PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Tired of exhaust leaks. Best way to seal clamps?
  2. HVAC help.. may have a dead compressor
  3. Truck Starter on LS1
  4. Balancer Install Question - LQ4
  5. Motor mount bolt
  6. Help with TSP Header Leak
  7. LS6 Alternator Wiring
  8. SLP Loudmouth Failed TX Inspection
  9. Valve cover gaskets at 192K
  10. American racing1 7/8 headers and y pipe,stainless works 3.5" catback? Good for 800hp?
  11. Broken Corsa baffle symptoms?
  12. i have to start 89 ls1 with screwdriver
  13. Started LQ4 swap for first time and runs really rough, long term fuel trim way off
  14. dumb question - ls6 intake bolts, individual removal?
  15. impact harmonic balancer bolt ?
  16. FM 3"-4" Merge Fit Stock Tunnel Brace?
  17. Anyone have direct comparisons with an TBSS intake swap on a 4.8?
  18. FAST 102 and Chevrolet Performance 89018052 water pump
  19. SSRA with AC worth it?
  20. Blackhearts Duals with Borla XR1's?
  21. No spark or fuel to spark plugs
  22. Which ign wires fit around longtunbes
  23. Another flowmaster merge question! I used the search :)
  24. Alternator Problems need 'HELP"!!! PLEASE.
  25. New TPS sensor needed?
  26. Stock Y Pipe Question
  27. Fuel rails for FAST ?
  28. C5 Ram Air Hood for 150+ mph Check My Math / Thoughts - Anyone made one? -
  29. Port Matching... What it's worth?
  30. Woke up last night thinking about Y pipes
  31. What is this part called?
  32. Oil leak around driver's side valve cover
  33. LS1 wiring question
  34. Jegs 50228 oil pan.
  35. Advice for MAF
  36. No spark cylinder 6
  37. under drive pulleys
  38. Lsx454 in c5 pcv help
  39. Thermostat housing doesn't sit flush with water pump
  40. MAP sensor
  41. LS6 Upgrade Path
  42. Oil catch can install
  43. Fast 92 vs 102
  44. UD Pulley question/problem?
  45. power steering pump swap. now belt squeaking
  46. diff between o2 sensors?
  47. Fuel Pressure Gauge installation.
  48. SLP long tubes vs. ARH/kooks long tubes
  49. Decrease Exhaust Volume on Existing System
  50. GUYS!! help out a rookie with his pcv routing
  51. Where's the TAC on a Rainier/TBSS?
  52. 5.3 ls suggestions
  53. A.I.R. removed
  54. Coil Pack Chaos
  55. face lift
  56. Bad oil pressure sensor
  57. Need starter for my 99 ls1 formula tomorrow. 5.3 or 6.0 truck
  58. Need help asap, DD
  59. Help me beat my wife...
  60. Looking for feedback from owners of Hooker Blackheart True Duals
  61. Gear/vacuum type noise in accessory area (video)
  62. What Lid and Coupler to NW92
  63. PCV option with LSX454 NW102TB fast 102
  64. kooks driver side header won't go in.
  65. Size of headers
  66. Holley Hi-ram for appearance only? What injectors?
  67. Best Website to Purchase Headers
  68. Advice on installing LT headers and tuning
  69. PCV hose size?
  70. Summit RacingSFI Harmonic Dampers any one using them?
  71. car tuned with LT/ORY, so what exhaust?
  72. Hooker blackheart duals and s60
  73. Need help choosing engine management system
  74. Solved: CS130 Alternator Wiring
  75. Thermostat/fan setting question
  76. Ported 92 on trickflow fitment. Help!!
  77. Erratic Vacuum Gauge... what's causing it?
  78. Lsx cooling
  79. Injector O-rings for MSD intake
  80. AIR/EGR Removal Help
  81. New bullet/muffler for SLP Loudmouth--opinions!
  82. Getting rid of power steering
  83. ASP pulley throws timing chains?
  84. Fast 102 map sensor issue
  85. replacing motor in 2001 pontiac trans am
  86. Ported 92 on trickflow kit
  87. Lq4 build, what size throttle body
  88. Chaned IAC, now extremely high idle.
  89. mounting fuel pressure gauge
  90. LT Header Swap, what else should I get done? List inside
  91. Intake madness!!!!
  92. **UPDATE**I might be the only one to have done this... True dual setup with Madhammer
  93. Harmonic balancer problems
  94. Newbie with idle issues looking for help
  95. Running 33lb injectors can I go to 42LB?
  96. bets on headers? on 403 ls2....
  97. 98 LS1 computer mount
  98. Gmc sierra truck single cab 6.0L iron block
  99. PCV set up.
  100. Fast 102 on an LQ4
  101. injector hat for stock LS1.....possible ???
  102. Oil pan options
  103. Lowest profile intake hose options
  104. Crank pulley
  105. Slave Cylinder Issue
  106. Problems after tuning
  107. 5.3 Steam tube with ls6 intake
  108. Oil Pan question
  109. Throttle Body and Cruise Control
  110. Screwed up position here need help!
  111. 90mm TB/intake, 85mm MAF... worth LS7 4" MAF upgrade?
  112. Relocated Battery Alternator Wire
  113. Yet another LS1/LS6/SLP Intake Question:
  114. Air pocket at the T-State :-(
  115. Coil Relocation Kits
  116. Oil pan removal?
  117. Opinions on a ITB setup on a 408
  118. Alternator dropping voltage at high RPM?
  119. P0155 code - tearing my hair out.
  120. O2 Sensors for LTs - Denso 2344617 & 234-4025
  121. LS6 Intake,lid and exhaust
  122. replaced valley cover, now no Tach?
  123. New LS1 build, looking for info on best parts for performance.
  124. Autometer playback tach
  125. Starter for 5.3 and T56
  126. Need some help understanding Borla exhausts
  127. FAST Intake seals
  128. Factory 5.3 intake manifold maxed out?
  129. Ls1 smoking fast 102 full of oil!!!!! Need help!!
  130. Holly 92mm snioper intake
  131. How/Best way to vent this thing...
  132. Sooooo I did a Thing.. With My WARR Performance TB....
  133. proof that cut out lowers 1/4 mile time?
  134. needing some info please
  135. MAF part#'s
  136. Dumped borla xr1 thinking of changing, few ???
  137. Mini Race bullet worth it ?!?
  138. Center Exhaust question
  139. Is this Ported FAST 90 worth it?
  140. '99 SS Power Steering Pump - Need Help
  141. SLP Blackwing Lid on 99' WS6
  142. What's my machined ls1 worth?
  143. Cheap & Good Looking Intake is Junk I Assume....
  144. Anyone have a good solution to a lower mount alternator bracket?
  145. Ftp clear air lid
  146. two little vacum air hoses in the which goes on top and bottom?
  147. What electric water pump
  148. Need Help relocating a coil!
  149. LS6 vs FAST 78
  150. 4150 setup vs FAST
  151. Anyone using a catherdral port msd intake? (ported)
  152. Identify these valve covers please
  153. Temp gauge works at startup up, but then goes to zero
  154. Can a poor TPS connection at the TB cause loss of idle?
  155. What kind of headers are these? *pic*
  156. 102mm drive by wire throttle body
  157. OEM LS starter power level?
  158. Looking to Upgrade LS1 Camaro
  159. air "egr" question
  160. Tsp ORY
  161. Any one modify a Moroso 21150 oil pan
  162. Removing PCV and Installing Breather
  163. FAST 102 Setup - Complete build info
  164. Help with vacuum lines
  165. Down and Forward headers with fbody alternator
  166. Giant Air Pocket in Slanted Radiator
  167. 102mm TB on 90mm Intake?
  168. oil sandwich adapter with holley 302-1 oil pan?
  169. 98 z -28 idle surge issues
  170. Gmc 6.0 hard starting
  171. Alternator connection
  172. AEM 30-4110 A/F gauge & E85?
  173. Charcoal canister
  174. mounting the p1sc onto my ls1
  175. Stock throttle body blade screws
  176. Cherry red headers
  177. FM 3"-4" Merge with 4" Cutout Build
  178. HELP: Car runs like crap now!!!
  179. 500+ N/A guys what is your exhaust setup videos would be helpful!
  180. LS3 coolant crossover on LS1?
  181. New steam lines with AN hose and Fittings
  182. Help selecting spark plugs
  183. MAF mounting location LS3/F-body/Holley Hi-Ram
  184. TPS issues HIGH idle
  185. B1 and B2 O2 sensors and fuel trims arent the same - O2s reading at different rates?
  186. PCV valve hose split, would that cause...
  187. Help! Anyone Have a Flowchart for these Injectors?
  188. Knock sensors not working
  189. Ls1 into 94 t/a won't start
  190. PSA: Don't descreen your MAF!
  191. need part numbers for Power Steering lines
  192. How much will a 3.5" catback exhaust flow before being a restriction?
  193. Beating headers with hammer
  194. Mavns WARR Performance 102mm TB Review/write up. + Nic Williams 102 for reference!
  195. FIC vs DeatschWerkz injectors?
  196. SSRA Mega Mouth
  197. MSD Airforce on 5.3 with truck drive system
  198. Stock lq9 throttle body
  199. Valley cover bolts for Fast intakes.
  200. Leaking Out of my slp lm1 exhaust
  201. Huge shout out to Pacesetter
  202. Slp loudmouth exhaust with tsunami cam
  203. Exhaust system for 550rwhp and no rasp or drone????
  204. Headers
  205. Is my current exhaust adequate for my setup!?
  206. Re-Routed catch can, now gerring blue smoke
  207. ZL1/CTSV idler pulley on corvette water pump?
  208. Hotter Spark Improved ignition MSD ?
  209. Engine harness clip. What does it do?
  210. No oil pressure!!!???
  211. Carven mufflers ????
  212. Pontiac V8 + LS1 EFI. Feasible?
  213. Pulley question!!!!!!
  214. Are my brake hoses on right?
  215. CHRS1313 modified questions
  216. Question about which muffler is used on kooks duals
  217. Exhaust leak tricks?
  218. PCV routing any good?
  219. TB intake manifold Question/ suggestion.
  220. A pretty dumb harness question
  221. Opsu or cps oil leaks?
  222. I'm confused EO/IC
  223. Redundant and over-asked question... LoL
  224. Solid Plate Motor Mounts
  225. Installing new roller tip rockers, which bolt??
  226. Is this Exhaust Rattle? Or what the hell?
  227. New LS7 lifters in LS6, 1 bad out of the box?
  228. holley sniper sheet metal intake
  229. Throttle Body conversion
  230. 450-500rwhp from a n/a 5.3l
  231. LS stumbles under acceleration
  232. these new parts worth it?
  233. Iron 408 ls3 top end with stock ls1 water pump and accessories?
  234. size of the 4 bolts for fuel rail
  235. Getting lost with swap, TBSS, truck coils and blue/green harness
  236. Tsp dual proving question?
  237. what is the bolt torque sequence for intake manifold?
  238. remote oil filter location
  239. MAF Question
  240. Help with Flywheel balance
  241. Having trouble getting torque arm bolts back in
  242. LS2 into a Fbody?
  243. 2.5" true duals compared to 3"
  244. NW 90mm TB blade
  245. Steam tube/cross over setup question...
  246. Trick Flow coolant crossover
  247. IAC Question
  248. need help with lq4 catch can routing
  249. Radiator for a 289 cooling a 5.3?
  250. 2002 trans am just shuts off
