PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 [234] 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. what are true duals??
  2. Mac mids
  3. Electric water pump
  4. Dumped Exhaust
  5. Headers Y-pipe
  6. Clicking sound above 4500RPMS.
  7. Tired of my SLP Loudmouth
  8. stainless CME tips on ebay, anyone have these?
  9. metalic ringing noise from front of engine when warm
  10. Ahhhhhhhh Help
  11. opinions on edelbrock stepped headers and ypipe
  12. ok need a little advice......
  13. rear 02 Mil elims
  14. true dual custom build
  15. SLP HO Hood Owners
  16. LS6 intake gains for my near full bolt on LS1
  17. Dumped Exhaust
  18. One more AIR system question
  19. has anyone else had this code after header install?
  20. IAT problems
  21. New Cat-back Exhaust ... Opinions
  22. AC Delco Iridium 7.99?
  23. Effects of running without thermostat?
  24. AC blowing on my knees?????????
  25. **HELP** problems after ls6 intake install
  26. AC dripping on header
  27. **pics** kickass custom valvecovers
  28. QTP LT's W/ DUAL CUTOUTS
  29. Pacesetter Problems
  30. Big Mac's tonight.
  31. Want to put on a new AC belt
  32. clogged AIR CHECK VALVE cause ticking?
  33. sputtering after header install and cat removal
  34. Is there anyway? (coolant)
  35. Need help choosing exhaust ... PLEASE HELP
  36. Oil Pan Removal
  37. Had to Quiet the car down
  38. wet carpet on drivers side
  39. oil pressure sensor
  40. Oil filter change challenging after LTs
  41. A new way for good ole' #8
  42. what size bolt is the egr pump held onto the head with
  43. short reach spark plugs
  44. Someone please convince me on header Y vs. header x
  45. A/C Blows Hot? All Sugestions Welcome.
  46. Anybody Running Headman Headers?
  47. Pacesetter shortries!!!!
  48. GMMG vs Loudmouth
  49. settin code after headers
  50. which one is better ?
  51. single or dual cutouts???
  52. C5 header and exaust-cut out question...
  53. very interestin question
  54. Where and how does the Mufflex LS1 Y-Pipe "Bump Stop" Hanger Connnect?
  55. New Plugs...Still alittle misfire....
  56. Need BIG Help: Looking for 3" Slip-fit Piping (Anyone at TSP?)
  57. Fast (78mm) Vs Ls6
  58. Pacesetters with ORY and loudmouth
  59. Super Sucker Ram Air - Where To Purchase?
  60. slp headers and y pipe
  61. What's my next mod??
  62. True Duals with BMR Trak PAK
  63. What did you guys use to port your own tb?
  64. pcv problems with head swap
  65. ASP Pulley (NON SFI)
  66. Dynomax muffler queston..
  67. Loud noise
  68. rings around the 02's
  69. Duel exhaust list
  70. kooks QTP combo
  71. smooth bellow sucks
  72. Need this part!!
  73. Hooker Aero chamber Sucks Ass
  74. Power steering GONE!
  75. slp ported tb
  76. Changed spark plugs and wtf?
  77. About to buy underdrive pulley
  78. Slp Dual/dual $50
  79. ticking noise coming from merger collector?
  80. Price
  81. Over heating? Help please.
  82. pacesetters installed(forgot I had a radio)
  83. APC Stainless mufflers, never heard of them?
  84. How much can I expect to pay.......
  85. Ported TB tune?
  86. i`m getting sick of it
  87. 02 LS1 SS question
  88. Still Having Problems
  89. 02 sensors again? 2nd set in 2 months
  90. cleaning up the engine bay...what dont i need?
  91. borlamouth fitting problems?
  92. Which Muffler For a Ls1 Truck With Stock Cats and Manifold?
  93. Has any one noticed if the #6 & #8 plugs hold up better than the other ones?
  94. Removed AIR and EGR pics.
  95. Gap On Tr55?
  96. problems!!
  97. True Dual owners get in here.
  98. Stock Exaust Diameter
  99. loose sensor?
  100. Corsa Exhaust
  101. FTRA Owners: How Often Do You Clean Your Air Filters?
  102. duel pipes
  103. QTP header and ory install??
  104. Question: need help with 02 sensors
  105. whats this??
  106. A/C Removal question
  107. 1 7/8 headers? Who all makes em?
  108. hooker y-pipe
  109. Need help... PLEASE..... Anyone
  110. Emissions in Boise, Id
  111. Code 1153 With Long Tubes
  112. Fast 78 vs Fast 90 tb/intake on H/C
  113. Uh oh - I think I screwed myself doing LS6 intake install
  114. a/c condensor removal radiators fit well?
  115. '05 'vette Intake/t.b. On A Lq9 ??
  116. best sounding exhaust by far...
  117. Y-Pipe Banging
  118. Does anyone know the bolt pattern measurements of an LS1 throttlebody?
  119. Throttle cable cam off after FAST 90mm intake and NW TB???
  120. Doing the headers next weekend, I have an inspection question...
  121. Poor Man's GMMG
  122. Nasty exhaust leak when I put in the ORP's...
  123. Thoughts on this TD setup...
  124. do i need to reinstal this..
  125. Vette O2's and exhaust manifold question..
  126. SLP 85mm MAF
  127. confusing problem with my 99 Z28
  128. Threaded fan spacer
  129. Shorty header owners.
  130. AIR restrictor for MAC headers...
  131. wats the best air intake
  132. Would I gain anything from 1 7/8 or stepped 1 3/4 to 1 7/8 from 1 3/4 headers?
  133. sapose to be this loud?
  134. question about sound im gonna get from duals
  135. To gut or not to gut?
  136. LS1 throttlebody bolt pattern dimensions?
  137. Another 00 EGR question?
  138. CANT get y-pipe on!
  139. TB cable question?
  140. Any Rasp or Drone with Twisters
  141. Can I use LS2 intake mainfold with my LS1? is ls2 intake better than ls6 intake?
  142. help guys, ive got an idea to make clearance
  143. 90 mm throttlebody brands
  144. Throttle body from SDPC
  145. headers finally on!
  146. lanes duals
  147. exhaust question
  148. newbie exhaust mod - GMMG
  149. Powerbond 10% Pulley for Vette - Belt Size
  150. Heat Relfective Tape
  151. Hedman LT Headers?
  152. headers with or w/o emissions
  153. Battery relocation and alternater feedback
  154. Headers/Y-Pipe Or Induction Package???
  155. i have a question
  156. Increased Heat with Headers?
  157. ls6 intake (Pre install)
  158. do you think it would be worth the money to switch from hooker to kooks?
  159. Headers installed and car is mis-firing..backfiring..running like CRAP!!
  160. Header wrap????
  161. oil consumption
  162. MAC exhaust leak.....
  163. EGR delete
  164. Broke cruise control Throttle cable. info plz
  165. Security Light is back on
  166. For a procharged t/a which should I keep dyna tech or kooks
  167. Not that any one cares but.....
  168. Muffler Help!!!
  169. whats the best throttle body
  170. 98-99 Pacesetter LT Vs. 01-02 Pacesetter LT
  171. 05 mustang gt
  172. exhaust poll question
  173. Why does ASP keep changing their pulleys?
  174. LTs or LS6 intake
  175. pulling out dip stick
  176. Which mods provide most HP gain?
  177. uh oh, broke the dang oil temp sender...
  178. ECT sensor
  179. breaking crank bolt free....HELP!!!!!
  180. Better gas mileage after headers?
  181. started uninstalling
  182. Hooker long tube 4"
  183. what do i need/tips? QTP LT install
  184. Help troubleshoot air conditioning
  185. HP difference: cats vs no cats
  186. Anyone with 400+ cubes using a LS2 intake (search is down)
  187. best aftermarket muffler for loudmouth
  188. need 4" straight bellows
  189. Need to replace alternator, any suggestions?
  190. loud whistling sound
  191. no tach?
  192. Borlamouth flow as well as Loudmouth?
  193. LS2 Intake
  194. cutout disadvantages.
  195. catback length ???
  196. cats or resonator?
  197. magnaflow cat back
  198. Reusable oil filter ????
  199. Mid Length Headers
  200. Help dropping driver's side header pleez!!!!
  201. Header gaskets???
  202. 2.5" pipe on 3" collector...losing power?
  203. Weird whistle...
  204. Patriot Heads
  205. Performance question after header install
  206. Help Please
  207. Friggin AC
  208. Borlamouth sounds great.
  209. exhaust leak common after header install?
  210. Valve covers???
  211. anyone ever do a 4" single exhause setup?
  212. Any advanyage of true duals over a normal cat-back?
  213. Induction boxes
  214. Where to buy Sheet Metal Intake
  215. intake: Firehawk vs WS6???
  216. y pipe dumped or a catback
  217. 350 horse slp power package
  218. please excuse my ignorance about AIR removal
  219. Ported throttle body on an 01'
  220. air pump removal question
  221. Taking off march pulley....what kind of puller do i need???
  222. Making Hood Functional
  223. Installed the FTRA
  224. March Pulleys, anyone have info
  225. TRI's
  226. Help! Need advise on future mods.
  227. pacesetters
  228. sh!t...header bolt busted
  229. Best way to clean MAF?
  230. which mufflers are loud?
  231. stock cats on mac oryp
  232. muffler opinions
  233. uninstall stock exhaust manafolds...
  234. need help quick
  235. tensioner question
  236. Electric Cutout Installation Tutorial
  237. 3" y-pipe to 2.5" cat back
  238. 90mm tb setup help
  239. Oil Soaked knock sensor??
  240. Water Pump
  241. Are magnaflow cats any good?
  242. SICK of waiting for SLP LM II
  243. Best Performing Spark plug???
  244. Performance bolt-ons
  245. Think Maf is Bad
  246. Lane's true duals installed.
  247. installation of X-pipe
  248. Had headers installed?? check this out
  249. is it worth it
  250. GMMG uninstall question....
