PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 [243] 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Pro-M out of business...who else makes a 90mm MAF??
  2. BBK 80mm LS1 Throttle Body????
  3. stock tach cant keep up
  4. My header install experiance
  5. New GMMG's with a cut out.
  6. Borla = Quiet enough?
  7. Oil leak from the filter..help
  8. stock thermostat opening temp
  9. O2 Extensions
  10. My True Duals Under the Axle
  11. true duals??
  12. Throwing Codes even after tune?
  13. After Magnaflow install
  14. car run one one o2 sensor????
  15. Need Exhaust Advice....
  16. Not sure where to post this question
  17. Water Pump Gasket question for 1998 LS1
  18. Hooker exhaust?
  19. WTF!!!!! Header install!!
  20. Intermediate Pipe
  21. do i need a tune after a slp header and cold air install?
  22. amw catch can
  23. What to do with my exhaust?
  24. LS6 intake/coolant pipe
  25. Does the GTO use the same pulley?
  26. Oil Cooler Question
  27. putting on headers?
  28. exhaust ?
  29. Strange noise when accelerating
  30. need louder exhaust...
  31. Why are more people not running the GMPP intake?
  32. GMPP Carb Manifold with EFI
  33. Lane's TD's pics
  34. Crank Pulley Questions
  35. pacesetters so easy
  36. plugs, normal vs iridium
  37. Those that have port matched your FAST 90mm intake manifold, who did it?
  38. what puller do i need for stock pulley
  39. just order qtp electric cut out some q's
  40. Intake ?
  41. Lsx Intake ???????
  42. MTI Tb
  43. Your Opinion Please!
  44. ?
  45. throttle stop
  46. slp quad exhaust ?
  47. GMMG installed...Impressions.
  48. fast ....
  49. cats or no cats?
  50. Anyone ever get dyno numbers or any proof that the Edelbrock headers work?
  51. " Bo White " Ported Throttle Body
  52. Engine Coolant question
  53. Which Kooks For Me?
  54. Brand new plugs... seafoam... ?
  55. MSD 6A Ignition problem on 1st gen
  56. Corsa
  57. MSD Wires tall valve covers Part #
  58. What can Brown do for you?
  59. Where to find DYNOMAX BULLITS??
  60. Pacesetter LT install Q's
  61. muffler/lm
  62. Do these tips look like the GMMG oval tips????
  63. TSP ORY exhaust clamp leaks?
  64. pulley's and long tubes
  65. Z06 LS6 Manifolds
  66. Y-pipe won't fit after recoating
  67. wooshing sound
  68. Coated Kooks?!?
  69. Ported MAF Sensor
  70. Y Pipe
  71. TD tail pipes and/or muffler swap to Magnaflows?
  72. Header guys....
  73. ls6 vs fast
  74. What size cats with coated Hooker ORY pipe
  75. True Duals w/Stock Manifolds
  76. Stock Y with LTs?
  77. SShorty headers
  78. cutout gasket???
  79. Has anyone ever done headers *AFTER* doing heads/cam?
  80. ASP Pulley on Back Order!?!
  81. once again exhaust questions...
  82. 2 chamber mufflers weight?
  83. ? About Kooks ORY Pipe
  84. My A/C belt slipped off and shredded!
  85. Just ordered Hooker catback...cheap $
  86. Header Dyno Comparison Request 1-3/4 vs 1-7/8
  87. TSP true duals
  88. QTP y-pipe????
  89. Starter tips?
  90. HELP! need ideas for y-pipe...
  91. K&N FIPK intake kit worth it?
  92. x pipes
  93. Kooks & borlas
  94. Glazed serpentine belt?
  95. Oil Pressure Help!!!!
  96. Tried a Search: 1 7/8" LT ?s
  97. those with TSP duals
  98. Texas Speed Cat Y Pipes Back In Stock & On Special!!
  99. The time has come, my friends...
  100. First Toy
  101. ported MAF's? yah or nay?
  102. 90/90 setup
  103. New exhaust...how to stop rattling?
  104. Im stuck Need Help ASAp
  105. Ticking noise after spark plug change
  106. rattling/chirping noise after Lt install
  107. QTP LT's | QTP Catted Y | GMMG Catback
  108. Simple spark plug question!
  109. Does the march pulley clear
  110. Couple questions.....
  111. Question about Flowtech cutout studs - problem with driver side cutout
  112. What size is the bolt that connects the AIR pipe to the exhaust manifold?
  113. Y-pipe with cats
  114. 80mm TB, will it make more power?
  115. Trying to decide on an exhaust...
  116. Weiand Aluminum LS6 Intake
  117. kooks lts and ypipe
  118. Coolant bypass ???????????
  119. gettin money
  120. Power Steering Pump (DELETE)??????
  121. Electric Waterpump??
  122. Any good X-pipes for 00 Z28?
  123. duals go on tomorrow 4/11/05
  124. Coil Relocation Help
  125. Help, SLP-Flo Pac Installation Question!!
  126. oil cooler
  127. edelbrock long tubes???
  128. Header Help
  129. How do I find out
  130. Spark plug gap?
  131. My 3" custom true duals clip
  132. Help me out.
  133. Cutouts vs. duals
  134. y-pipes
  135. engine cuts out
  136. ASP pulley wobble
  137. BBK SSI intake
  138. Making Stock O2 sensors longer (pic)
  139. Ignition? problem with new firehawk
  140. MAC to LT ? (About O2 Extensions)
  141. true duals
  142. how to eliminate Air
  143. wide open
  144. Figure this one out for me.....
  145. NE1 Have serious mileage on Iridium plugs?
  146. tsp true duals installed today
  147. Which 02 Sensors?
  148. motormounts
  149. o2 sensors
  150. throttlebody bypass
  151. borla xr1
  152. Pacesetter headers fitment
  153. Inline Water Pump
  154. Anyone's and Everyone's opinion
  155. FAST Setup In My Situation?
  156. multiple codes after lt install
  157. Anyone ever tried this exhaust setup?
  158. Anyone see this carb intake before?
  159. Would exhaust leak cause o2's to throw codes, idle/run rough, bad gas mileage?
  160. Flp Vs Qtp
  161. '02 SS tcs question
  162. Anyone ever modded their I-pipe for a bolt in bullet muffler?
  163. need help
  164. lt header inner weld?
  165. what site would show me how to install LTs?
  166. Want to trade my magnaflow Cb for something esle no flowmaster or LMS
  167. Need to replace o2 sensors (p1153 and p1133 codes) where are they, how to replace?
  168. Squeal-Be-Gone
  169. Weird RPM problem
  170. Would bad O2's cause rough idle and crappy gas mileage
  171. Flowmasters dont flow.
  172. Flowmaster D-Port Scavenger pipe
  173. True duels or Borlamouth
  174. pipes banging
  175. WHY does a car run rich after header install?
  176. Zed cutout/Dynomouth
  177. Clean or replace valve cover breathers?
  178. Best method to check for exhaust leaks?
  179. Manifold and Headers
  180. Fast 90 with 224 cam... too much?
  181. 400rwhp possible with just bolt-ons?
  182. Y pips to cutout problem
  183. WOT=rattle
  184. Header studs where to get em
  185. New Car Comes With New Car Problem, Help Please
  186. Borla XR-1 VS High Flow cats.
  187. C6R Intake....
  188. Yet another Pacesetter question.
  189. car misses sometimes but goes away....?
  190. Lm Vs Gmmg
  191. LS2 or LS6 intake?
  192. Maf
  193. Air tube conversion
  194. Problems with stock tach
  195. Searched... Underdrive pullies. Anyone with proven gains?
  196. Fast LSX 90/90 installed
  197. March Pulleys
  198. Another x-pipe ?
  199. March Pulley installed...
  200. What ORY fits the MAC mid's?
  201. Will Pacesetter LTs work with a Hooker ORY?
  202. Opinions needed on upcoming setup
  203. True duals with Flowmaster single chamber mufflers??
  204. Pace Setter Coating
  205. Why Are Coil Pack Relocation Kits Necessary?
  206. Which maf Pace 85mm "ls1 calibrated" z06 or SLP 85mm?
  207. banging in floorboard for exhaust clearance??
  208. peice of catt stock in gmmg
  209. Stock y-pipe ground clearance
  210. plugs and strokers
  211. Exhaust cut out
  212. Electrolysis problem with Aluminum Head?
  213. Electric cut out
  214. V/R Velocity Stack
  215. QTP vs. LG headers
  216. Firebird Side Exhaust Idea
  217. Flp
  218. Anyone thinking about Corsa...come in!
  219. bolt on questions
  220. NGK TR55 problems?
  221. Cutout questions!?!
  222. Tsp Ory????
  223. LS6 Intake install questions..
  224. New headers and True Dual install...now missing out...HELP!!
  225. 98 TB is diff then exceeding years?
  226. Be Cool radiators
  227. crank pulley???
  228. tb porting???
  229. Just installed raptor shift light, 2 questions!!
  230. Header bolts
  231. What is this thing? (pic)
  232. O2 question
  233. my B&B TriFlow soundclip (no cats)
  234. Banging Floorboard - right under my feet, what is it?
  235. Ignition help
  236. LS6 and TB??
  237. Another BorlaMouth Sound Clip
  238. LS1 Bassani SS high-flow catted YPipe
  239. Driver Linkage
  240. Exhaust Help Needed?
  241. Changing Exhaust, Will It affect Gas Mileage?
  242. Does scraping your y-pipe set off knock sensor??
  243. Need some help with A/C system...
  244. stock exhaust flange thickness
  245. Whats a good o2 for racing & n2o?
  246. Header Coating
  247. relocate engine fuel lines
  248. Are Stainless Steel Headers Impervious to Water?
  249. Merge pics?
  250. must read! stock bolts with qtp headers nightmare
