View Full Version : Generation III External Engine
- Exhaust stinks, bad tune? need cats? AIR? EGR?
- Carbon Fiber Valve Covers
- New cam Video.....Whiplash II
- Hooker 2253-1 and 2468-1
- Exhaust mount?
- catch can oil looks like poo?? help!
- few questions (MAF, scangauge(misfire), idle)
- Harland Sharp Non Adj Rockers
- need some help!
- magnaflow or hooker catback?
- heater
- Inspection pretty soon
- Exhuast Cutout?? low profile?
- crank sensor
- fra and ftra
- 1 7/8" Header Gasket
- LS2 intake question?
- Z28 hooker longtubes?
- Hooker LT guys, questions about AIR
- Will I pick up any power?
- how to tell difference between ls1/ls6 intake!
- New True Duals Idea... Thoughts? Opinions?
- Solid Motor Mount "Comfyness"
- california emissions question*
- Thunderbolt cats?
- What Belts With ASP Pulley
- Header/Ypipe question
- Exhust question
- How well does the Corsa system tuck?
- Grinding LS6 intake tab
- Why is my exhaust turning my bumper black?
- Will I need a tune?
- 3" duals under axle on 1.75" drop?
- just put a crank pulley on, what size belts??
- Broken Motor Mount Bolt
- side exit exhaust?
- My catch can routing ok?
- Adding 85mm MAF and LID worth it?
- Mystery connector on the engine harness black 5 pin. No fuel long story... lol
- LS6 Intake Question
- exhaust for my td's
- Head porting question....
- Intake question
- catch can?
- NEEd Part # For GMPP L92 Intake
- Meziere People- What is a Part Number for a 180 SBC Thermo
- Motor mounts?
- Shocks
- Problems after LT's & ORY installed...
- Finally getting an LS6 intake! Do I need a tune?
- My newest exhaust
- ported maf ends, good idea?
- Cat in I pipe
- !EGR=blinking SES light?
- What sensor is this?
- Help quick???
- youre gonna hate me
- ls1 removal from the top?
- CNC Throttle Body
- Oil pan has a small leak
- Need Advice
- What's the size of a SLP dual/dual I-pipe?
- Mac mids question..
- borla stinger exhaust
- short simple question
- Speed Inc AIR Blockoff
- Rims
- Somebody's gonna add a little HP...
- Is an X-Pipe an X-Pipe?
- ls6 heads---243 and the 241's
- Belt issue
- Exhaust
- tsp true duals (lowered car)
- Corsa really really quiet?
- Coolant bypass/crossover lines do I need?
- ls1 water pump weep hole?
- Where can I get an ls6 IM and a ud pulley for the best price?
- Swap?
- E3 spark plugs
- 408 Stroker w/ L92 Heads
- Serp System ????
- Stock cam specs?
- Kooks 2" race headers sound clip
- Low Oil Level Sensor Block Off
- Deleting the air???
- exhaust y-pipe question
- fuel question
- TPIS 90mm LS6 Intake Pics
- to swap or not to swap catted y pipe vs true duals
- LS1 Throttle Bodies....
- 98 coolant temp sensor to autometer gauge? reading inaccurate!!!
- P/P TB or Bigger TB?
- To header or not to header
- ls6 intake on a 02z stripper
- Stock MAF with 90/90 setup Q's
- TSP true duals & American Racing 1 7/8" headers?
- Full 85mm setup
- Brand new air lid (MTI) has holes - worth trying to fix, or return?
- Oil pressure for my mechanical oil pressure gauge
- pulley and harmonic?, or pulley or harmonic?
- Need to know a bolt size
- intake ?
- Did you have this problem after LT install??
- 6.0 questions lq4
- Silver PRC Duals?
- Throttle body on Super vic
- Help Getting Fan Off
- Need Detailed TB porting writeup
- So i drew my exhaust to see what you guys think
- Help with new 5.3l project
- What is the vacuum box (cylinder) at the front??
- Throttle Position Sensor
- 2800 to spend on the WS6, I need recommendations!
- headers/ y question
- LS1 vs LS6 Intake
- what is the difference
- Hooker Catback
- Will my combo benefit from a fast 92mm setup?
- 03 lq4 questions
- Help with the EGR Tube O ring, 00 Camaro, LS1
- Oops. Forgot to install heatshield on GMPP wires
- MAF connector
- Where did i go wrong
- 2000 C5 vette intake
- burning at least 1 qt every 1000 miles
- Where could I get TTS headers at?
- Header Bolt ,,,,Leaks question
- Should i paint them red or leave them?
- Where to buy center bolt valve cover coil bracket?
- 02 SS SLP CMExhaust question
- AIR removal on 2000. sick of searching. no write-ups explain this.
- Will Ls7 intake work on ls1?
- Which headers would you go with?
- what is needed when swapping LS1 intake with LS6?
- LS6 intake question ?
- cracking problems with FAST 90/90???
- cat question
- Engine shroud cover options for LQ4 6.0L
- Victor Jr with fuel rail questions.
- Help: Intake tubing and sensors
- Valve cover breather?
- Are Rockers worth considering on a H/C install. Educate me :)
- Installing a/c compressor question?
- volant intake fit under superhawk hood?
- Powersteering pump questions
- Throttle body spacer
- I know its been beat to death but i have to ask...
- where to get fuel pressure gauge
- egr & air
- head casting numbers
- What tips for GMMG?
- Why is the pcv valve grounded????
- Why is the pcv grounded??
- Y-pipe question???
- PML valve cover questions
- do i have a vacuum leak?
- Is there a good y pipe if I am going to lower my car?
- 90mm tb?
- Dumped BORLA
- Valve Float
- Getting GMMG Exhaust.
- ORY w/o headers......
- Best way to fix an exhaust leak? Header @ Y
- ??? about removing my air/egr
- Need fast help on my TD exhaust set up
- maf issue
- FAST 90/92 or LS-6 for me
- help identify where this bracket goes
- SLP Header fit!
- 5.3 questions
- anywhere local i can pick up GOOD header bolts?
- Installed Texas Speed Longtubes yesterday
- Weight of a 4.8 liter vortec??? NEED INFO
- Things I should replace since my motor is out
- My Tru Duals with One Chambers
- Plug Readers inside please.
- Pulleys????????
- pulleys?????
- Spark plug choice and gap question HELP!
- What is the best way to clean the inside of a intake manifold
- Not sure what this is, or if it's normal
- ***Volant SEALING MOD*** PICS INSIDE
- exhaust on a stock camaro
- safe to drive a little with header gasket leak?
- Highway Vibration
- What the hell is on my oil cap!!!!
- ARH + Corsa = Poor Fit
- 408 hci opinions
- Bassani
- How much does a Magnaflow system weigh?
- factory tb
- Maf
- hedman 1 5/8 step to 1 3/4 go to 1 7/8 worth it
- asp pulley
- Underdrive Pulley and Belt
- what should I look for with a used TB
- True Dual Mufflers
- anyone install 1/78 kooks on 98-02 F-body?
- 99 ws6 throttle body
- how to find a vacmn leak?
- Comment/advice on my possible exhaust setup
- super victor plenum questions- pictures inside
- how to hook up an A F RATIO gauge on a camaro
- Throttle Body sticking
- 6.0 swap questions
- Autometer Wideband Guages Rebate
- driveshaft question
- custom p.s. pulley questions
- Steering Pump Groan?
- Balencer and P/S question
- Sponsors I'm in need of a quote for Magnaflow exhaust
- magnaflow muffler to slp resonator?
- Any fitment/install issues with Hooker/Jet Hot LTs, and how's ground clearance?
- spark plugs...
- SLP loudmouth 2?
- question for those with cutouts
- FAST 92mm, intake runner question???
- question about air and egr
- Hypertech programmers worth it?
- Vette manifolds as good as LT's????
- motor mount question
- Installing air box lid/IAT sensor question
- FTRA/SSRA guys, come in
- Mac header question for a friend
- Vid of a few revs of the WS6
- True Duals vs y pipe setup
- QTP question.
- ***** 5.3 intake swap to a ls1 intake
- is there any advantages....
- straights
- misfire in cylinder 1... Desperate
- OEM Exhaust Hangers
- Adding 85mm TSP lid what do I do with the air hose that goes into my SLP lid?
- is their any advantages
- AC delete on 02 z28
- More air = less reliability??
- Quick Mac header question
- QTP's came today, I have a question though.
- Muffler questions...
- Gettin new setup
- Magnaflow cat-back to loud?
- smooth bellow
- Pacesetter Header and Y Pipe Combo Question
- annoying popping
- Saft question [Steering pump related]
- CME inlet pipe size?
- Cut out's before the Y-pipe ?!
- Boosted valve cover blow by options.
- F series alternator harness# and power pin?
