PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 [190] 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Question about TD's
  2. Emissions question
  3. Installing loudmouth...startup with no exhaust
  4. Coolant Question
  5. Question for 98 owners with NW TB
  6. asp or slp pulley?
  7. ANNOYING exhaust rattle!
  8. What do i torque the headers to?
  9. Headers installed then developed a misfire!
  10. Corsa Vette Mufflers
  11. How should I hook up this MSD shift light setup??
  12. Is this an LS6 or LS1 MAF sensor?
  13. radiator questions
  14. My !MAF setup w/ pics.
  15. XS Driver Side LT Wont Fit :(
  16. Dynatech or magnaflow cat. converters
  17. Exhaust Questions
  18. EGR question
  19. Pics needed of inside of moroso spiral flow or flo pro twisters
  20. y-pipe bump stop
  21. intake question
  22. GMMG Exhaust Question
  23. Ported LS2 manifold
  24. exhaust set-up questions?
  25. Spintech Mufflers for TD's
  26. !MAF guys what size fernco did you use?
  27. just heard this??
  28. 1.5 " Exhaust lol ...
  29. Help me out: Dual or single cutout?
  30. what header are good
  31. Pic of an LS6 intake anyone?
  32. Volant Cold Air System
  33. Don't EVER EPOXY Throttle Body (IAT/Air) holes !!!!
  34. Exhaust tips? - appearance mod only?
  35. where can i find this
  36. Gained 8whp with Flowtech Cutout
  37. Help Me !!!.. LT install
  38. need help with air lid on my 01 ws6
  39. MAF Question
  40. pcv hose routing question
  41. P/P TB question
  42. SYNERGY Motorsports Custom True Duals
  43. Installing WS-6 hood, is current bolt-on setup compatible?
  44. Parts For sale
  45. cutout being installed tomarrow, need tips
  46. True Duals or Hooker catback
  47. How much horsepower would I be leaving on the table??
  48. 25% ud pulley..
  49. Will this fit?
  50. what did you use for for your true dual setup?
  51. Summit racing pacesetter headers
  52. Is it pointless to put an aftermarket throttle body on stock LS1 intake?
  53. Finally a Loud Mouth 2 Video.
  54. Throwing belt problem
  55. Header Clearence Issues...
  56. need pics for custom air intake routed through the grille openings
  57. h-pipe owners, what h-pipe are you runnin?
  58. Cut-Out, HP Gains/Placement??
  59. quick question for you tsp true dual guys
  60. XS headers and dual cutouts
  61. anyone have pics of a kooks y?
  62. getting rid of rasp
  63. Alt. Overdrive pulley, or new Optima battery?
  64. Should I Upgrade 2 A Fast 78mm Intake From A Ls1
  65. Fresh air tube? remove it or not?
  66. If you have headers you need 13111's
  67. Chambered exhaust? GMMG vs. Chambered loudmouth!
  68. Should I get 1 7/8 Headers? Or keep my 1 3/4s?
  69. Power Steering Pump and Cooler?
  70. Throttle cable adjustment (for non TCS car)
  71. Holden Commodore ss Intake ???
  72. LG LT's for F-Bodies
  73. Ouch!!!
  74. What Is This Sensor Called?
  75. Throttle body question
  76. True Duals finally
  77. what part to take off March U/D pulley?
  78. Do Fuel Rail Covers lead to more Underhood temps ?
  79. Price for welded in cutout
  80. Help!! Bad MPG
  81. ticking radio after c/h swap
  82. Exhaust Questions?
  83. Few Questions on True Duals
  84. What would i gain with a FAST 90/90 setup
  85. ok to remove heat shields on cats?
  86. Spark Plugs w/ new setup?
  87. Help! Accidentally put oil in Power steering
  88. Just got cutout
  89. Pacesetters installed (pics)
  90. Replacing Flowmaster w/ Hooker question
  91. FAST 90\90 Combo vs Stock LS6 Intake and TB
  92. Spark Plugs
  93. 160 degree thermostats w/ housing @ $19.99ea
  94. 90mm Bellow what are you guys using?
  95. To Descreen the MAF or not to descreen the MAF..that is the question
  96. Ebay Headers - Sponsor Review
  97. GMMG video going through gears, not just idle and rev
  98. Underdrive alternator/crank pulleys...
  99. Single tips or Dual tips on T/A Valance? Would these dual tips be restrictive?
  100. Charging problem
  101. magnaflow quad exit.
  102. LT Headers for 2002 on 1998
  103. Need Help!!
  104. turn-down question
  105. PCV conversion???
  106. true duals with ebay headers
  107. A mysterious rattle...
  108. slp underdrive crank pulley what BELTS?
  109. Thinking about putting cats back on!!!
  110. ls6 with EGR provision ?
  111. Tach Wiring Troubles.
  112. I need pics of SW SS LTs from the guys who have 'em.
  113. Good deal on GMMG??
  114. Please help....
  115. Whatcha Think?
  116. magnaflow is sick!!
  117. Sea Foam Help PICS
  118. Replacing resonator
  119. How does the Volant cai stack up?
  120. cut out is now in! mccord going on tonight.
  121. Should I wear a raincoat?
  122. Pacesetter Question
  123. Are 12" O2 extensions long enough?
  124. Coil relocation???
  125. FAST 90/90 Peeps, Trouble With the TPS/Throttle Cable?
  126. Trapping 110 in a mildy bolted on car?
  127. Coolant pipes? ("H" looking hardlines under intake mani)
  128. New Era Ported Throttle Body ?'s
  129. Time For a Cat Back system
  130. Pacesetters Versus Kooks
  131. is this pic an ls6 manifold
  132. TSP rumbler and cut out
  133. quick exhaust questions
  134. will this fit?
  135. Exhaust Opinions
  136. how much restriction on the stock ws6 muffler?
  137. Crao coming from beneath Intake?????
  138. pacesetter exhaust leak
  139. What spark plug?
  140. what should i get?!?!?!
  141. Cats
  142. QTEC Wires
  143. Porting the mass air flow.
  144. Help!!!! Mod List Inside
  145. LS6 install Question.
  146. Help...Im leaking
  147. TD question
  148. QTP Y-pipe
  149. Bad to run open cutout?
  150. 95 db limit
  151. Bad Vibration and noise??? WTF help me out guys!
  152. header install what do i need?
  153. Dumped?
  154. Remote Thermostat Housing Available?
  155. A.I.R Delete Finished
  156. Finally getting my headers
  157. QTP headers,
  158. pulley question
  159. Exhaust gurus in here please!
  160. how much $ to have a Y pipe modified?
  161. Exhaust dilema
  162. where can I find this kind of breather cap?
  163. Header Size??
  164. coolant leak....
  165. serp belt size for pulley
  166. LTs/ORY/Magnaflow Catback??
  167. Drag Cars post pics of your exhaust setups
  168. x pipe and cam lope
  169. True Duals or Y-Pipe??
  170. ls6 intake
  171. SLP Double-Roller
  172. PCV...replacing hose
  173. catco direct fit
  174. SLP clearance????
  175. LS6 Manifolds
  176. B&B, Mecham or GMMG? Hmm....
  177. Header Confusion! Please Help!
  178. Installed QTP HVMC headers and ORY-pipe
  179. starter motor adjustment
  180. Aftermarket wires bad for your car?
  181. Flowmaster or borla pro xs????
  182. banks catback?
  183. Electric cutout installed..check it out!
  184. where do these vacuum lines go?
  185. Y-Pipe: That much more power?
  186. deleting rear o2s?
  187. 02 sensors keep going bad!
  188. Using Cold Welds on Exhaust...
  189. best 85MM MAF to buy...and where
  190. TSP Lid
  191. Underdrive Pulley
  192. Has anyone tried o2 sim.
  193. Installing a Loudmouth after a stock
  194. Lakewood safety loop question
  195. maf translator ?'s
  196. Part name please
  197. My Car Is Running Rough
  198. Electric cut-out on a Borlamouth
  199. HELP cant get rear header bolts in
  200. My thoughts on the FTRA
  201. MTI Throttle Body???
  202. Throttle position sensor issues?
  203. 2-step question
  204. Trying to install Autometer oil temp sender
  205. Exhaust questions
  206. cutout help
  207. Needing QTP instructions/wiring HELP!!
  208. ac
  209. slp thermostat questions
  210. edelbrocks headers with a/c anyone? or kooks.
  211. Just installed the LS6 w/ EGR
  212. Pacesetters and ORY completed :)
  213. blank lid
  214. Loudest Borla Setup ?
  215. QTP cutout switch pics?
  216. F-body loudmouth vs. Corvette borla sound levels.
  217. Polyurethane motor mounts...where?
  218. broke a balancer tab....
  219. How restrictive is a CME exhaust on a camaro SS
  220. Trying to track down coolant leak?
  221. 80mm throttle body
  222. How did you guys wire your e-cutouts?
  223. Need help on picking new muffler!
  224. turn downs or not
  225. what size band clamp to use
  226. Bad luck or no luck!!!
  227. 98-99 vs 01-02 headers
  228. Header Gaskets
  229. LQ9 ex manifold vs LS1 camaro ex manifolds
  230. true duals with, chassis mount torque arm?
  231. V6 Header install
  232. Y pipe for stock manifolds
  233. Tubular LS1 Solid Motor Mounts...get em or no?
  234. Mufflex or Duals?
  235. True dual exhaust
  236. Just ordered!!
  237. HELP!!!!!!!! Car is running horrible after header install...??
  238. Jet coating headers question...
  239. where to get a zo6 maf for a good price and will it fit on slp air lid
  240. Got some bolt-on dyno figures...
  241. Need Help With a Muffler Decision
  242. Exhaust for a 5.3 truck?
  243. Borlamouth question
  244. Coated or Header wrap????
  245. How To Remove The AIR Pump
  246. A\C compressor help
  247. 3 inch cutout right?
  248. Y Pipe problems
  249. Which Series Flowmaster Do Yall Recommend?
  250. Exhaust System Questions
