PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Kooks vs. TSP Headers
  2. Throttle body issues
  3. True Dual Setup, Need Help
  4. SLP MAF and Tuning
  5. Does this chip in this intake manifold look like it will leak?
  6. SSRA or SSRA megamouth
  7. Help a brotha out please...cam sensor woes
  8. FTP 104 vs 98 with 100mm MAF vs 85mm MAF
  9. Billy Boat (B&B) Exhaust
  10. Not sure what is stock, help?
  11. LS6 Intake..how to fix
  12. Advice setup?
  13. Remove EGR & AIR Pump Wiring ?
  14. coils not firing?
  15. Just installed motor and t56 and
  16. True duals setup
  17. Can running 1 cat damage engine?
  18. SSRA intake questions and opinions.
  19. New LS1 Guy, Exhaust Question
  20. BBK LTs & Y nice easy fit
  21. Headers on lowered F body
  22. Victor JR intake and fuel rails?
  23. Low mount alternator bracket for LQ4?
  24. Taylor wires suck r MSDs better?
  25. T/A Header Install
  26. What happened to K&N???
  27. Collectors leak
  28. Band clamp question.
  29. Any one have a mangaflow bullet dumped after y pipe?
  30. another O2 sensor thread...
  31. After market valve covers, which are good ??
  32. true duals vs catback
  33. Anyone have this exhaust setup? Spintech duals?
  34. 5.3 to 4l80e help!!
  35. Normal Idle Vacuum for Cammed 5.3L?
  36. Where Should My Thought Process Be?
  37. IAT cable and ??
  38. fast 85 mm intake
  39. What else now?
  40. Whistle sound after long tubes.
  41. 3.5 dual to 5 single bullet
  42. anyone know where I can buy this from???
  43. Anyone made this or see a problem with it?
  44. SD or MAF tune
  45. Who uses ARP header studs
  46. New Holley LS Mini Ram Intake
  47. P0171, Volant related?
  48. pcv question
  49. Exhaust leak under load? Header gaskets?
  50. Coolant bubbling over
  51. 1 3/4 header Y pipe to 1 7/8 and duals on 370ci?
  52. dmh cutout issue
  53. fast 102 couplers?
  54. Will I need a retune?
  55. March UD Pulley Users!!! Please Chime In!!!
  56. 100mm maf question
  57. Moroso 68352 good valve covers???
  58. Exhaust set-up thoughts.
  59. Silent exhaust?
  60. bbk headers rubbing
  61. help with maf id
  62. PCV system vs. Breather......Fight!
  63. SLP Stuff
  64. Dual cut-outs, any danger?
  65. need help installing header ASAP
  66. fast 102 and fast rails. issues?
  67. For the Guys With No Cat F-Body Exhausts
  68. super victor jr , what valley cover to use??
  69. LM4 Build combo
  70. 92mm TB to a ls6 intake?
  71. True duals question
  72. Loose Kooks merge spike
  73. State Farm Buying New Engine. Help
  74. question about x pipe..
  75. Best way to seal front of air box
  76. My custom chambered 'powerflo' exhaust
  77. Clear Coating a New Black Fast 92...any suggestions?
  78. L33 to LH6 intake upgrade?
  79. ls1 rain puddle=power surge and headlights flicker on and off
  80. Rough Idle, Especially When Warm
  81. Powder coating engine parts
  82. Car won't start. Security light on. I'll explain...
  83. Budget catch can?
  84. Chuck Mallet in QTP Booth at the 2012 Sema SHow
  85. aftermarket f body PS pump reservoir... does one exist?
  86. My budget your advice $1000, 02 z28....
  87. Pacesetter
  88. stupid ignition problem
  89. Cold air intake? Minor performance mods?
  90. sweet thunder question
  91. Going single in/out, need thoughts
  92. Problems with the new car
  93. PICS ADDED: Texas speed true duals w/ 3" dynomax ultra flo mufflers
  94. Porting and polishing my intake worth it?!?!
  95. Loud BOOM noise when starting after sitting
  96. oil pressure gauge
  97. 241 heads worth port and polishing?
  98. Can you use a single Cat?
  99. Help! LS1 wont start, idle, other issues.
  100. Intake over Radiator
  101. BMR Alt. Relocation on LQ9 HELP!!
  102. Help! Car starts only after a few tries.
  103. will a 2002 8.1L ECM work with my 99 4.8?
  104. OEM Crank pulley VS Aftermarket
  105. Where should I go?
  106. Herlux ignition coils??
  107. New exhaust sound with CME
  108. B&B Catback with Headers?
  109. What's going on with my O2s?
  110. Magnaflow
  111. Questions about Cutouts
  112. Need help with headers
  113. Help needed :( LS1 won't fire for more than a second!
  114. Add "cats" to an off-road y-pipe
  115. Dumb question!?
  116. Spark Plugs/wires
  117. Texas Speed Longtubes
  118. TSP duals and ARH
  119. Gains from 2" Headers?
  120. Glasspack on a LS1
  121. Edelbrock efi intake questions- Pics wanted
  122. Underdrive pulley questions
  123. intake swap
  124. Spark Plug Question
  125. Decisions, decisions...
  126. Thermostat Degree Selection
  127. Help!
  128. Am I just being cheap?
  129. cruise control delete help ! ?
  130. Need help on matching heads/cam/t/c
  131. at what point do u need better injectors?
  132. Possible vacuum leak?
  133. Clamshell alternative?
  134. Mid length headers?
  135. noob question about fitting ls6 intake on 5.3
  136. True duals without x/h pipe. Who has done it? How is the sound?
  137. Need urgent help fellas
  138. remove map sensor connection sucking air
  139. LQ9 Turbo build
  140. Fast 102 owners
  141. Ctsv accessories to c6 accessories
  142. BBK underdrive pully ?
  143. Heavy car, 400hp, and good mileage.. possible?
  144. which good intake
  145. Factory Tach
  146. NEED HELP ASAP! Vacuum Leak??
  147. Fuel pump check valve
  148. ZO6 MAF.... Do i have to tune for it??
  149. Ls1 to ls3
  150. Cc dumps track 1 track 2 fresh virgin
  151. PCV Oil Consumption
  152. Choosing between two Manifolds
  153. height of a 102 fast
  154. need alt. bracket help please!!
  155. check engine light for high voltage to coolant temp sensor??
  156. 1998 Coolant Temp Sensor Questions
  157. bad cat, now what
  158. ls1 bottem end ls2 upper anyone do it?
  159. question about fan wire mod..
  160. Measurement
  161. Misfire
  162. 243s to 862s ???
  163. True duals with madman torque arm
  164. Headers with air/egr provisions
  165. Have an exhaust set up question.
  166. Starter Bolt Issue!!
  167. Poly motor mount orientation
  168. Cost to have new a/c lines made?
  169. Flowmaster Catback
  170. CHRS1313 install questions.
  171. Failed Start attempt
  172. Seized Pilot Bearing
  173. 04 truck intake or NNBS truck intake, better?
  174. Which heads should i get?
  175. Checking for vacuum leaks... Propane didn't work!
  176. will volant cai fit under sleek beak
  177. Oil Pressure Sensor & Knock Sensor Questions
  178. WS6Store FAST 92 Manifold damaged
  179. stock bellows w/ a nw92mm tb
  180. 2000 ws6 intake swap
  181. Can I remove my Drive by wire?
  182. Caspers adapter to MAF?
  183. Needing a True estimate on getting Paint job........
  184. What motor mounts with my headers?
  185. 1 7/8 vs 2 headers
  186. Broken intake manifold bolt
  187. GM Head Bolts Break?
  188. Borla cutout help
  189. Problems after TSP True Dual Install. Any suggestions?
  190. Questions Regarding Intake Mani's and Cats/ORY
  191. What should i search for on ebay to find truck fead?
  192. Edelbrock Pro Flow intake manifold TB size ?
  193. How do i know which heads i need?
  194. pics of kooks true dual tips on a camaro
  195. Any pics of DIY 2-piece timing covers?
  196. wich exhaust for me?
  197. TSP TD's or GMMG
  198. What intake??? Mast,Holley High Ram, Super Vic??
  199. random misfire after header install
  200. ls conversion
  201. Electric cutout help!
  202. LQ4 Swap guys cmon in
  203. Hose diagrams??
  204. "Cool Flex" Radiator Hose
  205. Throttle body help!!!!!!
  206. powersteering?
  207. New mods..
  208. 25% ud pulley belt rubs on alternator bracket lower bolt
  209. NW TB Question
  210. Is it possible to put a small portable a/c unit in a car?
  211. underdrive pully qestion
  212. different size header bolts
  213. where to pull vacuum for headlights operation?
  214. broken exhaust manifold bolts
  215. Fuel injector question
  216. 02 LQ9 BDW throttle body no response..
  217. ls1 motor mount bolt question
  218. Fast 92 TB install
  219. pn for accessory belt
  220. Coated vs Stainless steel
  221. Removing all the accessories?
  222. 3" exhaust with UMI short TA, Who has pic of theirs?
  223. Need input on intakes!!!
  224. Finally installed my ARH 1 7/8" longtubes today...
  225. Reinstall intake or value covers first??
  226. Wire mod done... what is this for???
  227. Texas Speed headers good reputation?
  228. GMMG with CME question
  229. New to LS motors
  230. main engine harness.
  231. 01-02 manifolds
  232. Should I replace the cat?
  233. Need Advice on a intake set up (ram air).
  234. I think i got RIPPED OFF from ebay !!!
  235. LS1 swapped truck. Running rich and lean on different banks
  236. Can anybody identify this throttle body??
  237. IAC sensors
  238. How much I am leaving on the table?
  239. 102 intake problems
  240. turbo ls1 leaking oil between motor and tranny!!?! not main seal!
  241. Intake Gasket change now p0107 code and tcs off light on
  242. low idle after intake swap
  243. Valve cover bolt spacing?
  244. older fast 90 tb sticking closed/off idle
  245. Best Priced FAST 92 TB??
  246. Starter Question
  247. broken intake manifold bolt
  248. A/C Wiring Diagram 98 Trans Am?
  249. 408 spec'd cam in a ls1
  250. Comparison Pics Potz TB And Maf to STOCK
