PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 [158] 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Exhaust quote....
  2. PLEASE help me get this SOUND!
  3. Im back...proof of ported TB gains.
  4. Im back.....proof of ported TB gains.
  5. idle
  6. Who makes 2.5'' inlet corsa clones??
  7. Which pulleys for my setup?
  8. Can I reinstall a screen on my MAF? Or new/used one?
  9. Quieting the Loudmouth (SF VS Powerstick)
  10. Rust on my SS headers????
  11. LS6 valley cover?
  12. K&N Generation II FIPK
  13. exhaust/ground clearance issues,, what options with flowteck headers?
  14. Questions as to tube size on exhaust?
  15. Texas Speed Rumbler Catback(owners come inside)
  16. shopping for headers.
  17. where can I get borla adj plates
  18. 2 1/2" diameter mufflers, whats size piping?
  19. TB Coolant Clamps (Bypass)
  20. Best underdrive pulley that will allow double roller timing set
  21. DIY true duals (i've read the TD sticky)
  22. First Mod - Exhaust
  23. LS1 intake gaskets
  24. Extending O2s
  25. 00 ls1 throttle fit a 99 ls1 ?
  26. meth injection
  27. over axle duals
  28. Where to find AIR/Lid plug?
  29. Exhaust Pipe Joining Clamps?
  30. spark plugs on my dad's 02 silverado
  31. need help, I dont know much about headers!
  32. Borla Adjustable plates
  33. FAST or LS6 Question
  34. air pump holes on exhaust header
  35. fuel rail psi gauge?
  36. Will This Exhaust Set-up Work In My Corvette?
  37. Oily Substance in LS6 intake manifold
  38. Lingenfelter Intake Gaskets!!!!!
  39. slp header ground clearence
  40. header install finished questions left
  41. PS Pulley install..how far onto shaft
  42. Where's the oil pressure sending unit?
  43. Loss Of Power?????
  44. Nick Williams or Holley TB?
  45. Limits of stock coils.
  46. Quieting down true duals
  47. Changing knock sensors without completely remomving intake?
  48. Borla 3" adjustable for '02 trans am
  49. Help..TB questions
  50. Ls6 intake swap
  51. @#$#$% Spark Plugs!
  52. Blocking off heater hoses at Water Pump
  53. H-Pipe Duals Fitment Questions..
  54. Shooping for Cat-Back
  55. Anybody know the part number(s) of this??
  56. Do Moroso Spiral Flows Flow Ok or....
  57. Do I Need The Complete Cat Back/
  58. Check gauges light at drag strip??
  59. What diameter cut-out?
  60. Lanes True Duals?!?!
  61. pacesetters w/no cats?
  62. ls1 intake manifold gaskets? ----help
  63. MAF Sensor & K&N Filter
  64. Victor Jr setup with Air cleaner
  65. Pacesetter ORY.. so easy to install.. why do people bitch about it
  66. it's been beaten to death..Corsa or B&B?
  67. Throttle cable question
  68. Got an awesome deal on an LS6 intake!!!
  69. Pics of the new duals and a Question
  70. LM 2 Muffler restrictive?
  71. 85mm Summitt Throttle body
  72. Cut Off My Muffler?
  73. what kind of power
  74. Bbk Lt
  75. Price Increase
  76. Coolant crossover conversion questions.
  77. Pacesetter headers w/ cat y-pipe
  78. Engine Vibration HELP!
  79. Anyone ever see these flex pipes??
  80. LS6 intake results
  81. Selling car with modded exhaust?
  82. BBK SSI intake on a Cam only LS6 car, worth it?
  83. How much do headers affect the air/fuel ratio?
  84. taking off the stock exhaust.
  85. Exhaust ?
  86. true duals with no balancing pipe
  87. installing TSP duals
  88. Kooks On Speed Channel Tonight
  89. shift light
  90. car is sputtering, HELP please
  91. Whoah!~. . chokemaster gone ....
  92. Need Intake Help
  93. what underdrive pulley ASP or SLP
  94. Fast 90mm over LS6 intake
  95. After install its just not loud enough!!
  96. Off Road Y-Pipe
  97. Damn Header Bolts...
  98. Alternative alternators?
  99. Need Help!!
  100. Ls6 intake part numbers
  101. Intake gasket on high-ish mile engines
  102. true duals at last
  103. 2k idol/ running hotter / TB blade sticking
  104. which plugs
  105. Best X-Pipe
  106. what heads do i have?!?!?!
  107. header install on my ss
  108. What size O2 EXT?
  109. Changing radiator cap pressure
  110. L/Ts
  111. JBA cat4rward headers?
  112. Shelp life of spark plugs
  113. Flywheel....crank bolts....torque specs
  114. some one help!!!!!!!!!!
  115. Truck coils question
  116. Third Gen exhaust help...
  117. What exactly entails a "built motor"
  118. Harness Relocation
  119. Intake Manifold Install
  120. Removing AC Compressor and lines?
  121. true duals soon which mufflers.
  122. Super Victor LS1 vs. GMPP Carb style EFI
  123. slp lid
  124. Quiet muff needed
  125. Spark Plug wire question
  126. FAST Intake Install.
  127. Heat shield removal
  128. Electric water pump questions
  129. cooler thermostat?
  130. What Catted-Y for Jet Hot Headers?
  131. What LS2 waterpump for LS1 F-bodies?
  132. Can stock fuel rails be switched around?
  133. Wow, I think I need a tune
  134. spark plug selection...?
  135. Reusing stock manifold gaskets.
  136. Book?
  137. Searched...what size Magnaflow?
  138. Question for others who have Flowmaster single chambers...
  139. Header gasket
  140. Can you clean fuel injectors and O2 sensors?
  141. Porting Corvette TB
  142. Engine Covers
  143. DMH Electric Cutouts
  144. how to tell new vs. old pacesetters?
  145. Moroso resonator
  146. horse power
  147. FAST90 on stock fuel lines
  148. NKG TR-55's
  149. What do I need to install Pacesetters??
  150. Motor/ Tranny Mounts
  151. 02 Sensor Thread Size and Pitch
  152. running hot at idle water pump or balancer?
  153. Another " I just installed my headers" thread
  154. FRC's and Aftermarket Fuel rails
  155. pacesetters or hooker?
  156. o2 Sims
  157. 97 t/a or 99 t/a
  158. Pacesetter LTs
  159. Which y-pipe with QTPs?
  160. stock SS muffler
  161. Rattling Noise
  162. What Mods next?
  163. got my DUALS done
  164. ASP Pulley
  165. low end torque
  166. Exhaust shops?
  167. truck coil packs on LS1...
  168. Headers?
  169. Help Headers?
  170. Exhaust question
  171. Free mods
  172. Cat Question
  173. warped belt sound coming from LS6 intake?
  174. need to shed some weight
  175. Ls6 Intake Hp Guess with my Setup?
  176. Is gmmg too loud....
  177. Painted my new FAST
  178. 02 trANS am cam Qs
  179. Typhoon Manifold
  180. pwoder coating headers?
  181. Wheres the best place to get........
  182. honing noise
  183. FRPP dual-mode mufflers?
  184. Stock exhaust removal?!
  185. Cut out pipe size question / help
  186. Damn SLP headers...
  187. Trans-brake?????
  188. what type of muffler shop needed
  189. Before i debaffle my hood...
  190. wires for coil relocation?
  191. New setup...
  192. which header?
  193. crank pulley bolt
  194. stupid question
  195. DMH Cable Cutout Question
  196. F.A.S.T intake or Spectialy products intake manafold
  197. slp headers
  198. FAST 90 w/ stock internals?
  199. OBX R headers- any good?
  200. running on 7?
  201. true dual under axle questions
  202. Ac blows through the bottom after ls6 intake install.
  203. CME tips Broke!
  204. header, ory and cutouts installed ??
  205. Used heads, been massaged, have questions
  206. What paper filter do you like best?
  207. Which paper air filter do you think is the best?
  208. Favorite or best paper air filter?
  209. Stupid Question time.....
  210. Cali people with Headers come on in!~
  211. LT header decision
  212. Getting the most out of a cammed car (exhaust)
  213. SSRA CAI Installation Question
  214. Autozone PCV Delete Questions
  215. Do qtp's come with 02 extensions.
  216. McCord Powerplate From byunspeed question
  217. Fast 78
  218. How the world to get powerbond underdrive pulley off?!
  219. Custom Ram Air!!!
  220. Plan on getting an SLP Lid
  221. car idles low immediately after startup...
  222. Pacesetter LTs+Y-Pipe Combo
  223. true duals off hooker on
  224. Speed Density Bridge????
  225. What sensor did I break off? (pic)
  226. O.D. of SLP MAF and 90mm TB?
  227. Weird Problem
  228. Vengeance Fast Porting Vs. Mamo Fast porting..
  229. HELP: I need a throttle body blade screw
  230. Broke oil pressure sending unit, need part number.
  231. Is this the IAT sensor?? or what??
  232. What to use to seal K&N intake to airbox?
  233. Ultimate True Dual Exhaust?
  234. Msd Coil Packs Photo
  235. SLP PULLEY Question
  236. what to do with rear o2 sensor plugs
  237. GMMG Purchase Group?
  238. SLP y pipe
  239. true duals off hooker on
  240. true duals off hooker on
  241. 2" header flanges
  242. please help valve covers and timming cover
  243. Do I need a tune after LT and High flow cats?
  244. drive shaft safety loop
  245. Those with American Racing Headers: Come on inside !
  246. Help Me Please!! Pulley problem
  247. Car caught fire
  248. after the LT install, I only have one gripe... can anyone help?
  249. muffler is rattleing not sure why?
  250. qtp cutout location
