- what to get a 11.9 or lower....
- Has anyone tried this exhaust setup?
- dyno my car
- ****FLP LT owners inside please******
- SLP Headers
- O2 sim placement
- hypertech power programmer
- Lids
- dyno results suck
- True Dual vs. QTP cutouts
- Warranty Question
- Flywheel
- Hooker LT's and Offroad Ypipe questions and opinions
- How much does your Z28 weigh?
- BBK Headers
- Holley intake vs. LS6 intake?
- Anyone running a pace MAF
- After market valve covers
- A.I.R. Restrictor mod question
- loudmouth
- Spiralmax
- gutting the cats
- Headers???
- Does the Holley intake really work?
- Ok, time for true duals with x pipe.
- Does the BBK 80mm t/b work?
- Do Granatelli mafs work?
- How much of a difference as far as flow goes compared to 2.5" and 3" pipe?
- LM owners, step into this cell
- How to fix the FLP banging
- whats the best mod to go with next
- Missing at WOT! Plug Gap/Wires Ok??? Help!?!
- Need help! (Non-LS1)
- MagnaFlow Catback
- need some help quick
- coil pack relocation
- Starting Hooker LT install today, got a few questions
- Please Advise - SDPC Rollmaster Timing Chain/Set
- Please Help: Car starts then dies
- Kooks custom headers........
- looking towards a true dual set-up
- Question about stock SS exhaust vs SLP Dual-Dual
- Question after Hooker LT/True Dual Install
- FLP headers installed
- Repairing aluminum fuel line?
- What company is making the headers eveyone is getting now?
- Jet Hot is now selling their own design LS1 headers
- G-Tech Pro
- Mac header guys.
- mass air flow sensor
- Air Filters
- ssra or volant on a 2002 SS
- Best C-back W/hooker LT & ORY
- Lower air box question ?
- Removing Traction control
- Which Exhaust System?
- Want Smog Legal Headers
- ws6 lower air box
- SLP y pipe worth buying?
- ssra volant ? is anyone going to answer???
- Need help on next mod
- ssra or volant induction on 2002 SS
- need your opinions on this
- Which Exhaust System? (Catback)
- Opinions on HPP3 on A4 cars.
- Funky exhaust question..kinda weird.
- Does SLP LS6 intake still leak?
- Fuel system for 422 with n2o
- bypassing powersteering pump
- Racetronix intank pumps
- JBA headers (shorty) Are they worth it?
- GMMG W/ TR224
- Why buy the Hooker Catback instead of the Hooker Muffler?
- Perfecting the Hooker LTs
- thread lock or anti-seize on header bolts?
- Current discount on Loudmouth??
- Light weight Drag Batteries????
- to loud mouth or not to loud mouth
- ignition coil
- what next?
- car BOGS on takeoff
- what diffrences between SLP Cold Air Induction & FTRA & SSRA
- Tsb question?
- bolting block to engine stand ?
- DSL+FLPs?
- Misfires on 5 & 7.
- 98 Intake Vs. 01-up
- B&B triflow ?'s
- Header scraping with a lowering kit???????
- Shift points & rev limiter question?
- Fuel sending unit
- Testing injectiors?
- Hooker Catback w/ Headers/Cam
- Slp header bolts??
- Went to gut the cats and................
- cat back help
- Any Extra Power Swapping The Catback on a Heads and Cam C5
- Jet Hot Coated Hookers came in today
- Help if you have uninstalled Hooker (or any other brand)Headers
- do headers make a noticable difference in performance?
- SLP Header?
- what rpm are u head/cam guys running
- 1st timer needs tips on installing a Walbro 340 in a 00'SS M6!
- how long does it take to pull an ls1 out of car
- Bret Bauer: I want to buy a Throttle Body..
- Best place to get Dr. Gas 3inch universal X pipe
- Fuel Rail....98-02 Same?
- Dealer Warranty Info via SSDude
- ported MAF ends
- TB bypass option
- burning rubber at high rpm's? (not what you think)
- Fram, K&N, or Powershot?
- Disappointed in Poor Quality of Hooker Long Tube Headers
- Tb diffrences
- does a hypertech make a big difference on a ls1?
- are pulleys worth the money??
- Where to Buy Parts for an LS1?
- what are the affects without running o2 sensors
- Directions - FLP header install guide?
- My car and I are in a Fight!!
- Will cam help out....
- aftermarket fuel rail
- ATI damper pin kit
- True duals topic beaten to death again!
- Temp question
- Stock exhaust question
- NGK TR6 users:
- Dyno sheets for bolt-on cars
- How to quieten shifter vibration
- Best way to quiet down exhaust??
- Everybody with aftermarket Tachs come inside......
- Mods
- How much longer for G2's?
- Beat the hump out of the passenger side near seat... Yes or No?
- shift light help please
- Borla xr1's
- Need help installing SLP LT's please.
- TA DIES IN BURNOUT BOX!
- Odd Noises....
- Cant find the answers to true dual ?'s
- MAF ends causing rev limiter problems?
- Question about chirpping problem
- Need Install Pages
- Vette ASP pulley w/ belts
- How well do they flow and how much for Carsound Cats#94109?
- Best flowing 3" catback?
- Tired of Loudmouth
- Problems starting car, anyone have any ideas?
- header install = tick from exhaust
- Pics of X-pipe with XR1's??
- Will K&N filter cleaning kit work w/ Holley filter?
- O2 simms do they work?
- AIR tube lines
- Indexing the plugs...
- Problem with '98 belt tensioner?
- Throttle body..
- Huge loss of power going with stock cats over Carsound?
- Can I get LS1 Hookers directly from Jethot like LT1 headers
- How would this sound?
- Will FTRA cause any changes in AF ratio
- should I change my converter myself or have a pro do it?
- fuel mix up
- High Flow Cat?
- ASP Pulley bolt questions
- How bad do gutted cats sound?
- check this out
- Is FIPK worth the extra $ over lid?
- oil pressure problem
- Twin cutouts vs 3" true duals
- LS6 in stall/ no oil pressure
- my AN fittings are a leakin! WTF?
- Dynomouth Gains
- !FRA question...
- Question on Off Road pipes
- Do 2001 and Up Have EGR?
- using ls1 edit to delete the rear o2 sensors,will it pass inspection?
- Have strange problem with coolant temp... Need help plssssss!!!!!!
- Flowmaster has true dual over the axel exhaust
- Any effects from over-oiling a K&N filter?
- new Y pipe???
- gutted one cat
- Which Spark Plugs?
- how much hp is gained cutting MAF's screen
- Nitrous and race gas dilema
- EGR schematic?
- Metco driveshaft loop w/aftermarket Y-pipe
- True Dual In Car Videos >>>
- installing a LS6 intake today/HELP/FAST
- Who has stock dyno sheets
- Oil pressure hihg? 40 at idle and 80 at WOT
- O2 sim
- Couple of questions!!
- Homemade Thermostat? How to and what temp is best?
- Dyno Question
- where can i get a used loud mouth... any sellers?
- Dyno'd FLP cat's/no cats. Big loss of HP
- My car went into the sand traps w/o a filter or MAF screen and FTRA!
- Where can I get a good fuel pump?
- does slp y-pipe bang
- PLEASE POST PICS OF GMMG ON FIREBIRD
- RT Cats #703000's
- 98 Z Bolt-on Results and a Question
- Anyone used Dr. Gas mandrel bent kit with their macs?
- O2 sensor problems after off road y-pipe install
- LM Dynomax resonator replacement
- TCS Module
- Meziere electric water pump
- New Product - Urethane Motor Mounts
- Long tube header install instuctions
- Roll master double rollor timing chain and ASP pully.Does it fit?
- pics of air high flow lids
- How many Whisper 1 7/8" midlength headers were made???
- loudmouth really that loud?
- Y-pipe hitting floorboard
- Mac Pics
- TB Bump Stop Fine Tune
- Making a comparable exhaust to GMMG for half the cost?
- convertible and sfc???
- 5.3 Truck Intake
- Crank Pulley Fell Out!!!!!!
- Buying used gmmg....Need advice.
- ls6 instake problems
- To those pushing over 430 rwhp...
- Installing Borla Y-pipe
- Anyone have the MTI TB??
- X-pipe and dumps on an LT-1
- Do you have to change plugs?
- LS6 intake dyno's before & after.. anyone?
- Very tricky question within...Controlling idle via switch...
- Will QTEC affect A/F ratio???
- Dyno results - driving questions now
- Does LS1 Loudmouth exhaust fit on LT1 formula
- True duals one more time please!
- GMMG vs Loudmouth exhaust
- Gutting the Cats. Need your input!
- Hooker LT's
- What Mods Should I Do First?
- Anyway to "trick" the coolant sensor?
- will 2 walbro 340s support 650 at the wheels?
- Would FTRA work well with my gfx's?
- Change lifter valley cover with LS6 intake?
- slp ypipe
- WTF?!?! Hitting rev limiter between 2nd and 3rd at WOT and won't shift
- teflon tape on npt or -AN or both for fuel?
- PLEASE POST PICS OF BOLA ON FIREBIRD
- n00b exhaust questions
