View Full Version : Generation III External Engine
- Anyone else order their 1 7/8" Speed Engineering headers?
- DMH cutouts? Junk?
- What heads for Speed inc SI6 cam? To many choices out there.
- New ATI balancer/Evans water Pump
- which injector?
- oem waterpump part number
- 4.8 surge at idle
- valve covers
- ALT issues when HOT
- Denso A/C compressor question
- Cruise control module
- starter staying engaged
- Rear Steam Tubes Fast 102
- Wtb lq9 6.0
- TFS heads
- LS1 valve covers
- LS1 coil packs
- Lq4 running rich
- help! texas speed catted y-pipe fitment issues
- 4" have rasp?
- Crank Pulley mishap
- LQ4/9 in 99 C5
- Pacetter LTs vs BBK LTs
- Radiator caps?
- oil catch can
- 99 f body header installation
- Low rpm missfire
- lq4 swap
- Converters and tune.
- LS1 valve cover on LS3 heads
- alternator question
- Rear o2 Sims?
- Corsa Catback
- need help on header identification
- Alternative Y-pipe for 1 7/8 Kooks Lt's
- Charging / Alternator / Exciter Wire Questions
- Race Ready Performance e-cutout - Lifetime Warranty
- 02 Bung Location w/ Shorty Headers
- Slow cranking and won't turn over till you pump on the gas pedal
- CHEAP Metal Spoked Power Steering Pulley for LS1
- LS2 Inlet on LQ4
- ATI UDP question
- Holley valve covers.....
- LS1 w/Hydroformed “tri-Y” 2014 Z/28 Exhaust Manifolds?
- 5.3l TSP torquer V2 and Aerochamber exhaust
- L77(same as L76) in 2001 Camaro drag car
- motor alignment problem...
- Used longtubes/y pipe on ebay
- valley cover
- LQ9. What PCV system to run.
- Fast Billet Fuel Rails & Fast 102 Questions
- Dual Exhaust
- Quietest muffler?
- TB size for 6.0
- Coolant Temp Sender 90deg elbow - where to buy?
- Starter question
- Will LS1 Pacesetter LT's fit a 2000 5.3 Silverado?
- fast intake advice
- Fast 102 Fitiment Questions
- Anyone in TN, KY, AL want to trade their catback for LPP True Duals?
- single chamber dual out.
- mast small bore ls3 heads for ls6
- Which head bolts??
- Best Starter Motor lsx
- Cannot Get the Exhaust Hanger Bracket Around Hanger.
- question about texas speed catted y-pipe
- Cut-outs and the CAT-
- Need muffler input...Please
- Are the 2 connections on the side of the throttle body replacable?
- Showing off my new exhaust. 4 inches of fun!
- 92 mm FAST INTAKE ISSUE
- cam/Crank sensor bolt size
- alternator issue!!
- sound on reving? borla cat back? VIDEO
- Removing the Harmonic Balancer has to be easier than this
- Always low coolant
- anyone modify a pacesetter y pipe?
- LS1 Belt Kit minus Aircon & Powersteering
- New 427 motor now have bank 1 rich and bank 2 lean help
- LQ4 with an LSA supercharger kit? Anyone try this?
- EGR Block of with IAT sensor, link provided
- Help! Broken plastic channel on valve cover!
- Anyone upgrade and want to sell me your FTP 98mm Lid?
- porting/powdercoating TB
- alternator upgrade question
- porting 5.3 truck intake?
- Just got my first LS1 - need some advice on mods.
- 4l60e passenger side dust cover size
- Oil cap cause vacuum leak?
- Gains with UD pulley w/ graph & vids
- What is this thing? (Intake manifold piece)
- LQ9 brackets
- LM2 muffler into SLP CME catback?
- dipstick
- Need help. Starting issues.
- Tuning with Pypes High Flow Metallic Catalytic??
- FAST 102 or Clutch
- TSP ory and th400 t/a relocation bracket fitment issue
- ls1 throttle body gasket?
- Be-Cool Package
- Fuel system question
- Nasty pro touring fuel gauge sending unit issue?
- LS1 H/C swap, have 90MM TB, what intake
- My results swapping my lmII resonator to a powerstick.
- LQ4/T56 S10 Questions
- Want to put A/C back
- My solution to the fast 92 high idle problem
- Corsa catback
- cam, ls1 exhaust cut out quaustion?
- Getting a TSP Rumbler soon, had a quick question
- Which one, lq4 or 9 to buy for a fully built 4l60e?
- DBW gas pedal help!
- ls2 water pump on 5.3?
- Where to buy 4inch manual cutout
- dumb valve cover question
- Gotta put cats back on for inspection
- LS3 injectors and rail on LS6 intake?
- Which Manifold??
- intake, suggestions, advice
- belt drive arrangement
- Headers and exhaust problem
- map sensor retainer clip?
- 60% ATI underdrive pulley?
- PCV harness
- MAP Sensor Relocation
- fast 102 oem style fuel rails?
- Lg header install
- NEW Timing Chain
- Normal to have sludge so quickly
- intake/tb 102 worth it LS6 NA?
- Looking for some insight. Car has loss of power when warmed up
- Cut outs
- Who's made a custom ORY? I need a parts list
- starter issues 5.3
- Where can I buy this vacuum fitting?
- Help with aem uego wideband.
- 01 ls oil pan
- Nick Williams 102mm Blade Gap and vac leaks
- Intake duct between TB and MAF ?
- Exhaust ideas
- hi-ram sensors...
- 98 Z28, TB/Intake/Goo questions
- Pcv routing ? For 98 ls1
- my exhaust too small in diameter?
- good nitrous kit for carb 5.3?
- Need some electrical help.
- What benefots if any switching to electric water pump?
- Brake booster line goes where? Lq4/LS3 build
- A/C compressor
- Msd 5096
- Am in trouble or not? Valve seals
- Next Mod?
- Afr 205cc which headers on c5 corvette
- Proper gap on tr6 plugs
- Fast 102 has confused me already
- LS truck/car engine harness differences
- remote water pump setup
- Confirmed: EB Pro Flo XT will fit under WS6 hood
- I need hellp identifying my powerbond balancer
- Sux2bu intake
- Throttle body cable
- need help with front accessories
- Which custom wire harness? Pros and Cons
- modification help
- Kooks LT to pace setter ory
- What did u do to get rid of "rasp" sound
- Headers?
- 67 skylark power steering
- WTF!!! Air box doesnt have air filter tray
- Y-Pipe Scraping on 1" Lowered Camaro
- Dual exhaust pics
- starter?
- Headers too big?
- Quick Questions Intake and exhaust
- ls1/6 alternator question
- WTB: FTP 98mm Lid
- Intstalling TSP headers and ory, any tips?
- Fast Vs Typhoon Manifold
- throttle position controller
- Largest Capacity Oil Filter?
- dynomax 17536
- Intake upgrades??
- Bolts!
- Intake restriction
- ls1 coolant temp reading newbie -39 help!!!!!!!
- Dorman Balancer slides right onto snout...
- how much
- Bang for your buck HP help!
- Block ground loose
- LS Intake Heat Shield
- Fast 92 porting question
- Prestone Flush Kit Install Guide- LS1 engine Camaro
- Stock manifold
- 4" exhaust with factory style muffler
- Very high idle after coil pack relocation??
- Help Choosing A Intake Manifold
- intake manifold heat sheild. does it work?
- 2002 LQ9 Must Do upgrades before install?
- FAST 78&90mm bolt questions
- Quick Help! Header Bolt
- real feedback on S&P Maf Needed
- Single magnaflow with single exit 3"?
- H or X pipe? in a 85 Vette w/LS1
- WhAt bellow to use for 104 lid and 100mm maf
- 9" bullet.
- TSP Headers and ??? Y pipe, with cheap cats
- Conical Valve Springs from Comp -Anyone Tried These?
- Wanna get my vert into the 12's 1/4 mile
- Bolt On, Over The Axle True Dual Extensions? Anyone Made These Yet?
- Stupid injector question
- TB + Intake porting recommendations
- How do I make my VFN hood work with the RAM AIR?
- Did Holley ever fix the casting problems with the High Ram, and other questions
- Thinking about a exhaust cutout for my 99 SS
- Interested in High Flow Cat's
- IS it worth porting a LS6 intake to ported LS1 heads?
- Harmonic Balancer Seating?
- Replacement MAF tubing
- Changing Valve covers and have an issue....
- hey kooks true dual guys
- Good exhaust set-up for California?
- will nw 92mm TB fit ls6 intake
- Cruise Control Cable
- Newer style LS2/LS3 coils on a LS1 Camaro will they work? Is there any gains?
- no spark! help :(
- Tap stock radiator?
- Gen 3 to gen 4 conversion
- Mufflex catback opinions needed
- Which one is for the MAP sensor??? Picture
- Coil mounting???
- 5.3 ls1 brackets
- 1 chamber vs. bullets
- Quest for Bolt-on 11s
- what is this... lol please help
- Cruise and traction control delete. ?? Lost
- Fast 90 intake install problems..
- ls1 terminal battery fuse cover
- Engine break up under load
- 94 Trans Am LS1 SWAP w donor car. What else do i need?
- 06 5.3 crank adapter problem with 4l60e
- Hi Ram port alignment
- Ls6 exhaust manifold question
- Pressure washing my engine bay...what to cover?
- Fast 92 question
- LS1 intake on 5.3 fitment
- map sensor help
- Lm7 bolt on build, need some cam suggestions...
- Exhaust holding car back?
- Ls1 seems no more powerfull then my lt1
- Help with belt routing and brackets
