View Full Version : Generation III External Engine
- drivers side lower alt bracket?
- Carb Intake manifold question
- Single chamber flowmaster
- Eliminating the EGR
- ls6 vs fast 90
- thinking about fast 90/90
- new LPP headers install on a camaro
- Cai K&n Fipk
- CME horespower?
- Buying mods, have question
- ls1 3-5 wire maf/ait adapter or lt1
- Spacing accessory brackets??
- Trying to change Valve Cover gaskets on a V6... Need Help!
- best street legal headers/ypipe combo?
- what else do i need
- Weird issues with new intake
- how off would my tune be??
- Freeze plugs, oil galley plugs..number ,part number
- Question for Magnaflow or anyone that knows
- Bad Map Sensor?
- Clip of the new exhaust.
- Broken Sensor In Back Of Motor??????need Help
- Manifold Removal
- How much does the SLP Y-pipe weigh?
- Catback setup question.......
- LT1 Radiator <1" core?
- best place to buy ARH
- slp cme tips , should i sell?
- Pacesetter Long Tubes or TSP Long Tubes???
- Do I need to keep my MAF sensor if I'm going FAST 92/92?
- What Happened to MTI?
- Whos running an engine oil cooler?
- what do you think of this exhaust combo
- Still Needing Help
- I can't stand a thief
- mass air sensor screen
- another catch can ?
- Anyone running a Dynomax O/R Y?
- Can A Lt Headered Ls1 Pass Emission???
- EGR block off at the intake
- 98 camaros/ta's intake
- Rocker Arms and push rods?
- Would a 1/8" gap between my TB stop and linkage effect performance that much?
- Can't figure out what exhaust setup would make me happy.
- 5.3l or ls6 heads?
- Exhaust setup
- exhaust
- need opinions on my exhaust. help!!!!
- Would this kill hp?
- TSP 100mm maf on this setup
- Coating SS Long tubes?
- Sweet-Thunder on a v6?
- Need some exhaust help
- Exhaust piping
- o2 bung on true duals
- ARP Header Bolts
- flp headers what y-pipe to use?
- slp air box lid
- Routing of AIR and vacuum lines
- map sensor
- too stock, help...
- Any sponsor able to sell Pacesetter LT's for ~$300? Want to support sponsors
- Cheap MSD Wires w/plugs... which sponsor was having the special?
- Idler pullys that don't squek? Very tired of hearing mine.
- Spark knock from old spark plugs
- Soldier in Iraq needs help
- LS6 Heads and Cam
- AR Headers or SuperMaxx headers
- 0 gauge wire for battery relocation
- SS Autochrome on C5
- LQ4/6.0 valve covers with LS1 coil brackets?
- Just finished my LT's, ory, and GMMG install
- what is this sensor?
- misc picture request
- dual exhaust help.
- More questions!!!
- need some help/timing chain
- what to do 5.3 swap
- need info on CME!
- Headers
- intake question
- Put on new parts
- What is actually "ported" on LS1 Ported throttle bodies? Pics?
- duals or y?
- Ported TB epoxy?
- AIR Solenoid Diagram Questions
- LS1 Oil Pan Alignment
- What muffler are you using with your CME?
- Bullet Cat for emissions help!?!?
- GMMG, LT(with CATS)=Worth it??
- ls9 intake
- lift engine for long tubes?
- Need Imediate Help
- oil leak at track. don't know where from
- pacesetters are on! have a few questions
- ???real quick question????
- Power Windows And Radio Aint Working Help.....
- Will 85m vette....
- Pulling my Motor
- cutout or no???
- Best Y pipe ..
- LS1 Exhaust port flange spec?
- ported throttle body ,now a po507dcode
- New Exhaust Hand built by me!
- Pics of over the axle TD chambered mufflers?
- Need Heads
- Full Access to Installation Information
- SLP fan switch isntall, Help please!!
- 160 stat in a 99 ls1?
- Any tricks to getting discounts @ GM dealerships for parts?!?
- intake manifold swap?
- how to mount dual cutouts?
- H/c C5 with straight pipes!
- LPP LS1 Stainless headers and Y now on Sale
- what should i do w/ my slp loudmouth after lt's and ory?
- Help-Headers-Not another which brand haha
- I Need Instructions On How To Wire My CutOut
- what throttle body with 92mm fast intake
- HELP what throttle body should I buy???
- Installing map sensor
- Is it the Borla muffler that sucks?
- How to test crank position sensor?
- Just when you want things to go smoothly
- Cutout sizing help!
- What muffler to replace my Flowmaster?
- Ftra
- Man how much a cracked y-pipe hurts!!!!
- Cherry Bomb Crossflow Muffler
- quick question about hooker
- Installing QTP headers & Ypipe - what small parts do I need?
- How restrictive are OEM LS1 mufflers?
- Heres A Poll To Give Your Thoughts On Two Cams
- How to keep ARP crank pulley bolts tight?
- What length bullit muffler
- coolant boiling at about 210
- tsp true duals not fitting..plan b?
- Where to get breather
- American Racing y-pipe with Kooks headers
- SLP Part # 23060, is it the 85mm MAF?
- WHAT CRANK PULLEY SHOULD i USE ON A LS6
- true duals with cats?
- Getting a whine noise that increases/decreases with rpms...
- 92/92 Intake & TB Question
- ARH headers installed
- Underhood Temps with Stainless LT's
- 2001 Corvette Borla Headers for 99 Corvette LS1
- stupid flowtech headers
- Will headers cause
- need opinions for catback
- where is the best place to get 02 sensors...cheap!
- Finished the 100MM lid (with pics)
- ? for those with gmmg and cme tips
- Those With Cme And Gmmg
- ???which Exhaust Is Quieter???
- Installed a Powerstick on my LS1 today, stock manifolds/cats
- Heater core?
- Anyone selling stock ws6 exhaust?
- Those with K&N fipk, come in.
- Thoughts on engine build?
- need catback opinions please
- Getting my magnaflow muffler tomorrow!
- has this happened to anyone else with their LT's?
- which pushrod with this cam?
- Longtubes for my c5 z06
- What Other Mods/Bolt-Ons Can I do?
- Help won't run right
- Looking to paint my 6.0 408 iron block temp of paint..
- Would this cause my belt to come off?
- coolant crossover pipes?
- Can Mufflex be bought with a borla muffler?
- scorpion rocker arms?
- y-pipe question
- How Much Will A Catback Hold Me Back?
- Kook's vs B&B Headers on LS6. B&B Really 20HP More?
- 408ci vs 440ci Engine Build (Suggestions/Opinions)
- ARH Install Experience
- t.b. bracket
- 4" Exhaust Connectors
- installed my ls6 intake
- ati balancer for gto
- 03 zo6 ls6 intake about to buy..
- Breathing DEEEEEP!
- starter ?
- pully squeel
- what adapters needed for ls2 rails/injectors
- Power Steering Pump bad?
- Which ud pulley
- Vr Jr Intake manifold
- part number for power steering
- power steering help
- Exhaust Temperature Difference
- Burned up my alternator at the track on friday.
- WS6 and Cold Air Intake or Lid?
- what kind of spring compressor
- fast 90 install Q's
- HP numbers?
- ???waterpump To Bleed Coolant???
- What connection is this?
- What happened with the Speedtweekerz raffle?
- DUALS DUALS DUALS lets see the pics!
- What Intake Should I Go With??
- FAST intakes
- FIPK2 Modded
- Changing plugs..
- ls2 6.0L Valve covers?
- My dyno numbers.....
- I have a couple of questions about T-Rex cam
- Alternator Overdrive Pulley?
- NEW UD pulley, What Bolts can I use
- cutout location
- What lid to run with fast 92/92?
- Question on throttle bodies
- Anyone have Flowtech y-pipe pics?
- mac mids
- Corsa installed, Not happy
- Urgent!!! Need a new muffler!
- ??? about ls7
- Wrapping Shorties.
- Meziere Installation Problem
- Pacesetter LT w/Jet Hot Coating
- Clutch Pedal pushes up toward foot @ high RPM
- Mac Midtube Headers?
- headers rubbing?
- cheaper single chambers
- LS1 VS 6.0 Headgasket
- Header swap from the top?
- what did you gain from your longtubes?? and a few questions
- Help on weight of 6.0
- Do any sponsors carry Mufflex products
- heater hoses
- Seconday AIR Injection Help - *Pic*
- True duals?
- Latest CNC ported/patternd TB's in stock!
- EGR code P0401
- How can i make my magnaflow louder?
- Return my Kooks ORY for catted Y ?
- Ory??
- Coolant lines under fast 90 manifold?
- IAT Resistor
- new valley bolts for fast 90?
- Muffler baffle blown out
- Car is popping out the exhuast???
- ARH vs Pacesetter, price/performance...?
- true duals all the way out
- magnaflow?
- underdrive pulleys?
- cutout
- moving and might need cats
- slp ls6 intake manifold??
