PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 [135] 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Bought some pacesetters, not another header thread... I know
  2. Need different location a/c compressor outlet
  3. Worried about floating a valve straight pipes no cats no muff
  4. StOcK AlTeRnAtOr PrObLeMs!!!!!
  5. Ok so what do i do here?
  6. Accessory and Swap Questions?
  7. infamous hanging idle
  8. Spark plugs??
  9. LS6 intake MAP sensor broken..
  10. pacesetter ory rattling under floorboard
  11. corvette acc. in f body?
  12. Best Balancer?
  13. Blackwing not latching tight...
  14. Head Gasket and a few more
  15. sheetmetal intakes?
  16. tps code
  17. LS6 Manifold Just came, got a question
  18. Differences between ARH and QTP Headers?
  19. balancer weight
  20. Crappy Flowmaster
  21. Cutout with Hooker Catback?
  22. 900 whp is it possible?
  23. Powermaster XS Torque Stater Clearance Issue?
  24. High flow cats and horsepower
  25. true duals in wisconsin
  26. problems installing pacesetter ORY
  27. Cold Start Idle Question/help!!!! ASAP
  28. LS6 intake questions
  29. What causes HIGH idle in gear?!!?!
  30. Full True Duals
  31. Solid Motor Mount Height
  32. Exhuast Backfire!
  33. heads and cam
  34. Help finding fuel rail pressure valve/bolt
  35. Terrible Gas Mileage... Misfire at Idle...
  36. Pacesetter header gasket question...
  37. what will grind down chromolly
  38. air!/egr! and frc's
  39. 100mm MAF IAT Question???
  40. Ngk Tr6???
  41. i need the torque spec for a knock sensor
  42. Best way to gut cats
  43. Need belt size info for 04 GTO/ATI 10% underdrive pulley
  44. Mufflers for H pipe
  45. SLP Cold air "flow pack" worth it?
  46. help me quiet my ls1
  47. LM1 too loud for street night. Any suggestions?
  48. Catch Can with PCV delete
  49. Where can i get Bolts for transmission to engine?
  50. can anyone help me?
  51. QTP LTs with Stock Cats
  52. Ideas for a bolt-on.
  53. MS4+No2+intake(insert here)
  54. 90/90 too much for my set-up?
  55. Multiple Cylinder Misfire
  56. March SFI U/D Pulley
  57. Magnamouth
  58. dual exhaust question
  59. street warrior intake
  60. UMI TB and surging
  61. BBK SSI Manifold...Or Save For The Fast 90/90?
  62. FTRA vs. SSRA
  63. Bassani Tri-Y vs. QTP LT
  64. ls1 vs ls6 w/egr
  65. 2005 5.3l into a chevelle
  66. tps sensor maybe??
  67. headers?
  68. Fast 78 Mm Intake Question
  69. 1.8 roller rockers
  70. Ported FAST 90 intake vs LS6 intake dyno comparison
  71. pulleys
  72. Underdrive Pulley Question
  73. Help me get 400 reliable, streetable rwhp...
  74. Bullet in I-pipe works great!
  75. Just a couple of Perfrormance Newbie questions
  76. Need opinion
  77. RevXtreme Catch Can Setup
  78. Using GM high lip pulley on F-body LS1
  79. Help ....egr Delete On Ls1
  80. Help EGR DELETE
  81. whitch intake should i use ?
  82. volant owners help needed
  83. polishing after market heads
  84. Iron Block in 2005 C6 Vette - question
  85. didint know where to post
  86. Problem Starting Car - Need Help
  87. 2004 pontica gto engine wiring with t56.
  88. catchcan
  89. Pacesetter headers installed - story and tips!
  90. LS7 Porting Experiences
  91. Need shorter ls1 plug wires.
  92. Are high flow cats louder than stock cats?
  93. Ssra
  94. another cutout thread!
  95. question about fast intake
  96. Starter Question
  97. what tb is better shaner s2 or s3?
  98. Anybody have the new Hooker LT's?
  99. who has pics on teh ls7 intake manifold
  100. 4" exhaust throught the back
  101. Full Bolton LS1 HP Rating
  102. Anyone know if you can use an f-body alternator on an ls1 ('04) GTO?
  103. Another PCV Hose Question.
  104. Whats the difference?
  105. Where do/did you buy LS2 plug wires?
  106. is there any advantage to raceheader
  107. best ypipe for stock manifolds
  108. going from stock to bullets, need help
  109. Powersticks or Cherry Bomb Extreme
  110. Need help with an electrical short issue
  111. Time for a new Waterpump Already!
  112. restrictor plates/block off plates????
  113. header and ory question
  114. Bolt on DYNO #'s
  115. So confused....PCV issues
  116. exhaust problem
  117. Exhaust clips of magnaflow with lt headers w/cats?
  118. Stock 3 pin Maf Pigtail part number needed
  119. got a SLP LM2
  120. Cut out wingnuts?where to get them
  121. qtp cut outs
  122. ARP bolts with Fast 90??
  123. Vacuum leak question?
  124. Valve cover air breather?
  125. need to quiet down my true duals alot
  126. coolant leak, 2k2 suburban
  127. TSP Rumbler with stock Z28 tips?
  128. wondering where to get morel lifters
  129. two step rev limit???
  130. ordering pacesetter longtubes...what y-pipe to use??
  131. kinda of confused..ls1??
  132. Exhaust size q...
  133. Fuel Rail Covers
  134. spark plug wires
  135. pacesetters and ORY+ fowmaster= Rasp????
  136. Ported tb help
  137. is there Lower temp fan switch for 99 ls1?
  138. Spark plug wires
  139. Holes in valve covers HELP!
  140. What do you guys think about the granatelli mass air meters?
  141. What kind of mufflers are on my TSP TD's?
  142. New exhaust
  143. Texas Speed 100mm MAF: Pre-Order Now!!!
  144. spohn solid mounts - cracked block?
  145. XS Headers
  146. Which Header Gasket?
  147. anyone ever used one of these??? they look freakin sweet
  148. Air Pump Check Valve Help
  149. ARP Intake Bolt Kit
  150. Poly motor mount install question.
  151. Rear Battery re-location (wiring)
  152. N/w
  153. verdict? Tune for Ported TB?
  154. ls1 programmer.
  155. 402 pipe size for duals and single
  156. Reworking a LS1 instaed of buying LS6 intake
  157. TSP 100mm MAF???????????
  158. going to install pacesetter headers and ory
  159. Any successfull Corsa/LT rasp killers W/O ***s...
  160. 6.0 intake options
  161. On a 402 how good would Pacesetters be?
  162. Flowmaster American Thunder
  163. oil and coolant in tail pipes
  164. To long tube or not to long tube that is the question?
  165. You think the stock y-pipe is flat?
  166. Long Tube Header Question
  167. Dynatech Supermaxx stainless header system
  168. O2 extenders & Kooks headers?
  169. Slp Exhaust
  170. Cat-back vs. catted y
  171. exhuast set up?
  172. Center bolt valve covers, how much?
  173. Stainless Headers..Are they all the same?
  174. 2004 GTO intake manifold part number?
  175. Which One? ****Stainless Hooker or Jet-hot coated pacesetter's*****
  176. MAFcleaning question..???
  177. Help with my shopping list - Pacesetter install
  178. How shall i build my Crank Case ventilation?
  179. looking for a cat back. which one to get
  180. fast 90 problems?
  181. porting throttle body
  182. need exhaust help
  183. Need Help!! FAST 90 guys come inside!!
  184. LS6 balancer broken. Is my engine FU#@*%???
  185. muffler recommendations
  186. Magnaflow Dual/Dual just arrived....Pics
  187. Direct Hits Ignition....
  188. Comparision between 10% UD and 25% UD
  189. question about my soon to be exhaust setup
  190. car is running like crap after installing lt's
  191. what size cutout I have one but not sure on the size of it
  192. installing headers question?
  193. best throttle body?
  194. LS6 ported head question
  195. possible ignition problem, hestitation and popping
  196. Hey guys where do our cars suck air from?
  197. ATI Super Damper
  198. cleaning volant cai
  199. GM LS6 intake on my LS1. What else is needed??
  200. Harmonic Balancer.....different type of ?.....
  201. Loudest exhaust possible...
  202. Headers to cause SES light?? And other questions.
  203. Slp Loudmouth 2
  204. 243 head questions
  205. spark plug question
  206. cheapest place to have my tb ported
  207. PCV fix?
  208. ported, polished tb
  209. my new TD's video clips
  210. New track times, from SLP induction
  211. Question about under intake coolant lines
  212. TSP TD problems...
  213. y-pipe to cat bolts part #
  214. SLP later or Pacesetter now?
  215. Exhaust set up, SPL loudmouth II??
  216. Will Ses Light Turn Off With Catalytics Converters???
  217. picture of back of intake manifold
  218. doing a head swap ..... damn driver header!!!
  219. Question about starter
  220. Open Exhaust Question
  221. which borla xr-1
  222. Need help. Installed headers and ory but...
  223. Y-Pipe
  224. Intake manifolds
  225. LS6 Swap: Can I keep stock drive train?
  226. what exhaust to get
  227. Need new PS pump pulley
  228. Is anyone running edelbrock SDT mufflers on their duals?
  229. Header bolts
  230. !!!!stock metal fuel rails wtf?????!!!!!!!
  231. 400whp Corvette vs Mazda Miata. Who will win... G i wonder....
  232. 3.5 inch Mufflex with spintech muffler *video*
  233. heads!
  234. ported tb, 4500 idle
  235. Removing A/C belt
  236. hp gains w/ FAST intake???
  237. 02 ? plz help!!!
  238. Edelbrock Super Victor LS1 EFI out yet??
  239. NEW JAAM, Rain will afect the car????
  240. Rattling noise from exhaust...
  241. need (CO) emission help fellas!
  242. Hooker exhaust
  243. Confused with my current exhaust setup.
  244. My magnamouth sound clips
  245. 02 sensors
  246. Wiring diagram for Oxygen sensors? Or pics!?
  247. Who makes the BEST electric exhaust cutout?
  248. Jet hot headers
  249. Stock computer limitations
  250. Exhaust connections
