PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 [315] 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. wrapped headers?
  2. Do I need new 02 sensors?
  3. is this what im looking for......(exhaust)
  4. i know it is internal
  5. New Corsa muffler disintegrated
  6. Anyone here benefitting from cutouts on a true dual exhaust?
  7. Urgent Spark Plug/Wire Question!
  8. TR 224/227 114 LSA Cam
  9. under drive pulley problems!! please help
  10. NGK's Platinums or not? why?
  11. AIR Pump Removal
  12. Custom Y setup for Hookers w/ cats.
  13. 15.8 mpg???
  14. fuel pump for fuel module??
  15. Hooker LT`s & o2 extensions?
  16. What are the main down sides to Hooker LT's?
  17. please help car keeps throwing serpitine belt
  18. At last rid of rasp!!!!
  19. about flowmaster catback????
  20. Paging users of the Hooker & Borla cat back
  21. Go with SLP 85 mm MAf, or the Z06 85mm MAF???
  22. torque converter...????
  23. new spark plug wires?
  24. Airborn coated headers?
  25. Whats wrong with running a 160* thermostat?
  26. Torque Specs for Bellhousing bolts please?.....
  27. What cat back flows best?
  28. asp crank pulley
  29. what to do..................???? hell if i kno
  30. yes...another exhaust question..???????????
  31. Dipstick in way of headers
  32. Has anyone ever had their SLP longtubes hitting the steering knuckle?
  33. Best Airlid
  34. Hooker 3" Cat Back System
  35. LS6 Intake Identification
  36. around $200 to spend, what mod would you guys recomend?
  37. How to tell if the O2's are bad????
  38. K&N FIPK and SS Camaro
  39. Best Cat Back Exhaust System ???
  40. Will a MAF or MAF ends help me get more power out of my cam?
  41. Anyone try a 99+ gas tank in a 98 car?
  42. Wet carpet when I run the A/C
  43. Aluminum header gaskets....
  44. Whisper Underdrive pulley
  45. Magnaflow muffler questions
  46. true dual exhaust?
  47. Oil Derivative plate for header install
  48. SLP's Loud Mouth?
  49. Help How the F#@& do you remove the steering linkage
  50. Installed my true dual w/ x-pipe on my M6 SS yesterday - Pics Inside...
  51. SLP Install?
  52. Car is running really hot what to check first
  53. belt problem
  54. Trying to figure out gears!
  55. Corsa installed at Thunder?
  56. NE1 with mufflex, have pics showing tips?
  57. FLP's vs. Hooker's
  58. calling nineball
  59. Can anyone give me a reason not to get Hooker LT?
  60. Nitrtous raffle
  61. bosch platinum+4 spark plugs?
  62. HELP.......What to do!!!!!!!!!
  63. Question about aftermarket external fuel filters.....
  64. ASP Pulley voltage question
  65. Who built this Ram Air system?
  66. Picked up 25rwhp w/ true dual exhaust
  67. ANy pics of TAs with X-pipe exiting out the back of the car?
  68. Help.. need thermostat info.
  69. Cartek Ported TB vs the competition
  70. Headers/Custom Y questions, and first post
  71. Noise
  72. Exhaust question on heads/cam car with Borla
  73. Stock WS6/SS exhaust: Is there improvement?
  74. Holley Intake (basic problems)
  75. People with sumped gas tanks...
  76. flowtech cutout
  77. Running Rich!!!!!
  78. Need a GM part #, please
  79. if i use top end cleaner or seafoam?
  80. Headers
  81. headers or Y-pipe or both
  82. spark plug wires
  83. A/C belt ???
  84. Mandrel Bends
  85. Crank Pulley question...
  86. exhaust experts wanted
  87. WALBRO PUMP?
  88. IS this cutout location good for ET/MPH?
  89. FLP vs SLP LT
  90. Received the Lingenfelter EGR mod for an LS6 intake.
  91. Which is better true duals or y pipe?
  92. Dynatech users!!!!!!!!!!!
  93. Ignition??
  94. New member question
  95. Secondary Air Injection (AIR) System Bank 1
  96. FTRA or SFIK?
  97. cutout question
  98. Where can I buy some AIR tube block off plates for my FLP LT's
  99. Newbie w/ LM question
  100. What Converter??
  101. ANYONE ever have a good experience with ASP alt. pulley???
  102. adj fan mod problems
  103. Anybody having problems with ASP tensioner pulley?
  104. Installing a New Bauer Throttle Body, Hard?
  105. Smoke when revving!
  106. C5R Valve Cover owners Step inside
  107. LS6 intake vs holley intake
  108. Katech Solid Adjustable Billet Belt Tensioner
  109. the longest 14 hours
  110. Are rear o2's same as front o2's???
  111. Vendor List
  112. Are the '01 FLP's a direct bolt on?
  113. MAF HELP!!!
  114. LT's with the best ground clearance?
  115. Ported Throttle Body
  116. Has anyone tried the Qwik Stick.?
  117. Anyone know how to contact Bret Bauer (for ported TB)
  118. Hooker LT install ??
  119. My car cam's hard, but i dont have a cam?
  120. What thermostat for my 408 Stroker??
  121. BBK TB questions...
  122. Need Help:Building My Own Exhuast!!
  123. WHAT MAF????
  124. Bellows Smooth or ??
  125. What sponsor has the LS1 Motor Plate ?
  126. What next??
  127. backfire between shifts?
  128. Does The IAT Timing Tricker Mod Work?
  129. Keeping HP with True Dual????
  130. Who's Ported Their TB?
  131. Will this setup work???
  132. o2 sensors
  133. Costco has Optima red top for 104.00
  134. Headers how?
  135. Weld Pro Stars for everyday use
  136. Headers or y pipe
  137. People with LM and LTs........????
  138. Corsa exhaust tips? Are they sold seperately?
  139. still learning please help
  140. Can someone explain
  141. header question...(?)
  142. gay cop with exhaust problems
  143. rear end poping?
  144. ported 2000 manifolds vs my stock 98 manifolds...is it worth it?
  145. all LS1 water pumps the same?
  146. Lucas oil stops whinning steering pump
  147. Tire Pressure
  148. Got 1000 bucks saved up. Time to help me with my exhaust decisions.
  149. Any HP loss with Bullet Muffler?
  150. Intake Gaskets Reusable?
  151. Pics of my Grotyohann Y
  152. Who has the Stealth High-Flow Airbox?
  153. Anyone tried to reduce resonation from a cutout?
  154. LS6 intake or not
  155. Off Road Y-Pipe?
  156. QTEC(quicktime electronic cutout)
  157. NEED HELP FAST>>>PLEASE!!!
  158. a/c ?
  159. Direct-Flo Airlid------ or SLP Air Lid
  160. New gas tank with 427?
  161. Gears
  162. Can someone help out a newbie please!
  163. Need your help with a ticking noise from my car
  164. question about thermostat
  165. Loose Terminals on NGKs...can this cause loss in HP?
  166. Hotcam
  167. these race pipes fit?
  168. cat back poll
  169. fuel system for mti 382 all bore and tnt 100 shot
  170. Truck style intake on LS1?
  171. 4 RWH with ported TB.
  172. installed Ls6 intake.. now my AC doesn't work.
  173. Questions about drilling the Throttle Body
  174. 17 Rear Wheel HP from Muffler only
  175. To those with LTs and cutout before the axle, and wanting to add a bullet...
  176. when revving to 6000 rpm, my engine hesitates fro a slight second
  177. Where is everybody putting their cutouts these days?
  178. getting rid of DexCool
  179. direct flo lid
  180. Explain why a bad coolant sensor causes startup/idle issues
  181. best headers for camaro?
  182. What Mods?
  183. What RWHP/RWTQ gains could I expect from this set-up????
  184. Moving to the lounge?
  185. what if I don't switch the fans with 160 T-Stat?!?!
  186. thoughts on my exhaust plan....
  187. ASP Pulley cant be put on b/c of ridge? Help plz (pics)
  188. Whats it take for an all motor 10-11 sec LS1????
  189. Tylor 10.4 or stay with MSD??
  190. 01 vette vs 02 camaro
  191. Part number for the Coolant temp sensor(98TA)
  192. Those of you who installed LT headers (especially SLPs), did you run rich afterward?
  193. 6.0 LS1 Truck Throttle body on an F-body.
  194. what MAF does Z06 use?
  195. Electrical problem
  196. Exhaust questions
  197. what # my camaro is
  198. Which flows more? Cutout or Mufflex?
  199. Does your McCord Electric Cutout leak? How long does it take to open?
  200. 18" Bullet welded in I-pipe today to kill rasp
  201. Hows this exhaust idea sound?
  202. BULLET LENGTH
  203. H/D Aluminum Driveshaft or Carbon Fiber???
  204. need to i.d. a bolt
  205. Harlan shift light ??
  206. Installed my hypertech 160 T-Stat tonight, and.....
  207. plug wires
  208. removed cats, black smoke????
  209. SLP Loudmouth
  210. SPARK PLUGS
  211. Header install guide.
  212. TB-MAF?
  213. Header question
  214. ? Flowtech cutout and Fit
  215. Rating pressure for Lucas Injectors
  216. 305 Engine Install for 3rd Gen Camaro
  217. True Duals with with stock manifolds and cats with Dynomax Ultraflos
  218. Flowtech Purple Hornies
  219. Never buy parts from Excessive Motorsports
  220. How bad is oil consumption....
  221. another pulley question, please help!
  222. Weird sound when I shut the car off...
  223. FIPK vs Lid: Track Results!
  224. Hooker LT's are on!
  225. Cutouts with catbacks?
  226. Y Pipe Size for the New QTP Headers(Grots)
  227. need new mods
  228. After market fuel rails
  229. BMR "boxed" SFC`s & Hooker Y-pipe....
  230. Header tube size question
  231. Need help ASAP identifying some injectors!
  232. Will C5 LS6 intake fit F-body LS1 engine?
  233. ASP alternator pulley worth it? anyone running it on an M6?
  234. 53 RWH off custom made headers
  235. Cutout location?
  236. big question .. need a REAL genious for this... seriously.. seriously
  237. clutch ?
  238. People w/ Grotts...
  239. Best Y pipe
  240. How loud is....
  241. How to disconnect fuel line from the rail
  242. Modifying a stock plastic gas tank
  243. ADJUSTABLE FUEL PR. REGULATOR
  244. Anyone tried Direct Hits ignition for their LS1/LS6?
  245. Grott headers sold where????
  246. Ported MAF ends causing incorrect load readings and KR?
  247. How would this exhaust sound?
  248. Water in the intake !!!
  249. Debris on my MAF screen..K&N letting it through..concern
  250. Radiator Fan Control - Thermostats
