- Starter mounting tab broke!?!
- vararam filter???
- Headers Question
- I ordered the Jet Hot Y-pipe
- heard stainless headers like to crack.... is this true?
- meizere wp/ drill stat? reuse gaskets?
- Another benefit of poly motor mounts...
- volant vs. fipk vs. tsp vs. stealth
- B&M Engine Oil Cooler
- Carbon Deposits in Intake
- Got a cool NEW intake Idea!!!!
- Qtp electric cutout rocks.
- Post Your Exuast Sounds Here (Audio or Video)
- Accu-sump / oil coolers and hose sizing
- Installed an exhaust cutout a few weeks ago and......
- DynoJet vs Mustang
- Just got my true duals installed!!! Pics Inside
- Any of you run a K&N or Holley without...
- Curious as to what long tube headers to get???
- LS6 Intake!!
- true duals
- I installed GMMG!!!!!!
- What plug to use for EGR hole in intake?
- sound clips
- Gas pedal slack????
- question about loose hose??!!
- question on hooker catback
- Fuel filter, owners man. vs. real life( different #'s)
- Electric Cutouts on lowered Fbody?
- Look what mr UPS gave me :)
- Would somebody explain What Longtubes will do to my Air/Fuel
- Meziere Street EWP installed and impressions. lots o pics
- Advice should I remove the CME or keep it?
- So if an MAF makes you run leaner...
- Hesitation?
- Car running weird... help pls
- WORST THERMO INSTALL EVER!! $225 and 4 days later...
- 3" bullet cats who sells them cheap
- How hard is it to install a Brake Master and brake Booster?
- SLP MAF question...
- What sensor is this?
- air restrictor mod or remove air system
- Best plug wire for heat resistance?
- Shaner S2 TB ???
- Where can I find a stock Maf sensor?
- Exaust pop
- motor mounts
- New Meziere Electric water pump pics, mine looks different
- Greddy Catrch Can installed pics setup OK?
- running without cats...any problems? backpressure and codes?
- crankcase vent filter
- A/C problem
- SAMCO hose kit from LPE
- Did they send me the wrong size electric cutout?
- How the heck does this thing come apart?
- Gutting Cats
- Exhaust size - 3" or 2.5"
- Cyclone anti reversionary headers Does anyone remember them?
- Convertibles and Headers
- Car problems
- Starter issues??
- Mac headers
- Speed Inc duals just installed with dyno....
- Should I put Dual Cutouts on my Unflowing Mac Y-Pipe??
- catback comparison
- FLP's are in.
- Driver's side valve cover breather??
- Will 98' Mac Headers fit my 2002???
- True Dual Loudmouth
- SLP LS6 Intake
- QTP Header questions
- should i get tr6 plugs?
- Best Sounding Muffler
- Where is the engine block to chassis ground wire?
- Headers rusting
- anyone with Lane's True duals kit, please read
- Dynomouth.
- electric cut-out.?????
- Who makes a good ignition wire
- What kind of gains will I see?
- FTRA or Ram air II
- Do you all really think Flowmaster sounds that bad?!
- Best Place To Buy SLP LoudMouth
- a few ?'s about true duals
- headers...what problems can come from doing them? and prices
- AC Delete, whos done it?
- Exhaust pics, Macs, 18 inch bullet and cutout in the I-pipe
- FYI when installing Pacesetters...
- Descreened MAF replace or not?
- Quick question for replacing injectors
- metco breather ?'s
- Will a Borla catback from a 98-02 fit on a 96 Trans Am?
- LT's with Cats? Pics?
- PPC 3", Headers, Y-Pipe and Cats?
- Pacesetter Y Pipe????
- coolant temp gauge from autometer hook up? help me!!!
- Descreened MAF
- Looking for your exhaust recommendation....
- Which XR1 for LM
- newbie here, what should i do?
- Spark plug gap for n/a cars
- Magnaflow Pics
- Will putting on my LT headers richen up my Air/Fuel??
- Pretty set on hooker catback. Any others worth considering?
- Running battery to back of car?
- Proposed exhaust setup...
- full length pacesetter headers on ebay?
- MAC vs Grott dyno #s
- Dual owners, anyone have 2 1/2 inch pipe?
- Electric Cutout pass Emissions(visual test)
- Edelbrock true duals preliminary pics
- Thought it was suspension squeaking, but its motor related
- Water Pump Stuck to Block
- Air Bag
- Headers
- Checking wiring
- Spark plug #8
- O2 extension locations
- What Plugs should I get??? NGK TR##IX????
- Super Sucker Ram Air scoop for the FTRA
- borla
- Could a ported TB cause a low/rough idle?
- Tips for disconnecting the steering linkage?
- Bought a dyna battery like the one on thunders website HELP!
- FLOWDISASTER!!!!!!!!!!!!!!!!!!!
- Need help with header install quick
- Thanks for everyone's help on Exhaust....
- What compnay has the premade true duals?
- Crank AND alternator pulleys, or just go with the crank?
- What belt to use without the power steering pump/pulley
- Those using Dr. Gas X Pipe, need help ASAP
- Impressions of Magnaflow over Flowmaster 80 series......
- Installing cats
- Loudmouth
- Pics of TSP Lids?
- air/fuel pod hat shows ratio????
- headers
- Hey Silver TransAm those dual/duals.....
- Stock Throttle Body Hole Size
- Re-position MAF?
- Next mod???
- MTI vs. TSP lid: Which is best
- Lokar throttle cable
- Forum Director - Marker
- Who runs FLPs with the dual dual and CATS v. OR pipes
- Pacesetter Y-Pipe: am I missing something?
- My new PPC headers
- Valve Adjustment on LS1
- Be Cool Radiator Has Arrived
- Best entry level ignition system?
- How to check a plug wire to see if its bad?
- To dieletric grease or not to, that is the question
- which Y-pipe to use with the edlebrock headers
- TB drill hole size
- I need to add a muffler to LM . where and which one?
- Another good day!!!!!
- Where to put water temp gauge sender?
- People that have installed tranny coolers, IN HERE.
- cold air intake
- LS6 intake????????
- Questions on TR6 spark plugs
- PCV modification, what are my options?
- Can a mismatched set of plugs cause Knock Retard??
- Opinions on cats needed.... Please!!
- Relocating fuse boxes?
- Guys with Mufflex Y pipe....
- Check out this Electric water pump!
- Just Installed FLPs On A Vette...
- Anyone have the TSP intake package?
- Got my T.B back From Bauer.........
- New Corsa exhaust and HUGE gains in gas milage!!!
- ORY + O2 simms = knock???!!! help...
- Can Anyone Help?
- I F***ing HATE Dynatech headers!!
- Knock Sensor Install - Help Please!!!
- Installing coil packs???
- Magnaflow...
- Stock exhaust?
- crankcase vacuum
- Is a Corsa Exhaust loud????
- What gap for NGK TR55s?
- Electric water pump?
- mac y-pipe with cats
- Are 2 1/2 inch duals enough ?
- Lowest price for a new AC compressor???
- New LS1 intake.. Coming Soon!!
- best mid-length headers and y-pipe combination?
- GMMG Muffler
- Header Install ????
- Plug gaps
- Banks Exhaust
- The very cheapest youve seen the LS6 intake....
- best Sounding Muffler?
- True Dual People - What Muffler you using?
- Where to buy 18" Dynomax Bullet Muffler???
- Dynomouth or Muffler
- Cats or NO Cats
- All possible reasons for a cylinder not to get spark?
- Low end loss w/ LT's????????
- Header y-pipe install prep
- 160 T stat......worth it???
- DIY Manual fan switch.
- Cooling problems!
- Pacesetter headers?
- SLP Cold air as good as FTRA or SSRA
- Exhaust system inquiry
- racing use only (?)
- spark plug gap, whats the deal??
- 1 7/8" Kooks sound AWESOME. No more rasp!
- Electric Cutout vs. SLP LoudMouth...
- Corsa Premium Pro- Series Tips ?????
- Smooth Bellows: The cheap way
- dual exhaust
- Anyone have a Corsa Exhaust Clip?
- Just curious...what is the exhaust popping at cold start
- harlan light and battery swap
- Macs
- Thanks for your opinions, what about air out now.....
- lingenfelter intake manifold question
- Those who have SLP headers......
- High flow cats?
- Putting together a QUIET high flowing exhaust...
- hooker cat-back exhaust for sale
- Hot Rod Power Tour 2003
- GMMG exhaust question
- Part numbers for stock and truck PCV setups?
- Pictures of Pacesetters Coated and installed!!!!
- Header and loudmouth
- Please help me out with gauges
- Airbox opening on WS6 vs Firehawk?
- Need Site Information for Cats
- What was your gain from adding headers?
- what's the deal with the A/M intakes?
- Are there any aftermarket belt tensioners?
- electric cutout on stock exhaust
- LS6 Intake...Never expected...
- 1 3/4 vs. 1 7/8 kooks headers
- Will this be too loud
- SLP maf Vs stock maf
- Reading Spark Plugs..need some help
- 3" True Duals + G2 Super Springs = no ground clearance
- Anyone have a picture of a stock LS1 power steering pump?
- Blackwing Lid?
- JetHot's new Y pipe for Hookers with Cats - details?
- Question About New Exhaust Setup....
- Finally took some pics of my exhaust
- Serious Serious Problem!!!! Please come in
- Serious Serious problem!!! PLEASE COME IN
- Loudmouth with dual QTEC's
- what should I gap the NGXTR55IX?? at..... 50 ?? 55???59???
