PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 [211] 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. ls6 intake question
  2. header wrap?
  3. Edelbrock Victor Series LT's are not Stainless Steel.
  4. Exhaust idea... will it work???
  5. Possible power loss with this exhaust change?
  6. keep shorty headers or replace with longtubes?
  7. custom air intake
  8. What size is OEM LS1throttle body?
  9. XR-1 Doesn't Fit - WTF?!
  10. anyone use the BBK intake manifold???
  11. Spark plug/wire combo PLEASE!!!!
  12. magnaflow catback
  13. True Duals Under Axle Out The Back
  14. Speed INC x-pipe
  15. FAST manifold porting/sealing question
  16. 1” longer Spark Plug Wire?
  17. Mufflers on true duels
  18. Spintech on a Loud Mouth setup?
  19. tr55ix iridiums or regular tr55's
  20. Pacesetter (different years)
  21. sealing up headers
  22. Summit/Jegs X-pipe?
  23. Z06 pully puller?
  24. For all the guys having idle problems after ported TBs...
  25. what plugs to go with?
  26. Is tuning necessary
  27. where do guys with loudmouths mount their ele cut outs?
  28. 2 Questions on headers and muffler
  29. exhaust
  30. Sunday Question - What plug wires fit the ET Heads?
  31. Mac ball flange mod
  32. Stumbling after LT install!
  33. Kooks ORY->catback install issues...
  34. pulley different for ls1/6?
  35. 1 3/4 to 1 7/8'' OR 1 7/8" on 408ci????
  36. Changing knock sensors during intake swap
  37. a louder magnaflow?
  38. Headers question / Sound quality
  39. ls6 intake install ?'s
  40. Connecting the Electrical portion of a Cutout
  41. BNR True duals vs. TSP True duals??
  42. Sticking TB After Porting Anyone Else?
  43. Magnaflow bullets?
  44. Quietest Muffler for TDs
  45. Borla with QTP's ORY
  46. FlowTech Headers ... Go or no?
  47. Need Help, Car runs crappy after Header install
  48. ORY Hitting Floorboard!
  49. Is it ok to yank out air system ?
  50. True duals/1 chamber flowmasters (sound clip)
  51. Underdrive Pulley for M6 car?
  52. fast 90mm intake/tb
  53. Worth porting lsx 90 intake w/stock heads?
  54. installing Pacesetters race headers
  55. Dropping Engine out of C5
  56. install tips for lt headers and ory?
  57. Anybody have qtp headers
  58. painting hearders
  59. header exhaust combo which ones
  60. Bassani?
  61. how loud are td's out the back?
  62. Good news about my LTs!
  63. exhaust questions
  64. Best LT's catted Y combo?
  65. Which fan is the primary fan (left or right)
  66. LS6 intake to FAST?
  67. Fast idle on new BBK throttle body
  68. Header install Question
  69. help out the newbie
  70. Does the fast intake come with gaskets?
  71. M Co or however the hell you spell it exhaust?
  72. Fast 90 questions?
  73. airconditioner mounts
  74. Are pacesetters equal length ?
  75. Magnaflow muffler?
  76. better or worse gas mileage with true duals?
  77. How to get from A to B with a hole in my header primary?
  78. poll: true duals VS Ypipe & cat-back?.....
  79. Loudmouth Dual Setup?
  80. foreigner Mod question
  81. Exhaust Nightmare!
  82. Pics of My Kooks.. What is the
  83. driveshaft loop and dual exhaust
  84. Maybe doing headers soon, is this a good list?
  85. Intake comparison: spreadsheet and graphs inside
  86. Spohn Ls1 Solid Motor Mounts..
  87. porting DBW tb
  88. exhaust question(s)
  89. LSX intake comparison test - which mag?
  90. tpis long tubes and x pipe.
  91. Yet another header question.
  92. Pulleys??
  93. ball-joints
  94. Problems with LT install. Help!
  95. PCV "vent tube"
  96. cat question
  97. QTP, Hooker, or SLP LT Headers
  98. why would my airbag light randomly start blinking?
  99. extending o2 wires help?
  100. Cut-Outs...
  101. which pulley to get?
  102. QTP Y-Pipe Fitment Issues?
  103. wich headers for stage 2 ported heads?
  104. Coolant Level
  105. MY SLP loud mouth clips
  106. 90 mm TB on 90 mm Wilson Elbow
  107. stepped header tubes
  108. Best header/exhaust combination for 04 Z06???
  109. Kooks 1-7/8 x 2" stepped headers - clearance problems?
  110. Over axle pipe
  111. I'll never know unless I ask...
  112. Harlan Shift Light??
  113. 2000 Z28 and Pacesetter LT's
  114. TPIS has a new look
  115. really weird issue with dim t/a head lights
  116. ASP Pulley ????
  117. WTF....another broken FAST Intake.
  118. Hooker Header Install
  119. exhaust help!
  120. Which throttle body for FAST90, and why?
  121. Any idea about how hot the outside of a cat can get?
  122. 1 series Flow. vs Powerstick...help me decide!
  123. catback install ?
  124. Broken FAST Intake
  125. Throttle body and intake combos?
  126. Will a QTP Y-pipe fit around a Spohn DS loop?
  127. Did I just find a GMMG exhaust for under 100?
  128. Exhaust diameter requirements for 400 HP
  129. Which Plug wires are you using with ETP Heads?
  130. Installed FAST90/90, dont feel any difference
  131. Non-Sponsor Soliciting Policy (clarification)
  132. Custom fab intake manifolds? good/bad choice?
  133. help, what kind of batteries are u guys using?
  134. LS6 Intake a good thing to have for a cammed LS1?
  135. volant question
  136. TSP True Duals
  137. Loud Muff
  138. LS6 swap
  139. TSP ORY ground clearance?!?!?!
  140. high flow cats with no air?
  141. where can I get a Silicone Coupler??
  142. What's keeping your TSP Y together?
  143. WIX air filters...anyone know anything about them?
  144. Air pump filter?
  145. 98-99 TB cam on a 00-02 TB?
  146. Want to replace stock muffler...
  147. B&B Exhaust Question
  148. Dual/Dual silencer cone
  149. lt install
  150. Need help.... lost hp go to a 90/90 setup
  151. Spark plug wires, worth it?q
  152. Where can I get my TB ported???
  153. For people with flowmaster
  154. Alternator Overdrive Pulley
  155. How much can I get for my stock exhaust?
  156. 160 thermo
  157. Best Td Exhaust Muffler
  158. Pacesetter v Edelbrock
  159. Shorties installed
  160. Good idea to change knock sensor? part#?
  161. Want opinion on TD muffling...
  162. poly mounts craking tranny case?
  163. Cold Air Worth It?
  164. 99 TB on a 02
  165. fast 90mm install (mods,plez allow this to go on....thanks!)
  166. 98-99 y-pipe problem / 00-02 work?
  167. Cheaper LSX/Fast replacement??? Check this out!
  168. Coolant change?
  169. Exhaust Clamps
  170. fast 90mm intake install......
  171. Need pictures of back of engine with wiring harness
  172. Slp 2otl
  173. Banging Y pipe Question
  174. a/c change out
  175. spark plug wires
  176. which throttle body?
  177. which spark plug wires are best?
  178. Custom Exhaust Mod?
  179. Thoughts on the Vararam Throttle Body velocity stack??
  180. header install question
  181. Ported my TB. Pics
  182. Y pipe Clearance Issue
  183. ls2 or ls6 intake manifold?
  184. exhaust setup
  185. Lm vs Td Loudness
  186. dynatech headers
  187. ~what the hell is this inside my LSX 90mm intake?
  188. Redo my exhaust when installing headers?
  189. FLP Longtube Pics
  190. Is one cat legal
  191. QTP electric cutout switch???
  192. My 4" Exhaust TD Before Rear Axle *PIC's*
  193. Any notable sound gains with LTs?
  194. Tuned Headers?
  195. Edelbrock Victor Series Headers?
  196. which of these is the Better setup?
  197. I have no idea which headers to get.
  198. Exhaust Questions???
  199. TD's under the axle
  200. Edelbrock Stepped Headers on a 408???
  201. LS1 exhaust note
  202. How much loss of oil thorugh dip stick tube inlet???
  203. Question about a stupid mistake
  204. Secondary Exhaust Pipe Questions
  205. Custom Valve Covers
  206. Pacsetter lt's and tsp ory
  207. Pacesetter headers O2 sensor holes
  208. Engine removal
  209. SLP 85mm MAF, should i descreen?
  210. Black Anodized NW TB Pics
  211. QTP HVMC or Kooks Venturi Collectors
  212. gaskets
  213. Underdrive Pulley needed?
  214. Kooks LT's and Corsa Catback, Cats Y or N?
  215. what part number for LS6 intake manifold
  216. where is your electric cutout located?
  217. Headers/X-pipe
  218. Epoxy TB ???
  219. SLP powerflo catback
  220. Fast90 Ported how much gain?
  221. A culmination of exhaust questions
  222. Need some Dual/Dual Exhaust tips!
  223. Ses Light On!!!
  224. People with Summit or Jegs X pipe on LT1, come in.
  225. Does anyone have the part number for a water pump?
  226. Oil Filter
  227. Radiator hole leak
  228. True Duals and torque arm??
  229. Optima Battery Problem
  230. need help asap.....fuel related...(mods, i know but i figurd i'll get more exposure)
  231. Vacuum leak after LS6 intake install
  232. tune after td install?
  233. Edelbrock Y-pipe
  234. new exhaust
  235. FAST TB problems
  236. Need some advice
  237. ANOTHER QTP post...
  238. Headers in Alexandria VA $$$$$$$ YEAH RIGHT!!!
  239. LS1 to LS2 conversion question (C5)
  240. Intake Manifold Gaskets
  241. Does Holley's "LS1" intake flow as good or better then LS6 w/0 being ported???
  242. Question about QTP headers and TSP Ypipe
  243. maf sensor
  244. F.A.S.T. 90mm intake manifold
  245. LS6 manifold or LT's + ORY??
  246. MSD coil packs?
  247. Its Time!
  248. Kooks or QTP headers??
  249. Pics-Custom stainless Magnaflow Exhaust !!!
  250. installing asp pulley
