 7/8" headers with poly motor mounts
  52. kooks header to kooks y pipe leak?
  53. Aftermarket Water Pumps
  54. Air Intake Question??
  55. JAAM WS6 Ram Air Kit Sale - Ends Friday Feb 10th
  56. Weiand/Lingenfelter Intake differences from LS6
  57. gasket sealer on thermostat yes or no?
  58. What do you think?
  59. Header Time :) :ORY or Catted?
  60. smoking header
  61. Quick help! Manifold question
  62. exhaust cutouts
  63. LQ9 with shaved 243's (.020) CR and PTV issues?
  64. who makes the bwst sounding quiet catback?
  65. Missing parts
  66. stock ls1 dyno #'s to high
  67. Y pipe vs Bullets
  68. oil pan gasket question
  69. Gains w/ untouched 243 heads??
  70. Fabricated valve covers/W T& Shafts
  71. Whats my next bolt-on?? What should it be??
  72. HELP: Where to buy LS1 H/T lead kit
  73. NEED HELP! installing under drive pulley
  74. Best Intake/TB porter for LS3?
  75. How to get 3" ID tips onto GMMG?
  76. Weiand Intake?
  77. High flow cats
  78. Fast intake setup and accessories
  79. Lq4 Rust
  80. Header shopping help!
  81. Offroad Y-pipe with Oxygen Bungs?
  82. LS1 NO spark any help please
  83. need to buy a new exhaust but cant decide whi h way to go
  84. profiler cylinder heads
  85. Long Tubes, No cats, Magnaflow 14419 mod to new TSP S/S ORY, GMMG
  86. How did you wire your cutout?
  87. LS valve covers won't tighten
  88. Clearance with 3" to 4" Flowmaster Merge back to 3" !!!(PICS)!!!
  89. Need Help T5 Keisler Trans
  90. engine is crooked after re-install
  91. Magnaflow quad tip with ORY and headers
  92. SLP Underdrive Pulley/balancer reviews?
  93. Anyone have a NW 92mm T/B stick open?
  94. Lq4 throttle body
  95. Raspy 383
  96. stock rocker tightneing
  97. turning crank for 1.850 rods
  98. quick exhaust question
  99. Difficulty of swapping LT header gaskets?
  100. Just got a Flowmaster 80 Series Installed...Question Inside!
  101. 92mm TB Suggestions
  102. Can I Do This?...
  103. new a/c, need advice
  104. 85mm MAf to Volant cai
  105. Should Texas-Speed make an OTA extension to their Td's???
  106. Tsp vs pacesetter headers
  107. Exhaust questions?
  108. lq9
  109. Coil pack question
  110. popping in exhaust
  111. intake manifold question
  112. 317 Heads for my 408
  113. valey cover bolt size
  114. Metal shavings low oil pressure HELP
  115. Best exhaust for my new setup
  116. Wiring Help
  117. head bolt felt loose when torquing to 70*
  118. rear cover seal install quesiton
  119. Free Ram Air
  120. Help me make a custom Y-pipe
  121. Broke exhuast manifold bolt
  122. if i already have the slp induction kit, should i buy a chris1313 or FTRA
  123. reduce LS1 power steering pressure?
  124. exhaust cutout muffler option
  125. Any companies make 3" I/over axle pipe by itself?
  126. For those with TSP X PIPE and DUMPS
  127. adjusting TSP duals with lowering springs
  128. Kind of a noob at headers..
  129. Carb style TB or TB elbow
  130. LS1 vs LS6 intake manifold
  131. Quick Alternator Question
  132. AIR Removal after header install?
  133. 2001 ls1 motor price?
  134. Air intake to MAF fitment question
  135. About to install LT's & !AIR/!EGR?
  136. poly motor mount ???
  137. help needed to restore procharged car back to N/A
  138. Header Studs
  139. 02 LQ4 intake?
  140. Welding injector bosses on Performer RPM intake?
  141. Vibrant bullet race mufflers
  142. TSP dumped true duals to full rear exit exhaust kit?
  143. umped true duals to full rear exit exhaust kit?
  144. Port behind Air Filter
  145. relocate coils
  146. Intake?
  147. B&M Shifter for my 98 Z28????
  148. Car dying at Low Idle and throwing codes.
  149. Good idea / safe to replace front O2s?
  150. Kooks EGR block off plate
  151. manifold and fuel rail install
  152. Help Assembling Engine, LS6 Build, First Timer.
  153. Exhaust question 98-2002
  154. Now With Stainless Works
  155. Power Steering Bracket in Billet
  156. Suncoast Creations airbox + LS3... is it possible?
  157. New TSP Stainless ORY not fitting
  158. pulley question
  159. Looking for this piece of piping...
  160. weiand intake bolts are they the same as the ls6
  161. 16 volt setup
  162. QTP y-pipe question/options
  163. 5.3 heads on ls1?
  164. Truck starter question
  165. How much more effecient is a dyno tune over a mail tune?
  166. Alternator only kit?
  167. New GMPP Camaro valve covers - Made in USACHINA
  168. Need a Bullet style muffler
  169. What's a good 3" resonator?
  170. Cheap Dual Mode Exhaust?
  171. TSP Headers & Y install pics; FINALLY
  172. FTP 98mm lid + gm 85mm maf + 92mm tb
  173. Help!!!!
  174. F-body fuel lines
  175. sorta dumb o2/tune question
  176. Rear 02
  177. Complete Bolt size List for ls1
  178. part # help
  179. question about a ls6 intake map sensor
  180. TSP DUALs outta stock until late december??
  181. Help
  182. 1 7/8" arh HEADER INSTALL BY RPM
  183. Lq4 intake
  184. Finally!!
  185. Need Oring for Oil level sensor
  186. Help With Header Bolt Hole
  187. Nitrous express throttle body...anyone seen it?
  188. TSP Y pipe issues
  189. P0332 code driving me crazy!!!
  190. Best price for poly mounts?
  191. True dual question
  192. Head swap questions
  193. SLP Loudmouth resonator on stock exhaust?
  194. Fixed my Exhaust hanger problem.
  195. fuel rails (anyone use these?)
  196. Cam shaft choice
  197. How much should I expect to pay for a custom exhaust?
  198. Modified Intake Idea! Input welcome
  199. ebay SS headers help*
  200. Quiet Muffler Help
  201. Question regarding DMH cutout with a flowmaster muffler vs stock muffler
  202. How much gain if any?
  203. Broken PCV Fitting on Vortec Manifold
  204. engine wiring harness?
  205. Chris1313 Ram Air Fitment Issues
  206. I hate to post this but.... PCV question.
  207. SLP Air Lid
  208. 317 heads!
  209. muffler options for the 5.7 corsa?
  210. T56 C5 97-04 and T56 Camaro/Fbody what difference?
  211. 2.5 inch exhaust too restrictive??
  212. L92 and TBSS?
  213. DMH electric problem...
  214. Squeaky pulley?
  215. clamshells
  216. Who makes these pulleys?
  217. coil packs
  218. Thoughts on Moroso spiral mufflers compared to bullets and sweet thunders?
  219. Custom low budget cross ram intake
  220. Getting my POTZ eBay P&Pd Throttle Body & MAF Ends tomorrow... reviews?
  221. Reposting this, requesting it be a sticky
  222. Craigslist 243 head questions
  223. LS6, FAST 90,92 or 102???
  224. Help with converters
  225. Edelbrock Shortys, Catco Cats, stock Y-pipe, SLP LM1: in progress. Review within.
  226. Where to get FAST 78 Ported?
  227. are me weiand intake bolts the same as the ls6
  228. is my TB damaged?
  229. HeadStuds/Bolts Which to use!?
  230. ? about what i believe is a coolant crossover
  231. stock heads ls1 hp limits
  232. true dual crossover nessacery?
  233. Crane springs?
  234. Under Drive Pulley
  235. H/C LS1- ported LS6 or Fast 90/92
  236. LoudMouth 1 modification options / opinions
  237. Fuel Line flip mod
  238. 1 3/4 to 1 7/8 v. 1 7/8 LT's
  239. Lid Or Cone on Throttle Body?
  240. quick question
  241. Weiand lingenfelter vs PP Typhoon Intake
  242. back to front o2 wire switch.... HELP
  243. 243 heads work on LS1 with stock cam?
  244. True Duals ? w/ Magnaflow 6" Round Mufflers
  245. Body Techs and knowledgeable people please give me your advice
  246. What size exhasut pipes?
  247. Who has done this? Really confused!!!!!
  248. Anyone running headers & Y pipe through Stock SS Muffler?
  249. Modded TSP Offroad Y pipe
  250. What size header reducer needed? Stock size is?
