View Full Version : Generation III External Engine
- Cutout Info Needed
- car starts then dies
- what does this code mean
- Coolant leak?
- coils have rust/corrsion on them? wtf!
- changed oil, now a new noise!
- I Just Spent The Last Hour And A Half Of My Life Polishing My Headers....Why?
- Which longtubes have the most ground clearance?
- Best way to clean the blocks deck?
- Which Y for stainless works Headers?
- Exhaust has me puzzzled
- qtp hvmc's install passegners side touhching k-member arggg :(
- ASR problems (can't turn off or on) light is always on??
- Need Some Help.....
- LT Headers... the driver's side bitch...
- Pulleys
- Forsakened LS6 Intake?
- best header fasteners?
- 02 Sims--where to buy
- any how-to on Kmember installs?
- installed ls6 intake manifold now it revs to 2k rpm...wtf???
- DMH Cutout!!
- vibrations
- ATI balancer-what belt?
- Poll: For Pacesetter LT owners satisfied?
- Lid problem?
- I need an LSX intake........where do I get one???
- Cherry Bomb on Fbody ???
- WTF that wasn't supposed to happen...
- valve springs to use
- Fast 78 Vs. Stock Ported 78 TB
- what sensors for edelbrock ign module
- trickflow heads on tsp 408
- Oil in TB
- pulsing vibration???? WTF
- ARP header studs
- Idle and stalling issues
- *Other* catback owners/reviews ONLY!
- True duals owners/reviews ONLY!
- Magnaflow catback owners/reviews ONLY!
- Borla catback owners/reviews ONLY!
- GMMG catback owners/reviews ONLY!
- SLP catback reviews/owners ONLY!
- Need Info On Sheet Metal Intakes
- Dynoed my HCI 98 Z28
- WTF? P0480 and P0481
- valves vs spring pressures???
- which catback?
- pining a ATI crank pulley.
- Corsa Catback Installed!
- quieting car down
- Cam sensor
- Gen 3 alternators
- What style muffler is this?
- Anyone have a set of LS6 intake bolts laying around?
- Ws6 Hood Hp Gains
- quick ory question about o2 sensors
- Edelbrock Heads valve question
- Crank Pulley install question.
- Are Stainless Works Headers good as Kooks?
- spark plug wire question quick please
- Can't get fuel line off!!
- just installed slp cai
- header bolts from napa, anyone use them?
- how much would this set up dyno
- Dash Lights Pulsating???
- I'm bummed...
- exhaust after header question...
- Ok need some manifold encouragement
- Flowmaster muffler with a Bullet in the I pipe?
- Ls1 Coil Rail
- ATI super dampner Question.
- New Era PTB....Now NO CRUISE???
- Jut put on my ported thorttle body!
- typhoon manifolds
- Best ground clearance?
- Throtte body for 96mm Typhoon
- Stock exhaust pics!
- Installing my Loudmouth i got from New Era Performance
- Hooker quad tips...
- LT1 to LS1
- SLP Lid problem
- Lose TQ with TD's?
- FAST 85/85 Track Results
- ARP Studs or Stage 8 header bolts?????
- true duals-vs-borlamouth catback
- HELP!!!! Mount Question
- Coolant level problem when cold
- what should i do?
- Did a Search--LS6 Intake!!!
- Is this a good price??
- Crank Pulley Help!!
- LSX? What can they do?
- Smooth Bellow Question
- Can't decide...what do you think?
- Help! Need to fit 3" round tip to GMMGs!
- Air intake elbow??????
- Ahhh! No A/c!!!
- Considering a QTP Cut-Out...will it effect AFR?
- Blackwing Lid?
- race style pacesetter header install
- are 1 7/8 headers overkill on mild cam only
- dual springs now..
- power steering
- Tach not working and hard starting.
- Question about header/ory
- New to California, Emmision ?
- Pacesetter's ordered today
- Video of my newly installed Pacesetter LT's - TPS Catted "y" - LM1
- Help o2's
- rwhp #'s?
- Short Belt Question? How to bypass power steering
- exhaust leak question
- got a few questions
- Which Edelbrock headers?
- Valve cleaning
- center exit exhaust?
- pacesetters uncoated
- Any guesses on new gains ?
- Headers work with GMMG exhaust
- uncoated pacesetter ?
- Help o2's
- PCV Delete
- Damn AIR System....
- 420 HP After tune What NEXT??
- Best coil pack relocation setup?
- ? about painting H2O pump bell housing
- Ordering Jet-hot headers
- Stock Catback Quick Question.
- show me your exhaust tips
- Compression ratio for camaro
- Getting rid of bullets thinking about oval magnaflows...
- pcv hose part numbers
- evans vs meziere
- Chocotaco
- Stainless work headers question
- Cleaning and polishing jet-hot headers?
- to remove or not egr?????????????
- sweet thunders vids please
- i have a wierd exhaust question
- finding Shaner throttle bodies
- Thinking of duals read this
- fast intake
- Full Underbody Pic Of Exhaust?
- How U tell its a LS6 intake
- Mac mids collector size???
- the 02 vette came stock with a ls6 intake correct?
- Glasspack
- [rant] Fkn Junk Taylor Wires!!!
- HELP!!! 90/90 change gone awry??
- NEED HELP 90/90 change gone awry!!!
- Came Across A Great Deal!!!!!
- Kooks OR Pacesetters
- 98 z28 pcv valve?
- Screw size for IAC and TPS?
- ls1 air box hood clearance
- fan relay
- People with true duals....
- Bassani BX Exhaust System Dual System w/''X'', Dual Rear Split Exit Anyone Have this
- 28'' Bullet
- What motor mounts and where to get em?
- LS1 Intake And Race Headers???
- Sponsor With The Best Exhaust Prices?? =-D
- Just installed my single chamber flowmasters
- High Flow Cats
- Magnaflow replacement muffler
- A/C delete guys
- 02 simulator question
- Anyone cruising around with no AC Belt
- EGR/AIR blockoff plates
- gmmg exhaust with duals?
- Electirical Essues!!!
- LM1 and cats, or GMMG?
- so i took the cat off my LM setup
- SLP induction kit-is this normal?
- Need help with exhaust parts
- stepped header vs 1 7/8 all the way
- Grinding Ribs on LS6 Intake, Pics?
- is this the cruise control cable?
- I blew my Corsa up...?
- POS Serpentine belt problems..HELP!!!!
- pacesetter header and qtp y pipe
- Question for Guys with Single Chambers or Two Chambers
- Video of my car w/ Pacesetter LT's, ORY and LM2
- Need opions for the best bang for the buck.
- edelbrock victor jr intake
- Corvette o2 sensors
- Best sounding catback w/ORY is now the best looking too!
- My plugs are fouled, pass side head cold?
- Need Torque Spec for Proper Tightening of Katech Tensioner
- Borla or Corsa
- Dual disc clutch. Need your opinion
- Borla or Corsa
- Fans Not Working Help!!!!
- 2 bullets, 4 bullets or 2 bullets with mufflers...
- Fouled plug?
- Is this the same Magnaflow muffler as in the catback?
- Exhaust gaskets
- 5.3 Center Bolt Valve Covers
- underdrive pulley
- header gasket question
- Exhaust/Muffler question....
- Need some help peeps!
- Finally got some vids of my LM2 setup
- Guys w/ the TSP Rumbler, how do you like it?
- Anyone Know What Kind of Heads These Are???
- Throttle body Part# question
- Throttle bracket for FAST LSX 90mm
- Help on pacesetter header install
- Mount Problem
- o2 sensors socket needed or wrench ?
- Smooth Bellows instead of Fernco
- Can an inexperienced person fabricate over the axle pipes? (welding cutting)
- side exit exhaust camaro
- Which Cat back on Stock header and Y-pipe
- TSP TD's w/dumps = LoudAsFuk!!
- When is an oil cooler needed??
- attn LTs and TDs all the way back... come inside
- Cures on Y bang
- Straight pipes/no mufflers?
- just a quick question about borla
- Is it worth getting a 80mm TB when intake is only 75mm?
- Cold air & ram air?
- efi throttle body for victor jr or gmpp ?'s
- occasional miss
- ~Some Advise~
- pacesetter race header fitment
- Baackfire and flames shooting out the tailpipes...what's going on here??
- Exhaust Problem
- LS1 and LS7
- Bull Tongs (pictures)
- MAC question
- Shorty Headers worth the $$??
- Thread Lock on Oil Filter and Plug?
- GM part numbers
- LS1 Corrosion
- 85mm Throttle Body guys in here....
- how does this muffler sound?
- My New Y-Pipe Arrived!!
- Incorrectly poeted tb causing bad idle????
- Need Help! Please Give Your Insight On Motor Issue!
- Inside of Magnaflow factory replacement muffler?
- Getting ready to install LS6 intake... Any suggestions?
- SES Light & AIR removal
- Kooks Or Qtp???
- O2 Simulator what do you think?
- how well does this work?
- Ok fellas today is the day!
- help pleas guys
- Air system
