View Full Version : Generation III External Engine
- Quick Question!
- How to strip paint on uncoated headers?
- Best place for catylitic converters?
- Can Headers cause this
- LS1 280Z
- Jet hot lt's in!
- looking for exhaust tips
- crank f*ck up! help!!!!!
- Owners of Whisper 1 7/8" Headers inside please
- ASP pulley or FTRA? Which mod to do first?
- when will a new intake arive?????
- why does my 02 sims blink on and off with a red light????
- is my water pump ok?
- Loudmouth?
- new memeber z28
- Top Engine Cleaner???? Little Help Please.
- Catback or Muffler only?
- how would I get more spark?
- Dyno before and after with Pacesetter LT's???
- LS6 Maf conversion
- Hooker catback or Magnaflow catback?
- exhaust suggestions for 00 Z28
- jet hot lt's going in tomorrow!
- Mustang vs. Dynojet
- wuts a cut out
- need to make exhaust louder
- header suggestions
- mufflex catback owners come in
- ported/polished tb hp/trq gains?
- Proform Shiftlight
- Pacesetter long tubes, y-pipe, and magnaflow.
- Just ordered new Edelbrock longtubes
- spintech exhaust
- Need Bolt-On help
- Aftermarket warranties? Which is the best?
- Want a Deeper Exhaust Note
- will flex pipe work for making dual exhaust setups?
- kooks just came in!!!
- Anyone running the K&N kit?
- crank pulley removal
- Air conditioning problem--huge leak!!
- where can i get some mandrel bent 90* bends?
- Removing A/C how hard?
- Big cam = no ASR?
- ASP pulley is on, runs hotter
- Where can i get a cut out cap?
- Exhaust??????
- DO U LOSE POWER????
- whats wromg with my 160 stat
- Cutout wiring
- Wiring question....
- Exhaust Installation
- WHAT IS THE BEST LID FOR MY 01 Z-28
- flp headers
- looking at light weight battaries.
- I need Belt Sizes ASAP
- Which PCV soultion ???
- EGR question
- Just installed LS6 intake, Z06 injs, & LS6 PCV + EGR Delete.
- squeeky problem! PLEASE help
- headers
- What's the best way to...
- Is my et slow for my mods?(9.019@81.142mph) 2.107 60'
- Stock MAF or SLP MAF?
- Powershot filter cleaning
- Where to get a y-pipe for hookers?
- FTRA+Lid questions
- Anyone with SLP LT'S
- the best plugs
- Can I do this since I have a metco breather?
- Mac Collector Location
- Y PIPE??????
- Radiator cap question
- No Y = Car Fire
- will electric cutout make loudmouth louder
- slp 2otl
- Metco breather...good or bad
- What y pipe for dyna tech headers?
- post a pic of 2OTL on T/A
- Suggestions On A Muffler
- Came Upon SOME XTRA $$$$
- Just did the free ram air mod!!!
- will LS1 borla fit on a LT1
- If your post is locked - Read Here
- What is the best LTs for a lowered car?
- need "Top End Cleaner" advice
- Are my dyno numbers up to par?
- Tore up FLP clamps with iron block setup....
- Headers......on Ebay, but still.....it's a killer price
- Anyone running the Jeg's harmonic damper
- Crank pully size...what is better?
- What are the best times for A4s w/ bolt ons and DRs
- Just added Jet hot header and off road Y & dropped 2mph
- back of serp. belt wearing away after asp
- Where do these ground wires go?
- SLP loudmouth Duel/ Duel yea or nay
- True dual pictures
- Starter Solenoid HELP!!!!!!!!
- Car is Running WAY to Hot Hot Hot..........
- Has anyone problems with justin sutton sending parts??
- How do I know if pully needs machined??
- what muffler is the best...X-pipe involved...Opinions please
- HOLY Crap listen to this exhaust by GMMG inc.!!!
- Pulley replacement......
- Need info on short belt for our cars
- What have you heard about ported MAF ends
- Exhaust collecters?
- Purpose of the EGR?
- Kooks or Jet Hots GP???
- Extreme Volume Video of QTP Headers
- Corsa on the ground, need some advice...
- will a 01 whisper lid fit a 99
- Need help with smooth bellows FAST!!!
- Exhaust backpressure???
- aftermarket valve covers
- Bad coil pack......What are the symptoms....................
- No AIR/EGR Race headers and VET testing?
- Disable the converter lock-up
- EGR or no EGR, that is the question....
- Y pipe/cats with dual cutouts
- Gains from LT headers inside
- Okay to Get LS6 Manifold at a Junkyard?
- Can header and Off Rd Y cause my car to ping (run lean)
- Ported Throttle Body ???
- Error DTC P0782 2-3 Shift Malfunction?
- looking for ideal location for Autometer water temp sender.
- FLP Install
- update...
- How can I block off the EGR on my intake?
- help with pullies
- Hesitation / Bounce Problem HELP!!!!
- Where is the link to the "free" thermostat mod?
- Wahoo!!! LS6 Intake Manifold
- Are 99s different
- bauer TB
- home made smooth bellows
- Electric Water Pump
- SLP headers or Hooker headers or Jet hot headers
- GMMG.......
- What do you guys think about the new ls1edelbrock longtubes
- Line lock question?
- Pressure test coolant system; need to remove thermostat???
- Which air lid?
- WHERE TO GET LINE LOCK?
- McCord Powerplate
- What bolt to seat stock crank pulley?
- 1 3/4 or 1 7/8 headers
- Where is that post that has weights of everything
- My belt squeeks bad when I shift at high RPMs
- First time on dyno
- need to swap out my SLP LM....SLP DD or Hooker???
- SLP Air Lid Rubbing, HELP!
- Where can I get TR55's and LS1 edit fast
- BRINGING CAR IN FOR PISTON SLAP NOISE!
- Anyone running the CAT damper??
- LS6 Intake Leans Car
- how much power am i missing ?
- New dyno #s with the better exhaust 707.0 rwhp 721.8 rwtq
- Pulley install,.. remover tool "nipple" is stuck in crank
- exhaust exiting in front of rear wheels
- Mufflex Y-Pipe and Hooker LT question.
- thre belt off without spinning high rpm's???
- Belt is walking off pulleys......
- Electric Supercharger? Do they realy work?
- where do i get coil relocation brackets?
- Problem after TB Bypass HELP!!
- Which Stock MAF Would You Buy?
- GUYS WIT
- For those of you that have Hooker LTs
- x-pipe
- Solid motor mounts, pros and cons
- the best set-up
- How important is the MAP sensor?
- removing WS6 Hood Baffles
- went to track last night..WTF!! pleaassee HELP!!
- just put a new catback kit on a murcielago
- true duals with stock manifolds??
- Volant induction VS aftermarket lid
- How to Re-Fill Coolant
- Ls1 Coil Packs
- name this part
- How to remove the wiper motor, and linkage?
- Anybody try the new Edelbrock headers yet?
- ASP pulley wobbles at idle
- Long Tube Headers
- New Member
- Poly motor mount question
- QTP's over JetHots - Is it worth it ???
- exhaust question, fast replies please
- Just received QTPs, that collector on the Y is huge!
- ASAP: Which Wire is the Signal Wire for the Oxy Sensors?
- Are Ram-Air Systems Worth the $$$?
- spohn torque arm doesnt fit!!!!
- Another TB Question: CFM?
- Anyone with the SLP 345 lid remove the AIR pump?
- Anyone ever heard a Bassani ???
- Carsound Cats
- What would I benefit more from??
- Bolt ons
- Hooker Aerochamber
- GUYS WIT HOOKERS OR JET HOT LT'S
- looking for loudness
- Anyone Have ATR Exhaust on SS?
- Where can I get a new gasket for Weiand/Holley intake ?
- need info on C5 intake installed on a f-body.
- Any need for vacuum lines on intake with no HVAC?
- t'stat ?
- TR6 gap on 422ci+power adder??
- Anyone know the sound of SLP Dual/Dual with headers?
- pacesetter?????
- Who makes larger radiators?
- Cats Gone Bad
- Hooker headers and Y-pipe
- SSRA vs. Downpour
- pulley squeak????
- People that have had your car dynoed...
- DMH ELECTRIC CUTOUT OR MPP2
- looking for soundclip, (x-pipe and borlas)
- So here's my new dyno...
- Flo header install
- Changing Cat's to o/r pipes question
- Should I.....
- high flow cat or O2 SIMS?
- What's the stock Throttle Body size?
- new headers, now new problems...
- 3 BOLT FLANGED ON JET HOT LTS?
- Dealership found "nothing wrong".... Advice?
- i must be stupid. cant install airlid :(
- How to replace front 02 connector?
- FTRA- WTF did I do wrong??
- Flowmaster Collector
- going to track soon. need help quick
- Part # for Goodyear Gatorback serpentine belt for our cars?
- any new dyno or track info from that new lid?
- Need quick info on vacuum hoses for LS6 intake....
- Dual Exhaust..Best Place to Buy???
- How to spend $450-$500.
- Best pulley kit to get?
- are you guys still running with your warranty
- Thoughts on FLP electric cutout?
- Anyone running Borla XR-1's?
- GMMG Install?
- Help me kill the rasp!
- NO EGR on 01-02 Reasons?
- Underdrive Pulleys bad according to HPP
- heavy voltage drop???
- Ideal Location for Cutout
- deleted
- how much gain for removing cats?
- Throttle Body "Drilled & Epoxied"
