View Full Version : Generation III External Engine
- RTV silicone sealant and 02 sensors dieing
- Best Fuel Pump
- question about re-oiling holley
- HELP after Hooker LT install
- I have no idea where to post this, but...
- Backfiring! WTF
- Bauer racing throttle body
- TR-55s or Champion spark plugs?
- Muffler or full cat back system?
- how do you get the spark plug and wire for the #8 cylinder out
- Does anyone have flow #'s for different exhaust pipe sizes ?? Searched with no luck..
- Difference in coated or plain headers?
- fuel pump and injectors?
- Quick question > What are TR-55s gapped at?
- Hooker LT's and Y-Pipe ??
- aletator pulley
- short belt part number?
- Question on Hooker headers and automatics
- Home Ported TB
- Got Baseline dyno numbers from Speedtek today!
- Fuel Rail Surge Damper mod question????
- What plug wires for relocated coil packs?
- 346 cid, 430rwhp+, what plugs/gap?
- Am I running lean/rich with my mods?
- How to install a LS6 intake?
- Pulley Puller?
- need some help please
- one qustion please..!
- Running Lean and Rich questions
- Ported throttle body
- MAF ends?
- Dual Cutouts....Yay or Nay
- Whisper owners-check your lid!
- Is it worth changing out a SLP D/D muffler for a B&B muffler?
- Difference between 98-99 and 00+ Throttle Bodies
- Fuel Filter change?
- Is the loudmouth the best?
- pulley ???
- TB Question
- Why is my car so slow ?
- I want some 12's w/out conveter, gears, or headers..... read on.
- TB Bypass
- Coolant Type - What to use
- Complete EGR system removal questions.
- H pipe
- billingsley a/c delete plate???
- Ravin Exhaust
- Preparing for JET Hot LT Install (advice plz)
- Anyone try putting the XR1 muffler on the LM?
- whats the size of the thread on a O2 sensor?
- Need help on pulling motor from top.... quick!!
- gutted cats, now the motor is pinging?
- Grots (QTP Headers)
- FLP dual turndown option (picture)
- Vacuum leak???
- FLP header dual cutout option (picture)
- Removing MAF screen????
- Baker hose for K&N FIPK system.
- hesitation between 2000 and 3000 RPM
- LSI Crank Pulley
- What's the diameter of the primaries on Mac Headers?
- Where can I find 02 ZL1 replica front grille?
- High Flow Cats?
- Spark Plug Gap????
- Does anyone's lid make a whistle sound?
- Factory water pump who's lasted the longest?
- Cat Swap
- Finished x-pipe duel today!!!
- freeze plug size for intake manifold?(egr cars)
- X-pipe True Duals-18'or12' Bullets?
- Ill effects from longer plug wires from coil relocation????
- Jay Fisher Pontiac electric H2O pump kit
- CAN ANYONE TELL WHAT KIND OF HEADERS THESE ARE????
- the best exhaust for the money??
- NE one use wingnuts to hold cap on cutout?
- Whats the throttle body bump stop mod?
- Where can I get good cheap exhaust wrap?
- asp pulley ? please help
- What Temp. Is Stock 2001 Camaro SS Thermostat?
- Had an vibration come up since it got cold - guess what I found?
- HEADERS HELP.....PLEEZ
- Fuel Pump Question
- exhaust question?
- sealing lid question?????
- What LT's tuck tight for dropped cars?
- Are all lids created equal?
- IGNITION SYSTEM ???
- Why hasn't this been done on our throttle bodys yet?
- ported TB = idlng problems
- Loudmouth installed, not that loud
- porting and polishing ur throttle body?
- Good shops located in Detroit area
- GMMG installed!
- Emission legal?
- hooker lt's installed and they are loud
- Apology to Speed, Inc. and Tom Izzo.
- Help on eliminating rattles from FLP's
- Super Sucker or Fast Toys Ram Air?
- Temp guage reads the same with 160 stat and HPP3.
- high flow cats
- Shaner or Bauer what would you choose
- SES Bank 1 and 2 codes, What do they mean?
- Volant Induction - Air Intake System ??
- SES Code
- Daytime Running Lights
- Help oil
- Stealth Air Box
- Do the Hooker headers rasp like the MAC's and should I change?
- ***Need Advice on MODS***
- Hooker, Flowmaster, or something else?
- Where can I get a cheap smooth bellow?
- HEADERS HELP
- How many miles on your underdrive pulley?
- Question about High-Flow Cat
- ??Muffler placement??
- Gutted cats and ran new best!
- off road pipe?
- After LS6 install no air will come out of the vents
- help, camaro is messed up
- Who sells Jet Hot LT headers ?
- How much power does a LS6 intake make over the LS1 intake?
- Got an SS, will a ram air kit do any good?
- Does anyone make a replacement muffler
- Dynomouth Bullet Question
- K&N FIPK question-HELP
- Mac Headers Install Question
- Speed, Inc. sells used/repacked parts? (Pics)
- 2 questions about SLP laodmouth !!
- LS1 intake to LS6 intake
- 352RWHP/362RWTQ...right or wrong
- Kook's Custom LT headers
- Need help w/spark plugs & LT`s
- Muffler removal dyno question
- Exhaust......
- Just had stock manifolds dumped behind the front tires
- Unhappy with Bullet
- How to Spring Install
- Which battery ??
- Need help- SES P0128 cooling thermostat
- Tips for starter replacement?
- Where can i get the small caps for end of SVo injectors?
- paging "Ramchargers" > any luck fabbing a quality engine strap yet?
- Got rattles with my new FLP's, please help!
- Just installed FLP's, need some help!
- Oil usage!
- FLP or SLP whith do you suggest?
- 1-7/8" to 2" stepped headers???
- borla xr-1 in place of LM resonator?
- FLP LT Dyno Results (99 M6 Before & After)....
- Magnaflow owners opinions please
- Which fuel filter???
- Any proof a Ported MAF will cause A4 tranny problems?
- What mod(s) next?
- Reliability issue.... exhaust
- How do I drain all coolant
- Borla XR-1 or Dynomax Bullet??
- Relocated Coil Wires????
- SLP Loudmouth Price Good?
- Today's dyno numbers.
- What is the lightest, best flowing, catback
- Fuel Pressure Regulator?
- Anyone have Thunder Racing MAF ends?
- Exhaust manifold/header bolt??
- Cablebandit or others: how to fix AC so it stops leaking:
- 98 and 99- 02 coil question
- Borla vs True Dual w/ X-Pipe vs Loudmouth
- ASP
- People with hooker LT's and true duals...
- it is still a bolt on
- Hooker Long Tubes
- An O2 sensor that is immune to RACEGAS
- replacing stock muffler
- 85MM MAF/80MM TB for All Bore 388...Worth it?
- Anyone in Northern Va know how to do those PCV mods on LS1's?
- Difference between 98-99 & 01-02 Mac mid length headers?
- Any tips to changing plugs?
- Corsa or Magnaflow?
- SLP 85mm MAF
- Has anyone heard of PPC LT's??
- Where to Get 99 Style Smog Tube and EGR Block Off Plate?
- another lid question
- SLP Header Install
- Exhaust
- Stuck in WOT?
- QTP Header System Pics
- Need Help!! SES light is killing me...need adivce from the experts
- Sprak Plug change?
- Help Please! Fuel T Fitting???
- Hooker Headers Came in today
- Walbro 340 or 255???
- New dyno numbers... good?
- GMMG exhaust With Headers?
- FLP headers with stock cat-back - no gain???
- Why are Ford SVO 30 lb Injectors so popular?
- Broke Something During the Intake Removal
- The PRI Show
- Could K&N oil cause this????
- exhaust
- When do you need bigger Injectors
- Cruise Control ???
- Belt ?
- Whats the longest anybody has gone on stock plugs?
- ????Buying a Z28 ????
- Parts List / Duals
- SLP Smooth bellow
- ws6 weight??
- Fan problems
- exhaust question
- Everyone's header opinion
- need metal fuel tank for 2001 Z28
- Will this bellows fit?
- Got the car dynoed
- what is up with my fuel pump?
- MAF.....good or bad???
- Fast eddie's pic
- Hooker
- ls1 99 STOCK PCM
- gmmg at WOT
- MAC Header install
- Belt Fell Off
- B2S1 at 1.005 at WOT... Bad Sensor???
- Removable Exhaust - shed that weight.
- Header Question
- will hooker LT and MAC headers is same HP/ TQ on stock internal ??
- Important spark plug?
- can it be done......
- Damn the Fernco mod was a pain....
- Weight of HT vrs T-Top cars with same trans?
- Anyone using the Qwik Stick?
- Getting LT headers but not a cam???????
- ported tb ?
- Meziere Water Pump announcment >>>>
- Autometer tach install
- How bad are the MAC cats??
- ? on STEEL header gaskets!!!!!
- Bullet installed today....IMO
- going 140!!
- solid motor mounts
- Plug wires...
- Fuel pressure drops under WOT....is this normal?
- dyno results on hooker lt's
- Hookers, ORP, and Loudmouth went on this weekend!!
- Trouble with my A/F guage
- Question about Metco Breather affecting Maf Readings
- Flowtech Cutout Wingnut Size?
- Descreened MAF or stock MAF
- What kind of mufflers are these? Muffler selection for true dual over axle?
