PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Harmonic Balancer Flew off!?!?!?
  2. best lsx intake chose ? fast , ls6 , weind for blower n20
  3. Power loss and backfires afer exhaust install
  4. Coolant through intake
  5. Suggestions on getting car up in air for header install
  6. Stroker Build Coming Along/Pics
  7. Will this 85mm throttle body work with my Holley/Weiland intake?
  8. trickflows + ms4 ptv clearance
  9. Patriot stage 3 heads 6.0 Cam choice???
  10. sounds like a corvette??
  11. couple fast 90 install questions
  12. Fuel Pump on it's way out... Hesitation at HIGH RPM...
  13. Jet Hot LT's installed
  14. Anyone know where I can get this piece?
  15. Header Install Problem
  16. Sound deadening advenures... New tips... (Just read)
  17. MAC headers discontinued? What to do.
  18. Bullet
  19. Issues getting crank bolt out... Help with Ideas
  20. Alternator
  21. Coolant Sender Location - FINALLY FOUND!
  22. Msd Super spark coils and Random misfire code
  23. Pacesetter long tubes rusting
  24. My SES light keeps coming on. HELP!!!
  25. Wont start!!!! Out of suggestions!
  26. loud ticking PLEASE HELP!
  27. Fuel rail fitting
  28. Is this a Head Gasket Problem???
  29. Anyone using Dynatech 1 7/8" Headers w/ slip on collectors?
  30. If and when my fuel pump goes should I go with stock?
  31. Exhaust Shipment
  32. supply/return on water pump holes???
  33. When is a 3in true dual needed over a 2.5in?
  34. race muffler off the header?
  35. March vs. ASP Underdrive Pulley Questions
  36. ABS module question
  37. ported throttle body
  38. fuel pressure regulator
  39. Need to tune a car after, short or mid tube header install?
  40. Polished BBK intake?
  41. exhaust help
  42. Drive By Wire Throttle Body ? for a LS6 Motors
  43. ARH 2in race header and 4in race muffler sound clips
  44. Please help!! Fast 90 worth it?
  45. 90mm air lid?
  46. how hard are motor mounts to put in on an F-body?
  47. can anybody post pics of your cme from under the car
  48. Scored a TSP true dual Set-up today
  49. accessory drive part # and cost?
  50. ls6 intakes
  51. Any sponsors have plans to do real world testing on the F.A.S.T. vs. Street Warrior?
  52. Aftermarket 90MM DBW TB??
  53. has anybody tried 2 port a fast 90 2 100mm?
  54. questions about 317 heads
  55. stock air lid modification
  56. thermostat
  57. stock exhaust??!!
  58. hidden coil valve covers
  59. tsp tds hang to low
  60. clunking/banging noise when spinning out/shifting
  61. Atlanta area tuners
  62. cam spec question?
  63. 1998 AIR Quick question??
  64. Removing intake MAP fitting?????
  65. early xmas - ar headers!!!
  66. GMMG tube sizes? length?
  67. What to use to cover battery
  68. Need help
  69. Oil Pressure Sender Threads?
  70. Injectors?
  71. VIC JR & Aaron Elbow owners
  72. New exhaust set up
  73. wheres the new weiand intake?
  74. intake install ?
  75. #5 Has Water....F*CKING PISSED
  76. Oil catch cans
  77. O2 Sensor(delete)
  78. what is a good fitting Y pype
  79. headers?
  80. Leaky Meizere EWP? Picture inside
  81. PTV clearence on 5.3l heads?
  82. new SLP ceramic coated give off less heat ?
  83. I Have a very Strange Cooling Problem
  84. Is this normal?
  85. SLP Underdrive Pulley
  86. emergency brake adjustment
  87. ls1 stainless headers on ebay.....
  88. LPP performance part headers? anyone running them???
  89. trying to change my exhaust note!!!!!
  90. which headers
  91. 2004 Ls1 Head Bolts??? Mid-year change???
  92. smaller pulley
  93. Weiand intake ?
  94. Help with gauges on swap
  95. How much will this combo make
  96. 2 Borla mufflers in-line = QUIET?
  97. True Duals Back In Stock at Texas Speed!
  98. X-merge before cats or vice-versa?
  99. ARH Exhaust
  100. MAf sensor quit working. any quick fix tips?!?
  101. Which spark plug wires?
  102. BBK SSI Intake Discussion
  103. MotoBlue UD Pulley?
  104. under drive pulleys
  105. quick heads ?
  106. Quick ?
  107. Should I trade my Hooker Catback + Cutout for Under the Axle Duals w/ XR1's?
  108. more questions about ebay headers i know...
  109. Lid
  110. Long tubes ory flowmaster cat-back
  111. MAF sensor questions
  112. Flowmaster merge..
  113. horse power help
  114. Will this work...
  115. Has any one used the jantzer 92mm throttle body?
  116. broken Magnaflow kit... post pics of your magnaflow install!
  117. What Headers for my 2000 Z28 ????
  118. Is there a Sticky or anything on how to intsall headers
  119. Spiral Flow Outside diameter?
  120. Ported Throttle Body...worth it?
  121. another ebay header...
  122. Whats the biggest TB I can fit on an LS6 intake?
  123. Need STS Diablosport tune
  124. Custom quiet TD exhaust setup questions
  125. TSP vs. SLP LM1
  126. stock throttle body
  127. QTP header install problem?
  128. Which flywheel setup??
  129. Another Hard One (Carb Guys)
  130. Starter keeps snapping
  131. Help with intake??
  132. Recognize this exhaust?
  133. i know its a stupid question but
  134. Deluxe Seat Heater Kits
  135. power steering reservoir leaking, how to fix?
  136. exhaust?
  137. Anyone know about this TPIS TB ?
  138. Catback
  139. 408ci head gaskets
  140. Which TB for Fast 90 intake???
  141. TR6 to TR55. Need a change in tune?
  142. So what to get for christmas....come vote and share your list!
  143. From where i can order this thermostart ?
  144. Is anybody running edelbrock "stepped" headers ??
  145. LPP headers
  146. Valve Cover Swap
  147. U.D install
  148. Need a good idea for gift/gifts for my dad for Xmas
  149. Keep stock CME or Upgrade??
  150. motor mount????
  151. 241's
  152. narrowest rear?
  153. Wanted: Stock MAF housing
  154. downgrading from true duals?
  155. Fast 92 (HELP ,INSTALL )
  156. ls1 starter
  157. Alternator Disassembly...
  158. Hollow rattle sound from muffler area
  159. 3in cut-out V. 4in. Magnaflow muffler
  160. Which Y-pipe for the CHEAPEST Ebay headers?
  161. zo6 02vs c6 07
  162. O2 Bung Plug
  163. ls1 in 69 maro
  164. In with the new and out with the old, ARH vs Kooks
  165. Where can I get a replacement filter for the K&N FIPK
  166. EGR valve and headers? What to do?
  167. Cleaning a FAST 90
  168. Bbk lt?
  169. routing knock sensors wire/wire plug
  170. patriot or TSP heads?
  171. Heat problem!!! Need some help
  172. Spark Plugs
  173. money's no object, can a set of 241 heads compete.
  174. Problems after installed the lid
  175. guys converting to carb setups what are you doin with your harness?
  176. How much Do MDS coils Help?
  177. LS3 accessory drive
  178. Anybody know if the Street Warrior intake is any good.
  179. LS2 243 heads onto LS1
  180. anyone know where to get this hood?
  181. Powersteering Pulley
  182. sound
  183. Magnaflow Ovals Chevelle LS1 Video
  184. oil pan
  185. ? for people with hooker headers
  186. MSD on Steroids
  187. EGR/AIR manifold size question
  188. GM hot cam
  189. hooker 1 3/4 header
  190. stall converter for a4? Benifits?
  191. Installed my LPPs over the weekend - review
  192. how do you hook up a wideband on TDs?
  193. Show me your aftermarket fuel rails/lines!
  194. MAF minus the screen??
  195. Who's got the cheapest 1 7/8" headers?
  196. Motor-mounts Backwards?
  197. need to find part# or info on thses parts [ pics]
  198. coolant lines and intake minifold swap
  199. bad cat what do i do???
  200. Catch Can/Seperator
  201. How much $$ to complete?
  202. WS6 Stock Exhaust vs. True Duals IRL
  203. Grotts
  204. Power diff. w/ cut out open vs. closed
  205. FAST 78mm tb to 78mm intake - quick silly q
  206. lid vs CAI?
  207. Ported MAF
  208. need info on two parts
  209. A New Catback, Need Suggestions
  210. Where to get these brackets for TD setup
  211. whats the diff. between these 2 magnaflow mufflers
  212. vacuum inlet for AC on back of fast 92/92
  213. Oil leaking from heads!
  214. pace setters.
  215. 2 Videos, 2 Problems.
  216. SLP lm1 vs. GMMG???
  217. 5.3 TB the same as the LS1 F-body TB?
  218. Headers came in.. take a look
  219. Help me decide which ported TB
  220. Which is better????
  221. true duals, got questions
  222. Good deal or not?
  223. which intake
  224. re-installing AIR and EGR
  225. intake
  226. Is 90mm to big
  227. AIR question; backfiring? gas mileage? valves? (mostly gas mileage)
  228. Swap a fast 78 top for a 90?
  229. p0410 how do i get rid of this
  230. Slp lm1
  231. true dual pics plz
  232. ARH + FLowmaster + DMH cutout Clip
  233. How to clean inside of ls6 intake manifold??
  234. Sweet Thunders?
  235. Throttle body questions.
  236. Lq9
  237. Trouble Accelerating
  238. Decided on the Weiand
  239. coolant lines under intake
  240. Will a ARH Y-pipe fit Kook's headers????
  241. TDs and quit"er" mufflers
  242. Stock intake gaskets work on FAST 92?
  243. Heat Wrap for headers?
  244. Broken Starter Mount on Block!!!
  245. LT's Whats your choice?!
  246. Duals w/ Pro-kit??
  247. GMMG/cutout
  248. Rear out of 3rd Gen???
  249. Help me plz!!
  250. Why do we choose MSD wires & why change plugs to improve lost tenths @ the track?
